Hallo, nachfolgend die Log-Datei mit Level debug:
2021-02-04 07:51:32.983 [update notice] received update-write bai SetMode QQ=10: auto;52.5;-;-;0;0;1;0;0;0
2021-02-04 07:51:34.824 [mqtt debug] publish ebusd/bai/SetMode {
"hcmode": {"value": "auto"},
"flowtempdesired": {"value": 52.5},
"hwctempdesired": {"value": null},
"hwcflowtempdesired": {"value": null},
"disablehc": {"value": 0},
"disablehwctapping": {"value": 0},
"disablehwcload": {"value": 1},
"remoteControlHcPump": {"value": 0},
"releaseBackup": {"value": 0},
"releaseCooling": {"value": 0}}
2021-02-04 07:51:34.824 [mqtt debug] publish ebusd/bai/Status01 {
"0": {"name": "temp1", "value": 56.0},
"1": {"name": "temp1", "value": 51.5},
"2": {"name": "temp2", "value": 7.562},
"3": {"name": "temp1", "value": 42.5},
"4": {"name": "temp1", "value": 46.0},
"5": {"name": "pumpstate", "value": "on"}}
2021-02-04 07:51:37.827 [mqtt debug] publish ebusd/global/uptime 33714
2021-02-04 07:51:39.513 [main debug] performing regular tasks
2021-02-04 07:51:42.774 [update info] received MS cmd: 1008b5110101 / 0971679007555c0100ff
2021-02-04 07:51:42.775 [update notice] received read bai Status01 QQ=10: 56.5;51.5;7.562;42.5;46.0;on
2021-02-04 07:51:43.047 [update info] received MS cmd: 1008b51009000069ffffff040000 / 0101
2021-02-04 07:51:43.047 [update notice] received update-write bai SetMode QQ=10: auto;52.5;-;-;0;0;1;0;0;0
2021-02-04 07:51:43.309 [update info] received MS cmd: 1008b5110102 / 06013c9646826e
2021-02-04 07:51:43.309 [update notice] received read bai Status02 QQ=10: on;60;75.0;70;65.0
2021-02-04 07:51:44.836 [mqtt debug] publish ebusd/bai/SetMode {
2021-02-04 07:51:44.836 [mqtt debug] publish ebusd/bai/Status01 {
"0": {"name": "temp1", "value": 56.5},
2021-02-04 07:51:44.836 [mqtt debug] publish ebusd/bai/Status02 {
"0": {"name": "hwcmode", "value": "on"},
"1": {"name": "temp0", "value": 60},
"2": {"name": "temp1", "value": 75.0},
"3": {"name": "temp0", "value": 70},
"4": {"name": "temp1", "value": 65.0}}
2021-02-04 07:51:49.515 [main debug] performing regular tasks
2021-02-04 07:51:52.548 [bus debug] ERR: read timeout during receive command ACK, switching to skip
2021-02-04 07:51:53.071 [update info] received MS cmd: 1008b5110101 / 0971679007555c0100ff
2021-02-04 07:51:53.072 [update notice] received read bai Status01 QQ=10: 56.5;51.5;7.562;42.5;46.0;on
2021-02-04 07:51:53.344 [update info] received MS cmd: 1008b51009000069ffffff040000 / 0101
2021-02-04 07:51:53.345 [update notice] received update-write bai SetMode QQ=10: auto;52.5;-;-;0;0;1;0;0;0
2021-02-04 07:51:53.846 [mqtt debug] publish ebusd/global/uptime 33730
2021-02-04 07:51:54.848 [mqtt debug] publish ebusd/bai/SetMode {
2021-02-04 07:51:54.848 [mqtt debug] publish ebusd/bai/Status01 {
2021-02-04 07:51:57.958 [bus debug] ERR: read timeout during receive command ACK, switching to skip
2021-02-04 07:51:59.517 [main debug] performing regular tasks
2021-02-04 07:52:02.892 [update info] received MS cmd: 1008b5110101 / 0971679007555c0100ff
2021-02-04 07:52:02.893 [update notice] received read bai Status01 QQ=10: 56.5;51.5;7.562;42.5;46.0;on
2021-02-04 07:52:03.163 [update info] received MS cmd: 1008b51009000069ffffff040000 / 0101
2021-02-04 07:52:03.163 [update notice] received update-write bai SetMode QQ=10: auto;52.5;-;-;0;0;1;0;0;0
2021-02-04 07:52:03.369 [bus debug] ERR: read timeout during receive command ACK, switching to skip
2021-02-04 07:52:04.858 [mqtt debug] publish ebusd/bai/SetMode {
2021-02-04 07:52:04.858 [mqtt debug] publish ebusd/bai/Status01 {
2021-02-04 07:52:08.753 [bus debug] ERR: read timeout during receive command ACK, switching to skip
2021-02-04 07:52:09.519 [main debug] performing regular tasks
2021-02-04 07:52:09.864 [mqtt debug] publish ebusd/global/uptime 33746
2021-02-04 07:52:13.023 [bus debug] ERR: read timeout during skip, switching to no signal
2021-02-04 07:52:13.023 [bus error] signal lost
2021-02-04 07:52:13.645 [bus debug] ERR: SYN received during no signal, switching to ready
2021-02-04 07:52:13.645 [bus notice] signal acquired
2021-02-04 07:52:13.649 [bus error] device status: unexpected available enhanced following byte 1
2021-02-04 07:52:13.704 [update info] received MS cmd: 1008b5110101 / 0971679007555c0100ff
2021-02-04 07:52:13.705 [update notice] received read bai Status01 QQ=10: 56.5;51.5;7.562;42.5;46.0;on
2021-02-04 07:52:13.733 [update info] received MS cmd: 1008b51009000069ffffff040000 / 0101
2021-02-04 07:52:13.734 [update notice] received update-write bai SetMode QQ=10: auto;52.5;-;-;0;0;1;0;0;0
2021-02-04 07:52:13.761 [update info] received MS cmd: 1008b5040100 / 0a03145207040204219007
2021-02-04 07:52:13.762 [update notice] received read bai DateTime QQ=10: valid;07:52:14;04.02.2021;7.562
2021-02-04 07:52:13.786 [update info] received MS cmd: 1008b5110102 / 06013c9646826e
2021-02-04 07:52:13.787 [update notice] received read bai Status02 QQ=10: on;60;75.0;70;65.0
2021-02-04 07:52:13.998 [update info] received BC cmd: 10feb516080013520704020421
2021-02-04 07:52:13.999 [update notice] received update-read broadcast vdatetime QQ=10: 07:52:13;04.02.2021
2021-02-04 07:52:14.270 [update info] received MS cmd: 1008b5110100 / 0889030e20040f0001
2021-02-04 07:52:14.270 [update notice] received unknown MS cmd: 1008b5110100 / 0889030e20040f0001
2021-02-04 07:52:14.487 [update info] received BC cmd: 10feb51603019007
2021-02-04 07:52:14.488 [update notice] received update-read broadcast outsidetemp QQ=10: 7.562
2021-02-04 07:52:14.870 [mqtt debug] publish ebusd/bai/SetMode {
2021-02-04 07:52:14.870 [mqtt debug] publish ebusd/broadcast/vdatetime {
"time": {"value": "07:52:13"},
"date": {"value": "04.02.2021"}}
2021-02-04 07:52:14.870 [mqtt debug] publish ebusd/bai/DateTime {
"dcfstate": {"value": "valid"},
"btime": {"value": "07:52:14"},
"bdate": {"value": "04.02.2021"},
"temp2": {"value": 7.562}}
2021-02-04 07:52:14.870 [mqtt debug] publish ebusd/bai/Status01 {
2021-02-04 07:52:14.870 [mqtt debug] publish ebusd/bai/Status02 {
2021-02-04 07:52:18.266 [mqtt debug] received topic ebusd/bai/ValveStarts/get with data 1
2021-02-04 07:52:18.266 [mqtt info] received get topic for bai ValveStarts
2021-02-04 07:52:18.266 [bus info] send message: ff08b509030d1a00
2021-02-04 07:52:19.521 [main debug] performing regular tasks
2021-02-04 07:52:22.969 [update info] received MS cmd: 1008b5110101 / 0971679007555c0100ff
2021-02-04 07:52:22.970 [update notice] received read bai Status01 QQ=10: 56.5;51.5;7.562;42.5;46.0;on
2021-02-04 07:52:23.242 [update info] received MS cmd: 1008b51009000069ffffff040000 / 0101
2021-02-04 07:52:23.243 [update notice] received update-write bai SetMode QQ=10: auto;52.5;-;-;0;0;1;0;0;0
2021-02-04 07:52:29.523 [main debug] performing regular tasks
2021-02-04 07:52:33.034 [update info] received MS cmd: 1008b5110101 / 0971689007555c0100ff
2021-02-04 07:52:33.035 [update notice] received read bai Status01 QQ=10: 56.5;52.0;7.562;42.5;46.0;on
2021-02-04 07:52:33.307 [update info] received MS cmd: 1008b51009000069ffffff040000 / 0101
2021-02-04 07:52:33.307 [update notice] received update-write bai SetMode QQ=10: auto;52.5;-;-;0;0;1;0;0;0
2021-02-04 07:52:39.524 [main debug] performing regular tasks
2021-02-04 07:52:43.096 [update info] received MS cmd: 1008b5110101 / 0971689007555c0100ff
2021-02-04 07:52:43.097 [update notice] received read bai Status01 QQ=10: 56.5;52.0;7.562;42.5;46.0;on
2021-02-04 07:52:43.367 [update info] received MS cmd: 1008b51009000069ffffff040000 / 0101
2021-02-04 07:52:43.368 [update notice] received update-write bai SetMode QQ=10: auto;52.5;-;-;0;0;1;0;0;0
2021-02-04 07:52:43.632 [update info] received MS cmd: 1008b5110102 / 06013c9646826e
2021-02-04 07:52:43.633 [update notice] received read bai Status02 QQ=10: on;60;75.0;70;65.0
2021-02-04 07:52:49.526 [main debug] performing regular tasks
2021-02-04 07:52:53.159 [update info] received MS cmd: 1008b5110101 / 0971689007555c0100ff
2021-02-04 07:52:53.159 [update notice] received read bai Status01 QQ=10: 56.5;52.0;7.562;42.5;46.0;on
2021-02-04 07:52:53.432 [update info] received MS cmd: 1008b51009000069ffffff040000 / 0101
2021-02-04 07:52:53.433 [update notice] received update-write bai SetMode QQ=10: auto;52.5;-;-;0;0;1;0;0;0
2021-02-04 07:52:59.528 [main debug] performing regular tasks
2021-02-04 07:53:03.180 [update info] received MS cmd: 1008b5110101 / 0971689007555c0100ff
2021-02-04 07:53:03.181 [update notice] received read bai Status01 QQ=10: 56.5;52.0;7.562;42.5;46.0;on
2021-02-04 07:53:03.451 [update info] received MS cmd: 1008b51009000069ffffff040000 / 0101
2021-02-04 07:53:03.452 [update notice] received update-write bai SetMode QQ=10: auto;52.5;-;-;0;0;1;0;0;0
2021-02-04 07:53:09.530 [main debug] performing regular tasks
2021-02-04 07:53:13.245 [update info] received MS cmd: 1008b5110101 / 0972689007555c0100ff
2021-02-04 07:53:13.246 [update notice] received read bai Status01 QQ=10: 57.0;52.0;7.562;42.5;46.0;on
2021-02-04 07:53:13.517 [update info] received MS cmd: 1008b51009000069ffffff040000 / 0101
2021-02-04 07:53:13.517 [update notice] received update-write bai SetMode QQ=10: auto;52.5;-;-;0;0;1;0;0;0
2021-02-04 07:53:13.794 [update info] received MS cmd: 1008b5040100 / 0a03145307040204219007
2021-02-04 07:53:13.795 [update notice] received read bai DateTime QQ=10: valid;07:53:14;04.02.2021;7.562
2021-02-04 07:53:14.056 [update info] received MS cmd: 1008b5110102 / 06013c9646826e
2021-02-04 07:53:14.057 [update notice] received read bai Status02 QQ=10: on;60;75.0;70;65.0
2021-02-04 07:53:14.295 [update info] received BC cmd: 10feb516080013530704020421
Um 2021-02-04 07:52:18.266 ist der letzte Eintrag mit MQTT, eine Abfrage über get. Danach setzte die Kommunikation über MQTT aus.
Nach diesem Zeitpunkt sind u.a. aber auch keine Einträge mehr zum Polling über r1 in der Config-Datei zu finden.
