HmIP-WTH-2 - Boost funktioniert nicht
Begonnen von Stril, 27 November 2016, 14:41:43
ing.robby
Hier ist die Deviceinfo:
CHN 000C9709A7E018:0 HmIP-BWTH 000C9709A7E018:0
  DPT {b} HmIP-RF.000C9709A7E018:0.CONFIG_PENDING = false [RE]
  DPT {b} HmIP-RF.000C9709A7E018:0.DUTY_CYCLE = false [RE]
  DPT {f} HmIP-RF.000C9709A7E018:0.OPERATING_VOLTAGE = 0.000000 [RE]
  DPT {n} HmIP-RF.000C9709A7E018:0.RSSI_DEVICE = 199 [RE]
  DPT {n} HmIP-RF.000C9709A7E018:0.RSSI_PEER = 197 [RE]
  DPT {b} HmIP-RF.000C9709A7E018:0.UNREACH = false [RE]
  DPT {b} HmIP-RF.000C9709A7E018:0.UPDATE_PENDING = false [RE]
CHN 000C9709A7E018:1 HmIP-BWTH 000C9709A7E018:1
  DPT {i} HmIP-RF.000C9709A7E018:1.ACTIVE_PROFILE = 1 [WE]
  DPT {f} HmIP-RF.000C9709A7E018:1.ACTUAL_TEMPERATURE = 23.700000 [RE]
  DPT {b} HmIP-RF.000C9709A7E018:1.BOOST_MODE = false [WE]
  DPT {i} HmIP-RF.000C9709A7E018:1.BOOST_TIME = 0 [RE]
  DPT {f} HmIP-RF.000C9709A7E018:1.CONTROL_DIFFERENTIAL_TEMPERATURE =  [WE]
  DPT {i} HmIP-RF.000C9709A7E018:1.CONTROL_MODE =  [WE]
  DPT {i} HmIP-RF.000C9709A7E018:1.DURATION_UNIT =  [W]
  DPT {i} HmIP-RF.000C9709A7E018:1.DURATION_VALUE =  [W]
  DPT {b} HmIP-RF.000C9709A7E018:1.FROST_PROTECTION = false [RE]
  DPT {i} HmIP-RF.000C9709A7E018:1.HEATING_COOLING = 0 [RWE]
  DPT {i} HmIP-RF.000C9709A7E018:1.HUMIDITY = 53 [RE]
  DPT {b} HmIP-RF.000C9709A7E018:1.PARTY_MODE = false [RE]
  DPT {f} HmIP-RF.000C9709A7E018:1.PARTY_SET_POINT_TEMPERATURE = 0.000000 [RE]
  DPT {s} HmIP-RF.000C9709A7E018:1.PARTY_TIME_END =  [RWE]
  DPT {s} HmIP-RF.000C9709A7E018:1.PARTY_TIME_START =  [RWE]
  DPT {i} HmIP-RF.000C9709A7E018:1.SET_POINT_MODE = 1 [RWE]
  DPT {f} HmIP-RF.000C9709A7E018:1.SET_POINT_TEMPERATURE = 23.000000 [RWE]
  DPT {b} HmIP-RF.000C9709A7E018:1.SWITCH_POINT_OCCURED = false [RE]
  DPT {i} HmIP-RF.000C9709A7E018:1.WINDOW_STATE = 0 [WE]
CHN 000C9709A7E018:8 HmIP-BWTH 000C9709A7E018:8
  DPT {b} HmIP-RF.000C9709A7E018:8.EMERGENCY_OPERATION = false [RE]
  DPT {b} HmIP-RF.000C9709A7E018:8.FROST_PROTECTION = false [RE]
  DPT {b} HmIP-RF.000C9709A7E018:8.HUMIDITY_ALARM = false [RE]
  DPT {b} HmIP-RF.000C9709A7E018:8.STATE = false [RE]
CHN 000C9709A7E018:9 HmIP-BWTH 000C9709A7E018:9
  DPT {b} HmIP-RF.000C9709A7E018:9.STATE = false [RE]
CHN 000C9709A7E018:10 HmIP-BWTH 000C9709A7E018:10
  DPT {b} HmIP-RF.000C9709A7E018:10.STATE = false [RE]
CHN 000C9709A7E018:11 HmIP-BWTH 000C9709A7E018:11
  DPT {b} HmIP-RF.000C9709A7E018:11.STATE = false [RE]
CHN 000C9709A7E018:12 HmIP-BWTH 000C9709A7E018:12
  DPT {b} HmIP-RF.000C9709A7E018:12.STATE = false [RE]
Ich sehe die Werte zwar in den Readings, allerdings nicht in der Geräteübersicht.
Ich kann auch keine Werte wie Temperatur an das HmIP-BWTH weitergeben, gleiches gilt für Modi wie on/off/auto/manuel.
RasPi 3B+ | Ubuntu Mate 18.04, fhem 5.9
nanoCUL433 | IT1500
nanoCUL868 | CCU2, HM-ES-PMSw1-DR, HM-WS550STH, HmIP-BWTH, HmIP-STHO, HmIP-SMI
JeeLink868 | PCA301
hue Bridge | Single bulb, Lightstrip Plus, LivingColors Iris, ZigBee Smart+
Chris8888
das ist zu 99,99% identisch zum WTH-2.
Von daher mache es dir leicht und nutze die hier angebotene Konfig.
VG
Christian
FHEM 6.0 auf einem PI4 mit div. Homematic-Komponenten, Alexa, Tablet-UI und Homebridge...und läuft einfach. Erweitert mit CCU3 und Homematic-IP...und läuft immer noch.
ing.robby
Hallo CHristian,
das hatte ich gestern schon versucht, aber hat nicht funktioniert.
Ich habe dann das Gerät nochmal neu von CCU2 übernommen.
Jetzt erneut mit Deiner Config:
defmod Heizung_Wohnzimmer HMCCUDEV 000C9709A7E018
attr Heizung_Wohnzimmer userattr Typ Typ_map structexclude
attr Heizung_Wohnzimmer IODev HMCCU2
attr Heizung_Wohnzimmer ccureadingfilter (ACTUAL_TEMPERATURE|ACTIVE_PROFILE|BOOST_MODE|SET_POINT|PARTY|HUMIDITY|WINDOW_STATE)
attr Heizung_Wohnzimmer ccureadingformat datapoint
attr Heizung_Wohnzimmer ccureadingname 0.(LOWBAT|LOW_BAT):+battery
attr Heizung_Wohnzimmer controldatapoint 1.SET_POINT_TEMPERATURE
attr Heizung_Wohnzimmer event-on-change-reading .*
attr Heizung_Wohnzimmer eventMap /datapoint 1.BOOST_MODE true:Boost/datapoint 1.CONTROL_MODE 0:Auto/datapoint 1.CONTROL_MODE 1:Manual/datapoint 1.CONTROL_MODE 2:Holiday/datapoint 1.SET_POINT_TEMPERATURE 4.5:off/datapoint 1.SET_POINT_TEMPERATURE 30.5:on/
attr Heizung_Wohnzimmer genericDeviceType thermostat
attr Heizung_Wohnzimmer group Heizung und Temperatur
attr Heizung_Wohnzimmer homebridgeMapping TargetTemperature=1.SET_POINT_TEMPERATURE::1.SET_POINT_TEMPERATURE,,minValue=19,maxValue=23,minStep=0.5,cmd=control,nocache=true CurrentTemperature=1.ACTUAL_TEMPERATURE CurrentHeatingCoolingState=1.SET_POINT_MODE,values=1:0;;0:1  TargetHeatingCoolingState=1.SET_POINT_MODE::1.SET_POINT_MODE,values=OFF:1;;AUTO:0;;HEAT:3;;COOL:2,cmds=OFF:datapoint+1.CONTROL_MODE+1;;HEAT:datapoint+1.BOOST_MODE+1;;COOL:datapoint+1.BOOST_MODE+0;;AUTO:datapoint+1.CONTROL_MODE+0 CurrentRelativeHumidity=1.HUMIDITY
attr Heizung_Wohnzimmer icon hm-tc-it-wm-w-eu
attr Heizung_Wohnzimmer room Wohnzimmer
attr Heizung_Wohnzimmer stateFormat Ist: 1.ACTUAL_TEMPERATURE° Soll: 1.SET_POINT_TEMPERATURE° Feuchte: 1.HUMIDITY%
attr Heizung_Wohnzimmer statechannel 1
attr Heizung_Wohnzimmer statedatapoint 1.SET_POINT_TEMPERATURE
attr Heizung_Wohnzimmer stripnumber 1
attr Heizung_Wohnzimmer substexcl control
attr Heizung_Wohnzimmer substitute WINDOW_STATE!(0|false):closed,(1|true):open;;LOW_BAT!(0|false):ok,(1|true):low
attr Heizung_Wohnzimmer webCmd control:Boost:Auto:Manual:Holiday:on:off
attr Heizung_Wohnzimmer widgetOverride control:slider,12.0,0.5,25.0,1
Aber gleiches Problem, Nichts einstellbar und keine Werte in der Übersichtszeile (wie auf dem Bild, dass ich gerade gepostet habe...)
nanoCUL433 | IT1500
JeeLink868 | PCA301
Chris8888
#18
läuft denn dein RPC-Server? Welche Version setzt du ein?
Hast du andere HmIP-Devices die sauber funktionieren?
Woran machst du denn fest das du nichts einstellen kannst? Hast du mal einen parallelen Blick in die CCU geworfen?
VG
Christian
Edit: Und lösche mal testhalber deinen ccureadingfilter ....der sieht komisch aus.
M.E. muss der so aussehen: (^ACTUAL_TEMPERATURE|^ACTIVE_PROFILE|....
ing.robby
Ich werd' verrückt, es geht jetzt.
Ich kann Temp und Modi schalten, obwohl in der Übersichtszeile immer 15° angezeigt werden.
Am Wandthermostat kann man auto/manuel und ein Antennensymbol einstellen. Und mit dem Antennensymbol funktioniert's jetzt.
Wie kann ich mir jetzt in der Zeile die Temp und Luftfeuchte anzeigen lassen? So wie in dem Bild ungefähr.
(RPC läuft mit Version 4.1.004)
nanoCUL433 | IT1500
JeeLink868 | PCA301
Chris8888
#20
Hallo Robby,
mühsam ernährt sich das Eichhörnchen.  :)
Werden denn die aktuellen Werte in den Readings angezeigt? Hilft nach einer Veränderung ein Reload der Seite?
Das Antennensymbol im BWTH ist meines Wissens nach nur ein Test der Funk-Anbindung. Den Zusammenhang verstehe ich nur bedingt.
Welche Firmware hast du auf der CCU2? Die BWTHs werden erst seit 2.29.22 unterstützt.
Hast du dein FHEM mal durchgebootet? Es fehlern noch die Firmwareeinträge in deinem Devicelisting.
VG
Christian
ing.robby
Bei dem Antennensymbol steht in der Anleitung ,,Funkbetrieb".
Die readings sind von gestern, aktualisieren sich also nicht  :(
Ja shutdown restart immer durchgeführt.
CCU2 Version ist 2.29.23, gleich nach dem Kauf aktualisiert.
Vielleicht stimmt noch etwas mit dem HMCCU2 Modul nicht.
MfG
Robby
nanoCUL433 | IT1500
JeeLink868 | PCA301
Chris8888
werden die Readings bei einem "get Device update" aktualisiert?
Firewall in der CCU abgeschaltet?
Hast du im CCU-Modul die HmIP-Schnittstelle angegeben?
attr CCU2 rpcinterfaces HMHmIP-RF
Welchen Status hat der Server? Running?
VG
Christian
ing.robby
#23
Jetzt zeigt's auch die Werte Soll/Ist und Luftfeuchte an. Habe nichts geändert, außer auf Funkbetrieb gestellt und jetzt nochmal einen shutdown restart.
Vielleicht ging's auch schon gestern mit deiner config, ich hab's nur nicht mitbekommen, weil die Werte in fhem nicht angezeigt wurden (habe es nicht extra am Wandthermostat überprüft).
Vielen Dank Chris8888 und zap!  :)
MfG
Robby
nanoCUL433 | IT1500
JeeLink868 | PCA301
ing.robby
Hallo Chris,
ich habe doch noch 2 Fragen:
Bei mir aktualisiert es die readings nur, wenn ich get update durchführe, kann ich das auch automatisch generieren?
Ich würde gern ein Wochenprogramm einrichten. Wie spreche ich Temp Einstellung an? Im Wiki wird es über den Kanal *_Clima erklärt. Den gibt's aber beim HmIP BWTH nicht. Eine config Datei habe ich schon angelegt.
MfG
Robby
nanoCUL433 | IT1500
JeeLink868 | PCA301
zap
#25
Der RPC Server läuft nicht. Wie man den konfiguriert und startet ist im Wiki erklärt: https://wiki.fhem.de/wiki/HMCCU. Chris hat es weiter oben auch schon mal beschrieben.
Die Erklärung im Wiki bezieht sich auf CUL_HM. HMCCU verwendet andere Kanalbezeichnungen und unterstützt auch keine Wochenprogramm Templates. Ich würde Dir raten, die Wochenprogramme in der CCU einzustellen. Das ist deutlich komfortabler. In HMCCUDEV geht das zwar auch, bedeutet aber manuelle Berechnung der Zeitintervalle und Einstellung über viele set config Befehle.
2xCCU3, Fenster, Rollläden, Themostate, Stromzähler, Steckdosen ...)
Entwicklung: FHEM auf AMD NUC (Ubuntu)
Maintainer: FULLY, Meteohub, HMCCU, AndroidDB
ing.robby
#26
ZitatDer RPC Server läuft nicht. Wie man den konfiguriert und startet ist im Wiki erklärt: https://wiki.fhem.de/wiki/HMCCU. Chris hat es weiter oben auch schon mal beschrieben.
Der RPC Server läuft (Status running/ok). Ich habe die Konfiguration auch nach dem Wiki gemacht
   CCUNum     1
   CHANGED
   Clients    :HMCCUDEV:HMCCUCHN:HMCCURPC:
   DEF        192.168.178.29
   NAME       HMCCU2
   NR         79
   NTFY_ORDER 50-HMCCU2
   RPCPID     3469
   RPCPRC     internal
   RPCState   running
   STATE      running/OK
   TYPE       HMCCU
   ccuaddr    BidCoS-RF
   ccuchannels 64
   ccudevices 2
   ccuif      BidCos-RF
   ccuinterfaces BidCos-RF,HmIP-RF
   ccuname    HM-RCV-50 BidCoS-RF
   ccustate   active
   ccutype    CCU2
   host       192.168.178.29
   version    4.1.004
     2017-12-12 19:55:02   rpcstate        running
     2017-12-13 15:06:17   state           OK
   hmccu:
     evtime     1513104902
     evtimeout  1
     localaddr  192.168.178.24
     rpccount   1
     rpcinit    1
     rpcports   2000,2001,9292
     updatetime 0
     adr:
       HM-RCV-50 BidCoS-RF:
         address    BidCoS-RF
         addtype    dev
         valid      1
       HM-RCV-50 BidCoS-RF:0:
         address    BidCoS-RF:0
         addtype    chn
         valid      1
       HM-RCV-50 BidCoS-RF:1:
         address    BidCoS-RF:1
         addtype    chn
         valid      1
       HM-RCV-50 BidCoS-RF:10:
         address    BidCoS-RF:10
         addtype    chn
         valid      1
       HM-RCV-50 BidCoS-RF:11:
         address    BidCoS-RF:11
         addtype    chn
         valid      1
       HM-RCV-50 BidCoS-RF:12:
         address    BidCoS-RF:12
         addtype    chn
         valid      1
       HM-RCV-50 BidCoS-RF:13:
         address    BidCoS-RF:13
         addtype    chn
         valid      1
       HM-RCV-50 BidCoS-RF:14:
         address    BidCoS-RF:14
         addtype    chn
         valid      1
       HM-RCV-50 BidCoS-RF:15:
         address    BidCoS-RF:15
         addtype    chn
         valid      1
  cnt:
           ACTIVE_PROFILE 1
           ACTUAL_TEMPERATURE 1
           BOOST_MODE 1
           BOOST_TIME 1
           CONFIG_PENDING 1
           CONTROL_DIFFERENTIAL_TEMPERATURE 1
           CONTROL_MODE 1
           DURATION_UNIT 1
           DURATION_VALUE 1
           DUTY_CYCLE 1
           EMERGENCY_OPERATION 1
           FROST_PROTECTION 2
           HEATING_COOLING 1
           HUMIDITY   1
           HUMIDITY_ALARM 1
           OPERATING_VOLTAGE 1
           PARTY_MODE 1
           PARTY_SET_POINT_TEMPERATURE 1
           PARTY_TIME_END 1
           PARTY_TIME_START 1
           RSSI_DEVICE 1
           RSSI_PEER  1
           SET_POINT_MODE 1
           STATE      5
           SWITCH_POINT_OCCURED 1
           UNREACH    1
           UPDATE_PENDING 1
           WINDOW_STATE 1
     ev:
       DD         0
       EV         0
       EX         0
       IN         1
       ND         52
       RA         0
       RD         0
       SL         1
       ST         0
       UD         0
       total      54
     iface:
       BidCos-RF  1
       HmIP-RF    1
     rpc:
       CB2001:
         cbport     7411
         cburl      http://192.168.178.24:7411/fh2001
         clurl      http://192.168.178.29:2001/
         loop       2
         pid        3469
         port       2001
         queue      /tmp/ccuqueue_2001_1
         state      running
   ccudef-readingfilter ^(LOW_?BAT|UNREACH)$
   ccudef-readingname ^(.+\.)?LOW_?BAT$:battery;^(.+\.)?UNREACH$:activity
   ccudef-substitute AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
   ccuflags   intrpc
   ccureadings 1
   cmdIcon    on:general_an off:general_aus
   eventMap   /rpcserver on:on/rpcserver off:off/
   room       system
   rpcinterfaces BidCos-Wired,BidCos-RF,VirtualDevices
   rpcinterval 5
   rpcport    2000,2001,9292
   rpcqueue   /tmp/ccuqueue
   rpcserver  on
   stateFormat rpcstate/state
   stripnumber 1
ZitatIch würde Dir raten, die Wochenprogramme in der CCU einzustellen. Das ist deutlich komfortabler. In HMCCUDEV geht das zwar auch, bedeutet aber manuelle Berechnung der Zeitintervalle und Einstellung über viele set config Befehle.
Na das ist ja echt blöd, aber wenn's nicht anders geht...
nanoCUL433 | IT1500
JeeLink868 | PCA301
Chris8888
Hi Robby,
könntest du das bitte in CodeTags packen (die Raute oben)...so wird einem ja schwindelig beim scrollen.  ;D
Den RPC-Server zu supporten...da muss ZAP ran. ;-)
Mein Tipp: Stelle den Server mal auf den externen um: attr HMCCU ccuflags extrpc
vorher den Server stoppen und danach wieder starten...
Wenn das auch nicht läuft, dann braucht ZAP sicherlich deine Logs vom Start des Servers.
Auch nochmal die Firewall in der CCU kontrollieren (steht auch im WICCI).
VG
Christian
Chris8888
ich denke hier liegt dein Problem:
Lt Wicci: Wichtig! Die CCU2 stellt außer BidCos-RF nur die Schnittstellen bereit, für die auch Geräte vorhanden sind. Nicht verwendete Schnittstellen dürfen bei rpcinterfaces nicht angegeben werden, da sonst der RPC-Server nicht startet.
Da du nur HmIP-Devices hast (?) muss das rpcinterfaces auf HmIP-RF (und nur dahin) gesetzt werden.
VG
Christian
ing.robby
Hallo Chris,
Okay habe ich gemacht.
Die Firewall war die ganze Zeit aus.
Okay habe ich jetzt auch umgestellt.
Ich habe noch ein HM-ES-PMSw1-DR, das läuft aber nicht über die CCU2, sondern über einen nanoCUL.
Ist das normal, dass ich nach der Umstellung auf extern 2 HMCCU Devices habe? :o
nanoCUL433 | IT1500
JeeLink868 | PCA301
