"Diva Go" Funk-Thermometer
Begonnen von Guest, 12 Februar 2011, 21:01:55
Guest
I recently noticed I had a thermometer sending out traffic on the
868MHz band. I didn't even know until I saw it on the back in big
letters.
The details of the device can be found here, under "Diva Go":
http://www.tfa-dostmann.de/produkte/produkte.asp?Hg=2&Ug=3
Could somebody be so kind to help me get this device supported in
FHEM? I've got a CUNO device and I've put it in X67 mode for a while
to capture all traffic passing by. I've logfile the logfile to:
http://boom.kalf.org/temp/putty-2011-02-12-X67-debug.log
Sadly I'm not a programmer, but I hope somebody is willing to help me
and try to get this little device supported.
Kind regards,
Jelle Kalf
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
rudolfkoenig
Hi Jelle,
Can you tell me which part is supposed to be this device?
I only see FHT and EM in the log. Are you sure it is
AM at about 1kHz datarate? If not, you won't see it here.
Regards,
  Rudi
Guest
There you've already got me at a point I need to learn about. I just
saw the 868MHz part on the back and matched it to the fact that my
CUNO is on that frequenty as well.
I'll try to run some tests around the device with the CUNO in
debugging mode and the device switching on and pairing up with the two
devices.
It's a basic internal thermometer with an external thermometer
transmitting at 868Mhz. I'm hoping to catch the information from the
external thermometer.
I'll report back tomorrow with some new logfiles. Hopefully find some
usable data. Is the 1kHz datarate a fixed item or can it be changed on
the fly and is it compatible with how fs20 and fht works? (Sorry for
talking with a not so technical guy here, I'm trying to learn a bit
about this).
regards,
Jelle
2011/2/12 Rudolf Koenig :
> Hi Jelle,
> Regards,
>  Rudi
If you can't fix it with a hammer, you've got an electrical problem!
rudolfkoenig
> Is the 1kHz datarate a fixed item or can it be changed on the fly and is it
See my last posting in the CUL group for some details.
FS20 and FHT reception is best if the CC1101 is programmed for 1kHz datarate,
even when the data processing is done by the MCU. So receiving another protocol
with a significantly different datarate or modulation together with FS20 is a
real challenge.
This is why in BidCos/HomeMatic mode you won't receive FS20 and vice versa.
Guest
Jelle,
Am 12.02.2011 21:01, schrieb Jelle Kalf:
> Hi,
> letters.
it would only be possible to receive the temperature of the outdoor
sensor. For €5, You can get the S555TH from Conrad, which is ready to
run with fhem. It measures Temp. & Humidity and 8 pieces can be
connected to fhem.
-Manfred
Oskar
Am 14.02.2011 um 15:10 schrieb Manfred Caspari:
> connected to fhem.
Any replacement for this, since it is not orderable any more.
Anyone had success with the AKW9110?
Cheers
   Oskar
fhem geht auch auf mac os x
Oskar
> connected to fhem.
Any ide of an replacement part for this? Maybe the AKW9110?
Cheers
   Oskar
