OWServer uninitialized Value wenn DS9490R nicht eingesteckt
Begonnen von abc2006, 15 Februar 2017, 14:07:15
abc2006
bei einem Ausfall des DS9490R erzeugt OWServer u.a. Meldungen im Log.
Die Funktion stört es nicht, allerdings werden bei mir beide Adapter mit "present:0" geführt, obwohl einer angeschlossen ist (und Werte liefert) und der andere hier einzeln bei mir auf dem Schreibtisch liegt.
Stephan
2017.02.15 14:02:01.035 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/10_OWServer.pm line 369.
2017.02.15 14:02:01.036 1: stacktrace:
2017.02.15 14:02:01.036 1:     main::__ANON__                      called by ./FHEM/10_OWServer.pm (369)
2017.02.15 14:02:01.037 1:     main::OWServer_Find                 called by ./FHEM/11_OWDevice.pm (436)
2017.02.15 14:02:01.037 1:     main::OWDevice_ReadFromServer       called by ./FHEM/11_OWDevice.pm (730)
2017.02.15 14:02:01.037 1:     main::OWDevice_InitValues           called by ./FHEM/11_OWDevice.pm (705)
2017.02.15 14:02:01.038 1:     main::OWDevice_Notify               called by fhem.pl (3302)
2017.02.15 14:02:01.038 1:     main::CallFn                        called by fhem.pl (3223)
2017.02.15 14:02:01.038 1:     main::DoTrigger                     called by fhem.pl (573)
2017.02.15 14:02:01.043 5: OWServer child ID for reading '/81.E39D30000000/id' is 2561
2017.02.15 14:02:01.253 5: OWServer child read /81.E39D30000000/id: <undefined>
2017.02.15 14:02:01.254 5: OWServer: undefined response from child 2561
2017.02.15 14:02:01.838 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/10_OWServer.pm line 369.
2017.02.15 14:02:01.842 1: stacktrace:
2017.02.15 14:02:01.843 1:     main::__ANON__                      called by ./FHEM/10_OWServer.pm (369)
2017.02.15 14:02:01.843 1:     main::OWServer_Find                 called by ./FHEM/11_OWDevice.pm (436)
2017.02.15 14:02:01.843 1:     main::OWDevice_ReadFromServer       called by ./FHEM/11_OWDevice.pm (721)
2017.02.15 14:02:01.844 1:     main::OWDevice_InitValues           called by ./FHEM/11_OWDevice.pm (705)
2017.02.15 14:02:01.844 1:     main::OWDevice_Notify               called by fhem.pl (3302)
2017.02.15 14:02:01.845 1:     main::CallFn                        called by fhem.pl (3223)
2017.02.15 14:02:01.845 1:     main::DoTrigger                     called by fhem.pl (573)
2017.02.15 14:02:01.850 5: OWServer child ID for reading '/81.376436000000/type' is 2562
2017.02.15 14:02:02.059 5: OWServer child read /81.376436000000/type: <undefined>
2017.02.15 14:02:02.060 5: OWServer: undefined response from child 2562
2017.02.15 14:02:02.838 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/10_OWServer.pm line 369.
2017.02.15 14:02:02.839 1: stacktrace:
2017.02.15 14:02:02.839 1:     main::__ANON__                      called by ./FHEM/10_OWServer.pm (369)
2017.02.15 14:02:02.840 1:     main::OWServer_Find                 called by ./FHEM/11_OWDevice.pm (436)
2017.02.15 14:02:02.840 1:     main::OWDevice_ReadFromServer       called by ./FHEM/11_OWDevice.pm (730)
2017.02.15 14:02:02.840 1:     main::OWDevice_InitValues           called by ./FHEM/11_OWDevice.pm (705)
2017.02.15 14:02:02.841 1:     main::OWDevice_Notify               called by fhem.pl (3302)
2017.02.15 14:02:02.841 1:     main::CallFn                        called by fhem.pl (3223)
2017.02.15 14:02:02.841 1:     main::DoTrigger                     called by fhem.pl (573)
2017.02.15 14:02:02.846 5: OWServer child ID for reading '/81.376436000000/id' is 2563
2017.02.15 14:02:03.056 5: OWServer child read /81.376436000000/id: <undefined>
2017.02.15 14:02:03.057 5: OWServer: undefined response from child 2563
FHEM nightly auf Intel Atom (lubuntu) mit VDSL 50000 ;-)
Nutze zur Zeit OneWire und KNX
Prof. Dr. Peter Henning
abc2006
Muss jeder Beitrag eine Frage enthalten?
Ich wollte blos mitteilen, dass es bei mir so ist, und wenn das für den Entwickler uninteressant ist, dann einfach schließen/löschen/mit uninteressant markieren.
Andererseits könnte es ja sein, dass ich in meiner config einen ungeschickten Fehler gemacht habe, den ich vielleicht besser korrigiere.
Stephan
