also die Hardware ist ein Intel NUC DN2820, Welcome to Ubuntu 16.04.3 LTS (GNU/Linux 4.4.0-93-generic x86_64), fhem ist aktuell
2017.08.28 16:42:34 0: Featurelevel: 5.8
2017.08.28 16:42:34 0: Server started with 241 defined entities (fhem.pl:14945/2017-08-22 perl:5.022001 os:linux user:fhem pid:1259)
dmesg sagt konstant (unmittelbar nach reboot und auch 5 min später) folgendes:
dmesg | grep usb
[ 0.282458] usbcore: registered new interface driver usbfs
[ 0.282487] usbcore: registered new interface driver hub
[ 0.282521] usbcore: registered new device driver usb
[ 1.399115] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.403655] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.412454] usb usb1: Product: xHCI Host Controller
[ 1.417019] usb usb1: Manufacturer: Linux 4.4.0-93-generic xhci-hcd
[ 1.421548] usb usb1: SerialNumber: 0000:00:14.0
[ 1.449332] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.453780] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.462544] usb usb2: Product: xHCI Host Controller
[ 1.467085] usb usb2: Manufacturer: Linux 4.4.0-93-generic xhci-hcd
[ 1.471672] usb usb2: SerialNumber: 0000:00:14.0
[ 1.808147] usb 1-2: new full-speed USB device number 2 using xhci_hcd
[ 1.995436] usb 1-2: New USB device found, idVendor=0403, idProduct=6001
[ 2.001135] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.006626] usb 1-2: Product: RFXtrx433
[ 2.011988] usb 1-2: Manufacturer: RFXCOM
[ 2.017160] usb 1-2: SerialNumber: A1R10O0
[ 2.212593] usb 1-4: new full-speed USB device number 3 using xhci_hcd
[ 2.341852] usb 1-4: New USB device found, idVendor=8087, idProduct=07dc
[ 2.342139] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.307525] usbcore: registered new interface driver btusb
[ 6.152108] Modules linked in: bnep btusb btrtl btbcm btintel bluetooth intel_rapl intel_soc_dts_iosf intel_powerclamp coretemp kvm_intel snd_hda_codec_hdmi kvm snd_hda_codec_realtek snd_soc_rt5640 snd_hda_codec_generic snd_intel_sst_acpi snd_soc_rl6231 snd_intel_sst_core snd_soc_sst_mfld_platform iwlmvm(+) mac80211 snd_hda_intel irqbypass punit_atom_debug crct10dif_pclmul snd_hda_codec crc32_pclmul iwlwifi ghash_clmulni_intel cryptd snd_soc_core snd_hda_core snd_compress ac97_bus snd_hwdep snd_pcm_dmaengine snd_seq_midi snd_seq_midi_event cfg80211 snd_pcm snd_rawmidi serio_raw lpc_ich mei_txe shpchp mei snd_seq ir_xmp_decoder ir_lirc_codec lirc_dev ir_mce_kbd_decoder ir_sharp_decoder ir_sanyo_decoder snd_seq_device ir_sony_decoder ir_jvc_decoder ir_rc6_decoder snd_timer ir_rc5_decoder ir_nec_decoder
[ 6.429829] usbcore: registered new interface driver usbserial
[ 6.430586] usbcore: registered new interface driver usbserial_generic
[ 6.431750] usbserial: USB Serial support registered for generic
[ 6.515166] usbcore: registered new interface driver ftdi_sio
[ 6.516217] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 6.651188] usb 1-2: Detected FT232RL
[ 6.685584] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB0
Fehlermeldung ist immer noch:
2017.08.28 16:42:32 1: TRX: Initialization Error: No character read
2017.08.28 16:42:32 1: Cannot init /dev/serial/by-id/usb-RFXCOM_RFXtrx433_A1R10O0-if00-port0, ignoring it (RFXTRX433)
Es ist auch völlig egal, wie ich das Ding defniere, ob by-id, oder über ttyUSB0 oder eine selbst definierte Umleitung des USB ports.
Ich vermute das Problem am ehesten in der 45_TRX.pm (hexstring passt nicht mehr zum vom rfx gesendeten) oder Startverhalten von Prozessen in 16.04 (da ja der rfx unter 14.04 noch einwandfrei lief). Das 16.04 ist neu aufgesetzt, dann fhem aus backup wiederhergestellt.
Stecke ich den rfx an den win10-PC, reagiert er im rfxmngr ganz normal und zwigt auch brav alle eingestellten Parameter, auch der Firmwareupdate lief problemlos (P.S.: das kanns nicht gewesen sein, da ich das FW-Update erst nach der Fehlermeldung gemacht habe).
vG
Olli
