ich versuche gerade die Grundlagen für den Dot seit zwei Tagen zu installieren:
apt-get install nodejs-legacy
als System habe ich:
Linux cubietruck 3.4.107-cubietruck #6 SMP PREEMPT Thu May 21 20:27:01 CEST 2015 armv7l GNU/Linux
Statt einer Installation kommt folgende Fehlermeldung:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'nodejs' instead of 'nodejs-legacy'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nodejs : Depends: libc6 (>= 2.16) but 2.13-38+deb7u11 is to be installed
Depends: libstdc++6 (>= 5.2) but 4.7.2-5 is to be installed
E: Unable to correct problems, you have held broken packages.
Leider kann mir da Mama Google etc auch nicht weiterhelfen.
Hat jemand eine Idee ?
