Setup Entware-ng for graphviz and webdot
Begonnen von qbox4u, 19 Dezember 2016, 01:32:59
qbox4u
ipkg has died >:(, therefore i needed to start from scratch with Entware-ng
ps:
* my old user account was in https://wiki.fhem.de/wiki/Qnap:_clean_install
* php Extensions are in https://www.mediawiki.org/wiki/Extension:EUV
* my private TS459proII server is these days at https://qbox4u.com:8081/conf/abc/mwk/index.php
=References=
*[https://wiki.openwrt.org/doc/techref/opkg opkg]
*[http://www.qnapclub.eu/index.php?act=cat&id=4 Overvieuw availabe download opkg]
*[http://www.webgraphviz.com/ webgraphviz example]
=Setup Entware-ng=
Install [https://github.com/Entware-ng/Entware-ng/wiki/Install-on-QNAP-NAS Entware-ng] on QNAP TS 459 PRO II
In Detail
* Download [http://pkg.entware.net/binaries/other/Entware-ng_0.97.qpkg Entware-ng_0.97.qpkg]
* Login in the QNAP TS 459 PRO II as Admin
* Select '''App Center'''
* install Pyton V 2.7.3
* Press on the right top icon '''Settings'''
* Select in <code>Install manually</code> with the button <code>Browse </code> the downloaded file <code>Entware-ng_0.97.qpkg </code>
* Press the button <code>Install</code>
* [[Login with Putty]]
* Type the following commands
<pre>
[~] # opkg update
[~] # opkg upgrade
[~] # opkg install gnuplot
[~] # opkg install busybox
[~] # opkg install sudo
[~] # opkg install nano
[~] # opkg install ldd
[~] # opkg install make
[~] # opkg install gawk
[~] # opkg install sed
[~] # opkg install gcc
[~] # opkg install grep
[~] # opkg install findutils
[~] # opkg install tar
[~] # opkg install tcl
temporal fix ..... [~] # opkg install http://pkg.entware.net/binaries/x86-64/test/tcl_8.5.18-1a_x86-64.ipk
[~] # opkg install patch
[~] # opkg install diffutils
[~] # opkg install coreutils-install
[~] # opkg install libncurses
[~] # opkg install gnutls-utils
[~] # opkg install pkg-config
[~] # opkg install libjpeg
[~] # opkg install libpng
[~] # opkg install libfreetype
[~] # opkg install libexpat
[~] # opkg install libgnutls
[~] # opkg install git
[~] # opkg install curl
[~] # opkg install fontconfig
[~] # opkg install libpoppler
[~] # opkg install poppler-utils
[~] # opkg install ghostscript
[~] # opkg install ghostscript-fonts-std
[~] # opkg install ghostscript-gnu-gs-fonts-other
</pre>
<pre>
[~] # wget -qO- http://pkg.entware.net/binaries/x86-64/include/include.tar.gz | tar xvz -C /opt/include
[~] # more /opt/bin/gcc_env.sh
#!/bin/sh
export LDFLAGS="-Wl,-rpath=/opt/lib -Wl,--dynamic-linker=/opt/lib/ld-linux-x86-64.so.2 -L/opt/lib"
export CFLAGS="-O2 -pipe -fomit-frame-pointer -fno-caller-saves "
</pre>
=Create sudo=
'''Verified ..'''
[~] # nano /etc/passwd
copy admin:x:0:0:administrator:/share/homes/admin:/bin/sh
to
root:x:0:0:administrator:/share/homes/admin:/bin/sh
save file
[~] # nano /etc/shadow
copy admin:$1$$oAGEgbHGHDVAua2mvwKPI/:14233:0:99999:7:::
to
root:$1$$oAGEgbHGHDVAua2mvwKPI/:14233:0:99999:7:::
save file
[~] # EDITOR=nano
find
## User privilege specification
root ALL=(ALL) ALL
[~] # visudo
add.... admin ALL=(ALL) ALL
Hit esc to exit insert-mode.
Type ":x" to save and exit.
=libgd-2.2.3=
'''verified ....'''
download '''libgd-2.2.3.tar.xz''' from https://github.com/libgd/libgd/releases
<pre>
[~] # cp /share/MD0_DATA/Web/libgd-2.2.3.tar.xz  /share/MD0_DATA/.qpkg/Entware-ng/lib
[~] # cd /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf libgd-2.2.3.tar.xz
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd libgd-2.2.3
[/share/MD0_DATA/.qpkg/Entware-ng/lib/libgd-2.2.3] # source /opt/bin/gcc_env.sh
[/share/MD0_DATA/.qpkg/Entware-ng/lib/libgd-2.2.3] # ./configure --prefix=/opt --disable-werror
[/share/MD0_DATA/.qpkg/Entware-ng/lib/libgd-2.2.3] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/libgd-2.2.3] # make install
</pre>
=freetype-2.7=
'''verified'''
download http://download.savannah.gnu.org/releases/freetype/freetype-2.7.tar.gz
<pre>
[~] # cp /share/MD0_DATA/Web/freetype-2.7.tar.gz  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf freetype-2.7.tar.gz
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd freetype-2.7
[/share/MD0_DATA/.qpkg/Entware-ng/lib/freetype-2.7] # source /opt/bin/gcc_env.sh
[/share/MD0_DATA/.qpkg/Entware-ng/lib/freetype-2.7] # ./configure --prefix=/opt
[/share/MD0_DATA/.qpkg/Entware-ng/lib/freetype-2.7] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/freetype-2.7] # make install
</pre>
=expat=
'''verified'''
Download https://sourceforge.net/projects/expat/files/expat/2.2.0/
<pre>
[~] # cp /share/MD0_DATA/Web/expat-2.2.0.tar.bz2  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf expat-2.2.0.tar.bz2
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd expat-2.2.0
[/share/MD0_DATA/.qpkg/Entware-ng/lib/expat-2.2.0] # source /opt/bin/gcc_env.sh
[/share/MD0_DATA/.qpkg/Entware-ng/lib/expat-2.2.0] # ./configure --prefix=/opt
[/share/MD0_DATA/.qpkg/Entware-ng/lib/expat-2.2.0] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/expat-2.2.0] # make install
</pre>
=fontconfig=
'''verified'''
Downoad https://www.freedesktop.org/software/fontconfig/release/fontconfig-2.12.0.tar.gz
<pre>
[~] # cp /share/MD0_DATA/Web/fontconfig-2.12.0.tar.gz  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf fontconfig-2.12.0.tar.gz
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd fontconfig-2.12.0
[/share/MD0_DATA/.qpkg/Entware-ng/lib/fontconfig-2.12.0] # source /opt/bin/gcc_env.sh
[/share/MD0_DATA/.qpkg/Entware-ng/lib/fontconfig-2.12.0] # ./configure --prefix=/opt
[/share/MD0_DATA/.qpkg/Entware-ng/lib/fontconfig-2.12.0] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/fontconfig-2.12.0] # make install
</pre>
TEMPORAL FIX
THE DEFAULT LOOKS TO /usr/share/fonts
CHANGE THE FOLLOWING
<pre>
[/opt/share/fonts] # find / -name fonts.conf
/share/MD0_DATA/.qpkg/Entware-ng/etc/fonts/fonts.conf
/share/MD0_DATA/.qpkg/Entware-ng/lib/fontconfig-2.12.0/fonts.conf
change inside both
<!-- Font directory list -->
        <dir>/usr/share/fonts</dir>
to
   <dir>/opt/share/fonts</dir>
</pre>
Check
<pre>
[/opt/share/fonts] # fc-cache -vf /opt/share/
[/opt/share/fonts] # fc-list : file
[/opt/share/fonts] # fc-cat
</pre>
=libffi-3.2.1=
'''verified'''
Download ftp://sourceware.org/pub/libffi/libffi-3.2.1.tar.gz
<pre>
[~] # cp /share/MD0_DATA/Web/libffi-3.2.1.tar.gz  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf libffi-3.2.1.tar.gz
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd libffi-3.2.1
[/share/MD0_DATA/.qpkg/Entware-ng/lib/libffi-3.2.1] # source /opt/bin/gcc_env.sh
[/share/MD0_DATA/.qpkg/Entware-ng/lib/libffi-3.2.1] # ./configure --prefix=/opt
[/share/MD0_DATA/.qpkg/Entware-ng/lib/libffi-3.2.1] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/libffi-3.2.1] # make install
</pre>
=gettext-0.19.8=
'''verified'''
Download http://ftp.gnu.org/pub/gnu/gettext/gettext-0.19.8.tar.gz
<pre>
[~] # cp /share/MD0_DATA/Web/gettext-0.19.8.tar.gz  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf gettext-0.19.8.tar.gz
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd gettext-0.19.8
[/share/MD0_DATA/.qpkg/Entware-ng/lib/gettext-0.19.8] # source /opt/bin/gcc_env.sh
[/share/MD0_DATA/.qpkg/Entware-ng/lib/gettext-0.19.8] # ./configure --prefix=/opt
[/share/MD0_DATA/.qpkg/Entware-ng/lib/gettext-0.19.8] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/gettext-0.19.8] # make install
</pre>
=pcre-8.38=
'''verified'''
Download http://ftp.cs.stanford.edu/pub/exim/pcre/pcre-8.38.tar.bz2
<pre>
[~] # cp /share/MD0_DATA/Web/pcre-8.38.tar.bz2  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf pcre-8.38.tar.bz2
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd pcre-8.38
[/share/MD0_DATA/.qpkg/Entware-ng/lib/pcre-8.38] # source /opt/bin/gcc_env.sh
[/share/MD0_DATA/.qpkg/Entware-ng/lib/pcre-8.38] # ./configure --prefix=/opt
[/share/MD0_DATA/.qpkg/Entware-ng/lib/pcre-8.38] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/pcre-8.38] # make install
</pre>
=glib-2.49.6=
'''verified'''
Downoad http://ftp.gnome.org/pub/gnome/sources/glib/2.49/glib-2.49.6.tar.xz
glib-2.50.2: /opt/bin/ld: cannot find -lmount collect2: error: ld returned 1 exit status
<pre>
[~] # cp /share/MD0_DATA/Web/glib-2.49.6.tar.xz  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf glib-2.49.6.tar.xz
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd glib-2.49.6
[/share/MD0_DATA/.qpkg/Entware-ng/lib/glib-2.49.6] # source /opt/bin/gcc_env.sh
[/share/MD0_DATA/.qpkg/Entware-ng/lib/glib-2.49.6] # ./configure --prefix=/opt --with-pcre=system
[/share/MD0_DATA/.qpkg/Entware-ng/lib/glib-2.49.6] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/glib-2.49.6] # make install
</pre>
=tcsh-6.20.00=
'''verified'''
Download ftp://ftp.astron.com/pub/tcsh/tcsh-6.20.00.tar.gz
<pre>
[~] # cp /share/MD0_DATA/Web/tcsh-6.20.00.tar.gz  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf tcsh-6.20.00.tar.gz
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd tcsh-6.20.00
[/share/MD0_DATA/.qpkg/Entware-ng/lib/tcsh-6.20.00] # source /opt/bin/gcc_env.sh
[/share/MD0_DATA/.qpkg/Entware-ng/lib/tcsh-6.20.00] # ./configure --prefix=/opt
[/share/MD0_DATA/.qpkg/Entware-ng/lib/tcsh-6.20.00] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/tcsh-6.20.00] # make install
</pre>
=pixman-0.34.0=
'''verified'''
Download https://www.cairographics.org/releases/pixman-0.34.0.tar.gz
<pre>
[~] # cp /share/MD0_DATA/Web/pixman-0.34.0.tar.gz  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf pixman-0.34.0.tar.gz
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd pixman-0.34.0
[/share/MD0_DATA/.qpkg/Entware-ng/lib/pixman-0.34.0] # ./configure --prefix=/opt
[/share/MD0_DATA/.qpkg/Entware-ng/lib/pixman-0.34.0] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/pixman-0.34.0] # make install
</pre>
=libpng-1.6.26=
'''verified'''
https://sourceforge.net/projects/libpng/files/libpng16/1.6.26/libpng-1.6.26.tar.xz/download?use_mirror=nchc&download=
<pre>
[~] # cp /share/MD0_DATA/Web/libpng-1.6.26.tar.xz  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf libpng-1.6.26.tar.xz
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd libpng-1.6.26
[/share/MD0_DATA/.qpkg/Entware-ng/lib/libpng-1.6.26] # source /opt/bin/gcc_env.sh
[/share/MD0_DATA/.qpkg/Entware-ng/lib/libpng-1.6.26] # ./configure --prefix=/opt
[/share/MD0_DATA/.qpkg/Entware-ng/lib/libpng-1.6.26] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/libpng-1.6.26] # make install
</pre>
=cairo-1.14.8.tar.xz=
'''verified'''
* ref [https://github.com/bonzini/cairo/blob/master/INSTALL]
download https://www.cairographics.org/releases/cairo-1.14.8.tar.xz
<pre>
[~] # cp /share/MD0_DATA/Web/cairo-1.14.8.tar.xz  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf cairo-1.14.8.tar.xz
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd cairo-1.14.8
[/share/MD0_DATA/.qpkg/Entware-ng/lib/cairo-1.14.8] # ./configure --prefix=/opt
[/share/MD0_DATA/.qpkg/Entware-ng/lib/cairo-1.14.8] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/cairo-1.14.8] # make install
</pre>
=jpegsrc.v6b.tar=
'''verified'''
download http://www.ijg.org/files/jpegsrc.v9b.tar.gz
<pre>
[~] # cp /share/MD0_DATA/Web/jpegsrc.v6b.tar.gz  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf jpegsrc.v6b.tar.gz
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd jpeg-6b
[/share/MD0_DATA/.qpkg/Entware-ng/lib/jpeg-6b] # source /opt/bin/gcc_env.sh
create 2 extra directories in /opt
[/opt] # mkdir man
[/opt] # cd  man
[/opt] # mkdir man1
[/share/MD0_DATA/.qpkg/Entware-ng/lib/jpeg-6b] # ./configure --prefix=/opt --with-jpeg-dir=/opt/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib/jpeg-6b] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/jpeg-6b] # make install
</pre>
=libgd-2.2.3.tar=
'''verified'''
Downoad https://github.com/libgd/libgd/releases/tag/gd-2.2.3
<pre>
[~] # cp /share/MD0_DATA/Web/libgd-2.2.3.tar.gz  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf libgd-2.2.3.tar.gz
</pre>
=ttf files=
Download http://www.graphviz.org/Misc/fonts.tgz
unzip and copy the ttf folder to /opt/share/fonts
<pre>
[/opt/share/fonts] # cp -R /share/Web/ttf /opt/share/fonts
[/opt/share/fonts] # fc-cache -vf /opt/share/fonts/ttf
check by
[/opt/share/fonts] #fc-list : file
</pre>
=webdot-2.30=
Download [http://www.graphviz.org/pub/graphviz/stable/SOURCES/webdot-2.30.tar.gz  webdot-2.30]
<pre>
[~] # cp /share/MD0_DATA/Web/webdot-2.30.tar.gz  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf webdot-2.30.tar.gz
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd /share/MD0_DATA/.qpkg/Entware-ng/bin
</pre>
check if tclsh exist, otherwise do this
[/share/MD0_DATA/.qpkg/Entware-ng/bin] # ln -s /share/MD0_DATA/.qpkg/Entware-ng/bin/tclsh8.5* tclsh
<pre>
[~] # cd /share/MD0_DATA/.qpkg/Entware-ng/lib/webdot-2.30
[/share/MD0_DATA/.qpkg/Entware-ng/lib/webdot-2.30] # source /opt/bin/gcc_env.sh
[/share/MD0_DATA/.qpkg/Entware-ng/lib/webdot-2.30] # ./configure --prefix=/opt
[/share/MD0_DATA/.qpkg/Entware-ng/lib/webdot-2.30] # nano Makefile
</pre>
change HTTPD-USER-GROUP=apache:apache
to
HTTPD-USER-GROUP=admin
<pre>
[/share/MD0_DATA/.qpkg/Entware-ng/lib/webdot-2.30] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/webdot-2.30] # make install
</pre>
=graphviz-2.38.0=
download [http://www.graphviz.org/pub/graphviz/stable/SOURCES/graphviz-2.38.0.tar.gz graphviz-2.38.0]
<pre>
[~] # cp /share/MD0_DATA/Web/graphviz-2.38.0.tar.gz  /share/MD0_DATA/.qpkg/Entware-ng/lib
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # tar -xvf graphviz-2.38.0.tar.gz
[/share/MD0_DATA/.qpkg/Entware-ng/lib] # cd graphviz-2.38.0
[/share/MD0_DATA/.qpkg/Entware-ng/lib/graphviz-2.38.0] # source /opt/bin/gcc_env.sh
[/share/MD0_DATA/.qpkg/Entware-ng/lib/graphviz-2.38.0] # ./configure --prefix=/opt
[/share/MD0_DATA/.qpkg/Entware-ng/lib/graphviz-2.38.0] # make
[/share/MD0_DATA/.qpkg/Entware-ng/lib/graphviz-2.38.0] # make install
</pre>
Test
create an test file test1.dot
<pre>
digraph G {
    one -> two;
    one -> three;
    one -> four;
    four -> five -> six;
    five -> one;
    six -> two;
</pre>
create an test file test2.dot
<pre>
digraph dummy {
  abcdefghi -> babcdefghi -> cabcdefghi -> dabcdefghi -> eabcdefghi -> fabcdefghi -> gabcdefghi -> habcdefghi -> iabcdefghi;
  aabcdefghi [fontname="LiberationMono-Regular.ttf"]
  babcdefghi [fontname="LiberationSans-Italic.ttf"]
  cabcdefghi [fontname="LiberationMono-BoldItalic.ttf"]
  dabcdefghi [fontname="LiberationSerif-BoldItalic.ttf"]
  eabcdefghi [fontname="LiberationMono-Italic.ttf"]
  fabcdefghi [fontname="LiberationSerif-Italic.ttf"]
  gabcdefghi [fontname="LiberationSerif-Bold.ttf"]
  habcdefghi [fontname="LiberationSerif-Bold.ttf"]
  iabcdefghi [fontname="LiberationSerif-Bold.ttf"]
</pre>
<pre>
[/opt/bin] # dot -Tpng  /share/Web/test1.dot  >  /share/Web/output.png
[/opt/bin] # dot -Tpng  /share/Web/test2.dot  >  /share/Web/output.png
[/opt/bin] # dot -Tsvg  /share/Web/test1.dot  >  /share/Web/output.svg
</pre>
