[erledigt! war wohl defekt...] Hilfe beim Einbinden von Sensative Stripes
Begonnen von MadMax-FHEM, 07 Mai 2017, 13:50:05
MadMax-FHEM
hauptsächlich betreibe ich Homematic und für ein paar Sachen eben ZWave.
Aeotec AEOEZW090-C Aeon Labs USB Stick, hier das list:
   CallbackNr 32
   Clients    :ZWave:
   DEF        /dev/serial/by-id/usb-0658_0200-if00@115200
   DeviceName /dev/serial/by-id/usb-0658_0200-if00@115200
   FD         9
   MaxSendRetries 3
   NAME       zwave_usb
   NR         45
   PARTIAL
   RAWMSG     004a20060000
   ReadTime   1494156080.65356
   STATE      Initialized
   SendRetries 0
   SendTime   1494156080.55671
   TYPE       ZWDongle
   WaitForAck 0
   homeId     eae8e954
   nodeIdHex  01
   nrNAck     0
   zwave_usb_MSGCNT 38
   zwave_usb_TIME 2017-05-07 13:20:23
   Matchlist:
     1:ZWave    .*
   Readings:
     2017-05-07 12:52:50   caps            Vers:1 Rev:0 ManufID:0086 ProductType:0001 ProductID:005a SERIAL_API_GET_INIT_DATA SERIAL_API_APPL_NODE_INFORMATION APPLICATION_COMMAND_HANDLER ZW_GET_CONTROLLER_CAPABILITIES SERIAL_API_SET_TIMEOUTS SERIAL_API_GET_CAPABILITIES SERIAL_API_SOFT_RESET UNKNOWN_09 ZW_SET_R_F_RECEIVE_MODE ZW_SET_SLEEP_MODE ZW_SEND_NODE_INFORMATION ZW_SEND_DATA ZW_SEND_DATA_MULTI ZW_GET_VERSION ZW_SEND_DATA_ABORT ZW_R_F_POWER_LEVEL_SET ZW_SEND_DATA_META ZW_GET_RANDOM MEMORY_GET_ID MEMORY_GET_BYTE MEMORY_PUT_BYTE MEMORY_GET_BUFFER MEMORY_PUT_BUFFER FLASH_AUTO_PROG_SET NVM_GET_ID NVM_EXT_READ_LONG_BUFFER NVM_EXT_WRITE_LONG_BUFFER NVM_EXT_READ_LONG_BYTE NVM_EXT_WRITE_LONG_BYTE ZW_GET_NODE_PROTOCOL_INFO ZW_SET_DEFAULT ZW_REPLICATION_COMMAND_COMPLETE ZW_REPLICATION_SEND_DATA ZW_ASSIGN_RETURN_ROUTE ZW_DELETE_RETURN_ROUTE ZW_REQUEST_NODE_NEIGHBOR_UPDATE ZW_APPLICATION_UPDATE ZW_ADD_NODE_TO_NETWORK ZW_REMOVE_NODE_FROM_NETWORK ZW_CREATE_NEW_PRIMARY ZW_CONTROLLER_CHANGE ZW_SET_LEARN_MODE ZW_ASSIGN_SUC_RETURN_ROUTE ZW_REQUEST_NETWORK_UPDATE ZW_SET_SUC_NODE_ID ZW_DELETE_SUC_RETURN_ROUTE ZW_GET_SUC_NODE_ID ZW_SEND_SUC_ID ZW_EXPLORE_REQUEST_INCLUSION ZW_REQUEST_NODE_INFO ZW_REMOVE_FAILED_NODE_ID ZW_IS_FAILED_NODE ZW_REPLACE_FAILED_NODE UNKNOWN_66 UNKNOWN_67 GET_ROUTING_TABLE_LINE LOCK_ROUTE_RESPONSE ZW_GET_PRIORITY_ROUTE ZW_SET_PRIORITY_ROUTE UNKNOWN_98 ZW_SET_WUT_TIMEOUT ZW_WATCHDOG_ENABLE ZW_WATCHDOG_DISABLE ZW_WATCHDOG_CHECK ZW_SET_EXT_INT_LEVEL ZW_RF_POWERLEVEL_GET ZW_TYPE_LIBRARY ZW_SEND_TEST_FRAME ZW_GET_PROTOCOL_STATUS WATCHDOG_START WATCHDOG_STOP UNKNOWN_d4 UNKNOWN_ee UNKNOWN_ef
     2017-05-07 11:42:08   ctrlCaps        PRIMARY
     2017-05-07 11:42:08   homeId          HomeId:eae8e954 CtrlNodeIdHex:01
     2017-05-07 13:21:20   nodeList        zwave_usb Rauchmelder_Eingang Rauchmelder_SchlaZi Rauchmelder_FabiZi
     2017-05-07 11:42:08   random          e22561c81dcd9100c67ae88af7b603d7a6ea236e12ad74d70c13deb62250140c
     2017-05-07 11:42:08   state           Initialized
     2017-05-07 11:42:08   sucNodeId       no
     2017-02-28 18:39:45   version         Z-Wave 3.95 STATIC_CONTROLLER
   SendStack:
   room       System
   verbose    5
Daran laufen seit einiger Zeit Fibaro Rauchmelder ohne Probleme (bzw. ist mir bislang nichts aufgefallen).
An einem anderen System (bei meiner Freundin) habe ich an einem Z-Wave ZME_UZB1 ebenfalls einen Fibaro Rauchmelder und die "Augen" von Fibaro (Bewegungsmelder), ebenfalls ohne Probleme.
Jetzt habe ich seit kurzem einen Sensative Strip.
Ich habe schon lange überlegt aber bislang war mir der für 60EUR Plus zu teuer.
Bislang der einzige, der auch für Außen geeignet scheint, da ja komplett "zu".
Nun gab es ihn mal für ca. 50EUR und da habe ich mir gedacht ich bestell mal einen...
Anleitung gelesen, klingt ja simpel.
Also losgelegt:
den zwave_usb auf "add node on" (oder onNW weiß ich jetzt nicht mehr genau) gesetzt und die Magnete weg.
Das Ding blinkt ein paar Mal und nichts.
Kein Bestätigungsblinken und kein Gerät in fhem...
EDIT: autocreate ist/war natürlich aktiv ;)
Ein get nodeList liefert mir nur meine 3 Rauchmelder...
...aber keinen Strip  :-\
Dann versucht einen Reset beim Strip zu machen aber es kommt da auch nie das "Reset erfolgreich lange Leuchten"...
Dann etliche Male versucht neu einzubinden wie beschrieben bzw. wie in Youtube Videos zu sehen...
...mal mit "addNode on" mal mit "addNode onNW"...
Nichts.
Dann verbose auf 5 beim zwave_usb aber es kommt nichts (zumindest sehe ich nichts) also wenn ich das Gerät in "Anlernmodus" bringe...
Hier mal ein paar Logauszüge meiner Versuche:
2017.05.07 12:58:00 4: ZWDongle *** set zwave_usb addNode on
2017.05.07 12:58:00 5: ZWDongle_Write 004a8116 ()
2017.05.07 12:58:00 5: SW: 0105004a811627
2017.05.07 12:58:00 5: ACK received, removing 0105004a811627 from dongle sendstack
2017.05.07 12:58:00 4: ZWDongle_Read zwave_usb: rcvd 004a16070000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 12:58:00 5: SW: 06
2017.05.07 12:58:00 5: zwave_usb: dispatch 004a16070000
2017.05.07 12:58:00 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:07 ARG:0000 CB:16
2017.05.07 12:58:00 4: ZWDongle *** set zwave_usb addNode off
2017.05.07 12:58:00 5: ZWDongle_Write 004a0517 ()
2017.05.07 12:58:00 5: SW: 0105004a0517a2
2017.05.07 12:58:00 4: zwave_usb ZW_ADD_NODE_TO_NETWORK failed
2017.05.07 12:58:00 5: ACK received, removing 0105004a0517a2 from dongle sendstack
2017.05.07 12:58:00 4: ZWDongle_Read zwave_usb: rcvd 004a17060000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 12:58:00 5: zwave_usb: dispatch 004a17060000
2017.05.07 12:58:00 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:06 ARG:0000 CB:17
2017.05.07 12:58:00 4: zwave_usb ZW_ADD_NODE_TO_NETWORK done
2017.05.07 12:58:16 1: Perfmon: possible freeze starting at 12:58:11, delay is 5.846
2017.05.07 12:59:51 4: ZWDongle *** get zwave_usb nodeList
2017.05.07 12:59:51 5: ZWDongle_Write 0002 ()
2017.05.07 12:59:51 5: SW: 01030002fe
2017.05.07 12:59:51 4: ZWDongle_ReadAnswer arg:nodeList regexp:^0102
2017.05.07 12:59:51 5: ACK received, removing 01030002fe from dongle sendstack
2017.05.07 12:59:51 4: ZWDongle_Read zwave_usb: rcvd 010205001dc1010000000000000000000000000000000000000000000000000000000500 (answer SERIAL_API_GET_INIT_DATA), sending ACK
2017.05.07 12:59:51 5: SW: 06
2017.05.07 12:59:51 4: ZWDongle_ReadAnswer for nodeList: 010205001dc1010000000000000000000000000000000000000000000000000000000500
2017.05.07 13:02:53 4: ZWDongle *** set zwave_usb addNode on
2017.05.07 13:02:53 5: ZWDongle_Write 004a8118 ()
2017.05.07 13:02:53 5: SW: 0105004a811829
2017.05.07 13:02:53 5: ACK received, removing 0105004a811829 from dongle sendstack
2017.05.07 13:02:53 4: ZWDongle_Read zwave_usb: rcvd 004a18010000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 13:02:53 5: SW: 06
2017.05.07 13:02:53 5: zwave_usb: dispatch 004a18010000
2017.05.07 13:02:53 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:01 ARG:0000 CB:18
2017.05.07 13:02:53 4: zwave_usb ZW_ADD_NODE_TO_NETWORK learnReady
2017.05.07 13:06:12 4: ZWDongle *** set zwave_usb addNode onNw
2017.05.07 13:06:12 5: ZWDongle_Write 004ac119 ()
2017.05.07 13:06:12 5: SW: 0105004ac11968
2017.05.07 13:06:12 5: ACK received, removing 0105004ac11968 from dongle sendstack
2017.05.07 13:06:12 4: ZWDongle_Read zwave_usb: rcvd 004a19070000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 13:06:12 5: SW: 06
2017.05.07 13:06:12 5: zwave_usb: dispatch 004a19070000
2017.05.07 13:06:12 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:07 ARG:0000 CB:19
2017.05.07 13:06:12 4: ZWDongle *** set zwave_usb addNode off
2017.05.07 13:06:12 5: ZWDongle_Write 004a051a ()
2017.05.07 13:06:12 5: SW: 0105004a051aaf
2017.05.07 13:06:12 4: zwave_usb ZW_ADD_NODE_TO_NETWORK failed
2017.05.07 13:06:12 5: ACK received, removing 0105004a051aaf from dongle sendstack
2017.05.07 13:06:12 4: ZWDongle_Read zwave_usb: rcvd 004a1a060000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 13:06:12 5: zwave_usb: dispatch 004a1a060000
2017.05.07 13:06:12 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:06 ARG:0000 CB:1a
2017.05.07 13:06:12 4: zwave_usb ZW_ADD_NODE_TO_NETWORK done
2017.05.07 13:07:07 4: ZWDongle *** set zwave_usb addNode off
2017.05.07 13:07:07 5: ZWDongle_Write 004a051b ()
2017.05.07 13:07:07 5: SW: 0105004a051bae
2017.05.07 13:07:07 5: ACK received, removing 0105004a051bae from dongle sendstack
2017.05.07 13:07:07 4: ZWDongle_Read zwave_usb: rcvd 004a1b060000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 13:07:07 5: SW: 06
2017.05.07 13:07:07 5: zwave_usb: dispatch 004a1b060000
2017.05.07 13:07:07 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:06 ARG:0000 CB:1b
2017.05.07 13:07:07 4: zwave_usb ZW_ADD_NODE_TO_NETWORK done
2017.05.07 13:07:38 4: ZWDongle *** set zwave_usb addNode onNw
2017.05.07 13:07:38 5: ZWDongle_Write 004ac11c ()
2017.05.07 13:07:38 5: SW: 0105004ac11c6d
2017.05.07 13:07:39 5: ACK received, removing 0105004ac11c6d from dongle sendstack
2017.05.07 13:07:39 4: ZWDongle_Read zwave_usb: rcvd 004a1c010000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 13:07:39 5: SW: 06
2017.05.07 13:07:39 5: zwave_usb: dispatch 004a1c010000
2017.05.07 13:07:39 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:01 ARG:0000 CB:1c
2017.05.07 13:07:39 4: zwave_usb ZW_ADD_NODE_TO_NETWORK learnReady
2017.05.07 13:08:29 4: ZWDongle *** set zwave_usb addNode off
2017.05.07 13:08:29 5: ZWDongle_Write 004a051d ()
2017.05.07 13:08:29 5: SW: 0105004a051da8
2017.05.07 13:08:29 5: ACK received, removing 0105004a051da8 from dongle sendstack
2017.05.07 13:08:29 4: ZWDongle_Read zwave_usb: rcvd 004a1d060000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 13:08:29 5: SW: 06
2017.05.07 13:08:29 5: zwave_usb: dispatch 004a1d060000
2017.05.07 13:08:29 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:06 ARG:0000 CB:1d
2017.05.07 13:08:29 4: zwave_usb ZW_ADD_NODE_TO_NETWORK done
2017.05.07 13:08:39 4: ZWDongle *** set zwave_usb addNode on
2017.05.07 13:08:39 5: ZWDongle_Write 004a811e ()
2017.05.07 13:08:39 5: SW: 0105004a811e2f
2017.05.07 13:08:39 5: ACK received, removing 0105004a811e2f from dongle sendstack
2017.05.07 13:08:39 4: ZWDongle_Read zwave_usb: rcvd 004a1e010000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 13:08:39 5: SW: 06
2017.05.07 13:08:39 5: zwave_usb: dispatch 004a1e010000
2017.05.07 13:08:39 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:01 ARG:0000 CB:1e
2017.05.07 13:08:39 4: zwave_usb ZW_ADD_NODE_TO_NETWORK learnReady
2017.05.07 13:20:23 4: ZWDongle *** set zwave_usb addNode on
2017.05.07 13:20:23 5: ZWDongle_Write 004a811f ()
2017.05.07 13:20:23 5: SW: 0105004a811f2e
2017.05.07 13:20:23 5: ACK received, removing 0105004a811f2e from dongle sendstack
2017.05.07 13:20:23 4: ZWDongle_Read zwave_usb: rcvd 004a1f070000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 13:20:23 5: SW: 06
2017.05.07 13:20:23 5: zwave_usb: dispatch 004a1f070000
2017.05.07 13:20:23 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:07 ARG:0000 CB:1f
2017.05.07 13:20:23 4: ZWDongle *** set zwave_usb addNode off
2017.05.07 13:20:23 5: ZWDongle_Write 004a0520 ()
2017.05.07 13:20:23 5: SW: 0105004a052095
2017.05.07 13:20:23 4: zwave_usb ZW_ADD_NODE_TO_NETWORK failed
2017.05.07 13:20:23 5: ACK received, removing 0105004a052095 from dongle sendstack
2017.05.07 13:20:23 4: ZWDongle_Read zwave_usb: rcvd 004a20060000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 13:20:23 5: zwave_usb: dispatch 004a20060000
2017.05.07 13:20:23 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:06 ARG:0000 CB:20
2017.05.07 13:20:23 4: zwave_usb ZW_ADD_NODE_TO_NETWORK done
Ist der Strip überhaupt mit dem ZWave-USB-Stick den ich habe (Aeotec AEOEZW090-C Aeon Labs) kompatibel?
Mache ich etwas falsch?
Ist der Strip defekt?
Vielen Dank schon mal an die Helfenden!!
Gruß, Joachim
FHEM PI3 Buster (Test)
krikan
#1
Zitat von: MadMax-FHEM am 07 Mai 2017, 13:50:05
Ist der Strip überhaupt mit dem ZWave-USB-Stick den ich habe kompatibel?
Ja.
Der Stick "hängt" (ZW_ADD_NODE_TO_NETWORK failed) anscheinend. Bitte mal stromlos machen und ggfs. Server neu starten.
Bitte dann nochmals so probieren. https://wiki.fhem.de/wiki/Z-Wave#Hinzuf.C3.BCgen_eines_neuen_Z-Wave_Ger.C3.A4ts_.2F_Inklusion
(Da Du nicht schreibst, welches Youtube-Video, kann man nicht beurteilen, ob das dort gezeigte Vorgehen korrekt ist)
Evtl. ist der Strip auch schon inkludiert. Hast Du mal nodeList abgerufen?
Etvtl. auch mal Strip reseten, wenn der schon mal irgendwo anders inkludiert war.
Gruß, Christian
MadMax-FHEM
Hallo Christian,
danke schon mal.
Ich werde das gleich mal probieren (wobei ich es eigentlich so gemacht habe [mehrfach] dachte ich) und diesmal vorher fhem mal abschalten und neu starten...
Video, das war das von der Sensative Stripes Tips Seite (nachträgliches includieren).
Sollte ja wohl stimmen ;)
Wie gesagt einen Reset habe ich schon mehrfach versucht aber so wie beschrieben scheint es nicht zu funktionieren:
runder Magnet hin: Leuchten
weg und wieder hin: Leuchten (kommt halt nicht immer [gleich])
und dann beim dritten Mal: mind. 10sec dran lassen und warten bis das Bestätigungsleuchten kommt, kommt aber nicht  :-\
Wenn die Beschreibung stimmt sollte er aber noch nicht angelernt sein, da er (zumindest sieht es so aus) sich im "Demo-Modus" befindet:
eckiger Magnet hin/weg 2x kurz Blinken...
Kann/soll ich noch etwas zusätzlich einstellen?
Auf was filtere ich im EventMonitor?
(Wobei bei den letzten paar Versuchen ist nichts gekommen was ich mit dem Einbinden in Verbindung bringen würde)
Ja get nodeList habe ich gemacht (mehrfach), du meinst schon beim zwave_usb!?
Da kommen aber nur meine 3 Rauchmelder...
Danke, Joachim
MadMax-FHEM
Hallo Christian,
so, stromlos gemacht und von vorne...
Hier die Logausgaben aber irgendwie kommt von dem Strip wohl gar nichts?
2017.05.07 14:27:06 4: ZWDongle *** set zwave_usb addNode on
2017.05.07 14:27:06 5: ZWDongle_Write 004a8101 ()
2017.05.07 14:27:06 5: SW: 0105004a810130
2017.05.07 14:27:06 5: ACK received, removing 0105004a810130 from dongle sendstack
2017.05.07 14:27:06 4: ZWDongle_Read zwave_usb: rcvd 004a01010000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 14:27:06 5: SW: 06
2017.05.07 14:27:06 5: zwave_usb: dispatch 004a01010000
2017.05.07 14:27:06 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:01 ARG:0000 CB:01
2017.05.07 14:27:06 4: zwave_usb ZW_ADD_NODE_TO_NETWORK learnReady
2017.05.07 14:30:49 4: ZWDongle *** set zwave_usb addNode off
2017.05.07 14:30:49 5: ZWDongle_Write 004a0502 ()
2017.05.07 14:30:49 5: SW: 0105004a0502b7
2017.05.07 14:30:50 5: ACK received, removing 0105004a0502b7 from dongle sendstack
2017.05.07 14:30:50 4: ZWDongle_Read zwave_usb: rcvd 004a02060000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 14:30:50 5: SW: 06
2017.05.07 14:30:50 5: zwave_usb: dispatch 004a02060000
2017.05.07 14:30:50 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:06 ARG:0000 CB:02
2017.05.07 14:30:50 4: zwave_usb ZW_ADD_NODE_TO_NETWORK done
2017.05.07 14:30:57 4: ZWDongle *** get zwave_usb nodeList
2017.05.07 14:30:57 5: ZWDongle_Write 0002 ()
2017.05.07 14:30:57 5: SW: 01030002fe
2017.05.07 14:30:57 4: ZWDongle_ReadAnswer arg:nodeList regexp:^0102
2017.05.07 14:30:57 5: ACK received, removing 01030002fe from dongle sendstack
2017.05.07 14:30:57 4: ZWDongle_Read zwave_usb: rcvd 010205001dc1010000000000000000000000000000000000000000000000000000000500 (answer SERIAL_API_GET_INIT_DATA), sending ACK
2017.05.07 14:30:57 5: SW: 06
2017.05.07 14:30:57 4: ZWDongle_ReadAnswer for nodeList: 010205001dc1010000000000000000000000000000000000000000000000000000000500
2017.05.07 14:31:07 4: ZWDongle *** set zwave_usb addNode on
2017.05.07 14:31:07 5: ZWDongle_Write 004a8103 ()
2017.05.07 14:31:07 5: SW: 0105004a810332
2017.05.07 14:31:07 5: ACK received, removing 0105004a810332 from dongle sendstack
2017.05.07 14:31:07 4: ZWDongle_Read zwave_usb: rcvd 004a03010000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 14:31:07 5: SW: 06
2017.05.07 14:31:07 5: zwave_usb: dispatch 004a03010000
2017.05.07 14:31:07 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:01 ARG:0000 CB:03
2017.05.07 14:31:08 4: zwave_usb ZW_ADD_NODE_TO_NETWORK learnReady
Auch den Versuch ihn zu resetten habe ich mehrfach unternommen aber so wie es beschrieben ist funktioniert es (bei mir) nicht.
Ein paar Versuche mache ich noch und schaue, ob ich bzgl. des Strip noch was finde...
...ansonsten geht der erst mal zurück, vielleicht hat er ja einen Treffer...
Vielen Dank auf jeden Fall für die Hilfe!
Zumindest weiß ich, dass er prinzipiell funktionieren kann/sollte, also mit meinen Komponenten...
Gruß, Joachim
MadMax-FHEM
Noch ein paar Versuche:
2017.05.07 14:42:59 4: ZWDongle *** set zwave_usb addNode off
2017.05.07 14:42:59 5: ZWDongle_Write 004a0504 ()
2017.05.07 14:42:59 5: SW: 0105004a0504b1
2017.05.07 14:42:59 5: ACK received, removing 0105004a0504b1 from dongle sendstack
2017.05.07 14:42:59 4: ZWDongle_Read zwave_usb: rcvd 004a04060000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 14:42:59 5: SW: 06
2017.05.07 14:42:59 5: zwave_usb: dispatch 004a04060000
2017.05.07 14:42:59 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:06 ARG:0000 CB:04
2017.05.07 14:42:59 4: zwave_usb ZW_ADD_NODE_TO_NETWORK done
2017.05.07 14:43:06 4: ZWDongle *** set zwave_usb addNode onNw
2017.05.07 14:43:06 5: ZWDongle_Write 004ac105 ()
2017.05.07 14:43:06 5: SW: 0105004ac10574
2017.05.07 14:43:06 5: ACK received, removing 0105004ac10574 from dongle sendstack
2017.05.07 14:43:06 4: ZWDongle_Read zwave_usb: rcvd 004a05010000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 14:43:06 5: SW: 06
2017.05.07 14:43:06 5: zwave_usb: dispatch 004a05010000
2017.05.07 14:43:06 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:01 ARG:0000 CB:05
2017.05.07 14:43:06 4: zwave_usb ZW_ADD_NODE_TO_NETWORK learnReady
2017.05.07 14:43:41 4: ZWDongle *** get zwave_usb nodeList
2017.05.07 14:43:41 5: ZWDongle_Write 0002 ()
2017.05.07 14:43:41 5: SW: 01030002fe
2017.05.07 14:43:41 4: ZWDongle_ReadAnswer arg:nodeList regexp:^0102
2017.05.07 14:43:41 5: ACK received, removing 01030002fe from dongle sendstack
2017.05.07 14:43:41 4: ZWDongle_Read zwave_usb: rcvd 010205001dc1010000000000000000000000000000000000000000000000000000000500 (answer SERIAL_API_GET_INIT_DATA), sending ACK
2017.05.07 14:43:41 5: SW: 06
2017.05.07 14:43:41 4: ZWDongle_ReadAnswer for nodeList: 010205001dc1010000000000000000000000000000000000000000000000000000000500
2017.05.07 14:44:20 4: ZWDongle *** get zwave_usb neighborList
2017.05.07 14:45:32 4: ZWDongle *** set zwave_usb addNode off
2017.05.07 14:45:32 5: ZWDongle_Write 004a0506 ()
2017.05.07 14:45:32 5: SW: 0105004a0506b3
2017.05.07 14:45:32 5: ACK received, removing 0105004a0506b3 from dongle sendstack
2017.05.07 14:45:32 4: ZWDongle_Read zwave_usb: rcvd 004a06060000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 14:45:32 5: SW: 06
2017.05.07 14:45:32 5: zwave_usb: dispatch 004a06060000
2017.05.07 14:45:32 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:06 ARG:0000 CB:06
2017.05.07 14:45:32 4: zwave_usb ZW_ADD_NODE_TO_NETWORK done
2017.05.07 14:45:46 4: ZWDongle *** set zwave_usb addNode on
2017.05.07 14:45:46 5: ZWDongle_Write 004a8107 ()
2017.05.07 14:45:46 5: SW: 0105004a810736
2017.05.07 14:45:46 5: ACK received, removing 0105004a810736 from dongle sendstack
2017.05.07 14:45:46 4: ZWDongle_Read zwave_usb: rcvd 004a07010000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 14:45:46 5: SW: 06
2017.05.07 14:45:46 5: zwave_usb: dispatch 004a07010000
2017.05.07 14:45:46 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:01 ARG:0000 CB:07
2017.05.07 14:45:46 4: zwave_usb ZW_ADD_NODE_TO_NETWORK learnReady
2017.05.07 14:47:09 4: ZWDongle *** set zwave_usb addNode off
2017.05.07 14:47:09 5: ZWDongle_Write 004a0508 ()
2017.05.07 14:47:09 5: SW: 0105004a0508bd
2017.05.07 14:47:09 5: ACK received, removing 0105004a0508bd from dongle sendstack
2017.05.07 14:47:09 4: ZWDongle_Read zwave_usb: rcvd 004a08060000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 14:47:09 5: SW: 06
2017.05.07 14:47:09 5: zwave_usb: dispatch 004a08060000
2017.05.07 14:47:09 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:06 ARG:0000 CB:08
2017.05.07 14:47:09 4: zwave_usb ZW_ADD_NODE_TO_NETWORK done
2017.05.07 14:47:17 4: ZWDongle *** get zwave_usb nodeList
2017.05.07 14:47:17 5: ZWDongle_Write 0002 ()
2017.05.07 14:47:17 5: SW: 01030002fe
2017.05.07 14:47:17 4: ZWDongle_ReadAnswer arg:nodeList regexp:^0102
2017.05.07 14:47:17 5: ACK received, removing 01030002fe from dongle sendstack
2017.05.07 14:47:17 4: ZWDongle_Read zwave_usb: rcvd 010205001dc1010000000000000000000000000000000000000000000000000000000500 (answer SERIAL_API_GET_INIT_DATA), sending ACK
2017.05.07 14:47:17 5: SW: 06
2017.05.07 14:47:17 4: ZWDongle_ReadAnswer for nodeList: 010205001dc1010000000000000000000000000000000000000000000000000000000500
Aber bei get nodeList bekomme ich weiterhin nur meine 3 Rauchmelder...
Ich denke ich werde den Strip mal zurückschicken...
...außer du sagst es liegt nicht am Strip, dann versuche ich noch was...
Danke, Joachim
krikan
Ich sehe keinerlei Nachrichten vom Strip, sondern nur Nachrichten von ZWDongle. Die sehen für mich ok aus. Darum würde ich noch mal mit dem Strip experimentieren.
Persönlich hatte ich beim Inkludieren der Strips keine Probleme, aber es gab hier schon mal einen Problembericht, das Ding in den Inklusionsmodus zu bringen, den ich aber gerade nicht finde (richtige Seite vom Strip, richtiger Magnet,..?).
Hast Du auch mal mit der beiliegenden Anleitung verglichen, ob die mit dem Video übereinstimmt? Nicht, dass es verschiedene Varianten gibt.
MadMax-FHEM
Gut, dann bin ich wenigstens nicht blind, konnte vom Strip auch nichts sehen...
Ich suche mal noch ein wenig.
Bei einer ersten Suche habe ich aber nur 2 Threads zu den Strips gefunden und einer verweist nach 2-3 Einträgen auf den anderen, also nur einer.
Dort (so wie ich es beim durchlesen sehen konnte) ging es aber um Dinge nach dem Einbinden, daher hab ich mir das (noch) nicht näher angeschaut...
Muss ja erst mal so weit kommen ;)
Steht in der Anleitung genau so drin...
Aber ich spiele noch ein wenig rum, habe aber wenig Hoffnung und denke ich werde den erst mal umtauschen...
Aber schon mal beruhigt, dass von fhem-Seite alles passt.
Vielen Dank!!
Schönen Sonntag noch, Joachim
krikan
Habe gerade noch mal die Inklusion eines Strips probiert. Bei mir geht der Strip direkt in den Auto-Inklusionsmodus, d.h. am Strip muss ich nichts machen, sondern nur das Gateway muss im Inklusionsmodus sein.
MadMax-FHEM
Hallo Christian,
also ich hab auch noch mal ein wenig rumprobiert aber immer noch ohne Erfolg.
Hier noch ein paar Versuche:
2017.05.07 16:54:41 4: ZWDongle *** set zwave_usb addNode on
2017.05.07 16:54:41 5: ZWDongle_Write 004a8109 ()
2017.05.07 16:54:41 5: SW: 0105004a810938
2017.05.07 16:54:41 5: ACK received, removing 0105004a810938 from dongle sendstack
2017.05.07 16:54:41 4: ZWDongle_Read zwave_usb: rcvd 004a09010000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 16:54:41 5: SW: 06
2017.05.07 16:54:41 5: zwave_usb: dispatch 004a09010000
2017.05.07 16:54:41 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:01 ARG:0000 CB:09
2017.05.07 16:54:41 4: zwave_usb ZW_ADD_NODE_TO_NETWORK learnReady
2017.05.07 16:59:32 4: ZWDongle *** get zwave_usb nodeList
2017.05.07 16:59:32 5: ZWDongle_Write 0002 ()
2017.05.07 16:59:32 5: SW: 01030002fe
2017.05.07 16:59:32 4: ZWDongle_ReadAnswer arg:nodeList regexp:^0102
2017.05.07 16:59:32 5: ACK received, removing 01030002fe from dongle sendstack
2017.05.07 16:59:33 4: ZWDongle_Read zwave_usb: rcvd 010205001dc1010000000000000000000000000000000000000000000000000000000500 (answer SERIAL_API_GET_INIT_DATA), sending ACK
2017.05.07 16:59:33 5: SW: 06
2017.05.07 16:59:33 4: ZWDongle_ReadAnswer for nodeList: 010205001dc1010000000000000000000000000000000000000000000000000000000500
2017.05.07 17:00:00 1: my_CheckZWaveDevices     ActDevice: Rauchmelder_Eingang       WakeupInterval: 21600
2017.05.07 17:00:00 1: my_CheckZWaveDevices     ActDevice: Rauchmelder_FabiZi       WakeupInterval: 21600
2017.05.07 17:00:00 1: my_CheckZWaveDevices     ActDevice: Rauchmelder_SchlaZi       WakeupInterval: 21600
2017.05.07 17:01:13 4: ZWDongle *** set zwave_usb addNode off
2017.05.07 17:01:13 5: ZWDongle_Write 004a050a ()
2017.05.07 17:01:13 5: SW: 0105004a050abf
2017.05.07 17:01:13 5: ACK received, removing 0105004a050abf from dongle sendstack
2017.05.07 17:01:13 4: ZWDongle_Read zwave_usb: rcvd 004a0a060000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 17:01:13 5: SW: 06
2017.05.07 17:01:13 5: zwave_usb: dispatch 004a0a060000
2017.05.07 17:01:13 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:06 ARG:0000 CB:0a
2017.05.07 17:01:13 4: zwave_usb ZW_ADD_NODE_TO_NETWORK done
2017.05.07 17:01:20 4: ZWDongle *** set zwave_usb addNode on
2017.05.07 17:01:20 5: ZWDongle_Write 004a810b ()
2017.05.07 17:01:20 5: SW: 0105004a810b3a
2017.05.07 17:01:20 5: ACK received, removing 0105004a810b3a from dongle sendstack
2017.05.07 17:01:20 4: ZWDongle_Read zwave_usb: rcvd 004a0b010000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 17:01:20 5: SW: 06
2017.05.07 17:01:20 5: zwave_usb: dispatch 004a0b010000
2017.05.07 17:01:20 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:01 ARG:0000 CB:0b
2017.05.07 17:01:20 4: zwave_usb ZW_ADD_NODE_TO_NETWORK learnReady
2017.05.07 17:02:05 4: ZWDongle *** get zwave_usb nodeList
2017.05.07 17:02:05 5: ZWDongle_Write 0002 ()
2017.05.07 17:02:05 5: SW: 01030002fe
2017.05.07 17:02:05 4: ZWDongle_ReadAnswer arg:nodeList regexp:^0102
2017.05.07 17:02:05 5: ACK received, removing 01030002fe from dongle sendstack
2017.05.07 17:02:05 4: ZWDongle_Read zwave_usb: rcvd 010205001dc1010000000000000000000000000000000000000000000000000000000500 (answer SERIAL_API_GET_INIT_DATA), sending ACK
2017.05.07 17:02:05 5: SW: 06
2017.05.07 17:02:05 4: ZWDongle_ReadAnswer for nodeList: 010205001dc1010000000000000000000000000000000000000000000000000000000500
2017.05.07 17:06:20 4: ZWDongle *** set zwave_usb addNode off
2017.05.07 17:06:20 5: ZWDongle_Write 004a050c ()
2017.05.07 17:06:20 5: SW: 0105004a050cb9
2017.05.07 17:06:20 5: ACK received, removing 0105004a050cb9 from dongle sendstack
2017.05.07 17:06:20 4: ZWDongle_Read zwave_usb: rcvd 004a0c060000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 17:06:20 5: SW: 06
2017.05.07 17:06:20 5: zwave_usb: dispatch 004a0c060000
2017.05.07 17:06:20 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:06 ARG:0000 CB:0c
2017.05.07 17:06:20 4: zwave_usb ZW_ADD_NODE_TO_NETWORK done
2017.05.07 17:06:26 4: ZWDongle *** set zwave_usb addNode on
2017.05.07 17:06:26 5: ZWDongle_Write 004a810d ()
2017.05.07 17:06:26 5: SW: 0105004a810d3c
2017.05.07 17:06:26 5: ACK received, removing 0105004a810d3c from dongle sendstack
2017.05.07 17:06:26 4: ZWDongle_Read zwave_usb: rcvd 004a0d010000 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2017.05.07 17:06:26 5: SW: 06
2017.05.07 17:06:26 5: zwave_usb: dispatch 004a0d010000
2017.05.07 17:06:26 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:01 ARG:0000 CB:0d
2017.05.07 17:06:26 4: zwave_usb ZW_ADD_NODE_TO_NETWORK learnReady
2017.05.07 17:07:58 4: ZWDongle *** get zwave_usb nodeList
2017.05.07 17:07:58 5: ZWDongle_Write 0002 ()
2017.05.07 17:07:58 5: SW: 01030002fe
2017.05.07 17:07:58 4: ZWDongle_ReadAnswer arg:nodeList regexp:^0102
2017.05.07 17:07:58 5: ACK received, removing 01030002fe from dongle sendstack
2017.05.07 17:07:58 4: ZWDongle_Read zwave_usb: rcvd 010205001dc1010000000000000000000000000000000000000000000000000000000500 (answer SERIAL_API_GET_INIT_DATA), sending ACK
2017.05.07 17:07:58 5: SW: 06
2017.05.07 17:07:58 4: ZWDongle_ReadAnswer for nodeList: 010205001dc1010000000000000000000000000000000000000000000000000000000500
Jep, so sollte es sein.
Er blinkt auch als ob er im Inklusionsmodus ist.
Zumindest interpretiere ich das so...
Auch die Prozedur für nachträgliche Inclusion (wake-up) funktioniert nicht, ebenso wenig der Reset.
Ich denke er ist defekt...
Danke noch mal für die Hilfe und das Ausprobieren!
Ich schicke ihn zurück...
Gruß, Joachim
MadMax-FHEM
So, umgetauscht und siehe da:
klick, klack, kluck und er ist includiert...
Da war der andere wohl tatsächlich defekt...
Trotzdem oder gerade deswegen: DANKE!!
Gruß, Joachim
