Autor Thema: Help with FS20 SU Mains switch  (Gelesen 696 mal)
Offline Ingvar
  • New Member
« am: 10 Juli 2017, 17:08:29 »
Hi, I just bought an FS20 SU-3 mains switch. Now I need to program it. The manual keeps referring to the need for a remote control, which for this project is unnecessary.
Is there anyway I can set it up directly from FHEM?
(the computer interface is the FHZ1000PC)
Offline rudolfkoenig
  • Administrator
Antw:Help with FS20 SU Mains switch
« Antwort #1 am: 10 Juli 2017, 17:12:19 »
Define an FS20 device in FHEM with an arbitrary homeId and buttonId, like "define su3 FS20 1234 56", change the su3 in programming mode, and then send a command via FHEM like "set su3 off".
Offline Ingvar
  • New Member
« Antwort #2 am: 11 Juli 2017, 15:29:39 »
Thank you! That worked perfectly.
Offline Ingvar
  • New Member
« Antwort #3 am: 13 Juli 2017, 14:03:38 »
If I decide to get a remote control for my FS20 SU-3, is the FS20 S8-3 the one I should get?
https://www.elv.de/fs20-fernbedienung-fs20s8-3-fertiggeraet.html
