Fibaro FGFS-101 Flood Sensor Temperatur-Readings
Begonnen von Hauenschild, 26 Mai 2016, 11:20:05
Hauenschild
Hallo liebe FHEM-Gemeinde,
ich habe, soweit ich das richtig einschätze, erfolgreich einen ZWave Flood Sensor von Fibaro eingebunden. Ein list vom Device zeigt folgendes Ergebnis:
ZitatInternals:
   DEF        0e0d0c0b 18
   IODev      ZWAVE1
   LASTInputDev ZWAVE1
   MSGCNT     13
   NAME       flood_sensor_1
   NR         531
   STATE      TRANSMIT_NO_ACK
   TYPE       ZWave
   ZWAVE1_MSGCNT 13
   ZWAVE1_RAWMSG 00040412028407
   ZWAVE1_TIME 2016-05-26 09:57:17
   homeId     0e0d0c0b
   lastMsgSent 1464249437.79891
   nodeIdHex  12
   timeToAck  2.079
   Readings:
     2016-05-07 10:53:59   CMD             ZW_APPLICATION_UPDATE
     2016-05-17 18:04:22   alarm_type_00   level ff node 12 seconds 0
     2016-05-16 19:19:11   alarm_type_05   level 00 node 12 seconds 0
     2016-05-17 00:12:37   assocGroup_1    Max 5 Nodes ZWAVE1
     2016-05-17 00:12:37   assocGroup_2    Max 5 Nodes ZWAVE1
     2016-05-17 00:12:37   assocGroup_3    Max 1 Nodes ZWAVE1
     2016-05-16 23:06:40   assocGroups     3
     2016-05-16 19:19:11   basicSet        00
     2016-05-07 10:56:53   battery         60 %
     2016-05-07 10:52:34   configAcousticAndVisualSignals AcousticACTIVEVisualACTIVE
     2016-05-07 10:52:34   configAlarmFrameBasicSetFrame76 0
     2016-05-07 10:52:34   configAlarmFrameSentToGroup2TamperTilt MovementTamperAlarmACTIVE
     2016-05-07 10:52:34   configDeactivateTransmissionOfFrame9 AlarmFloodingCancellationACTIVE
     2016-05-07 10:52:36   configFloodSensorFunctionalityTurned77 DefaultFloodSensorOperationACTIV0
     2016-05-07 10:52:36   configForcedLevelOfDimmingGroup1 255
     2016-05-07 10:52:36   configHighTemperatureAlarmIndicator62 16711680
     2016-05-07 10:52:36   configHighTemperatureAlarmThreshold 3500
     2016-05-07 10:52:37   configIN1AlarmCancellationDelay 0
     2016-05-07 10:52:37   configInsensitivenessToTemperature12 50
     2016-05-07 10:52:37   configIntervalBetweenSuccessive10 300
     2016-05-07 10:52:37   configLowTemperatureAlarmIndicator61 255
     2016-05-07 10:52:39   configLowTemperatureAlarmThreshold 1500
     2016-05-07 10:52:39   configManagingALEDIndicatorUnder63 LEDIndicatesTemperature2
     2016-05-07 10:52:39   configTemperatureMeasurement73 0
     2016-05-07 10:52:39   configTransmittingTheAlarmOrControl13 BroadcastsINACTIVE
     2016-05-07 10:52:40   configTypeOfAlarmFrameForAssociation5 BASICSET
     2016-05-07 10:52:40   configVisualAndAudibleAlarmDuration 0
     2016-05-16 23:06:44   mcCapability_01 SENSOR_BINARY
     2016-05-16 23:06:45   mcCapability_02 SENSOR_MULTILEVEL
     2016-05-16 18:43:02   mcEndpoints     total 2, different
     2016-05-16 22:00:55   model           FIBARO System FGFS101 Flood Sensor
     2016-05-16 22:00:55   modelConfig     fibaro/fgfs101.xml
     2016-05-16 22:00:55   modelId         010f-0b00-1001
     2016-05-16 22:00:44   reportedState   closed
     2016-05-20 23:40:11   state           TRANSMIT_NO_ACK
     2016-05-26 09:57:19   transmit        OK
     2016-05-26 09:57:17   wakeup          notification
     2016-05-07 10:52:43   wakeupReport    interval 4000 target 255
   IODev      ZWAVE1
   classes    SENSOR_BINARY SENSOR_ALARM MULTI_CHANNEL ASSOCIATION MULTI_CHANNEL_ASSOCIATION MANUFACTURER_SPECIFIC CONFIGURATION VERSION BATTERY WAKE_UP
   icon       Icon_Fisch@red
   room       Aquarium,ZWave
Wenn ich z. B. den Sensor anhebe erscheint im LogFile auch folgende Meldung:
Zitat2016-05-26_11:03:53 flood_sensor_1 alarm_type_00: level ff node 12 seconds 0
Ansonsten sendet der Sensor laut LogFile aber nur:
2016-05-26_00:05:26 flood_sensor_1 wakeup: notification
2016-05-26_01:11:11 flood_sensor_1 wakeup: notification
2016-05-26_02:16:58 flood_sensor_1 wakeup: notification
2016-05-26_03:22:44 flood_sensor_1 wakeup: notification
2016-05-26_04:28:29 flood_sensor_1 wakeup: notification
2016-05-26_05:34:14 flood_sensor_1 wakeup: notification
2016-05-26_06:40:01 flood_sensor_1 wakeup: notification
2016-05-26_07:45:47 flood_sensor_1 wakeup: notification
2016-05-26_08:51:32 flood_sensor_1 wakeup: notification
2016-05-26_09:57:17 flood_sensor_1 wakeup: notification
2016-05-26_11:03:00 flood_sensor_1 wakeup: notification
Ich möchte aber gerne vom Sensor so ca. alle 1/4-Stunde die aktuelle Temperatur erfahren. Nach intensiver Recherche hier im Forum vermute ich, dass ich hierzu noch ein Reading anlegen muss. Ob das so stimmt und wie ich das bewerkstelligen könnte übersteigt aber bei weitem meine FHEM-Kenntnisse.
Auffällig ist, dass beim anlegen des Sensors FHEM automatisch zwei weitere Devices mit folgendem list angelegt hat:
ZitatInternals:
   DEF        0e0d0c0b 4609
   IODev      ZWAVE1
   NAME       ZWave_SENSOR_BINARY_18.01
   NR         535
   STATE      ???
   TYPE       ZWave
   homeId     0e0d0c0b
   nodeIdHex  1201
   IODev      ZWAVE1
   room       ZWave
und
ZitatInternals:
   DEF        0e0d0c0b 4610
   IODev      ZWAVE1
   NAME       ZWave_SENSOR_MULTILEVEL_18.02
   NR         533
   STATE      ???
   TYPE       ZWave
   homeId     0e0d0c0b
   nodeIdHex  1202
   Readings:
     2016-05-24 08:12:47   temperature     21.09 C
   IODev      ZWAVE1
   classes    SENSOR_MULTILEVEL
   room       ZWave
Beim ersten steht garnichts im LogFile und beim zweiten erhalte ich folgende Meldungen:
Zitat2016-04-22_14:36:12 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 23.25 C
2016-04-22_15:10:42 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 23.81 C
2016-04-22_16:24:35 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 23.46 C
2016-04-22_17:04:03 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 22.89 C
2016-05-07_09:08:56 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 23.13 C
2016-05-07_09:16:51 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 22.63 C
2016-05-07_09:31:40 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 22.12 C
2016-05-07_10:14:46 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 22.02 C
2016-05-07_10:35:54 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 22.63 C
2016-05-07_10:56:53 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 24.22 C
2016-05-07_11:59:44 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 24.53 C
2016-05-09_21:12:44 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 24.72 C
2016-05-12_06:38:12 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 24.60 C
2016-05-12_06:48:02 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 23.60 C
2016-05-13_07:38:26 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 24.53 C
2016-05-16_17:38:21 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 22.84 C
2016-05-16_17:43:16 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 21.93 C
2016-05-16_17:48:13 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 21.27 C
2016-05-16_17:58:05 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 20.67 C
2016-05-16_18:17:49 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 20.11 C
2016-05-16_19:48:54 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 19.76 C
2016-05-16_23:06:45 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 19.48 C
2016-05-24_08:12:47 ZWave_SENSOR_MULTILEVEL_18.02 temperature: 21.09 C
Kann mir jemand einen Tip geben wie ich weiter vorgehen sollte, da ich nicht weiß wo ich jetzt bei meinem Problem ansetzen kann.
Zum Schluß noch der Hinweis, dass mein FHEM mit ZWave auf einem Raspberry Typ B mit Komplett-Update von letzer Woche läuft.
Gruß Frank
marvin78
Ich verstehe dein Problem nicht. Über das Device ZWave_SENSOR_MULTILEVEL_18.02 erhälst du doch offenbar die Temperatur. Das ist offenbar der "Kanal" für die Temperatur (so würde man es bei Homematic sehen). Sehe es als Temperatursensor. Oder geht es ums Interval? Offenbar wird nur gesendet, wenn sich was ändert.
Was kann denn configTemperatureMeasurement73?
Hauenschild
#2
Oh sorry, da habe ich wohl mein Problem nicht ausreichend beschrieben.
Also, die oben stehenden LogFiles mit den Temparaturdaten sind Daten, die ich vom Device ZWave_SENSOR_MULTILEVEL_18.02 nur erhalte, wenn ich mit
get ZWave_SENSOR_MULTILEVEL_18.02 smStatus
eine Anforderung starte. Dann erscheint der Hinweis von FHEM "Scheduled for sending after WAKEUP". Wenn dann der Flood Sensor aufwacht oder ich ihn manuell durch 3x schnelles Tippen des kleinen Hebels im Gehäuseinnern (quasi die Anlerntaste des Sensors) aufwecke, erhalte ich in FHEM ein aktuelles Temperatur-Reading. Es ist also so, das der Sensor nicht wie z. B. bei Homematic automatisch laufend Temperaturdaten sendet. Auch nicht, wenn diese sich ändern. Jetzt suche ich eine Lösung, wo mir z. B. wie oben geschrieben im 1/4-Stundentakt automatisch Temperatur-Readings gesendet werden.
Ich habe den Sensor auch bereits einmal vollständig wie im ZWave-Wiki beschrieben ausgetragen und neu angelernt. Das Ergebnis ist aber dasselbe wie hier von mir geschildert.
Und die Frage
ZitatWas kann denn configTemperatureMeasurement73?
verstehe ich vermutlich nicht ganz? Dort ich seit Beginn des Anlegens des Sensors unter FHEM immer unverändert eine Null (0) eingetragen.
krikan
Laut Sensor-Handbuch http://www.fibaro.com/manuals/en/FGFS-101-Flood-Sensor/FGFS-101-Flood-Sensor-en-2.1-2.3.pdf bedeutet:
= alle 5 Minuten wird Temperatur und Batteriezustand gemessen (nur relevant bei Batteriebetrieb des Sensors) und an Controller gemäß Einstellung unter configInsensitivenessToTemperature12 verschickt.
= wenn Temperaturmessung um 0,5 Grad von vorheriger Messung abweicht wird ein Temperaturtelegramm an Controller verschickt; sonst nicht.
= Korrekturfaktor für Temperatur
Wenn es keine Einflüsse von anderen config-Parametern gibt (habe nicht das komplette Handbuch gelesen), sollte der Sensor mit den configs bei 0,5 Grad Abweichungen Reports schicken. Gemessen wird alle 5 Minuten. Das ist also das kleinste Sendeintervall.
Hauenschild
#4
Zunächst vielen Dank marvin und krikan für die schnellen Hinweise!
Wenn ich das richtig verstanden habe müßte also irgendwo das Temperaturtelegramm bei FHEM bereits ankommen. Müßte ich jetzt also hierfür ein Reading irgendwie aktivieren? Wie gesagt funktionieren ja folgende Readings:
(ich neige den Sensor)
(ich stelle den Sensor ins Wasser)
Ich müßte jetzt also ein Reading für das Temperaturtelegramm  beim vorhandenen Device ZWave_SENSOR_MULTILEVEL_18.02 einrichten da nicht automatisch vorhanden, oder? Puh, so etwas habe ich bisher noch nicht bewerkstelligt. Sollte ich dazu das FHEM-Modul CustomReadings nutzen?
krikan
Dafür musst Du nichts in FHEM einrichten. Nur die Konfiguration im Sensor muss korrekt sein. Das Reading "temperature" wird automatisch kommen, wenn der Sensor die Nachricht verschickt und Dongle empfängt. Vermute das landet im Hauptdevice ZWave_SENSOR_MULTILEVEL_18.
FunkOdyssey
Kurze Frage am Rande: Der FGFS-101 ist kein FLIRS-Gerät, oder?
Den Readings (s.o.) entnehme ich, dass es ein WAKE_UP Device ist.
Stimmt das?
Update: Hat sich erledigt ==> http://products.z-wavealliance.org/products/994
ZitatZ-Wave library type: Enhanced Slave, No FLiRS, No MR
