Autor Thema: Fritzbox PERL WARNING: Use of uninitialized value in concatenation (.) or string  (Gelesen 1637 mal)
Offline AET_FHEM
  • Full Member
seit kurzem hab ich in meinem Log immer den selben Eintrag
Es funktioniert eigentlich alles aber mein Log wird zu gemüllt und macht es nicht gerade übersichtlich ....
2017.01.30 09:53:20 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/72_FRITZBOX.pm line 1419.
2017.01.30 09:53:20 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1424.
2017.01.30 09:53:20 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1453.
2017.01.30 09:53:20 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/72_FRITZBOX.pm line 1460.
2017.01.30 09:53:20 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1460.
2017.01.30 09:58:20 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/72_FRITZBOX.pm line 1419.
2017.01.30 09:58:20 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1424.
2017.01.30 09:58:20 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1453.
2017.01.30 09:58:20 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/72_FRITZBOX.pm line 1460.
2017.01.30 09:58:20 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1460.
2017.01.30 10:03:20 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/72_FRITZBOX.pm line 1419.
2017.01.30 10:03:20 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1424.
2017.01.30 10:03:20 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1453.
2017.01.30 10:03:20 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/72_FRITZBOX.pm line 1460.
2017.01.30 10:03:20 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1460.
2017.01.30 10:08:21 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/72_FRITZBOX.pm line 1419.
2017.01.30 10:08:21 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1424.
2017.01.30 10:08:22 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1453.
2017.01.30 10:08:22 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/72_FRITZBOX.pm line 1460.
2017.01.30 10:08:22 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 1460.
diese Meldungen bekomm ich ständig
die Config Fritzbox 7362
allowShellCommand 0
allowTR064Command 1
boxUser XXXX
forceTelnetConnection 0
fritzBoxIP XXXX
verbose 0
hat jemand eine Idee??
Offline DeeSPe
  • Wer anderen eine Bratwurst brät...
Ich denke Du solltest Deinen Beitrag von "Anfängerfragen" nach "FHEM - Hardware -> FRITZ!Box" verschieben...
Dann wird Dir sicher jemand helfen können.
Dan
FHEM 5.9, Brix, VIVO mini, RPi3, Debian Jessie, ZME_UZB1
HM-CFG-LAN, HM-MOD-UART-WIFI, HUE, HarmonyHub, JeeLink, CO20
Hyperion auf RPi Zero W, Sonos, viel Z-Wave und HM
alles per HomeKit steuerbar
Offline AET_FHEM
  • Full Member
Hey DeeSPe,
hast recht --> Verschoben :-)
Offline AET_FHEM
  • Full Member
keiner ne Idee?
=> also wenn keiner so ein Problem hat muss es ja an meinen Einstellungen liegen ...
=> das es nochmal klar ist FHEM läuft auf meinem Raspberry und ich will nur die Daten meiner Fritzbox auslesen
Offline AET_FHEM
  • Full Member
OK --> hab jetzt weiter unten im Forum geschaut hier gibt's schon ein thread mit dem Namen Flut im Log .....
decade-submarginal
