Help with FS20 SU Mains switch
Begonnen von Ingvar, 10 Juli 2017, 17:08:29
Ingvar
Hi, I just bought an FS20 SU-3 mains switch. Now I need to program it. The manual keeps referring to the need for a remote control, which for this project is unnecessary.
Is there anyway I can set it up directly from FHEM?
(the computer interface is the FHZ1000PC)
rudolfkoenig
Define an FS20 device in FHEM with an arbitrary homeId and buttonId, like "define su3 FS20 1234 56", change the su3 in programming mode, and then send a command via FHEM like "set su3 off".
Ingvar
Thank you! That worked perfectly.
Ingvar
If I decide to get a remote control for my FS20 SU-3, is the FS20 S8-3 the one I should get?
https://www.elv.de/fs20-fernbedienung-fs20s8-3-fertiggeraet.html
