Autor Thema: Neues Modul zur Steuerung von WS2812b LED stripes  (Gelesen 50974 mal)
Offline tklein
  • Sr. Member
Antw:Neues Modul zur Steuerung von WS2812b LED stripes
« Antwort #165 am: 18 Januar 2019, 20:11:57 »
ich verzweifel gerade daran mit Atom oder Arduino IDE die ESP8266 Version auf den Wemos zu flashen.
Bei Atom bekomme ich diese Meldung beim Kompilieren:
Processing d1_mini_lite (platform: espressif8266; board: d1_mini_lite; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini_lite.html
PLATFORM: Espressif 8266 > WeMos D1 mini Lite
HARDWARE: ESP8266 80MHz 80KB RAM (1MB Flash)
Converting httpledstripe_esp_v1.ino
Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF MODES: FINDER(chain) COMPATIBILITY(soft)
Collected 31 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <ESP8266WiFi> 1.0
|-- <Adafruit NeoPixel> 1.0.6
Compiling .pioenvs\d1_mini_lite\src\httpledstripe_esp_v1.ino.cpp.o
Compiling .pioenvs\d1_mini_lite\libf7b\ESP8266WiFi\ESP8266WiFiMulti.cpp.o
C:/Users/tklein/Documents/PlatformIO/Projects/ws8212_fhem/src/httpledstripe_esp_v1.ino: In function 'void setup()':
C:/Users/tklein/Documents/PlatformIO/Projects/ws8212_fhem/src/httpledstripe_esp_v1.ino:43:15: error: 'stripe_setup' was not declared in this scope
stripe_setup();
C:/Users/tklein/Documents/PlatformIO/Projects/ws8212_fhem/src/httpledstripe_esp_v1.ino: In function 'void loop()':
C:/Users/tklein/Documents/PlatformIO/Projects/ws8212_fhem/src/httpledstripe_esp_v1.ino:99:87: error: 'stripe_color' was not declared in this scope
stripe_setPixelColor(ledix++, stripe_color(redLevel,greenLevel,blueLevel));
C:/Users/tklein/Documents/PlatformIO/Projects/ws8212_fhem/src/httpledstripe_esp_v1.ino:99:88: error: 'stripe_setPixelColor' was not declared in this scop
e
C:/Users/tklein/Documents/PlatformIO/Projects/ws8212_fhem/src/httpledstripe_esp_v1.ino:256:14: error: a function-definition is not allowed here before '{
' token
void reset() {
C:/Users/tklein/Documents/PlatformIO/Projects/ws8212_fhem/src/httpledstripe_esp_v1.ino:342:1: error: expected '}' at end of input
*** [.pioenvs\d1_mini_lite\src\httpledstripe_esp_v1.ino.cpp.o] Error 1
 [ERROR] Took 8.35 seconds
Hatte mal gelesen, dass das evtl. auf Sonderzeichen im Pfad hindeuten könnten. Dort sind aber keine.
So ist die identische Meldung bei Arduino IDE:
C:\Users\tklein\Documents\Arduino\FHEM-LEDStripe-master\FHEM-LEDStripe-master\Arduino\httpledstripe_esp_v1\httpledstripe_esp_v1.ino: In function 'void setup()':
httpledstripe_esp_v1:43: error: 'stripe_setup' was not declared in this scope
  stripe_setup();
C:\Users\tklein\Documents\Arduino\FHEM-LEDStripe-master\FHEM-LEDStripe-master\Arduino\httpledstripe_esp_v1\httpledstripe_esp_v1.ino: In function 'void loop()':
httpledstripe_esp_v1:91: error: 'colorVal' was not declared in this scope
               redLevel = colorVal(c);
httpledstripe_esp_v1:99: error: 'stripe_color' was not declared in this scope
httpledstripe_esp_v1:99: error: 'stripe_setPixelColor' was not declared in this scope
httpledstripe_esp_v1:103: error: 'stripe_show' was not declared in this scope
httpledstripe_esp_v1:252: error: 'blinkerEffect' was not declared in this scope
   if (blinker) blinkerEffect();
httpledstripe_esp_v1:256: error: a function-definition is not allowed here before '{' token
 void reset() {
vstripe:50: error: expected '}' at end of input
exit status 1
Die *.ino Datei hat folgenden Inhalt:
#include <Adafruit_NeoPixel.h>
#include <ESP8266WiFi.h>
const char* ssid     = "xyz";
const char* password = "123456789..";
WiFiServer server(80);
// Which pin on the Arduino is connected to the NeoPixels?
#define LEDPIN1           4
#define LEDPIN2           0
// How many NeoPixels are attached to the Arduino?
//#define NUMPIXELS1     8
#define NUMPIXELS1     140
#define NUMPIXELS2     0
int xfrom;
int yto;
int myredLevel;
int mygreenLevel;
int myblueLevel;
int myOn;
int myOff;
void reset();
// control special effects
boolean fire=false;
boolean rainbow=false;
boolean blinker=false;
uint16_t rainbowColor=0;
// setup network and output pins
void setup() {
// Open serial communications and wait for port to open:
  Serial.begin(9600);
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println(F("Booting"));
 // Initialize all pixels to 'off'
 stripe_setup();
  WiFi.mode(WIFI_STA);
Serial.println();
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
  server.begin();
// request receive loop
void loop() {
// listen for incoming clients
  WiFiClient client = server.available();  // Check if a client has connected
  if (client) {
    Serial.println(F("new client"));
    String inputLine = "";
   // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    boolean isGet = false;
    boolean isPost = false;
    boolean isPostData = false;
    int postDataLength;
    int ledix = 0;
    int tupel = 0;
    int redLevel = 0;
    int greenLevel = 0;
    int blueLevel = 0;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (isPostData && postDataLength > 0) {
          switch (tupel++) {
            case 0:
              break;
            case 1:
              greenLevel = colorVal(c);
              break;
            case 2:
              blueLevel = colorVal(c);
              tupel = 0;
              break;
          if (--postDataLength == 0) {
            stripe_show();
            sendOkResponse(client);
            break;
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          if (isPost) {
            isPostData = true;
            continue;
          } else {
            // send http response
            if (isGet) {
            } else {
              client.println(F("HTTP/1.1 500 Invalid request"));
              client.println(F("Connection: close"));  // the connection will be closed after completion of the response
              client.println();
            break;
        if (c == '\n') {
          // http starting a new line, evaluate current line
          Serial.println(inputLine);
// SET SINGLE PIXEL url should be GET /rgb/n/rrr,ggg,bbb
          if (inputLine.length() > 3 && inputLine.substring(0,9) == F("GET /rgb/")) {
            int slash = inputLine.indexOf('/', 9 );
            ledix = inputLine.substring(9,slash).toInt();
            int urlend = inputLine.indexOf(' ', 9 );
            String getParam = inputLine.substring(slash+1,urlend+1);
            int komma1 = getParam.indexOf(',');
            int komma2 = getParam.indexOf(',',komma1+1);
            redLevel = getParam.substring(0,komma1).toInt();
            greenLevel = getParam.substring(komma1+1,komma2).toInt();
            blueLevel = getParam.substring(komma2+1).toInt();
            stripe_setPixelColor(ledix, stripe_color(redLevel,greenLevel,blueLevel));
            stripe_show();
            isGet = true;
          // SET PIXEL RANGE url should be GET /range/x,y/rrr,ggg,bbb
          if (inputLine.length() > 3 && inputLine.substring(0,11) == F("GET /range/")) {
            int slash = inputLine.indexOf('/', 11 );
            int komma1 = inputLine.indexOf(',');
            int x = inputLine.substring(11, komma1).toInt();
            int y = inputLine.substring(komma1+1, slash).toInt();
            int urlend = inputLine.indexOf(' ', 11 );
            for(int i=x; i<=y; i++) {
              stripe_setPixelColor(i, stripe_color(redLevel,greenLevel,blueLevel));
            stripe_show();
            isGet = true;
          // POST PIXEL DATA
          if (inputLine.length() > 3 && inputLine.substring(0,10) == F("POST /leds")) {
            isPost = true;
          if (inputLine.length() > 3 && inputLine.substring(0,16) == F("Content-Length: ")) {
            postDataLength = inputLine.substring(16).toInt();
          // SET ALL PIXELS OFF url should be GET /off
          if (inputLine.length() > 3 && inputLine.substring(0,8) == F("GET /off")) {
            reset();
            isGet = true;
          // GET STATUS url should be GET /status
          if (inputLine.length() > 3 && inputLine.substring(0,11) == F("GET /status")) {
            isGet = true;
          // SET FIRE EFFECT
          if (inputLine.length() > 3 && inputLine.substring(0,9) == F("GET /fire")) {
            fire = true;
            rainbow = false;
            stripe_setBrightness(128);
            isGet = true;
         // SET EFFECT 1
          if (inputLine.length() > 3 && inputLine.substring(0,9) == F("GET /fx_1")) {
            fire = true;
            rainbow = false;
            stripe_setBrightness(50);
            isGet = true;
          // SET RAINBOW EFFECT
          if (inputLine.length() > 3 && inputLine.substring(0,12) == F("GET /rainbow")) {
            rainbow = true;
            fire = false;
            isGet = true;
          // SET no_effects
          if (inputLine.length() > 3 && inputLine.substring(0,9) == F("GET /nofx")) {
            rainbow = false;
            fire = false;
            blinker = false;
            isGet = true;
          if (inputLine.length() > 3 && inputLine.substring(0,11) == F("GET /blink/")) {
            xfrom = inputLine.substring(11, komma1).toInt();
            yto = inputLine.substring(komma1+1, slash).toInt();
            int komma3 = getParam.indexOf(',',komma2+1);
            int komma4 = getParam.indexOf(',',komma3+1);
            myredLevel = getParam.substring(0,komma1).toInt();
            mygreenLevel = getParam.substring(komma1+1, komma2).toInt();
            myblueLevel = getParam.substring(komma2+1, komma3).toInt();
            myOn = getParam.substring(komma3+1, komma4).toInt();
            myOff = getParam.substring(komma4+1).toInt();
            blinker = true;
            rainbow = false;
            fire = false;
            isGet = true;
          inputLine = "";
        else if (c != '\r') {
          // add character to the current line
          currentLineIsBlank = false;
          inputLine += c;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println(F("client disconnected"));
  if (fire) fireEffect();
  if (rainbow) rainbowCycle();
// Reset stripe, all LED off and no effects
void reset() {
  for(int i=0; i<stripe_numPixels(); i++) {
    stripe_setPixelColor(i, 0);
  stripe_setBrightness(255);
  stripe_show();
  fire = false;
  rainbow = false;
  blinker = false;
// LED flicker fire effect
void fireEffect() {
  for(int x = 0; x <stripe_numPixels(); x++) {
    int flicker = random(0,55);
    int r1 = 226-flicker;
    int g1 = 121-flicker;
    int b1 = 35-flicker;
    if(g1<0) g1=0;
    if(r1<0) r1=0;
    if(b1<0) b1=0;
    stripe_setPixelColor(x,stripe_color(r1,g1, b1));
  stripe_show();
  delay(random(10,113));
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle() {
  uint16_t i;
  if (rainbowColor++>255) rainbowColor=0;
  for(i=0; i< stripe_numPixels(); i++) {
    stripe_setPixelColor(i, Wheel(((i * 256 / stripe_numPixels()) + rainbowColor) & 255));
  stripe_show();
  delay(20);
void blinkerEffect() {
 for(int i=xfrom; i<=yto; i++) {
    stripe_setPixelColor(i, stripe_color(myredLevel,mygreenLevel,myblueLevel));
  stripe_show();
 delay(myOn);
 for(int i=xfrom; i<= yto; i++) {
    stripe_setPixelColor(i, stripe_color(0,0,0));
  stripe_show();
delay(myOff);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return stripe_color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return stripe_color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return stripe_color(WheelPos * 3, 255 - WheelPos * 3, 0);
int colorVal(char c) {
  int i = (c>='0' && c<='9') ? (c-'0') : (c - 'A' + 10);
  return i*i + i*2;
void sendOkResponse(WiFiClient client) {
  client.println(F("HTTP/1.1 200 OK"));
  client.println(F("Content-Type: text/html"));
  client.println();
  // standard response
  client.print(F("OK,"));
  client.print(stripe_numPixels());
  client.print(F(","));
  int oncount=0;
    if (stripe_getPixelColor(i) != 0) oncount++;
  client.println(oncount);
Wo ist der Fehler? Kann mir da jemand bitte weiterhelfen?
Muss ich noch eine Library einbinden?
Thomas
FHEM auf Pi 3, Echo (Plus, Dot und Connect), CUL868/433, HM Komponenten, Broadlink, Enigma (VU DUO2), Alexa/Homebridge, Sonoffs (POW, RF, Basic), Wemos D1 (IR, DHT, BH1750, OLED, BMP180), IT/Steckdosen, Fritzbox mit SIP, Wifilight, MQTT, Pilight, Xiaomi Flower Sensor, Spotify, Dooya, Shelly, Conbee2
Offline tklein
  • Sr. Member
« Antwort #166 am: 18 Januar 2019, 20:53:16 »
das wird bestimmt etwas mit der Aussgae von exciter zu tun haben: "Mit der vstripe aus dem Originalfile zu kompilieren. Pin, SSID, KEY, nach Bedarf anpassen."
--Allerdings verstehe ich das nicht so richtig, was da gemacht werden muss.
Offline Maui
  • Sr. Member
« Antwort #167 am: 18 Januar 2019, 21:05:35 »
Ist lange her aber ich meine du musst noch eine Library einbinden. Hab's mit Arduino IDE geflasht.
Neopixel brauchst du noch.
Hast du auch die auf wemos angepasste ino genommen?
Offline tklein
  • Sr. Member
« Antwort #168 am: 18 Januar 2019, 21:22:55 »
so sehen meine libs aus. Die ESP Version habe ich nur angepasst (SSID,PW,PIN, LED Anzahl)
Offline Maui
  • Sr. Member
« Antwort #169 am: 18 Januar 2019, 22:34:43 »
Wo hast den Sketch denn her? Direkt aus Github per console gezogen?
Offline tklein
  • Sr. Member
« Antwort #170 am: 18 Januar 2019, 22:38:04 »
von Seite 2 dieses Post glaube mich noch dran zu erinnern. --> https://forum.fhem.de/index.php/topic,50174.15.html
Wo kann ich mir den sonst ziehen?
Offline Maui
  • Sr. Member
« Letzte Änderung: 19 Januar 2019, 08:44:05 von Maui »
Offline tklein
  • Sr. Member
« Antwort #172 am: 19 Januar 2019, 12:02:38 »
besten dank für deine infos!! jetzt hat es geklappt.
habe allerdings die ordnerstruktur ein bißchen modifiziert. evtl passen jetzt die pfade die zuvor nicht korrekt waren.
gibt es noch andere sketchs/module die per fhem ws2812b ansteuern können?
Offline DazDavid
« Antwort #173 am: 21 Januar 2019, 11:55:45 »
erst einmal danke für das Modul.
Ich habe vor meine Treppenstufen zu beleuchten und bei 60LEDs/m werden es am Ende ca. 420 LEDs sein.
Ich habe mir dazu ein "Wemos D1 Mini kompatibles Board" mit 4MBit Speicher in der Bucht geholt.
Tendenziell sollte das von der Größe des Speichers kein Problem darstellen oder?
Brauche ich für das Wemos Board auch noch einen Level-Shifter für die Datenleitung oder ist dafür der Vorwiderstand von 470Ohm gedacht?
Gruß David
« Letzte Änderung: 21 Januar 2019, 12:34:17 von DazDavid »
FHEM (up2date) on Raspberry Pi 3B | nanoCUL 868 MHz | Raspbee Zigbee Gateway | Philips Hue | Osram Lightify | MAX Thermostate
Offline Maui
  • Sr. Member
« Antwort #174 am: 21 Januar 2019, 19:21:15 »
Also ich hab meine stripes direkt am wemos hängen.
Vom Speicher her sollte es gehen. Ich hab allerdings nur 120 am wemos hängen.
Offline e3xtreme
« Antwort #175 am: 14 Dezember 2019, 02:01:07 »
Hallo allerseits,
Hat das Ganze schon jemand mit SK6812 RGBW bzw RGBWW LEDs zum Laufen gebracht? Ich bin derzeit soweit dass die Programme laufen, aber nur die RGB Chips arbeiten nicht jedoch der weiße Chip, spiele nun schon paar Stunden aber weiß nicht so recht wie ich es einbauen soll.
Danke, LG
Offline daelch
« Antwort #176 am: 03 Juli 2020, 22:47:11 »
Kann ich auch einen Raspberry 4 mit diesem Modul einsetzen? Falls nicht: kann man mit einem ESP8266 rund 1150 LED sinnvoll steuern?
Vielen Dank und viele Grüße
« Letzte Änderung: 03 Juli 2020, 23:24:54 von daelch »
Offline swhome
« Antwort #177 am: 06 Juli 2020, 09:56:13 »
Im Prinzip schon, allerdings müsstest Du den Arduino-Teil des Moduls für Raspberry komplett neu aufsetzen. Mit einem ESP wäre es bestimmt weniger Aufwand. Ich erinnere mich dass man pro LED 4 Byte RAM benötigt, könnte klappen.
Im Einsatz: FHEM auf Raspberry Pi mit 350 devices, hauptsächlich Homematic Wired und HM-Heizungsregler, dazu diverse Eigenbauten für Fussbodenheizung und LED Beleuchtung. Und jetzt mit Alexa!
Offline tobi01001
  • Newbie
« Antwort #178 am: 06 Juli 2020, 11:59:09 »
die Herausforderung bei 1150 LEDs liegt hier in der Performance.
RAM
Der RAM eines ESP sollte genügen. Ich habe meinen (überladenen) Code gerade mal mit 1150 LEDs übersetzt und lande bei 56% RAM - statisch.
EDIT: Gerade mal hochgeladen. Für 1150 LEDs habe ich (bei mir) offenbar zu viel dynamische Speichernutzung. Also mit meinem Sketch mit DMA Nutzung nicht out of the Box - sorry.
Aber: bis 600 sollte es gut funktionieren. Ohne "Knob-Control" bestimmt noch mehr - aber dazu müsste ich jetzt genauer nach dem Problem suchen...
/EDIT
Performance
Die Frage ist eher in Richtung Performance. Bei mir laufen aktuell maximal 300 LEDs und damit bekommen ich etwas mehr als 100 FPS.
Die WS2812 mit 800kHz brauchen ca. 30µs pro LED + ein 50µs am Ende vom Frame.
Deine 1150 LEDs brauchen dann 1150*30µs + vernachlässigbare 50 µs um ein Frame geschrieben zu haben. Das macht um die 35 Millisekunden bzw ca 29 frames per second die nur für das Schreiben der LED-Daten benötigt werden. Etwas Rechenzeit für WLAN, das berechnen der Frames und allgemeine Informationen benötigt man ja zusätzlich.
Interrupts
Die nächste Herausforderung dabei ist, dass meist mit BitBanging gearbeitet wird, d.h. die Daten werden über SW geschrieben und dabei sind Interrupts meist gesperrt (sonst kommt das Timing nicht hin).
Mit 35 ms ohne Interrupts steigt of das WiFi aus bzw wird unzuverlässig oder andersrum, haben viele Probleme mit flackernden LEDs. ;-)
Wenn man die LEDs nur an und aus und evtl ein wenig die Helligkeit / Farbe regeln möchte, klappt das bestimmt. Wenn man etwas flüssigere Übergänge oder gar Effekte laufen lassen möchte sind die 30 FPS zu wenig...
Strom
Die nächste Challenge ist der böse Strom. Ein Annahme mit 60mA pro Pixel (mit RGB ohne weiß, real aber um einiges weniger) macht 69 Ampere an Strom die man auf die LEDs bringen möchte - sofern RGB komplett hell sind. (der Nachteil wenn die nur mit 5V laufen). Da muss man relativ oft einspeisen und genügend Strom zur Verfügung stellen.
Meine Messungen landen bei 11 mA pro Farbe. Sind aber immernoch 35A bei voller Aussteuerung. Man kann natürlich den Strom zu Lasten der Helligkeit per SW drosseln.
Das bedeutet natürlich nicht, dass das alles unmöglich ist. Man muss sich nur bewusst sein, worauf man sich einlässt.
Performance und Interrupts:
Ich war mit dem BitBanging Ansatz nicht glücklich. Daher habe ich einen der verfügbaren DMA-Ansätze implementiert.
  • - Vorteil: Das Schreiben der Daten läuft unabhängig von Interrupts und unabhängig vom Hauptprogramm (man kann den Rest währenddessen bearbeiten).
    - Nachteil: Doppelter Speicher für die LED Daten. Sehe aber zumindest in meinem Sketch kein Problem (müsste mal mit 1150 LEDs laufen lassen).
Damit befreit man den ESP davon 35 ms einen einzelnen Pin mit 800kHz zu toggeln. Aber man kann trotzdem nur alle 35 ms ein neues Frame schreiben, die FPS bleiben also LED-hardwarebedingt limitiert.
Die nächste Möglichkeit is Parallel Output:
Hier werden die 1150 in mehrere aufgeteilt. Die Berechnung kann weiterhin an einem LED-Array erfolgen. Das schreiben der Daten erfolgt parallel. Wenn man die LEDs also an 4 parallele PINs hängen würde, hätte man plötzlich die 4 fachen FPS, d.h in deinem Fall ungefähr 120 FPS was schon schön flüssig wäre...
Leider hat der ESP8266 lediglich pin 4 für DMA und soweit ich weiß funktioniert Parallel Output hier nicht. Mit einem ESP32 kann man das machen. Ich habe allerdings meinen Code noch nicht auf den ESP32 portiert und daher leider noch keine Erfahrung damit.
Zusammenfassung:
Es kommt drauf an was du erreichen willst - außer der Tatsache 1150 LEDs zu steuern. ;-)
Ich kann gerne mal ein kurzes Video mit (theoretischen) 1150 LEDs und ein paar Effekten machen, dann sieht man die Performance...
Ich habe (nicht mit deinem Code @swhome - aber mit deinem FHEM Modul als Basis) bei mir zu Hause 5 "Lampen" mit 50 - 300 LEDs am Laufen.
- im Flur eigentlich immer (sofern jemand zu Hause).
- im Wohnzimmer als Effekt / Ambientebeleuchtung wenn der TV läuft.
- im Kinderzimmer als Ambiente, Nachtlicht, zum Wecken und einschlafen und wecken mit Sonnenauf- /Untergang
- im Schlafzimmer als Leselicht
Alle lassen sich über FHEM (mit kleineren Einschränkungen da mir Modulentwicklung ein wenig schwer fällt) und über eine Webseite steuern. Im Kinderzimmer parallel noch über einen "Drehgeber mit Taster und 0.96 OLED".
Soll heißen: Es macht (zumindest mir) Spaß und lohnt sich ;-).
LG,
Tobias
P.S.: Erster Beitrag. Lese seit Jahren viel mit und lerne stetig. :-) Vielleicht kann ich so ja etwas beitragen und zurückgeben.
Und falls tatsächlich wer dran interessiert sein sollte: https://github.com/tobi01001/LED_Stripe_Dynamic_web_conf
« Letzte Änderung: 06 Juli 2020, 12:47:16 von tobi01001 »
Gefällt mir Gefällt mir x 2 Liste anzeigen
Offline pula
  • Sr. Member
« Antwort #179 am: 17 Juli 2020, 12:10:16 »
Hab das Ganze für eine nodemcu mit vscode kompiliert.
Dazu habe ich die inos in EIN cpp file zusammengeführt (anbei) und noch einen hostname eingebaut, mit dem das Ding sich beim DHCP-Server meldet. Ausserdem habe ich die ganzen declares am Anfang des files hinterlegt, damit der compiler zurechtkommt.
Die platformio.ini sieht so aus:
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
framework = arduino
Vielleicht kanns mal jemand brauchen. (Ich bin kein C-Profi, sicher kann man das eleganter lösen, aber es scheint zu tun).
Cheers,
Pula
fhem (debian auf proxmox), HM-LAN und wired, MySensors, FritzBox, Kodi, vdr, Onkyo, squeezeplayers, nanoCUL, wifilight (Ethernet-Bridge), Heizungssteuerung (python/vncdotool), doorpi, ESP/Arduinos/MQTT, Alexa, dash, HomeConnect, Sonoff/Tasmota, espRGBWW, Telegram
