Xiaomi Smart Home Komponenten
Begonnen von FosCo, 21 Dezember 2016, 18:59:59
m_gatz
Der Eintrag kommt genau alle 5 Minuten. Geschalte oder so wird nix
2017.08.15 23:31:55 5 : xi_gateway: Read> Read start
2017.08.15 23:31:55 5 : xi_gateway: Read> {"cmd":"heartbeat","model":"gateway","sid":"286c07891a3c","short_id":"0","token":"OGQGv0fymsE8Hu9o","data":"{\"ip\":\"192.168.47.49\"}"}
2017.08.15 23:31:55 5 : xi_gateway: Read> HASH correctly
2017.08.15 23:31:55 5 : xi_gateway: Reading> Reading start
2017.08.15 23:31:55 4 : xi_gateway: Reading> Heartbeat from 192.168.47.49 received with 286c07891a3c
2017.08.15 23:32:02 5 : xi_gateway: Read> Read start
2017.08.15 23:32:02 5 : xi_gateway: Read> {"cmd":"iam","port":"9898","sid":"286c07891a3c","model":"gateway","ip":"192.168.47.49"}
2017.08.15 23:32:02 5 : xi_gateway: Read> HASH correctly
2017.08.15 23:32:02 5 : xi_gateway: Reading> Reading start
2017.08.15 23:32:02 5 : xi_gateway: Reading> Dispatch {"cmd":"iam","port":"9898","sid":"286c07891a3c","model":"gateway","ip":"192.168.47.49"}
2017.08.15 23:32:02 5 : xi_gateway: dispatch {"cmd":"iam","port":"9898","sid":"286c07891a3c","model":"gateway","ip":"192.168.47.49"}
2017.08.15 23:32:02 3 : xi_gateway: Unknown code {"cmd":"iam","port":"9898","sid":"286c07891a3c","model":"gateway","ip":"192.168.47.49"}, help me!
2017.08.15 23:32:05 5 : xi_gateway: Read> Read start
2017.08.15 23:32:05 5 : xi_gateway: Read> {"cmd":"heartbeat","model":"gateway","sid":"286c07891a3c","short_id":"0","token":"RcwlO7pyPqDjfiy7","data":"{\"ip\":\"192.168.47.49\"}"}
2017.08.15 23:32:05 5 : xi_gateway: Read> HASH correctly
2017.08.15 23:32:05 5 : xi_gateway: Reading> Reading start
2017.08.15 23:32:05 4 : xi_gateway: Reading> Heartbeat from 192.168.47.49 received with 286c07891a3c
Danke und Gruß,
Mathias
torte
Hi Mathias,
das ist was komisch, ich bekomme diese Meldung nicht.
Das Gateway sendet diese Meldung
Eigentlich nur wenn man im Netzwerk auf Port 4321 eine UDP Anfrage durchführt dann Antworten die Gateways alle mit der Meldung oben.
Sollte im Laufenden Betrieb eigentlich passieren. Welche Firmware ist auf deinem Gateway? 1.4.1_149.0143 ist die letzte von Xiaomi.
Ich werde aber mal was einbauen damit die Meldung nicht mehr erscheint.
Torte
hanswerner1
Zitat von: torte am 15 August 2017, 23:06:37
baue in der nächsten Version was ein.
Torte
Gesendet mit Tapatalk
Super !!! Das wäre wirklich toll.
tterrafan
Ist es möglich, dass dein Gateway regelmäßig die Verbindung zum Router verliert?
Denn die "iam" Meldung im Log taucht bei mir immer nur dann einmal auf, wenn ich das Gateway komplett neu starte oder die IP-Adresse ändere.
Ich vermute mal, dass iam eine Art Initialisierung kennzeichnen soll, bis dann der erste richtige Wert vorhanden ist.
Und das sollte daher nur ein einziges mal auftreten.
rimjim
Ich muss euch mal wieder mit dem Homebridgemaping belästigen, und zwar zeigen alle Geräte in HomeKit "Batterie fast leer" an.
Die Batterien sind jedoch neu, wie kann das Homebridgemapping aussehen bzw. wie muss es verändert werden ? Ich habe ein paar dinge ausprobiert, jedoch klappt es leider nicht.
StatusLowBattery=BatteryState,values=normal:BATTERY_LEVEL_NORMAL;/.*/: BATTERY_LEVEL_LOW ???
Wäre Super wenn mir da jemand helfen könnte.
Stoanze01
habe leider im GW-Device kein 'set' um das 'password' zu setzen und die in der App verbundenen Devices (MotionSensor und SmartSwitch) sind auch nicht zu sehen.
Wenn ich es richtig verstanden habe müssten diese automatisch angelegt werden.
Es werden diese readings angezeigt:
password giveaPassword!
pct 100
ringtone 21
state Connected
volume 10
Jemand eine Idee was ich falsch mache!? Habe mir auch die neuesten Versionen von 71_XiaomiSmartHome_Device.pm & 71_XiaomiSmartHome.pm_13.08.2017 geladen, leider ohne erfolg.
FhemLog:
2017.08.27 12:17:58.459 1: Gateway01: getGatewaySID> Error no response from whois!! STOP!!
2017.08.27 12:17:58.552 3: Gateway01: connect> Connected
2017.08.27 12:24:34.350 5: Gateway01: Notify> NotifyStart
2017.08.27 12:24:37.914 5: Gateway01: Notify> NotifyStart
2017.08.27 12:24:38.760 5: Gateway01: updateAllReadings> Starting UpdateALLReadings
2017.08.27 12:24:39.169 4: Gateway01: Write> Get all Sensors
2017.08.27 12:24:39.169 4: Gateway01: Write> {"cmd" : "get_id_list"} xxx.xxx.xxx.34
2017.08.27 12:24:39.169 5: Gateway01: Write> End xxx.xxx.xxx.34
2017.08.27 12:24:39.170 5: Gateway01: Get> UpdateALLReadings Started
torte
pct 100
ringtone 21
state Connected
volume 10
FhemLog:
hast du eine Firewall? Sieht so aus das Port 4321 geblockt wird. Port 9898 und 4321 sind die Ports über die das GW kommuniziert.
Grüsse
Torte
Stoanze01
Grüsse
Torte
Hi torte,
nein ich habe keine Firewall. Läuft alles über eine FritzBox 6490 Cable auf der keine Ports geblockt sind. Habe jetzt aber erst bemerkt das es anscheinend Probleme bei der Installation von libcrypt-cbc-perl gab und immer noch gibt, könnte es daran liegen? Bekomme libcrypt-cbc-perl auch einfach nicht installiert, wenn ich mir mit:
apt-get install libcrypt-
und dann 'Tab' die Modulliste anzeigen lassen wird libcrypt-cbc-perl gelistet, beim Installationsbefehl bekomme ich dann aber
libcrypt-cbc-perl is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libcrypt-cbc-perl' has no installation candidate
Bin leider noch nicht dahinter gekommen wo genau das Problem liegt.
torte
also ohne CBC kannst Du keine Schaltbefehle zum GW senden weil die Write Befehle mit Verschlüsselt werden.
Worauf läuft Dein FHEM.
Torte
tterrafan
Kann es sein, dass du kein Update ausgeführt hast? Nur so kann ich mir das erklären.
Gebe bitte
sudo apt-get update && sudo apt-get upgrade
ein und Versuche die Installation danach erneut.
LG Timo
Raemsna
ich habe seit heute ein Gateway im Betrieb und auch im WLAN eingebunden.
Interessanterweise kommt bei mir genau der gleiche Fehler wie hier angegeben
2017.08.29 13:04:55 1: MI_Gateway: getGatewaySID> Error no response from whois!! STOP!!
2017.08.29 13:04:55 3: MI_Gateway: connect> Connected
Weder Lesen (Anzeigen aktueller Zustand in FHEM) als auch Schreiben (z.B. Anschalten/Ausschalten über FHEM) funktionieren.
Alle vier Module sind m.E.n. korrekt installiert.
Reboot von FHEM und Raspberry habe ich bereits durchgeführt...
torte
komisch! Wenn diese Meldung erscheint versucht das Modul über Port 4321 das Gateway anzufragen wie seine SID ist.
Das Klappt bei Dir nicht. Könnte also auch eine Firewall sein.
Welche Version vom Rasbian hast Du drauf?
cat /etc/os-release
Torte
scooty
hier leider die gleichen Meldungen wie bei Raemsna.
Zumindest bewusst habe ich keine FW auf dem Raspi implementiert.
Meine Raspian Version:
PRETTY_NAME="Raspbian GNU/Linux 7 (wheezy)"
NAME="Raspbian GNU/Linux"
VERSION_ID="7"
VERSION="7 (wheezy)"
ID=raspbian
ID_LIKE=debian
ANSI_COLOR="1;31"
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Danach versuchte ich es auch auf meinem Gigabyte Brix (eigentlich die Produktions FHEM-Instanz) zum Laufen zu bekommen, dort beendet sich nach Eingabe der Definition des Gateways leider FHEM.
Letzter Eintrag im Logfile:
Can't locate object method "new" via package "IO::Socket::Multicast" (perhaps you forgot to load "IO::Socket::Multicast"?) at /opt/fhem/FHEM/71_XiaomiSmartHome.pm line 273
Update/Upgrade/Install aller benötigten Pakete erfolgreich bzw. beim erneuten Install Meldung, dass alles auf dem neuesten Stand ist/Reboot vorher gemacht.
Die Debian Version auf dem Brix:
PRETTY_NAME="Debian GNU/Linux 8 (jessie)"
NAME="Debian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=debian
HOME_URL="http://www.debian.org/"
SUPPORT_URL="http://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
Hmm, auf einem der beiden würde ich es schon gern ans Laufen bekommen, sollen wir uns erst einmal auf den Raspi konzentrieren?
Liefere gerne noch weitere Infos/Tests.
Aber schon mal herzlichen Dank für Deine bisherige Arbeit,
Andreas
Fhem auf Gigabyte Brix
CUL V3 HM / CUL V3 MAX / MaxCube aFW Homematic&MAX / ZWave.me ZME_UZB1 / SDuino 433 / Velux KLF200
Homematic / MAX / Logitech Hub / ZWave / Wifi LED / div. 433 Temperatursensoren / pywws WH10880 / IO Homecontrol
Raemsna
Bei mir ähnliches Setup mit Raspbian wheezy.
VERSION_ID="7"
ID=raspbian
ID_LIKE=debian
ANSI_COLOR="1;31"
Hier irgendwo im Thread habe ich noch gelesen, dass es bei einem größeren Netzwerk ebenfalls Probleme geben könnte.
Zitat von: dgi am 17 Juni 2017, 15:53:23
Habe ein großes Netz, keine Firewall dazwischen. Aber zwischen dem Raspi und dem WLAN-AP sind ein paar switche dazwischen. Ich schau mal auf dem WLAN-AP nach, ob da multicast geblockt wird. Ansonsten ist der developer mode auf jeden Fall an. Im Log habe ich nichts gesehen.
Vielleicht liegt da irgendwo der Hund begraben...
Mein Gateway läuft über WLAN, der Raspi mit FHEM hängt über LAN am zentralen Router...
torte
VERSION_ID="7"
ID=raspbian
ID_LIKE=debian
ANSI_COLOR="1;31"
also zu wheezy kann ich nichts sagen, da wir aber schon bei Stretch sind würd ich mal updaten [emoji2] . Mein FHEM produktive und Developement Umgebung läuft unter Jessie.
apt-get Update und dist-upgrade läuft ohne fehler bei euch durch?
Torte
