Hauptmenü
Rollo mit Homebridge
Begonnen von Bumbum, 17 Oktober 2016, 15:13:34
Kenneth
#90
Danke nochmal, jetzt hab ich es wie es sein muss... Status/Zustand wird auch richtig angezeigt. Hatte "invert=1" bei CurrentPosition vergessen.
homebridgeMapping:
clear CurrentPosition=userposition,invert=1,minValue=0,maxValue=100,minStep=10 TargetPosition=userposition,invert=1,minValue=0,maxValue=100,minStep=10,cmd=pos
List:
   ADDRESS    54A103
   CFGFN      ./FHEM/Jalousien.cfg
   CHANGED
   DEF        54A103
   FUUID      5c81233b-f33f-2783-d005-c8335129318bc0de
   IODev      sduino433
   NAME       Jalou_WG_01
   NR         1103
   STATE      open
   TYPE       SOMFY
   move       stop
   CODE:
     1          54A103
     2019-03-09 13:44:53   enc_key         A2
     2019-03-09 13:44:54   exact           0
     2019-03-09 13:44:54   position        0
     2019-03-09 13:44:53   rolling_code    0132
     2019-03-09 13:44:54   state           open
     2019-03-09 13:44:54   userposition    0
   IODev      sduino433
   alexaName  Garteneins
   alexaRoom  Garteneins
   alias      Rollo 1
   devStateIcon open:fts_shutter_10 10:fts_shutter_10 20:fts_shutter_20 30:fts_shutter_30 40:fts_shutter_40 50:fts_shutter_50 60:fts_shutter_60 70:fts_shutter_70 80:fts_shutter_80 90:fts_shutter_90 100:fts_shutter_90@lightblue schatten:fts_shutter_90@lightblue down:fts_shutter_100@blue closed:fts_shutter_100@blue
   drive-down-time-to-100 22
   drive-down-time-to-close 26
   drive-up-time-to-100 4
   drive-up-time-to-open 26
   event-on-change-reading state,position,userposition
   eventMap   on:runter off:hoch off:up on:down go-my:schatten
   fm_type    state,offbutton,onbutton
   genericDeviceType blind
   homebridgeMapping clear CurrentPosition=userposition,invert=1,minValue=0,maxValue=100,minStep=10 TargetPosition=userposition,invert=1,minValue=0,maxValue=100,minStep=10,cmd=pos
   icon       fts_shutter_1w
   model      somfyblinds
   room       1.0.6_Rollladen,Alexa,Homekit
   userReadings userposition {(ReadingsVal($NAME,"state","open") eq "open")?0:
(ReadingsVal($NAME,"state","open") eq "closed")?100:
(ReadingsVal($NAME,"state","open") eq "200")?100:
(ReadingsVal($NAME,"state","open") eq "90")?90:
(ReadingsVal($NAME,"state","open") eq "80")?80:
(ReadingsVal($NAME,"state","open") eq "70")?70:
(ReadingsVal($NAME,"state","open") eq "60")?60:
(ReadingsVal($NAME,"state","open") eq "50")?50:
(ReadingsVal($NAME,"state","open") eq "40")?40:
(ReadingsVal($NAME,"state","open") eq "30")?30:
(ReadingsVal($NAME,"state","open") eq "20")?20:
(ReadingsVal($NAME,"state","open") eq "10")?10:100}
   webCmd     runter:stop:hoch:schatten
   widgetOverride pos:slider,0,5,100
Intel NUC @Ubuntu > FHEM 5.8
HM-LAN, NanoCul, Signalduino
EchoDot, Gardena Sileno, XT1, Somfy RTS
TabletUI
RitterSport
ich kämpfe gerade mit dem Mapping für Dooya Rolläden.
Aktuell habe ich :
"attr homebridgeMapping clear CurrentPosition=exact TargetPosition=CurrentPosition,cmd=pos"
"attr eventMap on:zu off:auf stop:stop"
set xxx pos 90 bewirkt 90% Beschattung
set xxx on bewirkt Rolläden komplett runter genauso wie set xxx zu
es gibt die Range 0-100, leider ist 100 aber nicht ganz zu sondern  dooya würde 200 melden, somit funktioniert ab ein on oder zu als komplettes Schließen.
Momentan kann ich per Alexa auf Prozent Werte setzen, aber ich kann nicht die Rolläden komplett schliessen.
"clear CurrentPosition=exact TargetPosition=CurrentPosition,cmds=pos;aus:on" gibt mir zurück das der Befehl zu oder on nicht existiert
Was muss ich bei Mapping eintragen damit ich zusätzlich zu den % Werten auch on oder off senden könnte?
Udomatic
#92
Zitat von: chrisse111179 am 21 Mai 2017, 13:10:40
Falls noch jemand das nachbauen möchte, hier der Code:
define Rollladen SOMFY 000001
attr Rollladen IODev CUL1
attr Rollladen alias Rollladen BlueSaloon
attr Rollladen devStateIcon closed:fts_shutter_100 open:fts_shutter_10 my:fts_shutter_50
attr Rollladen eventMap on:ab off:auf go-my:my on:close off:open
attr Rollladen genericDeviceType blind
attr Rollladen group Rollläden
attr Rollladen homebridgeMapping clear CurrentPosition=userposition,minValue=0,maxValue=100,minStep=50 TargetPosition=userposition,minValue=0,maxValue=100,minStep=50,cmds=0:close;;50:my;;100:open
attr Rollladen icon fts_shutter_updown
attr Rollladen model somfyshutter
attr Rollladen room Homekit
attr Rollladen siriName Rollladen Büro
attr Rollladen userReadings userposition {(ReadingsVal($NAME,"state","open") eq "open")?100:(ReadingsVal($NAME,"state","open") eq "go-my")?50:0}
attr Rollladen webCmd auf:my:ab
Ich habe die Lösung nachgebaut, aber in der HomeApp wird der Rollo als geschlossen angezeigt. Daraufhin habe ich ein invert=1 gesetzt. Leider wird der Status immer noch nicht richtig angezeigt
   IODev      radinoCC1101
   group      Rolladen
   homebridgeMapping clear CurrentPosition=userposition,invert=1,minValue=0,maxValue=100,minStep=50 TargetPosition=userposition,minValue=0,maxValue=100,minStep=50,cmds=0:close;;50:my;;100:open
   icon       fts_shutter
   model      somfyshutter
   room       Esszimmer,Homekit,Somfy
   webCmd     auf:my:ab
Wo könnte der Fehler liegen?
Habe die Lösung gefunden durch setzen des Attributs positionInverse 1
2x Raspberry 3B+, 1x Raspberry 4, Signalduino 433 (Somfy), CUL_HM (HM-MOD-RPI-PCB), MQTT, Hue, ConBee 2, Sonos, AVM DECT, Netatmo, eufy, Nuki,
marcel151
Ich hoffe es ist ok dieses Thema wieder hoch zu holen. Leider komme ich bei meinem Rolladenaktor von Homematic nicht weiter. Anscheinend arbeitet der anders als die hier besprochenen Aktoren. Rollade wird in Home korrekt angezeigt, leider werden aber keine Zwischenpositionen angezeigt und ich kann diese auch nicht anfahren. Außerdem wird die Rollade wird mir in FHEM als Licht angzeigt wenn die Rollade oben und unten ist (an für oben, aus für unten). Komplett hoch und runter funktioniert korrekt.
   DEF        56F5A8
   FUUID      5c4723ec-f33f-c236-ece0-696a32fda2248fc6
   IODev      hmusb
   LASTInputDev hmusb
   MSGCNT     90
   NAME       HM_56F5A8
   NOTIFYDEV  global
   NR         363
   STATE      on
   TYPE       CUL_HM
   chanNo     01
   hmusb_MSGCNT 90
   hmusb_RAWMSG E56F5A8,0000,79A1C0CB,FF,FFC8,99A41056F5A80003450601C800
   hmusb_RSSI -56
   hmusb_TIME 2019-12-02 11:56:49
   lastMsg    No:99 - t:10 s:56F5A8 d:000345 0601C800
   protLastRcv 2019-12-02 11:56:49
   protRcv    89 last_at:2019-12-02 11:56:49
   protSnd    90 last_at:2019-12-02 11:56:49
   protState  CMDs_done
   rssi_at_hmusb cnt:90 min:-57 max:-55 avg:-55.88 lst:-56
   rssi_hmusb cnt:65 min:-52 max:-50 avg:-51.26 lst:-51
     2019-12-02 11:56:39   CommandAccepted yes
     2017-11-09 18:16:11   D-firmware      2.11
     2017-11-09 18:16:11   D-serialNr      OEQ0265860
     2019-01-22 14:46:45   PairedTo        0x000345
     2017-11-09 18:27:54   R-driveDown     20.9 s
     2017-11-09 18:16:26   R-driveTurn     0.5 s
     2017-11-09 18:18:49   R-driveUp       22.5 s
     2017-11-09 18:16:25   R-pairCentral   0x000345
     2017-11-09 18:16:26   R-powerUpAction off
     2017-11-09 18:16:26   R-sign          off
     2019-01-22 14:46:45   RegL_00.        00:00 02:01 0A:00 0B:03 0C:45 15:FF 18:00
     2019-01-22 14:46:46   RegL_01.        00:00 08:00 09:00 0A:00 0B:00 0C:D1 0D:00 0E:E1 0F:05 10:00 30:06 56:00 57:24
     2019-12-02 11:56:49   deviceMsg       on (to hmusb)
     2019-12-02 11:56:49   level           100
     2017-12-31 14:52:13   levelMissed     desired:0
     2019-12-02 11:56:49   motor           stop:on
     2019-12-02 11:56:49   pct             100
     2019-12-02 11:56:49   position        100
     2019-01-22 14:46:44   powerOn         2019-01-22 14:46:44
     2019-12-02 11:56:49   recentStateType info
     2019-12-02 11:56:49   state           on
     2019-12-02 11:56:49   timedOn         off
     2019-12-02 11:44:21   userposition    0
   IODev      hmusb
   alias      Rollade Schlafzimmer
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   2.11
   homebridgeMapping clear CurrentPosition=position,minValue=0,maxValue=100,minStep=10 TargetPosition=CurrentPosition,cmds=/.*/:on;;0:off
   model      HM-LC-BL1PBU-FM
   peerIDs    00000000,
   room       CUL_HM,Homekit,Homematic,Schlafzimmer
   serialNr   OEQ0265860
   subType    blindActuator
   userReadings position {(ReadingsVal($NAME,"state","off") eq "off")?0:100}
   webCmd     statusRequest:toggleDir:on:off:up:down:stop
Seli
Ich habe den Homematic-Aktor erfolgreich im Einsatz. Hast Du alle Punkte im Wiki beachtet? Da das Gerät bei dir noch nicht alles Jalousie-Aktor erkannt wurde, fehlt vielleicht ein
set <name> getConfig oder get <name> reg all?
Grüße,
Seli
Raspberry Pi 3, FHEM 5.8
CUL868 V3 (FS20/IT): FHT80TF|PIRI|PIRI-2|TFK|S4A-2|ST|SU|S8|HMS 100 WD|IT-1500|GRR-3500
HomeMatic HMLAN_UART: HM-CC-RT-DN|HM-SEN-MDIR-O|HM-SEC-SC-2|HM-TC-IT-WM-W-EU|HM-LC-SW4-PCB 4|HM-WDS-OTH|HM-OU-LED16|HM-RC-4-3
JeeLink v3c, Rademacher duoFern, MiLight Bridge v4, RGB
marcel151
Grundsätzlich funktioniert der Aktor super wenn ich ihn mit FHEM steuere. Was nicht geht ist die Anzeige und das Fahren der Rollade in Zwischenstellungen.
Dia81
Auch wenn hier ewig nix stand brauch ich eure Hilfe. Habe meine Somfy Rolloes über Homebridge eingebunden. Wenn ich sage "fahre auf 0" dann öffnen sie sich, wenn ich sage "fahre auf 50"  gehen Sei in den "go-my = Schliitz modus" und wenn ich sage "fahre auf 100" gehen Sie runter.
Soweit so gut.
Wenn ich aber sage "öffne Rollo ..." geht es zu und bei "schließe Rollo ..." geht es auf? Wie kann ich das denn beheben??
Der Status wird in den Readings jeweils richtig angezeigt,
clear CurrentPosition=userposition,minValue=0,maxValue=100,minStep=50 TargetPosition=userposition,minValue=0,maxValue=100,minStep=50,cmds=100:close;50:go-my;0:open
userposition {(ReadingsVal($NAME,"state","open") eq "open")?0:(ReadingsVal($NAME,"state","open") eq "go-my")?50:100}
Danke für Hilfe :)
justme1968
Soweit so gut.
nein. nicht gut. genau falsch rum.
das wurde schon x-mal behandelt.
100% ist auf, 0% ist zu. so lange das nicht so ist geht öffnen und schließen nicht richtig rum.
Dia81
Danke. Zum Thema x-mal behandelt und dem leicht genervten Ton.
Wenn man sich nicht auskennt und sich jetzt 1 Woche durch Foren und Wikis prügelt um alles zum rennen zu bekommen, nur um dann zu lesen, das eh wieder nicht alles aktuell ist und manchmal einfach gar nicht mehr zu wissen was richtig aktuell ist und was geht. Da kann man sowas "x-mal" gestelltest auch mal überlesen.
Trotzdem Danke.
Muss ich mich jetzt entscheiden ob lieber die Anzeige sinnoll ist oder die Ansage.
justme1968
nein. musst du nicht.
schau dir vielleicht einfach die commandref und dort das attribut positionInverse nochmal an.
Dia81
danke, ich kriege es trotzdem nicht hin. Habe jetzt :
Fahre Rollo XXX runter geht. Ist das Rollo unten wird in EVE aber weiter 0 angezeigt, ist es oben 100. Wenn es irgendwie gehen sollte das das Kommando richtig ist UND die Anzeige in Homematic dann würd ich mich freuen. Setze ich das generelle Attribut stimmt die Anzeige in FHEM wiederum nicht mehr.
justme1968
du brauchst kein mapping, du musst das attribut setzen und die anzeige in fhem anpassen/reparieren.
AlexMuc
prinzipiell funktioniert mein Rolle super mit Homebridge und meistens kapiert sogar Siri, was sie machen soll.
Nun habe ich aber für einige Rollos bestimmte "Sonderstellungen per Webcommand und in der Eventmap definiert. Die Webcommands funktionieren, aber wie kriege ich Siri dazu, die zu verstehen.
hier die Eventmap
   eventMap   /opens:auf/closes:zu/position 32:halb/position 53:Blumen/
hier das aktuelle hombridgemapping
     homebridgeMapping clear CurrentPosition=position,invert=1 TargetPosition=CurrentPosition,invert=1,cmd=position
hier die Eventmap
hier die webCmd
   webCmd     auf:stop:zu:halb:position:Blumen
Mir geht es um die vordefinierten Positionen halb und Blumen. Kann man das in das Mapping integrieren und wenn ja: wie?
Michael
justme1968
das wären szenen. die kann man bei HomeKit nicht über das protokoll umsetzen sondern nur über eine native iOS app.
im prinzip müsste es aber mit passenden automationen über die home app umsetzbar sein. der einzige haken ist das du dann alles doppelt pflegen musst. einmal in fhem und ein mal in home/eve/...
AlexMuc
Schade, ich hätte gehofft, das sich da was "automagisch" basteln lassen würde.
Nun denn, dann muß ich wohl für jedes Rollo und "besondere Stellung" eine Szene erstellen... Kann man sicher auch nicht so ohne weiteres automatisieren, oder?
