CUL HOERMANN - und welcher gehört jetzt mir :-)
Begonnen von baukater, 19 Dezember 2016, 18:00:17
baukater
Bekomme seit gestern ständig neue Hörmann-Tore dazu. So viele Garagen gibt es hier gar nicht.
CUL_HOERMANN_2527e40000
Defined
CUL_HOERMANN_2527e40018
Defined
CUL_HOERMANN_2527e4005f
Defined
CUL_HOERMANN_2527e50000
Defined
CUL_HOERMANN_2527e50016
Defined
CUL_HOERMANN_2527e50017
Defined
CUL_HOERMANN_2527e50018
Defined
CUL_HOERMANN_2527e50019
Defined
CUL_HOERMANN_2527e50344
Defined
CUL_HOERMANN_2527e60000
Defined
CUL_HOERMANN_2527e60015
Defined
CUL_HOERMANN_2527e60016
Defined
CUL_HOERMANN_2527e60017
Defined
CUL_HOERMANN_2527e60018
Defined
CUL_HOERMANN_2527e60019
Defined
CUL_HOERMANN_2527e70000
Defined
CUL_HOERMANN_2527e70014
Defined
CUL_HOERMANN_2527e70015
Defined
CUL_HOERMANN_2527e70016
Defined
CUL_HOERMANN_2527e70017
Defined
CUL_HOERMANN_2527e70018
Defined
CUL_HOERMANN_2527e70019
Defined
CUL_HOERMANN_2527e80000
Defined
CUL_HOERMANN_2527e80014
Defined
CUL_HOERMANN_2527e80015
Defined
CUL_HOERMANN_2527e80016
Defined
CUL_HOERMANN_2527e80017
Defined
CUL_HOERMANN_2527e80018
Defined
CUL_HOERMANN_2527e80019
Defined
CUL_HOERMANN_2527e8035f
Defined
CUL_HOERMANN_2527e90000
Defined
CUL_HOERMANN_2527e9000b
Defined
CUL_HOERMANN_2527e90014
Defined
CUL_HOERMANN_2527e90015
Defined
CUL_HOERMANN_2527e90016
Defined
CUL_HOERMANN_2527e90017
Defined
CUL_HOERMANN_2527e90018
Defined
CUL_HOERMANN_2527e90019
Defined
CUL_HOERMANN_2527ea0000
Defined
CUL_HOERMANN_2527ea0004
Defined
CUL_HOERMANN_2527ea0014
Defined
CUL_HOERMANN_2527ea0015
Defined
CUL_HOERMANN_2527ea0016
Defined
CUL_HOERMANN_2527ea0017
Defined
CUL_HOERMANN_2527ea0018
Defined
CUL_HOERMANN_2527ea0019
Defined
CUL_HOERMANN_2527ea001b
Defined
CUL_HOERMANN_2527ea0026
Defined
CUL_HOERMANN_2527eb0000
Defined
CUL_HOERMANN_2527eb000e
Defined
CUL_HOERMANN_2527eb0014
Defined
CUL_HOERMANN_2527eb0015
Defined
CUL_HOERMANN_2527eb0016
Defined
CUL_HOERMANN_2527eb0017
Defined
CUL_HOERMANN_2527eb0018
Defined
CUL_HOERMANN_2527eb0019
Defined
CUL_HOERMANN_2527ec0000
Defined
CUL_HOERMANN_2527ec0014
Defined
CUL_HOERMANN_2527ec0015
Defined
CUL_HOERMANN_2527ec0016
Defined
CUL_HOERMANN_2527ec0017
Defined
CUL_HOERMANN_2527ec0018
Defined
CUL_HOERMANN_2527ed0000
Defined
CUL_HOERMANN_2527ed0017
Defined
CUL_HOERMANN_2527ee0000
Defined
CUL_HOERMANN_BF01000010
Defined
FB7490,Raspi 2/3,HM-Lan,Jeelink Classic (868),Logilink BT0015 Bluetooth 4.0, 2x mySmartUSB light,RS485USB , entities:272 device:14 channel:27 virtual:1, 6 x HM-LC-BL1-FM,4 x HM-LC-SW4-WM, 1 x HM-LC-SW2-FM,1 x Fensterkontakt,1 1x Türkontakt, 1 1x Bewegungsmelder, DECT-200,DECT100,6xAuthentic Xiaom
Sind vmtl. entfernte Tore, leider kann FHEM/culfw kein Checksum fuer Hoermann berechnen.
Lust auf Algorithmus raten?
Ich habe erst die wichtigen identifiziert/definiert, falsche geloescht und danach das Anlegen von Neuen mit "attr autocreate ignoreTypes CUL_HOERMANN.* unterbunden.
baukater
Ok, dann mal schauen, was mein Tor sein kann. Wie weit entfernt kann der CUL denn Signale empfangen? Es scheint mir, dass hier mehr Hörrmann-Tore rumstehen, als es hier Häuser gibt. Kann ich mir echt nicht vorstellen.  :D
RaspiLED
#3
also mein Handsender hat 4 Tasten und sendet vier Codes die sich jeweils in den letzten drei Stellen unterscheiden.
Aber ich habe auch Logfiles definiert, da wird ja mit Zeitstempel erfasst. So dass ich mit der Fernbedienung neben dem Rechner entspannt sehe, welche Taste welchen Code als Toggle auslöst.
Leider bewirkt der toggle am Hörmann Device nicht, dass das Tor sich in Bewegung setzt.
Geht das bei Euch? (Neueste CUL FW 868Mhz selbst compiliert und Hoermann aktiviert)
Gruß Arnd
Ja, meins kann ich relativ zuverlaessig oeffnen. Des Nachbars habe ich noch nicht versucht, das Empfange ich nur.
RaspiLED
Hi Rudolf,
ich schaffe leider noch keine Bewegung meines Supramatic E! Was bedeutet relativ bei Dir?
Wer hat denn das Modul  gebaut? Ich würde gerne helfen.
Gruß Arnd
Raspi2 mit FHEM, CUL, MySensor, HomeBridge, Presence, Bravia, ...
Michael
Moin RaspiLED
Hier kannst du den Modul Entwickler (Betreuter) finden.
https://fhem.de/MAINTAINER.txt
Und in diesen Fall ist es :
FHEM/18_CUL_HOERMANN.pm      rudolfkoenig         http://forum.fhem.de SlowRF   :)
Gruß, Michael
FHEM 6.0 auf RPi 3
CUL V3 868 Mhz | JeeLink LaCrosse & PCA301 | CCU3
BMP085(180) | 14x TX29DTH-IT | 5x PCA 301 | SMA Peripheries | MobileAlerts MA-10(100,120PRO,200,251,410,650,660,800) | HM IP
RaspiLED
Hi, Danke! Was für ein Zufall gelle ;-) Rudolf welches Hörmann Gerät hast Du genau?
Gruß Arnd
ZitatRudolf welches Hörmann Gerät hast Du genau?
Kann ich dir nicht genau sagen, steht auf dem Geraet/Fernbedienung nicht darauf, und in der Anleitung stehen mehrere Typangaben, da sie wohl fuer mehrere gilt. Die Fernbedienung ist haesslich, eckig und grau, mit blauen Knoepfen. Blau steht wohl fuer 868MHz, gruen fuer 433. Ist ueber 10 Jahre alt.
Wenn du die Fernbedienung so 3-4 Meter vom CUL entfernt drueckst, muesste das CUL eigentlich ein sauberes Signal empfangen. Dieses wuerde ich definieren und senden.
"relativ" bedeutet: ca 5-mal zum Testen geschaltet, da hat es einmal nicht geklappt, und 3-mal als "Notschalter" z.Bsp. aus der Ferne, dabei hat es immer geklappt. Bin nicht wirklich geneigt 100 Schaltvorgaenge durchzufuehren, um zu zaehlen :)
RaspiLED
#9
ja die FB habe ich auch und noch 3 andere FB, die diese Signale clonen können!
Ich meinte eher Deinen tatsächlichen Garagenöffner. Z.B. https://www.tor7.de/hoermann-supramatic-e-garagentorantrieb-serie-3-bisecur
Gruß Arnd
Ranseyer
hier habe ich mal ausführlich geforscht da ich auch eine Supramatic habe:
https://forum.fhem.de/index.php/topic,62657.msg544256.html#msg544256
Mich würde z.B. der Status vom Tor interessieren.
Ich denke hier geht nichts / wenig aufgrund der einigermaßen verfügbaren Sicherheit. Hier im Forum gabs mal einen Thread mit der Aussage dass jemand nen Key aus ~"einer Software" extrahiert hat. Ich habe dazu mal schnell die Android App inspiziert und kein direkt offensichtliches Problem gefunden. Also nicht nur ein simpler Key direkt in der App welcher dann an das Hörman Gateway gesendet wird. Eine Firmware für das Hörmann Gateway habe ich soweit ich das noch weiß damals nicht gefunden.
Welche FBs die Hörman-Signale clonen können, würde mich minimal interessieren. Man könnte damit dann steuern (gefällt mir nicht!), oder Angriffsvektoren suchen...
FHEM mit FTUI. Homematic-Funk für Thermostate und Licht. MySensors als Basis für eigene HW.
Zentrale ist der MAPLE-CUL mit RFM69+HModUART-AddOn.
Doku zu meinen Projekten: Github/Ranseyer. Platinen falls verfügbar gerne auf Anfrage.
Support: gerne wenn ich Zeit+Lust habe im Forum. Nicht per PN!
SamNitro
die "einfache" Hörmann Geräte werden bei mir per autocreate eingelesen, leider ist das Tor von meinem Schwiegervater der 15km entfernt wohnt und daher kann ich das leider nicht testen..
Ich habe ein ProMatic 3 Bisecur, da wird nix erkannt, kann es sein dass das tor nicht unterstützt wird bzw nicht per autocreate erfasst wird?
(Intel-Nuc Proxmox) (Homematic) (EnOcean) (CUL868) (CUL433) (Zigbee2MQTT) (ESP8266) (Echo) (DUOFERN)
RaspiLED
Ranseyer
Fürchte nicht... Und sehe ich das richtig ?
M.E. geht bei bisecure Toren gar nichts:
-kein clonen der FB (https://de.aliexpress.com/item/Hormann-HSM2-868-HSM4-868mhz-replacement-remote-control-top-quality/32721318974.html)
-kein exakter Empfang des Status
-auf gar keinen Fall Steuerung des Tors (zumindest ohne gewissen Keys)
RaspiLED
#14
Hi Martin,
Ich denke im Moment es gibt mehrere Hörmann Systeme:
1) >20 Jahre alt, 433 MHz, orange Tasten FB, keine FHEM Unterstützung
2) >10 Jahre alt, 868 MHz, blaue Tasten FB, toggle geht zum öffnen/schliessen per CUL, aktuelle Tests mit Signalduino,
3) >4 Jahre alt, 868 MHz, blaue Tasten FB (gleich zu 2), wird gehört, aber toggle bewirkt nichts, aktuelle Tests mit Signalduino, zB. Supramatic
4) aktuell, 868 MHz, schwarze Tasten FB mit Encryption oder Signierung (zB. HSE 1 BiSecur), bisher keine Unterstützung in FHEM, zB. Supramatic BiSecur oder HET/S 2 BS
Raspi2 mit FHEM, CUL, Signalduino, MySensors, HomeBridge, Presence, Bravia, ...
