8-fach-Taster 55er
Begonnen von Marekh, 24 Mai 2017, 19:06:02
rakete123
#45
habe den Schalter jetzt auch.
   CFGFN
   DEF        f7aac8f1 29
   IODev      zwstick1
   LASTInputDev zwstick1
   MSGCNT     16
   NAME       ZWave_SWITCH_REMOTE_29
   NR         12032
   STATE      wakeupInterval 86400 1
   TYPE       ZWave
   ZWaveSubDevice no
   endpointChildren ZWave_Node_29.1
   homeId     f7aac8f1
   isWakeUp   1
   lastMsgSent 1503430944.61751
   nodeIdHex  1d
   zwstick1_MSGCNT 16
   zwstick1_RAWMSG 0004001d08720503300003a305
   zwstick1_TIME 2017-08-22 21:42:22
     2017-08-22 21:42:22   CMD             ZW_APPLICATION_UPDATE
     2017-08-22 21:41:52   assocGroupCmdList_1 BATTERY:03 CENTRAL_SCENE:03 DEVICE_RESET_LOCALLY:01
     2017-08-22 21:37:55   assocGroup_1    Max 5 Nodes zwstick1
     2017-08-22 21:37:56   assocGroup_2    Max 5 Nodes
     2017-08-22 21:37:56   assocGroup_3    Max 5 Nodes
     2017-08-22 21:37:56   assocGroup_4    Max 5 Nodes
     2017-08-22 21:37:56   assocGroup_5    Max 5 Nodes
     2017-08-22 21:37:55   assocGroups     5
     2017-08-22 21:33:34   battery         100 %
     2017-08-22 21:42:22   model           0x0330 0x0003 0xa305
     2017-08-22 21:42:22   modelId         0330-0003-a305
     2017-08-22 21:33:11   state           wakeupInterval 86400 1
     2017-08-22 21:42:24   timeToAck       0.057
     2017-08-22 21:42:24   transmit        OK
   IODev      zwstick1
   classes    ZWAVEPLUS_INFO ASSOCIATION MULTI_CHANNEL_ASSOCIATION CONFIGURATION CENTRAL_SCENE ASSOCIATION_GRP_INFO TRANSPORT_SERVICE VERSION MANUFACTURER_SPECIFIC DEVICE_RESET_LOCALLY POWERLEVEL BATTERY SECURITY SECURITY_S2 WAKE_UP SUPERVISION MARK SWITCH_MULTILEVEL
   room       ZWave
   vclasses   ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 BATTERY:1 CENTRAL_SCENE:3 CONFIGURATION:1 DEVICE_RESET_LOCALLY:1 MANUFACTURER_SPECIFIC:2 MULTI_CHANNEL_ASSOCIATION:3 POWERLEVEL:1 SECURITY:0 SECURITY_S2:0 SUPERVISION:1 SWITCH_MULTILEVEL:0 TRANSPORT_SERVICE:2 VERSION:2 WAKE_UP:2 ZWAVEPLUS_INFO:2
set ZWave_SWITCH_REMOTE_29 mcaAdd 2 0 1 1
set ZWave_SWITCH_REMOTE_29 mcaAdd 3 0 1 2
set ZWave_SWITCH_REMOTE_29 mcaAdd 4 0 1 3
set ZWave_SWITCH_REMOTE_29 mcaAdd 5 0 1 4
Funktioniert prima, die Woche versuche ich nochmal eine direkte Association.
Zwave: ZMEEUZB1 (Fibaro, Aeotec, diverse)
Zigbee: Conbee (HUE, Xiaomi, osram)
Homematic: HM-MOD-RPI-PCB + diverse HM-CC-RT-DN
Sonstiges: Harmony, Android, Netatmo, Jabber (talk2fhem)
https://resize2fs.de
rakete123
#46
Komisch ist das ich die Events beim Schalten immer zwei mal bekomme:
Drücke auf ON bei Taste 1:
2017-08-24_08:03:01 ZWave_Node_29.1 basicSet: 255
Ist das normal?
Anbei nochmal ein aktuellen list:
   CFGFN
   DEF        f7aac8f1 29
   IODev      zwstick1
   MSGCNT     88
   NR         12032
   TYPE       ZWave
   ZWaveSubDevice no
   endpointChildren ZWave_Node_29.1,ZWave_Node_29.2,ZWave_Node_29.3,ZWave_Node_29.4
   homeId     f7aac8f1
   isWakeUp   1
   lastMsgSent 1503554497.32027
   nodeIdHex  1d
   zwstick1_MSGCNT 88
   zwstick1_RAWMSG 0004001d03800310
   zwstick1_TIME 2017-08-24 08:01:35
     2017-08-24 08:01:35   CMD             ZW_APPLICATION_UPDATE
     2017-08-24 08:01:17   assocGroup_1    Max 5 Nodes zwstick1
     2017-08-24 08:01:17   assocGroup_2    Max 5 Nodes
     2017-08-24 08:01:17   assocGroup_3    Max 5 Nodes
     2017-08-24 08:01:17   assocGroup_4    Max 5 Nodes
     2017-08-24 08:01:18   assocGroup_5    Max 5 Nodes
     2017-08-24 08:01:16   assocGroups     5
     2017-08-24 08:01:35   battery         16 %
     2017-08-24 08:00:59   mcaGroups       5
     2017-08-24 08:00:59   mca_1           Max 5 Nodes zwstick1
     2017-08-24 08:00:59   mca_2           Max 5 Nodes zwstick1:1
     2017-08-24 08:01:00   mca_3           Max 5 Nodes zwstick1:2
     2017-08-24 08:01:00   mca_4           Max 5 Nodes zwstick1:3
     2017-08-24 08:01:00   mca_5           Max 5 Nodes zwstick1:4
     2017-08-24 08:01:37   timeToAck       0.053
     2017-08-24 08:01:37   transmit        OK
     2017-08-24 07:28:03   wakeup          notification
   IODev      zwstick1
   room       ZWave
Und beim dimmen bekomme ich sowas:
2017-08-24_08:04:09 ZWave_Node_29.1 swmBeginUp
2017-08-24_08:04:09 ZWave_Node_29.1 reportedState: swmBeginUp
2017-08-24_08:04:10 ZWave_Node_29.1 swmEnd
2017-08-24_08:04:10 ZWave_Node_29.1 reportedState: swmEnd
Wie mache ich denn damit einen kontinuierlichen DimUp, wenn nur ein Event für Begin und eines für End kommt.
Da brauche ich ja irgendwie eine Schleife, muss ich da selber was bauen in Perl oder gibts da schon was fertiges in FHEM?
Danke!
Edit: Direkte Association z.b. mit Fibaro Aktoren geht!  Z.b. beim Fibaro Aktoren den zweiten Ausgang: mcaadd 1 0 11 2
11 ist bei mir die nodeID vom Fibaro Aktor.
Wolfgang Hochweller
Ich habe so einen Taster hier, aber irgendwie kann ich nix damit anfangen.
Inkludieren geht ohne Problem, das ist aber schon alles.
Jedenfalls scheint ein Tastendruck kein Event zu generieren.
Hat jemand vielleicht mehr Erfolg gehabt ?
Wolfgang Hochweller
Das hilft mir aber jetzt nicht wirklich weiter .....
Wie gesagt, es geht um oben erwaehnten 8-fach-Taster.
Das Problem ist auch einfach beschrieben :
Nach dem Inkludieren geht nichts mehr, heisst :
Das Gerate wird korrekt angelegt, aber ein Tastendruck erzeugt kein Reading irgendeiner Art.
ZitatDas Problem ist auch einfach beschrieben :
Mag sein, aber wir sind nicht der Hersteller, nicht (immer) Hellseher, so ein Geraet haben wir auch nicht alle, und deswegen brauchen wir die Hilfe, was im o.g. Link beschrieben ist.
Wolfgang Hochweller
Das verstehe ich ja auch.
Aber die Frage ist doch ganz einfach :
Kann ich nach der Einbindung bei einem Tastendruck ein Reading erwarten oder nicht ?
Da es ja offenbar einige gibt, die bei ihren Versuchen mit diesem Taster schon weiter gekommen sind, koennte es ja sein,
dass jemand mir diese Frage beantworten kann.
Versuche deshalb, weil, wie schon vorher beschrieben, die Anleitung offenbar nichts damit zu tun hat,
was FHEM nachher auflistet, sprich , grob fehlerhaft ist.
Ist aber auch egal, Geraet ist aus letzterem Grund schon auf dem Rueckweg.
Ohne Anleitung muss ich mir die Funktionen 'ertasten', das muss ich nicht haben.
Im uebrigen sind saemtliche Informationen im Thread schon gelistet worden( Fabikant, Listing mit classes, etc )
gamauf
Ein Listing des Gerätes aus DEINER FHEM-Installation würde mir z.B. zeigen ob bei DIR die Assotiationen zum Controller richtig gesetzt sind,  was eine mögliche Ursache für fehlende Events bei Tastendruck sein könnte. Das Listing von rakete123 zeigt mir nur, dass bei IHM die Assotiationen gesetzt sind, was man auch an SEINEM Log-Auszug mit den, bei Tastendruck generierten, Events sieht.
Schon deine Frage:
iritiert mich, da im vorherigen Post rakete123 die Events, die er bei Tastendruck bekommt, gepostet hat; deine Frage also schon beantwortet ist!
Deine Frage hätte vielmehr lauten sollen "Was ist an meiner Konfiguration falsch?"
Und damit man die Frage auch beantworten kann hättest du auch die Konfiguration (List des Gerätes) posten sollen.
Mir drängt sich der Eindruck auf, dass du nicht bereit bist ein bisschen Zeit in die Lösung DEINES Problemes zu investieren - ich bin es jetzt auch nicht mehr!
Wolfgang Hochweller
Schon ok, hat sich erledigt.
Ein Geraet mit einer derartigen miserablen Dokumentation kommt mir nicht ins Haus.
Denn : Entweder :
Die Beschreibung ist grob unvollstaendig
oder
FHEM denkt sich bei seinem Listing etwas aus.
Letzteres glaube ich natuerlich nicht, also gehe ich davon aus, dass die Funktionen, die FHEM auflistet, in der Dokumentation deswegen nicht erscheinen, weil sie nicht zuverlaessig implementiert sind.
Sollte hingegen die Dokumentation nur 'schlampig' sein, erwarte ich vom Rest auch nichts gutes.
gamauf
OK
wo has du denn das teil gekauft?
hab es bisher nur bei alibaba im 10er-pack gefunden.
Wolfgang Hochweller
#55
Gibt er hier in Norwegen im Versandhandel.
Ich bin nahe dran zu glauben, dass das Teil hier ein Fake ist.
Eigentlich schade, denn es koennte genau das tun, was ich gerne haette.
Zur Zeite benutze ich dafuer einen Nodon Octan Remote, ist aber ungleich komplizierter und als Wandschalter
schlecht zu bedienen.
gamauf
würde das teil gerne ausprobieren, aber nicht gleich 10 davon auf einmal!
scooty
Kannst auch dort wie in diesem Beitrag verlinkt bestellen.
Andreas
Fhem auf Gigabyte Brix
CUL V3 HM / CUL V3 MAX / MaxCube aFW Homematic&MAX / ZWave.me ZME_UZB1 / SDuino 433 / Velux KLF200
Homematic / MAX / Logitech Hub / ZWave / Wifi LED / div. 433 Temperatursensoren / pywws WH10880 / IO Homecontrol
DerBodo
Einfach bei Ali nach einem Sample fragen.
Hatte ich auch einmal gemacht und konnte dann einfach die gewünschte Menge nennen (bei mir waren es dann 2).
Die Antwort kam schnell und der Preis war eigentlich auch in Ordnung, ich hatte dann nicht bestellt da ich zu diesem Zeitpunkt keinen Anwendungsfall hatte.
https://forum.fhem.de/index.php/topic,72330.msg655603/topicseen.html#msg655603
gamauf
Danke allen für die Hinweise!
