WOLF eBus Allgemein
Begonnen von thgorjup, 04 Januar 2017, 14:32:04
stenny
habe mich mal ein wenig an den EBus der neuen Heizung gewagt....
Aber erfolg hatte ich bisher wenig-
mit ebusctl info
version: ebusd 3.4.v3.3-51-g57eae05
signal: acquired
symbol rate: 56
max symbol rate: 86
min arbitration micros: 216
max arbitration micros: 281
min symbol latency: 6
max symbol latency: 13
reconnects: 0
masters: 4
conditional: 0
poll: 0
update: 4
address 01: master #6, ebusd
address 03: master #11
address 06: slave #6, ebusd
address 08: slave #11, scanned "MF=Wolf;ID= !;SW=0002;HW=0000"
address 30: master #3
address 35: slave #3, scanned "MF=Wolf;ID=;SW=0204;HW=0100"
address 50: slave, scanned "MF=Wolf;ID= !;SW=0002;HW=0000"
address f1: master #10
Die Dateien hier aus dem beitrag habe ich alle duchprobiert aber ich erhalte keine lesbaren Werte im Log
2019-12-26 09:26:58.540 [update notice] received unknown MS cmd: 3008502203cc9a01 / 02c800
2019-12-26 09:26:58.775 [update notice] received unknown BC cmd: 03fe050308010048ff6125ff05
2019-12-26 09:26:58.933 [update notice] received unknown MS cmd: 3008502203cc192f / 020080
2019-12-26 09:26:59.325 [update notice] received unknown MM cmd: 3003502203cc0100
2019-12-26 09:26:59.760 [update notice] received unknown MS cmd: 3008502203cc1627 / 0240fe
2019-12-26 09:27:00.088 [update notice] received unknown MS cmd: 3008502203cc1d27 / 02b801
2019-12-26 09:27:00.502 [update notice] received unknown MS cmd: 3008502203cc4f27 / 024c00
2019-12-26 09:27:00.915 [update notice] received unknown MS cmd: 3008502203cc5727 / 023b00
2019-12-26 09:27:01.243 [update notice] received unknown MS cmd: 3008502203cc5e27 / 023300
2019-12-26 09:27:01.569 [update notice] received unknown MM cmd: 03f10800080080660580020005
2019-12-26 09:27:01.643 [update notice] received unknown MS cmd: 3008502203cc362a / 020080
2019-12-26 09:27:01.971 [update notice] received unknown MS cmd: 3008502203cc372a / 020080
2019-12-26 09:27:02.298 [update notice] received unknown MS cmd: 3008502203cc7c2a / 020080
2019-12-26 09:27:02.626 [update notice] received unknown MS cmd: 3008502203cc7c2a / 020080
2019-12-26 09:27:03.039 [update notice] received unknown MS cmd: 3008502203cc7c2a / 020080
hat hier einer einen Denkanstoß für mich
Vorhanden sind eine Wolf CGB-2und ein BM-2
DSLGigant
Was kommt denn bei ebusctl find?
3 Raspberry Pi, CUL 433, HMLAN, MAX!, Keymatic, Arduino Uno, IT Steckdosen, 2 Bewässerungssteuerungen Balkon, EBUS-Raspi an WOLF
schlund
ich habe die 1.6er Platine bei ebay gekauft und gelötet - soweit so gut.
Jetzt wollte ich das ganze an meiner Wolf CGB-2-20 mit BM2 in Betrieb nehmen.
Doch leider bekomme ich nur unknown commands (und das Datum). Situation ist also so ähnlich wie bei stenny...
root@raspberrypi:/etc/ebusd# ebusctl find
broadcast datetime = -;15:04:10;16.09.2020
broadcast error = no data stored
broadcast id = no data stored
broadcast signoflife = no data stored
memory eeprom = no data stored
memory ram = no data stored
scan.08  = Wolf; !;0002;0000
scan.35  = Wolf;;0204;0100
scan.50  = Wolf; !;0002;0000
scan.f6  = no data stored
root@raspberrypi:/etc/ebusd# ebusctl info
signal: acquired
symbol rate: 58
max symbol rate: 77
min arbitration micros: 832
max arbitration micros: 863
min symbol latency: 5
max symbol latency: 6
reconnects: 0
masters: 4
conditional: 0
poll: 0
update: 4
address 31: master #8, ebusd
address 36: slave #8, ebusd
Ausprobiert habe ich verschiedene CSV Files hier aus dem Forum und aus dem Git, ohne Erfolg.
Das log sieht immer ungefähr so aus:
Zitat2020-09-16 14:44:54.491 [update notice] received unknown MS cmd: 3008502203cc1a27 / 029b00
2020-09-16 14:44:54.906 [update notice] received unknown MS cmd: 3008502203cc3727 / 020100
2020-09-16 14:44:55.218 [update notice] received unknown MM cmd: 30035023054ff4020003
2020-09-16 14:44:55.635 [update notice] received unknown MS cmd: 3008502203cc5327 / 020d00
2020-09-16 14:44:56.049 [update notice] received unknown MS cmd: 3008502203cc5427 / 020000
2020-09-16 14:44:56.377 [update notice] received unknown MS cmd: 3008502203cc6327 / 020000
2020-09-16 14:44:56.791 [update notice] received unknown MS cmd: 3008502203cc6a27 / 020080
2020-09-16 14:44:57.202 [update notice] received unknown MS cmd: 3008502203cc762a / 020080
2020-09-16 14:44:57.621 [update notice] received unknown MS cmd: 3008502203cc7c2a / 020080
2020-09-16 14:44:58.456 [update notice] received unknown BC cmd: 03fe050308010000ff341a2f1c
2020-09-16 14:44:58.695 [update notice] received update-read broadcast datetime QQ=30: -;15:44:10;16.09.2020
2020-09-16 14:44:59.006 [update notice] received unknown BC cmd: 30fe50230528000a1400
2020-09-16 14:44:59.404 [update notice] received unknown BC cmd: 30fe5023054423000000
2020-09-16 14:44:59.714 [update notice] received unknown BC cmd: 30fe502305dc4e2a0800
2020-09-16 14:45:00.131 [update notice] received unknown MM cmd: 3003050709000350000080ff1408
2020-09-16 14:45:00.454 [update notice] received unknown BC cmd: f1fe0800080005661a00c0000a
2020-09-16 14:45:02.361 [update notice] received unknown MS cmd: 305050140720000500194014 / 09000000800080008828
2020-09-16 14:45:02.774 [update notice] received unknown MS cmd: 3008502203cc0e00 / 02df01
2020-09-16 14:45:03.102 [update notice] received unknown MS cmd: 3008502203cc2d00 / 029600
2020-09-16 14:45:03.430 [update notice] received unknown MS cmd: 3008502203cc9a01 / 02c800
2020-09-16 14:45:03.760 [update notice] received unknown MS cmd: 3008502203cc192f / 020080
2020-09-16 14:45:04.151 [update notice] received unknown MM cmd: 3003502203cc0100
2020-09-16 14:45:07.574 [update notice] received unknown BC cmd: 03fe050308010000ff341b2f1c
2020-09-16 14:45:12.263 [update notice] received unknown MS cmd: 3008502203cc0200 / 023200
2020-09-16 14:45:12.419 [update notice] received unknown MM cmd: 03f10800080080cc1c80000005
2020-09-16 14:45:12.577 [update notice] received unknown MS cmd: 3008502203cc1600 / 020d01
2020-09-16 14:45:12.991 [update notice] received unknown MS cmd: 3008502203cc1600 / 020d01
2020-09-16 14:45:13.408 [update notice] received unknown MM cmd: 3003050709000350000080ff1408
2020-09-16 14:45:13.738 [update notice] received unknown MS cmd: 3008502203cc1600 / 020d01
2020-09-16 14:45:14.067 [update notice] received unknown MS cmd: 3008502203cc1600 / 020d01
2020-09-16 14:45:14.480 [update notice] received unknown MS cmd: 3008502203cc1600 / 020d01
2020-09-16 14:45:14.808 [update notice] received unknown MS cmd: 3008502203cc6c01 / 020000
2020-09-16 14:45:15.154 [update notice] received unknown BC cmd: 30fe03010e200100800000000100000000
hat jemand einen Tip?
john30
schau doch mal am Anfang vom Log, ob ebusd was protokolliert bzgl. nicht gefundender CSVs
author of ebusd
schlund
Ja, ebusd gibt etwas in die Richtung aus. Ich habe auch schon verschiedene Konstellationen ohne Erfolg versucht.
Aktuell habe ich das ebusd-2.x.x/de/ Verzeichnis nach /etc/ebusd kopiert und gebe das als Config Verzeichnis mit -c mit.
Warum er trotzdem Element not found ausgibt, ist mir nicht ganz klar.
Zitatroot@raspberrypi:/etc/ebusd# tree
├── kromschroeder -> wolf
├── memory.csv
├── _templates.csv
└── wolf
    ├── 08.csv
    ├── 50.csv
    ├── broadcast.csv
    └── wolf.ods
Zitat2020-09-19 19:18:28.056 [main notice] ebusd 3.4.v3.3-51-g57eae05 started with auto scan
2020-09-19 19:18:28.148 [bus notice] bus started with own address 31/36
2020-09-19 19:18:28.212 [bus notice] signal acquired
2020-09-19 19:18:28.276 [bus notice] new master 30, master count 2
2020-09-19 19:18:28.281 [bus notice] new master 03, master count 3
2020-09-19 19:18:28.281 [update notice] received unknown MM cmd: 3003050709550450000080ff6e08
2020-09-19 19:18:29.204 [update notice] received unknown BC cmd: 03fe050308010000ff71363912
2020-09-19 19:18:37.745 [update notice] received unknown BC cmd: 30fe03010eb600008000000001000000000000
2020-09-19 19:18:38.076 [update notice] received unknown MS cmd: 3008502203cc1a27 / 029b00
2020-09-19 19:18:38.271 [bus notice] scan 08: ;Wolf; !;0002;0000
2020-09-19 19:18:38.271 [update notice] store 08 ident: done
2020-09-19 19:18:38.272 [update notice] sent scan-read scan.08  QQ=31: Wolf; !;0002;0000
2020-09-19 19:18:38.272 [bus notice] scan 08: ;Wolf; !;0002;0000
2020-09-19 19:18:38.294 [main error] unable to load scan config 08: list files in wolf ERR: element not found
2020-09-19 19:18:38.294 [main error] scan config 08: ERR: element not found
2020-09-19 19:18:38.432 [update notice] received unknown MS cmd: 3008502203cc3727 / 020100
2020-09-19 19:18:40.420 [bus notice] scan 35: ;Wolf;;0204;0100
2020-09-19 19:18:40.420 [update notice] store 35 ident: done
2020-09-19 19:18:40.421 [update notice] sent scan-read scan.35  QQ=31: Wolf;;0204;0100
2020-09-19 19:18:40.421 [bus notice] scan 35: ;Wolf;;0204;0100
2020-09-19 19:18:40.442 [main error] unable to load scan config 35: list files in wolf ERR: element not found
2020-09-19 19:18:40.443 [main error] scan config 35: ERR: element not found
2020-09-19 19:18:40.582 [update notice] received unknown MS cmd: 3008502203cc7c2a / 020080
2020-09-19 19:18:41.330 [bus notice] new master f1, master count 4
2020-09-19 19:18:41.330 [update notice] received unknown BC cmd: f1fe0800080005331600c00037
2020-09-19 19:18:42.092 [update notice] received unknown MM cmd: 3003050709550450000080ff6e08
2020-09-19 19:18:42.631 [bus notice] scan 50: ;Wolf; !;0002;0000
2020-09-19 19:18:42.631 [update notice] store 50 ident: done
2020-09-19 19:18:42.632 [update notice] sent scan-read scan.50  QQ=31: Wolf; !;0002;0000
2020-09-19 19:18:42.632 [bus notice] scan 50: ;Wolf; !;0002;0000
2020-09-19 19:18:42.652 [main error] unable to load scan config 50: list files in wolf ERR: element not found
2020-09-19 19:18:42.653 [main error] scan config 50: ERR: element not found
2020-09-19 19:18:42.871 [update notice] received unknown BC cmd: f1fe050308010000ff71ff3916
2020-09-19 19:18:43.288 [update notice] received unknown MS cmd: 3008502203cc0c00 / 02b600
2020-09-19 19:18:43.616 [update notice] received unknown MS cmd: 3008502203ccbf0a / 020100
2020-09-19 19:18:43.944 [update notice] received unknown MS cmd: 3008502203cc8813 / 020000
2020-09-19 19:18:44.187 [update notice] received unknown MM cmd: 03f10800080080331280000005
2020-09-19 19:18:44.345 [update notice] received unknown MS cmd: 3008502203cc1227 / 020000
2020-09-19 19:18:44.721 [update notice] received unknown MS cmd: 30505014072100050019406e / 09000000800080008828
2020-09-19 19:18:44.792 [main error] scan config f6: ERR: read timeout
JimKnopf
#65
Hi!
Lege mal den unter /etc/ebusd/de/
Deine Wolf Ordner an. Meine Broadcast CSV habe ich auch in dem Ordner abgelegt.
Hier mein Tree:
└── de
    ├── broadcast.csv
    ├── memory.csv
    ├── _templates.csv
    └── wolf
        ├── 07.csv
        ├── 08.csv
        ├── 50.csv
        └── wolf.ods
Und hier die comandline:
ebusd -f -d 192.168.2.163:9999 -l /var/log/ebusd.log --latency=20000 --address=01 --configpath=/etc/ebusd/de --accesslevel=* --mqttport=1883 --mqttjson --mqtthost=192.168.2.101 --mqtttopic=ebusd/%circuit/%name --pollinterval=10 --enablehex --enabledefine
Funktioniert bei mir wunderbar.
Wenn Du auf die "original" CSV tree siehst, siehst Du, dass dort auch im übergeordneten Ordner die broadcast.csv liegt. Ich denke mal, weil sie allgemeingültig ist. Vermutlich wird die vermisst.
Ich sehe gerade Dein log. Er vermisst ja direkt im Wolf Verzeichniss die 08. Hast Du die Rechte für die 08.csv geprüft? Nicht dass die leseberechtigung fehlt.
Burkhard
FHEM,LaCrosse,PCA301,Revolt,MAX!,HM,FS20, MQTT2, ebusd 3.4.v3.4-96-g96d5623, ebus Adapter 3.0 mit 20201219-offset , Wolf  CGB (-K)-20, Wolf ISM7, Wolf Solar SM, Speicher/WR E3DC S10, eGolf, Keba P30, Phoenix Contact EV, OpenWB
JimKnopf
Hi!
Ich habe bei mir nun folgendes Problem:
Mit einem ISM7 kann ich meine Heizungsanlage verstellen. Das ISM7 ist nur per eBus mit der Heizung verbunden.
Wenn ich jetzt auf Sommerbetrieb umschalte wird
ff305023097c120105005d010000
gesendet.
Wenn ich von Hand wieder auf Timer umschalte und jetz in ebusctl
write -s ff -h 305023097c120105005d010000
ausführe passiert ..... nichts
Im Fenster steht dann folgendes:
0-09-20 13:23:00.363 [update notice] received update-read broadcast Heizungsregler748: f4;02;04;04;5d;01;00
2020-09-20 13:23:01.522 [update notice] received write feuerung sollw2 QQ=10: 5.000;19.000;-;01;55.000
2020-09-20 13:23:01.815 [update notice] received update-read broadcast sollw QQ=f1: 5.000;15.000;0;Timer;55.000
2020-09-20 13:23:02.534 [main notice] write hex cmd: ff305023097c120105005d010000
2020-09-20 13:23:03.506 [update notice] received update-read broadcast Heizungsregler7f4b: 23;00;00;00;5d;01;00
2020-09-20 13:23:03.842 [update notice] received update-read master dateTimeMeldung QQ=30: -;13:23:10;-;-;So
2020-09-20 13:23:05.133 [update notice] sent poll-read regler betrd: 00;80
2020-09-20 13:23:06.527 [update notice] received write feuerung betrd QQ=10: Brauchwasser;Kesselpumpeaus;5.00;-;-;55.0;-
2020-09-20 13:23:06.824 [update notice] received update-read broadcast betrdHzRegler QQ=f1: 0;00;-;23.0;-;61
Kann jemand erklären warum das vom ISM funktioniert und von ebusctl nicht?
Burkhard
schlund
Zitat von: JimKnopf am 20 September 2020, 09:47:43
Hi!
Hier mein Tree:
└── de
    ├── broadcast.csv
    ├── memory.csv
    ├── _templates.csv
    └── wolf
        ├── 07.csv
        ├── 08.csv
        ├── 50.csv
        └── wolf.ods
Burkhard
Vielen Dank! Habe meinen Fehler durch deinen cmd Aufruf finden können.
Ich hatte einen Fehler in /etc/default/ebusd, daher hat es nie, egal was ich gemacht habe, die .csv Dateien aus dem Config dir geladen.
Dadurch, dass ich es mal mit -f gestartet hab bin ich dem auf die Schliche gekommen  ;)
Jetzt bekomme ich zumindest einige Werte der Heizung.
weini
Die Thread-Leiche wurde ja schon mehrmals wieder zum Leben erweckt, also versuchen wir es nochmal:
Ich habe meinen eBus 3.0 Adapter mit einer Wolf CGB2 55 & BM2 jetzt in Betrieb und bekomme schön Daten rein.
Hier für alle Mitstreiter meine Konfiguration:
# /etc/default/ebusd:
# config file for ebusd service.
# Options to pass to ebusd (run "ebusd -?" for more info):
EBUSD_OPTS="--configpath=/etc/ebusd --configlang=de --accesslevel=* --loglevel=notice --latency=100 -d enh:ebus.weinberger.local:9999"
Adressierung über FQDN geht übrigens einwandfrei.
Die Messages für feuerung-warmwasser-ist und feuerung-warmwasser-soll haben sich geändert. Die konnte ich aber herausfinden und entsprechend anpassen.
r,feuerung,warmwasser-soll,Warmwasser Solltemperatur,,51,5022,e40300,warmwasser-soll,,UIN,10,Grad Celcius,Warmwasser Solltemperatur,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
r,feuerung,warmwasser-ist,Warmwasser Ist-Temperatur,,51,5022,cc0e00,warmwasser-ist,,UIN,10,Grad Celcius,Warmwasser Ist-Temperatur,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Was mir noch fehlt ist jetzt, Warmwasser Soll auch setzen zu können.
Bei den anderen Einträgen sieht das in der 08.csv immer so aus:
r,feuerung,hg16,HG 16 - Pumpenleistung HK minimal,,08,5022,b95501,pumpenleistung_hk_min,,UIN,,min,Pumpenleistung HK minimal (20-100),,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
w,feuerung,hg16,HG 16 - Pumpenleistung HK minimal,,03,5023,005501,pumpenleistung_hk_min,,UIN,,min,Pumpenleistung HK minimal (20-100),suffix,,HEX:4,=9d010000,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Zum Schreiben wird also anstatt 08 die 03 adressiert und SB wechselt von 22 auf 23. Nun habe ich aber für die WW Messages ZZ=51 und damit passt die alte Systematik nicht mehr.
Ich habe auch schon versucht, die Messages zu sniffen. Aber das, was auf dem Bus kommt, wenn ich am BM2 die WW Soll einstellen, das hat mir leider nicht geholfen.
Wie könnte ich denn hier sinnvoll weitermachen?
Gurker
Gute Frage - ist bekannt welches CSV-Set bisher am besten für die einzelnen Thermen funktioniert?
Mein Interesse wäre nicht nur das Protokollieren, ich würde auch gern die CGB-11 mit einem KM so einstellen, dass sie nicht konkurriert mit einem Heizstab/einer WP?
m.zsolnay
Hallo an alle Profis !
Ich bin leider noch ein verzweifelter Anfänger, der es versucht seine WOLF Heizung über ebus abzufragen.
Ich komme nicht einmal drauf, wie ich die konfigurationsdateien richtig einsetzte, denn ich bekomme keine brauchbaren Daten.
Wenn mir jemand hierbei geduldig helfen kann, wäre ich dankbar !
Gruss,
M.
Kornelius777
@m.zsolnay:
So wird dir niemand helfen können.
Du müsstest erstmal erzählen, wie genau dein setup aussieht.
Was für Hardware setzt du ein, wie ist sie mit dem ebus verbunden, was hast du bisher selber versucht, um das Ganze zum Laufen zu bekommen?
Grüße!
Kornelius
stephanstricker
das ist jetzt etwas off topic aber da sich hier viel mit der Wolf Heizung beschäftigen hat hier vielleicht jemand einen Tipp. Ich möchte die Heizung gerne morgens für 2 Stunden anstellen. Wenn ich das über die Zeitprogrammierung mache, geht die Heizung außerhalb der Zeiten aber nur in den Absenkbetrieb, wo sie über den Tag immer wieder nachheizt. Ich möchte die Heizung aber komplett ausstellen. Alle Parameter, die ich finden konnte, lösen das Problem leider nicht. Einzige Lösung die ich im Moment habe wäre in Reihe mit dem Ein/Ausschalter ein Relais einzubauen, was ich dann extern programmiere. Hat hier vielleicht jemand eine Idee wie man das machen könnte.
Schöne Grüße
Stephan
Kornelius777
#73
Also, ich habe das folgendermaßen gelöst:
An meiner Wolf CGB-2-14 gibt es einen Anschluss "E1".
Wenn man dann den Fachmannparameter HG13 auf "RT (Raumthermostat)" stellt, wird bei geöffnetem Eingang E1 der Heizbetrieb gesperrt (Sommerbetrieb). Nennt sich dann "externe Deaktivierung". Das schaltet dann die Heizfunktion ab, aber nicht die Warmwasserproduktion.
Sobald Eingang E1 dann wieder geschlossen wird (Eingangsklemme E1 "kurzschließen"), ist der Heizbetrieb wieder da.
Am Eingang E1 darf keine externe Spannung angelegt werden, da dieses zur Zerstörung des Bauteils führt.
(Findet sich in der "Montageanleitung für den Fachhandwerker" auf Seite 39)
Ich habe dann einen ESP D1 Mini (https://amzn.eu/d/gDadHx0) mit einem Relay Shield (https://amzn.eu/d/dWRJ1BH) genommen und an genau diesen Eingang E1 angeschlossen. Damit geht meine Heizung genau dann in den Heizbetrieb, wenn ich das möchte.
stephanstricker
@Kornelius777
Das ist genau die Lösung, nach der ich suche und bei mir existiert der Kontakt auch. Aktuell ist das eine Brücke verbaut. Ich würde das folgende Modul nehmen um den Kontakt extern zu schalten.
https://de.elv.com/homematic-ip-schaltplatine-hmip-pcbs-150776?fs=463181306&c=778
Hast Du mal gemessen, was dort für eine Spannung anliegt, wenn die Brücke raus ist? Das Relais, das Du verwendest, ist bis 30V DC. Ich vermute das dort 5V oder 12V geschaltet werden?!
Schöne Grüße
Stephan
