Selbstbau CUN (MapleCUN)
Begonnen von Telekatz, 09 November 2016, 20:29:52
bilbolodz
Zitat von: RaspiLED am 06 Februar 2018, 20:15:38
Hi, do you mean the ESP-LINK Software on the ESP and then access the serial via ip adress and port 23?
Yes, exactly.
Ranseyer
FHEM mit FTUI. Homematic-Funk für Thermostate und Licht. MySensors als Basis für eigene HW.
Zentrale ist der MAPLE-CUL mit RFM69+HModUART-AddOn.
Doku zu meinen Projekten: Github/Ranseyer. Platinen falls verfügbar gerne auf Anfrage.
Support: gerne wenn ich Zeit+Lust habe im Forum. Nicht per PN!
bilbolodz
Thank Looks nice. I will check it.
bilbolodz
Zitat von: Ranseyer am 06 Februar 2018, 20:30:59
Arnd means ths one: https://github.com/jeelabs/esp-link
I've problem with these software. I've successfully flashed into ESP01 module but I can't get access to device. According documentation https://github.com/jeelabs/esp-link/blob/master/WIFI-CONFIG.md I should see additional (temporary) SSID and configure details of my WiFi networks. Unfortunately I can't see it. I've tried with two ESP01 and one Nodemcu 0.9 modules - the same behavior. Any ideas?
PeMue
Zitat von: bilbolodz am 09 Februar 2018, 12:20:26
Any ideas?
Do you use black ESP8266-ESP01 modules? They should have enough flash. The non black ones have not enough flash. As an alternative you could try the latest version of ESPEasy and use the serial bridge just for trying, if the problem is soft- or hardware related.
Sometimes also completely erasing flash helped.
Regards Peter
bilbolodz
Probably it's "blue one". Are there any "lighter versions"? I need only serial to telnet option.
PeMue
Probably you can use older ESP version (R120) which was also compiled for 512 k memory. See also ESPEasy wiki.
Kind regards.
Peter
bilbolodz
ESPEasy???? Previous post was about esp-link.
PeMue
I do not know, if there is a compiled version of esp-link for 512k modules, for ESPEasy there are. If you choose the serial interface in ESPEasy options, you should get the same result (or at least you can check, if your modules are workung). After that you can search for a smaller esp-link firmware  ;)
Regards Peter
bilbolodz
OK, I was not aware that ESPEasy has "serial tunneling" option.
Ranseyer
ZitatOK, I was not aware that ESPEasy has "serial tunneling" option.
This is correct. But some people believe using ESPeasy is not a really good idea because of security issues...
hexenmeister
I have looked at ESPEasy code ... security is currently very rudimentary (did not really exist). I hope that will change soon.
Maintainer: MQTT_GENERIC_BRIDGE, SYSMON, SMARTMON, systemd_watchdog, MQTT, MQTT_DEVICE, MQTT_BRIDGE
Contrib: dev_proxy
RaspiLED
Only for serial ESP-LINK is available:
https://github.com/jeelabs/esp-link/blob/master/FLASHING.md
Kölle Alaaf!
Gruß Arnd
Raspi2 mit FHEM, CUL, Signalduino, MySensors, HomeBridge, Presence, Bravia, ...
fhemfreund
Frage mal an die Spezialisten: Habe einen MapleCUN aufgebaut (1x 868, 1x 433, 1 HM-MOD-UART) und soweit funktioniert auch alles wie gewünscht ausser:
1) Ich kann auf den HM-MOD-UART nur von einer FHEM Instanz zugreifen - es sieht so aus, also ob keine parallele Zugriffe von 2 FHEM Instanzen via uart://192.168.xxx.xxx:2324 möglich sind.
Ist das so implementiert? (generell ist ja so etwas möglich, z.B. via ESP-Link zu einem ESP8266+HM-MOD-UART)
2) Ich empfange auf meinem 433er CC1101 IT einwandfrei, meine GT_WT_02 Wettersensoren jedoch überhaupt nicht (auch nicht irgendwelche andere in der Nachbarschaft). Auf einer anderen FHEM Instanz werden diese z.B. via Busware CUL einwandfrei empfangen. Sind da ggf. noch spezielle Einstellungen, bzw. Register o.ä. zu setzten?
Andreas
Telekatz
Ja, das ist bei der WIZnet Lib so implementiert.
Eigentlich nicht, aber vielleicht hilft es ja, die Register mit "raw e" wieder auf die Defaultwerte zu setzen.
