Modul für Kodi (ehemals 70_XBMC)
Begonnen von vbs, 02 Februar 2017, 23:11:10
kalleknx
Ich nutze auch Kodi Leia und beim Abspielen von TV bleiben sämtliche readings in FHEM leer (z.B. currentTitle).
Hat jemand hier auch dieses Verhalten beobachtet?
Tommy82
ich habe heute nochmal das Kodi Modul in Fhem aktiviert, und jetzt im Log jede Menge dieser Meldungen:
2018.09.22 09:56:19.688 3: KODI_CheckConnection: Connection lost! Last data from Kodi received 120.020795106888 s ago
2018.09.22 09:56:19.689 1: 192.168.188.25:8484 disconnected, waiting to reappear (Kodi)
2018.09.22 09:56:24.464 1: 192.168.188.25:8484 reappeared (Kodi)
2018.09.22 09:58:24.471 3: KODI_CheckConnection: Connection lost! Last data from Kodi received 120.013420820236 s ago
2018.09.22 09:58:24.472 1: 192.168.188.25:8484 disconnected, waiting to reappear (Kodi)
2018.09.22 09:58:29.699 1: 192.168.188.25:8484 reappeared (Kodi)
2018.09.22 10:00:29.715 3: KODI_CheckConnection: Connection lost! Last data from Kodi received 120.022053956985 s ago
2018.09.22 10:00:29.716 1: 192.168.188.25:8484 disconnected, waiting to reappear (Kodi)
2018.09.22 10:00:30.125 1: 192.168.188.25:8484 reappeared (Kodi)
2018.09.22 10:02:30.138 3: KODI_CheckConnection: Connection lost! Last data from Kodi received 120.019634962082 s ago
2018.09.22 10:02:30.140 1: 192.168.188.25:8484 disconnected, waiting to reappear (Kodi)
2018.09.22 10:02:30.668 1: 192.168.188.25:8484 reappeared (Kodi)
2018.09.22 10:04:30.686 3: KODI_CheckConnection: Connection lost! Last data from Kodi received 120.023766040802 s ago
2018.09.22 10:04:30.687 1: 192.168.188.25:8484 disconnected, waiting to reappear (Kodi)
2018.09.22 10:04:33.484 1: 192.168.188.25:8484 reappeared (Kodi)
2018.09.22 10:06:33.498 3: KODI_CheckConnection: Connection lost! Last data from Kodi received 120.019608020782 s ago
2018.09.22 10:06:33.499 1: 192.168.188.25:8484 disconnected, waiting to reappear (Kodi)
2018.09.22 10:06:33.797 1: 192.168.188.25:8484 reappeared (Kodi)
2018.09.22 10:08:33.821 3: KODI_CheckConnection: Connection lost! Last data from Kodi received 120.029769182205 s ago
2018.09.22 10:08:33.821 1: 192.168.188.25:8484 disconnected, waiting to reappear (Kodi)
2018.09.22 10:08:34.465 1: 192.168.188.25:8484 reappeared (Kodi)
Was kann ich dagegen tun?
Und kann ich mit dem Modul auch das LiveTV in Kodi schalten? Im idealfall direkte Sender auswahl so wie es auch im Enigma2 Modul möglich ist?
Fhem Cubitruck  Armbian Buster with Linux 5.3.9-sunxi
HM-CC_RT-DN, HM-Sec-RHS,HM-Sec-SD, HM-Sec-SCo,IT1500,1xIT GRR-3500 Fritz!Dect200,Powerline546E,Enigma2 Modul mit 3 Vu+,Wol Modul für WinServer2016 und WinServer 2019,FB6590
Allnetl Wandtablett mit FTUI
vbs
Hast du evtl. einen falschen Port konfiguriert?
Tommy82
Nein, ist der der in Kodi angegeben ist, über den ich auch auf mein Kodi von meiner IOS APP zugreife
vbs
Sieht danach aus, als würde er zwar eine Verbindung auf einen TCP-Port aufbauen können aber dann findet offenbar nicht die erwartete Kommunikation statt, so dass er dann wieder aufgibt und später erneut versucht.
Tommy82
#125
Seltsamerweise jetzt plötzlich seit 2 Tagen nicht mehr........
Werde es mal beobachten.
Andere Frage
EDIT
Heute hab ich den LOg wieder voller
2018.09.25 00:00:23.144 3: KODI_CheckConnection: Connection lost! Last data from Kodi received 120.018586158752 s ago
2018.09.25 00:00:23.159 1: 192.168.188.25:8484 disconnected, waiting to reappear (Kodi)
2018.09.25 00:00:28.374 1: 192.168.188.25:8484 reappeared (Kodi)
2018.09.25 00:02:28.386 3: KODI_CheckConnection: Connection lost! Last data from Kodi received 120.017473936081 s ago
2018.09.25 00:02:28.386 1: 192.168.188.25:8484 disconnected, waiting to reappear (Kodi)
2018.09.25 00:02:30.335 1: 192.168.188.25:8484 reappeared (Kodi)
meldungen.....
vbs
#126
Live-TV geht meines Wissens nicht nativ. Der einzige Workaround ist das Schicken eigener JSON-API-Nachrichten per "send".
Bei dem Connection-Probleme würde ich mal händisch eine Telnet-Verbindung auf der Konsole aufmachen und gucken, ob du da ordentlichen Datenverkehr siehst (also ohne FHEM).
patator
ich nutze auch das Kodi Modul und lasse mir wenn es an der Türe klingelt oder ein Anruf aufs Festnetz reinkommt am TV via Kodi msg signalisieren.
Hat jemand herausgefunden, ob man mit dem msg Parameter auch ein Bild übertragen kann, welches auf dem Rapsberry der FHEM Instanz liegt?
Ich würde nämlich sehr gerne das Bild dass durch das Klingeln über die Cam erstellt wird anzeigen lassen.
Danke schon mal im Voraus.
Tommy82
#128
Wie baue ich eine Telnet Verbinung zu Kodi auf? Auf CoreElec wo Kodi läuft kann ich per ssh zugreifen
Hab grad nochmal gesehen das viele der Readings auch nicht aktualisiert werden....
   DEF        192.168.188.25:8484 tcp kodi 1Tina9-
   DeviceName 192.168.188.25:8484
   FD         4
   Host       192.168.188.25
   LAST_RECV  1538497086.71557
   NAME       Kodi
   NR         348
   NextID     757
   PARTIAL
   Port       8484
   Protocol   tcp
   STATE      opened
   TYPE       KODI
   Helper:
     DBLOG:
       playStatus:
         myDbLog:
           TIME       1538497086.62136
           VALUE      stopped
       state:
         myDbLog:
           TIME       1538497086.72737
           VALUE      CONNECTED
       system:
         myDbLog:
           TIME       1538497086.68332
           VALUE      wake
   PendingPlayerCMDs:
     102:
       method     Player.GetProperties
       params:
         properties:
           time
           totaltime
           repeat
           shuffled
           speed
           partymode
     105:
     2017-10-21 14:58:20   3dfile          off
     2017-10-21 14:58:48   audiolibrary    update
     2017-10-21 14:58:20   currentAlbum
     2017-10-21 14:58:20   currentArtist   Micky Krause
     2017-10-21 14:58:20   currentMedia    D:\Musik\Sonstige\G-Q\Micky Krause - Zeig Doch mal die Möpse.mp3
     2017-10-21 14:55:08   currentOriginaltitle
     2017-10-21 14:55:08   currentShowtitle
     2017-10-21 14:58:20   currentTitle    Zeig Doch mal die Möpse
     2017-10-21 14:58:20   currentTrack    0
     2017-10-21 14:55:08   episode
     2017-10-21 14:55:08   episodeid
     2017-11-04 19:02:07   fullscreen      off
     2017-10-21 14:58:20   id              36483
     2017-10-21 14:58:20   label           Zeig Doch mal die Möpse
     2017-10-21 14:55:08   movieid
     2017-11-04 19:02:07   mute            off
     2017-11-04 19:02:07   name            Kodi
     2018-10-02 18:18:06   partymode
     2018-10-02 18:18:06   playStatus      stopped
     2017-10-21 14:55:08   playlist
     2018-10-02 18:18:06   repeat
     2017-10-21 14:55:08   season
     2018-10-02 18:18:06   shuffle
     2017-11-04 19:02:07   skin            Estuary(skin.estuary)
     2017-10-21 14:55:08   songid          36483
     2018-10-02 18:18:06   speed
     2018-10-02 18:18:06   state           opened
     2017-11-04 19:02:07   stereoscopicmode off
     2018-10-02 18:18:06   system          wake
     2017-10-21 14:58:20   thumbnail       image://music@D%3a%5cMusik%5cSonstige%5cG-Q%5cMicky%20Krause%20-%20Zeig%20Doch%20mal%20die%20M%c3%b6pse.mp3/
     2018-10-02 18:18:06   time
     2018-10-02 18:18:06   totaltime
     2017-10-21 14:58:20   type            song
     2017-11-04 19:02:07   version         18.0-20170914-ae8206a alpha
     2017-11-04 19:02:07   volume          100
     2017-10-21 14:58:20   year            0
   compatibilityMode kodi
   devStateIcon opened:rc_GREEN:on disconnected:rc_RED:off Initialized:message_socket_disabled
   group      Alexa
   room       Wohnzimmer
   updateInterval 60
bmaehr
Zitat von: Klauswirn am 05 April 2018, 17:59:25
hoffentlich darf ich in dem alten Thread meine Frage stellen.
Ich verwende das Kodi Modul erfolgreich und finde es toll.
Was ich bisher noch nicht geschafft habe ist folgendes:
Ich nutze in Kodi das "Radio.de" Plugin und habe dort mehrere Favoriten.
Bisher schaffe ich es nicht das ich geziehlt einen Radiosender starten kann.
Würde mir gerne selber Favoriten Buttons bauen, wo dann der direkte Stream gestartet wird.
Lasst das Modul das überhaupt zu?
Bin für Hinweise Dankbar!
Hab das Selbe gesucht. Nach dem Durchwühlen von Spezifikationen und Source-Code bin ich zu der einfachen Lösung gekommen:
set MediacenterKodi open plugin://plugin.audio.radio_de/station/9111
riker1
Hi, coole Sache.....
wo finde ich denn die Refenzenen zu den Stationsnummern?
FHEM    5.26.1 Ubuntu 18, FHEM    5.26.1 RPI 3 , Actoren: IT ,Tasmota, ESPEasy,
MAX CUBE, MAX HT, MAX WT, Selbstbau nanoCULs, FS 20,Tasmota, Homematic, FTK, SW. DIM, Smoke,KODI,Squeezebox
tpunkt
ich versuche verzweifelt, an meiner tablet ui einen thumbnail des gerade laufenden Films einzublenden. Dazu habe ich wie in der Hilfe beschrieben versucht, ein userReadings zu meinem KODI device hinzuzufügen und zwar so:
attr Videoplayer userReadings http_thumbnail { my $val = (ReadingsVal("$name", "thumbnail", 0)); $val =~ s/\%2f/\%252f/g;; return "http://192.168.178.12:8080/image/".$val;; }
Leider bekomme ich dann immer diese Fehlermeldung
Unknown command $val, try help.
Hat jemand eine Ahnung was hier das Problem ist?
Danke!
Porsti
habe das auch mal ausprobiert, aber bei Kodi wird das Addon Radio.de leider nicht gestartet.
Muss ich da noch etwas anderen Einstellen damit ich den Befehl benutzen kann.
Porsti
____________________________________
fhem 6.2  auf Raspberry 3b
Homematic HM-CC-RT-DN / HM-TC-IT-WM-W-EU / HM-SEC-SCo / HM-LC-SW1-PL2
SIGNALduino, KNX (Merten, MDT, Siemens, ABB)
riker1
Porsti
Hi muss do gehen, klappt bei mir auf jeden Fall.
Welche Kodi Version nutzt du? Habe Leia , 18....
{fhem('set Kodi open plugin://plugin.audio.radio_de/station/'.$channel)}
geht auf jeden fall mit diversen channels, allerdings nicht beispielsweise harmony.fm 8441.
siehst du denn am Kodi das er anfängt etwas zu machen? Kreis dreht sich....
VG Thomas
Porsti
Hallo Thomas,
Ich habe noch Kodi Krypton 17.6 auf einem Raspberry 3 laufen.
Wenn ich den Befehl ausführe passiert nichts auch kein Kreis der sich dreht.
Gruß Porsti
