Fibaro FGD-212 endpoint children devices
Begonnen von gw0udm, 10 April 2017, 21:19:01
gw0udm
Hi
I've got a few of the older Fibaro FGD-211 dimmers installed which work fine, and each creates one device eg  - ZWave_SWITCH_MULTILEVEL_1
However I've just got a new FGD-212 and after learning it in to the network it has created three devices:
ZWave_SWITCH_MULTILEVEL_1.01
ZWave_SWITCH_MULTILEVEL_1.02
I can see that the .01 and .02 devices are down as 'endpoint children' but I can't work out their functions. The main device (1) dims the light up and down. The 1.01 does the same, but the 1.02 doesn't seem to do anything.
I'm sure this is something to do with ZWave plus and being a generally newer device but I can't work it out. Can anyone help?
Thanks
James
I dont know the device, but I've read here something about Switch #1 and #2.
I assume the subdevices are used to report which switch was activated.
