KEYFOB keine Neighbours
Begonnen von MarkusAutomaticus, 16 Dezember 2017, 18:33:31
MarkusAutomaticus
ist es normal, dass die Fibaro Fernbedienung KEYFOB in der zWave neighbour map keinerlei Verknüpfungen zu anderen Devices hat?
Oder ist er noch nicht richtig konfiguriert?
Hier sein List:
   DEF        fd1cb8e9 29
   IMAGE      /fhem/deviceimages/zwave/ZC10-16125346
   IODev      ZWDongle_0
   LASTInputDev ZWDongle_0
   MSGCNT     67
   NAME       JarvisRemote
   NR         389
   STATE      wakeupInterval 86400 1
   TYPE       ZWave
   ZWDongle_0_MSGCNT 67
   ZWDongle_0_RAWMSG 0004001d055b034d8005
   ZWDongle_0_TIME 2017-12-16 18:09:29
   ZWaveSubDevice no
   cmdsPending 1
   homeId     fd1cb8e9
   isWakeUp   1
   lastMsgSent 1513372086.2392
   nodeIdHex  1d
     2017-12-15 21:34:19   assocGroup_1    Max 1 Nodes ZWDongle_0
     2017-12-15 21:34:19   assocGroup_10   Max 5 Nodes
     2017-12-15 21:34:19   assocGroup_11   Max 5 Nodes
     2017-12-15 21:34:20   assocGroup_12   Max 5 Nodes
     2017-12-15 21:34:20   assocGroup_13   Max 5 Nodes
     2017-12-15 21:34:19   assocGroup_2    Max 5 Nodes
     2017-12-15 21:34:19   assocGroup_3    Max 5 Nodes
     2017-12-15 21:34:19   assocGroup_4    Max 5 Nodes
     2017-12-15 21:34:19   assocGroup_5    Max 5 Nodes
     2017-12-15 21:34:19   assocGroup_6    Max 5 Nodes
     2017-12-15 21:34:19   assocGroup_7    Max 5 Nodes
     2017-12-15 21:34:19   assocGroup_8    Max 5 Nodes
     2017-12-15 21:34:19   assocGroup_9    Max 5 Nodes
     2017-12-15 21:34:19   assocGroups     13
     2017-12-15 22:21:06   battery         87 %
     2017-12-16 18:09:29   cSceneSet       5
     2017-12-15 21:29:48   model           FIBARO System FGKF601 Keyfob
     2017-12-15 21:29:48   modelConfig     fibaro/fgkf601.xml
     2017-12-15 21:29:48   modelId         010f-1001-1000
     2017-12-15 21:33:05   neighborUpdate  failed
     2017-12-15 21:26:40   state           wakeupInterval 86400 1
     2017-12-15 22:08:06   timeToAck       0.025
     2017-12-15 22:08:06   transmit        OK
     2017-12-15 22:08:04   wakeup          notification
   SendStack:
     set:481d04
   IODev      ZWDongle_0
   classes    ZWAVEPLUS_INFO ASSOCIATION ASSOCIATION_GRP_INFO BATTERY CENTRAL_SCENE CONFIGURATION CRC_16_ENCAP DEVICE_RESET_LOCALLY FIRMWARE_UPDATE_MD MANUFACTURER_SPECIFIC MULTI_CHANNEL_ASSOCIATION POWERLEVEL SECURITY VERSION WAKE_UP PROTECTION APPLICATION_STATUS
   icon       it_remote
   room       Arbeitszimmer,System,ZWave
   vclasses   APPLICATION_STATUS:1 ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 BATTERY:1 CENTRAL_SCENE:3 CONFIGURATION:1 CRC_16_ENCAP:1 DEVICE_RESET_LOCALLY:1 FIRMWARE_UPDATE_MD:3 MANUFACTURER_SPECIFIC:2 MULTI_CHANNEL_ASSOCIATION:3 POWERLEVEL:1 PROTECTION:2 SECURITY:1 VERSION:2 WAKE_UP:2 ZWAVEPLUS_INFO:2
Und noch eine Frage:
Wenn ich auf das Quadrat drücke, erscheint folgendes Event:
2017-12-16 18:21:31 ZWave JarvisRemote cSceneSet: 1
Wie müsste ein Notify damit aussehen?
Das hier tut nicht:
Define n_remoteWandlampe notify JarvisRemote cSceneSet: 1 set ArbeitszimmerWandlampe toggle
Markus
FHEM 5.8 |intel NUC Core i3: Ubuntu 22.04 | z-Wave: Aeon Labs USB Stick | Jeelink (v3c): LaCrosse-Sensoren | DuoFern Stick: Rademacher Gurtwickler | Philips Hue Bridge | CUNX: HomeMatic, EnOcean-Pigator
ZitatWie müsste ein Notify damit aussehen?
Wenn einem Regexp noch nicht gelaeufig ist, dann sollte man die notifies aus dem Event-Monitor anlegen.
Wg. den Nachbarn: ich vermute, es wurde beim KEYFOB noch kein neighborUpdate abgesetzt.
Meine ZWave-Fernbedienung hat Nachbarn.
MarkusAutomaticus
Stimmt!
Mir war so, als hätten die abgesetzten NeighborUpdates funktioniert, aber vermutlich war die Reihenfolge von OK drücken und und remote aufwecken falsch.
Dass man sich direkt aus dem Event ein Notify basteln lassen kann, wusste ich noch gar nicht.
Damit hat jetzt jedenfalls auch das geklappt.
Vielen Dank!
