set pct bringt warnings im log
Begonnen von the ratman, 23 März 2017, 12:34:00
the ratman
hiho,
ich hab n paar HM-LC-Dim1TPBU-FM wippen. ganz normal gepaired, keine sonderspielchen, ... nix.
jetzt ist mir eben beim durchsehen des logs aufgefallen: schalte ich ganz normal per befehl z.b. "set Sofa_Deckenlicht pct 30" (auch beim set-befehl des devices selber), gibts folgende warnings.
ist ja nix schlimmes, aber da ich gern automatisierte pct-befehle raus hau, gibt das n nettes log am abend *g*.
btw - bei befehlen wie "on" oder "off" gibts kien warnings.
2017.03.23 12:25:59 1: PERL WARNING: Argument "set_30" isn't numeric in numeric eq (==) at (eval 15835) line 1.
2017.03.23 12:25:59 1: stacktrace:
2017.03.23 12:25:59 1:     main::__ANON__                      called by (eval 15835) (1)
2017.03.23 12:25:59 1:     (eval)                              called by fhem.pl (4065)
2017.03.23 12:25:59 1:     main::evalStateFormat               called by fhem.pl (4156)
2017.03.23 12:25:59 1:     main::readingsEndUpdate             called by fhem.pl (4351)
2017.03.23 12:25:59 1:     main::readingsSingleUpdate          called by ./FHEM/10_CUL_HM.pm (8576)
2017.03.23 12:25:59 1:     main::CUL_HM_UpdtReadSingle         called by ./FHEM/10_CUL_HM.pm (4660)
2017.03.23 12:25:59 1:     main::CUL_HM_Set                    called by fhem.pl (3309)
2017.03.23 12:25:59 1:     main::CallFn                        called by fhem.pl (1652)
2017.03.23 12:25:59 1:     main::DoSet                         called by fhem.pl (1684)
2017.03.23 12:25:59 1:     main::CommandSet                    called by fhem.pl (1109)
2017.03.23 12:25:59 1:     main::AnalyzeCommand                called by ./FHEM/01_FHEMWEB.pm (2438)
2017.03.23 12:25:59 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (895)
2017.03.23 12:25:59 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (538)
2017.03.23 12:25:59 1:     main::FW_Read                       called by fhem.pl (3314)
2017.03.23 12:25:59 1:     main::CallFn                        called by fhem.pl (676)
2017.03.23 12:25:59 1: PERL WARNING: Argument "set_30" isn't numeric in numeric eq (==) at (eval 15839) line 1.
2017.03.23 12:25:59 1:     main::__ANON__                      called by (eval 15839) (1)
2017.03.23 12:25:59 1:     main::CUL_HM_UpdtReadSingle         called by ./FHEM/10_CUL_HM.pm (6050)
2017.03.23 12:25:59 1: PERL WARNING: Argument "set_30" isn't numeric in numeric eq (==) at (eval 15847) line 1.
2017.03.23 12:25:59 1:     main::__ANON__                      called by (eval 15847) (1)
2017.03.23 12:25:59 1:     main::readingsEndUpdate             called by ./FHEM/10_CUL_HM.pm (8565)
2017.03.23 12:25:59 1:     main::CUL_HM_UpdtReadBulk           called by ./FHEM/10_CUL_HM.pm (3619)
2017.03.23 12:25:59 1:     main::CUL_HM_pushEvnts              called by ./FHEM/10_CUL_HM.pm (2906)
2017.03.23 12:25:59 1:     main::CUL_HM_Parse                  called by fhem.pl (3510)
2017.03.23 12:25:59 1:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (779)
2017.03.23 12:25:59 1:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (604)
2017.03.23 12:25:59 1:     main::HMLAN_Read                    called by fhem.pl (3314)
→do↑p!dnʇs↓shit←
