26_tahoma.pm:2016-11-29 V 0208 HttpUtils used instead of LWP::UserAgent, BLOCKING=0 set as default, umlaut can be used in Tahoma names
Begonnen von System, 29 November 2016, 20:45:02
System
26_tahoma.pm:2016-11-29 V 0208 HttpUtils used instead of LWP::UserAgent, BLOCKING=0 set as default, umlaut can be used in Tahoma namesView Changes
Source: 26_tahoma.pm:2016-11-29 V 0208 HttpUtils used instead of LWP::UserAgent, BLOCKING=0 set as default, umlaut can be used in Tahoma names
