(Solved) weather error empty answer received
Begonnen von HarryT, 15 April 2016, 11:59:20
HarryT
Hi
I updated fhem today and installed the json files on my fritzbox 7490. Now I get the error:
2016.04.15 11:48:47 3: myWeather: https://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20weather.forecast%20where%20woeid=24549334%20and%20u=%27c%27&format=json&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys: empty answer received
every ten minutes. (I use the interval 600)
I searched the internet and the forum, but didn't find any clue why I get this.  Has anybody an idea what is wrong? (In german is fine too)
FHEM 6.3 auf Raspberry Pi3  (1,2 Ghz)
RFXTRX433XL, ZWave, KFL200 and ConBeeIII
Raspberry Pi1 (0,7 Ghz) and Raspberry Pi4 for testing
German reading skills are good.
jschmitt
Hi Harry,
I had the same Problem. Look here:
http://mkleine.de/blog/2014/01/19/raspberry-pi-zugriff-auf-fhem-per-https-sichern/
After that it worked for me.
Viele Grüße,
Johannes
FHEM auf (QNAP TS-219P II, alt) HP T610 Thin Client : 1 x HM-CFG-LAN + 6 x HM-LC-Sw1PBU-FM (Rolladen) + 12 x  HM-Sec-SD (Rauchmelder) + 2 x HM-SWI-3-FM (diverses)
Dr. Boris Neubert
Dear Harry,
does the problem persist? This could be due to the Yahoo Weather API being quite fragile at the moment.
Do you get some json code back when you enter the URL in your browser's address line?
Kind regards,
Boris
Globaler Moderator, Developer, aktives Mitglied des FHEM e.V. (Marketing, Verwaltung)
HarryT
#3
Zitat von: Dr. Boris Neubert am 16 April 2016, 10:44:59
Dear Harry,
Yes.  Now I get the error every hour.
Yes, if I enter the code in my browser I get correct information back.  Also twilights seems to have the correct info and as far as I know it also uses Yahoo.
Kind regards,
Boris
I will have a look in the code, but if you have already some info which I could test or how to get more info from the module that could help.
BTW, maybe important, the state is reported as ¨Initialized".
{HT}
Dr. Boris Neubert
Just realized that my latest version did not make it to the repo yet. There is now a new version of 59_Weather.pm and YahooWeatherAPI.pm in the SVN repo. You either wait until tomorrow morning and make an update or just retrieve the aforementioned files from Sourceforge. In either case the most recent version should be our common base for debugging.
Boris
HarryT
Boris
Ok
As I go to the theator tonight I will wait till tomorrow.
My findings, the problem exists within httputil.pm
I see twilight calling httputils and get a correct answer and weather gets an empty answer.  I was tracing this code:
    $data = $hdr.(defined($data) ? $data:"");
    $hash->{directWriteFn} = sub($) { # Nonblocking write
      my $ret = syswrite $hash->{conn}, $data;
      if($ret <= 0) {
        my $err = $!;
        RemoveInternalTimer(\%timerHash);
        HttpUtils_Close($hash);
        Debug "httputil connect2 1b";
        return $hash->{callback}($hash, "write error: $err", undef)
      $data = substr($data,$ret);
      if(length($data) == 0) {
        shutdown($hash->{conn}, 1) if($s);
        delete($hash->{directWriteFn});
        InternalTimer(gettimeofday()+$hash->{timeout},
                      "HttpUtils_ReadErr", \%timerHash, 0);
        Debug "httputil connect2 1c";
    $selectlist{$hash} = $hash;
                  "HttpUtils_WriteErr", \%timerHash, 0);
    Debug "httputil connect2 1e";
    return undef;
And see that  Debug "httputil connect2 1c"; is executed which seems not so good to me.
BTW I set the timeout in yaohooweather_api.pm to 150. So that shouldn't be a problem.
Maybe this gives already a clue.
PHT}
HarryT
#6
Hi
I just updated till the current version. The error stil exists,.
What can I do?
{HT}
Dr. Boris Neubert
I compared the mechanisms in Twilight and Weather and both modules do it the same. So no idea why Twilight should work and Weather not (apart from Twilight trying harder/more often to retrieve the data).
Do you never receive any data or only from time to time? Would you mind having a look at the pubDate... and validity readings?
Boris
HarryT
No, at the moment it seems weather tries every minute. I inserted  a debug line in httputils
HttpUtils_NonblockingGet($)
  my ($hash) = @_;
  my ($url)= @_;
  $hash->{hu_blocking} = 0;
  my ($isFile, $fErr, $fContent) = HttpUtils_File($hash);
  return $hash->{callback}($hash, $fErr, $fContent) if($isFile);
  my $err = HttpUtils_Connect($hash);
  Debug "HttpUtils_NonblockingGet Err: $err  Url: $url $hash->{displayurl}";
  $hash->{callback}($hash, $err, "") if($err);
and this gives me a message every minute.
I am afraid you over estimate my knowledge. I can read a bit of perl but for sure not a guru. Please give me so directions.
Boris
HarryT
Hi
Weather_ReturnWithError there is a rearm every 60 seconds. Was this intentionally?
    my $next= 600; # $next= $hash->{INTERVAL};
or should the 60 seconds just be temporarily?
If 60 seconds is your intention I would suggest introducing a counter which steps this after 20 tries or so.
{HT}
Dr. Boris Neubert
What I meant is: just have a look at the readings of your device myWeather, preferably through FHEMWEB or through list myWeather in the FHEM console.
The update every minute is intended. It does so as long as no valid answer is received. I consider your suggestion to increment the retrial period after several unsuccessful tries.
Kind regards
Boris
HarryT
Ok
It seems I can't attach a screendump here. So I send it in private mail. I don't see anything strange in the readingsl. And the url which is reported back in my logging works fine if I use it from my browser.
At the moment I am trying to log the url's in httputils originated from weather and twilight. Maybe that gives a clue.
During the night several calls from twilight where succesfull and as far as I can see all calls from weather failed.   (I use different location codes to see the difference)
{HT}
Dr. Boris Neubert
Dear Harry,
thanks for the image. This is unambiguous: you never get a reply other than the empty answer.
Please let it run for some more time, anyway. The logs will be useful as well.
Kind regards
Boris
HarryT
I now have this in my logging:
called by twilight:
http://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20weather.forecast%20where%20woeid=24549334
%20and%20u=%27c%27&format=json&env=store%3A%2%2Fdatatables.org%2Falltableswithkeys
called by weather:
https://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20weather.forecast%20where%20woeid=12596696
The first works, the second not. The big difference is the https call instead of http I guess.
Is https necessary?
And has anybody described how to get the https calls working from a fritzbox?
{HT}
HarryT
Changing https in http in YahooWeather.pm indeed is a workaround.
Is it possible to let HttpUtils give an error when this is a problem? I guess I won't be the only one who gets this problem?
{HT}
