[gelöst] Sonoff Dual mit MQTT (Arendt)
Begonnen von slowfinger, 17 Mai 2017, 21:16:08
slowfinger
ich finde meinen Knoten leider nicht. Habe einen Sonoff Dual mit der Tasmota 5.0.5 geflasht.
fhem.cfg
define Sonoff_ch1 MQTT_DEVICE
attr Sonoff_ch1 IODev myBroker
attr Sonoff_ch1 alias Sonoff CH1
attr Sonoff_ch1 devStateIcon on:rc_GREEN:off off:rc_RED:on
attr Sonoff_ch1 eventMap ON:on OFF:off ON:Ein OFF:Aus
attr Sonoff_ch1 icon light_ceiling
attr Sonoff_ch1 publishSet ON OFF cmnd/Rolladen_Kueche/POWER1/set
attr Sonoff_ch1 room MQTT
attr Sonoff_ch1 stateFormat Power
attr Sonoff_ch1 subscribeReading_Power tele/Rolladen_Kueche/POWER1
attr Sonoff_ch1 subscribeReading_state cmnd/Rolladen_Kueche/POWER1/set
attr Sonoff_ch1 webCmd Ein:Aus
mqtt-log (schalten über WEB-Oberfläche)
stat/Rolladen_Kueche/RESULT {"POWER1":"ON"}
Client mosqsub/12640-raspberry received PUBLISH (d0, q0, r0, m0, 'stat/Rolladen_Kueche/POWER1', ... (2 bytes))
stat/Rolladen_Kueche/POWER1 ON
Client mosqsub/12640-raspberry received PUBLISH (d0, q0, r0, m0, 'stat/Rolladen_Kueche/RESULT', ... (16 bytes))
stat/Rolladen_Kueche/RESULT {"POWER1":"OFF"}
Client mosqsub/12640-raspberry received PUBLISH (d0, q0, r0, m0, 'stat/Rolladen_Kueche/POWER1', ... (3 bytes))
stat/Rolladen_Kueche/POWER1 OFF
Client mosqsub/12819-raspberry received PUBLISH (d0, q0, r0, m0, 'tele/Rolladen_Kueche/STATE', ... (164 bytes))
tele/Rolladen_Kueche/STATE {"Time":"2017-05-17T20:13:58", "Uptime":1, "Vcc":3.056, "POWER1":"OFF", "POWER2":"OFF", "Wifi":{"AP":1, "SSID":"xxx", "RSSI":xx, "APMac":"xxx"}}
mqtt-log (schalten über fhem)
cmnd/Rolladen_Kueche/POWER1/set ON
Client mosqsub/12726-raspberry received PUBLISH (d0, q0, r0, m0, 'stat/Rolladen_Kueche/RESULT', ... (21 bytes))
stat/Rolladen_Kueche/RESULT {"Command":"Unknown"}
Client mosqsub/12726-raspberry received PUBLISH (d0, q0, r0, m0, 'cmnd/Rolladen_Kueche/POWER1/set', ... (3 bytes))
cmnd/Rolladen_Kueche/POWER1/set OFF
Wäre Euch sehr dankbar wenn sich jemand erbarmen würde.
Gruss
Slowfinger
fl_Indigo
aktuelles tasmota kennt kein /set
probier mal
so funzt es zumindest bei mir...
das hier kannst dir eigentlich sparen
den state vom sonoff kriegst eh in
geliefert...
slowfinger
SUPER & vielen Dank !!! Klappt nun tadellos.
Dann ist das Wiki leider nicht ganz up2date.
Gruss
slowfinger
fl_Indigo
