statistics power usage
Begonnen von kroonen, 01 August 2016, 20:48:18
kroonen
I got the module for smart power metering, but I want to us statistics module to calculate te values for low and normal tarif
I get these values in fhem for the smart meter
ElectricityDeliveredLowTariff      4990.403 kWh        2016-08-01 06:59:53
ElectricityDeliveredNormalTariff 3115.740 kWh        2016-08-01 20:40:20
I defined a statistics  like this
define STAT_EL statistics ElectricityD*.*|SmartMeterP1
attr STAT_EL singularReadings SmartMeterP1:ElectricityD*:Delta
I get not the right values I get these values
statStateDay  Initialized: 20:45:25 Initialized_Count: 1  2016-08-01 20:45:20
statStateDayLast  Initialized: 00:34:49 Initialized_Count: 1  2016-07-31 23:59:55
statStateMonth  Initialized: 20:45:25 Initialized_Count: 1 2016-08-01 20:45:20
Any idea how to get it right, so I get the values for de low and normal tarif.
regards Richard
fruit
I don't use either of those modules (so probably have no real idea ;) ) but perhaps you can extract low and normal tarrif values to separate dummies and run the statistics module on each of those?
Feel free to follow up in German if you prefer
kroonen
Hoi,
I created a dummy device like this
define SmartN dummy
attr SmartN room Meterkast
define Smart_Norm notify SmartMeterP1:ElectricityDeliveredNormalTariff.* setreading SmartN state $EVTPART1
and the statistics like this
define STAT_EL statistics SmartN
attr STAT_EL singularReadings SmartN:state:Delta:(Hour|Day|Month|Year)
But i get not the right readings?? not hourly and statStateday is not really one valut for the day??
What I do wrong?
fhem> l SmartN
   NAME       SmartN
   NR         7
   STATE      3117.449
   TYPE       dummy
   Readings:
     2016-08-02 16:41:00   statStateDay    3116.956: 00:02:08 3116.956_Count: 1 3116.963: 00:02:00 3116.963_Count: 1 3116.969: 00:02:11 3116.969_Count: 1 3116.976: 00:02:10 3116.976_Count: 1 3116.983: 00:02:00 3116.983_Count: 1 3116.989: 00:02:10 3116.989_Count: 1 3116.996: 00:01:00 3116.996_Count: 1 3116.999: 00:02:10 3116.999_Count: 1 3117.006: 00:02:00 3117.006_Count: 1 3117.012: 00:02:10 3117.012_Count: 1 3117.019: 00:02:00 3117.019_Count: 1 3117.025: 00:02:10 3117.025_Count: 1 3117.032: 00:02:00 3117.032_Count: 1 3117.038: 00:02:10 3117.038_Count: 1 3117.045: 00:02:00 3117.045_Count: 1 3117.051: 00:02:10 3117.051_Count: 1 3117.058: 00:02:10 3117.058_Count: 1 3117.065: 00:02:00 3117.065_Count: 1 3117.071: 00:02:10 3117.071_Count: 1 3117.078: 00:02:00 3117.078_Count: 1 3117.084: 00:02:10 3117.084_Count: 1 3117.091: 00:02:00 3117.091_Count: 1 3117.097: 00:02:10 3117.097_Count: 1 3117.104: 00:02:00 3117.104_Count: 1 3117.110: 00:02:10 3117.110_Count: 1 3117.117: 00:02:00 3117.117_Count: 1 3117.132: 00:02:00 3117.132_Count: 1 3117.206: 00:02:20 3117.206_Count: 1 3117.220: 00:02:10 3117.220_Count: 1 3117.224: 00:02:10 3117.224_Count: 1 3117.228: 00:02:10 3117.228_Count: 1 3117.232: 00:02:10 3117.232_Count: 1 3117.236: 00:02:20 3117.236_Count: 1 3117.240: 00:02:10 3117.240_Count: 1 3117.244: 00:02:10 3117.244_Count: 1 3117.248: 00:02:10 3117.248_Count: 1 3117.252: 00:02:10 3117.252_Count: 1 3117.256: 00:02:10 3117.256_Count: 1 3117.260: 00:02:00 3117.260_Count: 1 3117.264: 00:02:10 3117.264_Count: 1 3117.268: 00:02:10 3117.268_Count: 1 3117.272: 00:02:10 3117.272_Count: 1 3117.276: 00:02:10 3117.276_Count: 1 3117.280: 00:02:10 3117.280_Count: 1 3117.284: 00:02:10 3117.284_Count: 1 3117.288: 00:02:10 3117.288_Count: 1 3117.292: 00:02:20 3117.292_Count: 1 3117.296: 00:02:20 3117.296_Count: 1 3117.301: 00:02:10 3117.301_Count: 1 3117.305: 00:02:10 3117.305_Count: 1 3117.309: 00:02:10 3117.309_Count: 1 3117.313: 00:02:10 3117.313_Count: 1 3117.317: 00:02:20 3117.317_Count: 1 3117.321: 00:02:10 3117.321_Count: 1 3117.325: 00:02:10 3117.325_Count: 1 3117.329: 00:02:10 3117.329_Count: 1 3117.333: 00:02:10 3117.333_Count: 1 3117.337: 00:02:10 3117.337_Count: 1 3117.341: 00:02:10 3117.341_Count: 1 3117.345: 00:02:20 3117.345_Count: 1 3117.349: 00:02:10 3117.349_Count: 1 3117.353: 00:02:11 3117.353_Count: 1 3117.357: 00:02:10 3117.357_Count: 1 3117.361: 00:02:10 3117.361_Count: 1 3117.365: 00:02:10 3117.365_Count: 1 3117.369: 00:02:10 3117.369_Count: 1 3117.373: 00:02:10 3117.373_Count: 1 3117.377: 00:02:10 3117.377_Count: 1 3117.381: 00:02:20 3117.381_Count: 1 3117.385: 00:02:10 3117.385_Count: 1 3117.389: 00:02:10 3117.389_Count: 1 3117.393: 00:02:10 3117.393_Count: 1 3117.397: 00:02:10 3117.397_Count: 1 3117.401: 00:02:10 3117.401_Count: 1 3117.405: 00:02:10 3117.405_Count: 1 3117.409: 00:02:10 3117.409_Count: 1 3117.413: 00:02:20 3117.413_Count: 1 3117.417: 00:02:10 3117.417_Count: 1 3117.421: 00:02:10 3117.421_Count: 1 3117.425: 00:02:10 3117.425_Count: 1 3117.429: 00:02:10 3117.429_Count: 1 3117.433: 00:02:10 3117.433_Count: 1 3117.437: 00:02:10 3117.437_Count: 1 3117.441: 00:02:10 3117.441_Count: 1 3117.445: 00:02:10 3117.445_Count: 1 3117.449_Count: 1 (since: 2016-08-02_13:38:50)
fruit
I am finding it difficult to see what is going on, partly as you haven't shown the exact module you are using for power monitoring, perhaps a screenshot of that module would help
From your first post
define STAT_EL statistics ElectricityD*.*|SmartMeterP1do you have a device that matches ElectricityD*.* or should it be just SmartMeterP1?
Searches for statistics delta power or similar may give some workable examples but also look at https://forum.fhem.de/index.php/topic,55151.msg468187.html#msg468187
kroonen
I got it to work without the need of dummy devices
define STAT_P1 statistics SmartMeterP1
attr STAT_P1 deltaReadings GasDelivered,ElectricityDeliveredLowTariff,ElectricityDeliveredNormalTariff
attr STAT_P1 ignoreDefaultAssignments 1
attr STAT_P1 singularReadings SmartMeterP1:GasDelivered:Delta:(Year|Month|Day|Hour)|SmartMeterP1:ElectricityDeliveredLowTariff:Delta:(Year|Month|Day|Hour)|SmartMeterP1:ElectricityDeliveredNormalTariff:Delta:(Year|Month|Day|Hour)
fruit
That is good. Following my searches I thought you might be able to do it without the dummies
