Sonos: Neue Version vom 14.7.2017
Begonnen von Reinerlein, 14 Juli 2017, 12:58:27
essera
hier mal meine Versionsübersicht:
fhem.pl                               14828 2017-08-01 10:01:20Z rudolfkoenig
95_Alarm.pm                           13049 2017-01-12 20:17:00Z phenning
No Id found for 99_Asksin_HM_LC_Sw1PBU_FM_CustomFW.pm
90_at.pm                              14519 2017-06-15 19:01:24Z rudolfkoenig
98_autocreate.pm                      14530 2017-06-17 19:38:39Z rudolfkoenig
98_backup.pm                          11984 2016-08-19 12:47:50Z rudolfkoenig
00_CUL.pm                             14119 2017-04-27 11:41:18Z rudolfkoenig
10_CUL_HM.pm                          14797 2017-07-26 19:28:08Z martinp876
98_DOIF.pm                            14790 2017-07-26 10:27:41Z Damian
98_dummy.pm                           12700 2016-12-02 16:49:42Z rudolfkoenig
91_eventTypes.pm                      11984 2016-08-19 12:47:50Z rudolfkoenig
01_FHEMWEB.pm                         14827 2017-08-01 08:16:06Z rudolfkoenig
92_FileLog.pm                         14206 2017-05-06 11:42:54Z rudolfkoenig
# $Id: 01_fronthem.pm 21 2015-02-13 20:25:09Z. herrmannj $
# $Id: 31_fronthemDevice.pm 21 2015-02-13 20:25:09Z. herrmannj $
98_HMinfo.pm                          14608 2017-07-01 04:53:04Z martinp876
02_HTTPSRV.pm                         13976 2017-04-12 13:35:44Z neubert
30_HUEBridge.pm                       13710 2017-03-15 12:17:49Z justme1968
31_HUEDevice.pm                       14256 2017-05-12 13:35:40Z justme1968
98_IF.pm                              12944 2017-01-03 12:56:17Z Damian
10_IT.pm                              13196 2017-01-22 20:27:22Z bjoernh
91_notify.pm                          13630 2017-03-06 21:05:08Z rudolfkoenig
33_readingsGroup.pm                   14044 2017-04-20 07:48:44Z justme1968
00_SONOS.pm                           14715 2017-07-14 10:39:57Z Reinerlein
21_SONOSPLAYER.pm                     14715 2017-07-14 10:39:57Z Reinerlein
99_SUNRISE_EL.pm                      12485 2016-11-01 15:18:51Z rudolfkoenig
98_SVG.pm                             14655 2017-07-06 09:20:24Z rudolfkoenig
50_TelegramBot.pm                     14613 2017-07-01 10:18:33Z viegener
98_telnet.pm                          14453 2017-06-02 17:37:59Z rudolfkoenig
98_update.pm                          14768 2017-07-23 07:40:10Z rudolfkoenig
99_Utils.pm                           13259 2017-01-28 17:39:39Z rudolfkoenig
98_version.pm                         14745 2017-07-18 20:56:01Z markusbloch
98_weblink.pm                         13558 2017-03-01 09:42:51Z rudolfkoenig
32_WifiLight.pm                       14607 2017-06-30 21:16:09Z herrmannj
Blocking.pm                           14734 2017-07-17 09:07:13Z rudolfkoenig
Color.pm                              11159 2016-03-30 16:08:06Z justme1968
Common.pm                             10759 2016-02-07 20:00:12Z rleins
ControlPoint.pm                       14715 2017-07-14 10:39:57Z Reinerlein
DevIo.pm                              13865 2017-04-01 09:10:44Z rudolfkoenig
# $Id: fhconverter.pm 21 2015-02-13 20:25:09Z. herrmannj $
# $Id: fhwebsocket.pm 20 2015-02-03 16:14:14Z. herrmannj $
HMConfig.pm                           14631 2017-07-02 18:14:59Z martinp876
HttpUtils.pm                          14654 2017-07-06 08:17:38Z rudolfkoenig
Info.pm                                  28 2008-11-09 01:08:44Z dsully
myUtilsTemplate.pm                     7570 2015-01-14 18:31:44Z rudolfkoenig
RTypes.pm                             10476 2016-01-12 21:03:33Z borisneubert
SetExtensions.pm                      12935 2017-01-02 19:51:46Z rudolfkoenig
TcpServerUtils.pm                     14603 2017-06-30 09:38:41Z rudolfkoenig
fhemweb.js                 14827 2017-08-01 08:16:06Z rudolfkoenig
fhemweb_colorpicker.js     13580 2017-03-02 13:03:29Z justme1968
fhemweb_fbcalllist.js      13629 2017-03-06 20:50:43Z markusbloch
fhemweb_readingsGroup.js   13580 2017-03-02 13:03:29Z justme1968
fhemweb_readingsHistory.js 13580 2017-03-02 13:03:29Z justme1968
fhemweb_sortable.js        13629 2017-03-06 20:50:43Z markusbloch
fhemweb_uzsu.js            13580 2017-03-02 13:03:29Z justme1968
Ich habe am 2.8. das letzte Gesamt Update gemacht , da war das letzte Sonos Update dabei.
Für mich sieht es so aus, als wenn die Nachrichten in der "abgespeckten" Form im Event Monitor auftauchen seit dem ich alles auf Verbose "0" gesetzt habe.
Es kommen im Fhem Log auch keine Nachrichten von Sonos an seit diesem Zeitpunkt.
Nur immer diese Logeintrage im Event Monitor.
VG,
Andreas.
Nobby1805
#31
Nachfrage: kommen bei dir diese Meldungen im Logfile oder im Event-Monitor?
Edit: Hast du bei den Sonos-Devices Event.... Attribute gesetzt?
FHEM-Featurelevel: 6.2   (fhem.pl:28227/2023-11-29) auf Windows 10 Pro mit Strawberry Perl 5.32.1.1-32bit
TabletUI: 2.7.15
IO: 2xHMLAN(0.965)|HMUSB2(0.967)
essera
#32
die Meldungen tauchen im Event Monitor auf.
Die einzigen Attribute die ich im Sonos Device gesetzt habe sind Verbose auf 0 und Room auf Sonos.
Nachtrag: Ich hatte noch einen anderen Fehler und musst ein Paket nachinstallieren:
sudo apt-get install libswitch-perl  (Komisch - dachte das hätte ich längst installiert....)
Danach habe ich einen Restart durchgeführt.
Nun tauchen die Meldungen nicht mehr auf...... (2017-08-07 00:52:27 SONOS Sonos LastProcessAnswer: 2017-08-07 00:52:27)
Ich habe da keine Erklärung zu. (Es sei denn das Verbose 0 ist von dem Programmteil erst nach dem Restart erkannt worden.)
Ich denke ich kann dann das Thema erst mal wieder schließen.
Danke für den Versuch der Hilfe.
VG,
Andreas.
Nobby1805
die Meldung kommt aus dem Event-System und nicht aus dem Log, darum wirken m.E. die Verbose-Werte nicht ... ausgelöst wird das Event aus meiner Sicht durch den Update des Zeitstempels mit readingsSingleUpdate ... warum das allerdings (nur) bei dir kommt ist mir nicht klar
TabletUI: 2.7.15
Nobby1805
jetzt kommt es bei mir auch ... man muss nur den Event-Monitor "ganz normal" aufrufen ;) aber da kommen dann auch jede Menge andere Events
2017-08-09 10:32:07.272 CUL_HM Innen2_Climate desired-temp: 17.0
2017-08-09 10:32:07.272 CUL_HM Innen2_Climate humidity: 61
2017-08-09 10:32:07.272 CUL_HM Innen2_Climate measured-temp: 22.3
2017-08-09 10:32:07.272 CUL_HM Innen2_Climate T: 22.3 desired: 17.0
2017-08-09 10:32:11.750 SONOSPLAYER Sonos_Schlafzimmer currentTrackPositionSimulated: 0:00:52
2017-08-09 10:32:11.750 SONOSPLAYER Sonos_Schlafzimmer currentTrackPositionSimulatedSec: 52.6952829360962
2017-08-09 10:32:11.750 SONOSPLAYER Sonos_Schlafzimmer currentTrackPositionSimulatedPercent: 23.4
2017-08-09 10:32:12.296 SONOSPLAYER Sonos_Schlafzimmer LastActionResult: Pause: Success!
2017-08-09 10:32:12.301 SONOS Sonos LastProcessAnswer: 2017-08-09 10:32:12
2017-08-09 10:32:12.697 SONOS Sonos LastProcessAnswer: 2017-08-09 10:32:12
2017-08-09 10:32:12.795 SONOSPLAYER Sonos_Schlafzimmer transportState: PAUSED_PLAYBACK
2017-08-09 10:32:12.795 SONOSPLAYER Sonos_Schlafzimmer currentTrackPosition: 0:00:53
2017-08-09 10:32:12.795 SONOSPLAYER Sonos_Schlafzimmer currentTrackPositionSec: 53
2017-08-09 10:32:12.795 SONOSPLAYER Sonos_Schlafzimmer infoSummarize2: PAUSED_PLAYBACK => (Deep Purple) 'Smoke On Water' vom Album 'Einzeltitel'
TabletUI: 2.7.15
Spartacus
#35
habe seit längerer Zeit ein fhem update gemacht. dabei wurde auch das Sonos-Modul aktualisiert.
Zuerst bekam ich einen Java Fehler: "Uncaught SyntaxError: Unexpected token", den ich mit "attr WEB confirmJSError 0" unterdrücke.
Allerdings hat sich das Aussehen im Web Interface drastisch verändert. ICh bekomme nun eine Art Player angezeigt, der das System extrem langsam macht.
Wie kann ich das wieder abschalten?
Christian.
essera
@nobby
Beim "normalen" Aufruf des Event Monitors sind gestern die Meldungen ja eben nicht mehr gekommen. (Sonst immer exakt im 30s Rhytmus)
Ich sehe nun nur noch die Events die für mich da rein gehören....
essera
@nobby
Als wenn ich es gewusst hätte... :-(
Heute mache ich den Event Monitor wieder an und was muss ich sehen:
2017-08-10 19:34:31 SONOS Sonos LastProcessAnswer: 2017-08-10 19:34:31
2017-08-10 19:35:02 SONOS Sonos LastProcessAnswer: 2017-08-10 19:35:02
2017-08-10 19:35:32 SONOS Sonos LastProcessAnswer: 2017-08-10 19:35:32
Verzweiflung macht sich breit.
Wie kann ich das nur abschalten ??
Nobby1805
Komisch, dass sich das Verhalten ändert ohne das du etwas an der Konfiguration geändert hast  ::)
Mit den Events kenne ich mich leider nicht aus ... ist das nicht normal, dass ein Event erzeugt wird  wenn sich ein Reading ändert?
TabletUI: 2.7.15
l2r
hi,
bei mir habe ich mehrere SONOS-Devices im Einsatz. 2 Davon sind nicht immer erreichbar, da sie durch einen Schalter stromlos geschaltet werden.
wenn die Player nicht erreichbar sind, dann erhalte ich Stündlich folgende Fehlermeldung im Log:
Renewal of subscription failed with error: 500 Can't connect to 192.168.1.95:1400 at ./FHEM/00_SONOS.pm line 4085 thread 1
Laut WIKI kann ich das Vermeiden indem ich das SONOS-Device (also nicht den Player) auf disable stelle. Das hat aber zur Folge, dass ich die anderen Player nicht mehr steuern oder abfragen kann.
Gibt es da eine Lösung?
gruß Michael
Wissen ist Macht.
Ich weiß nix.
Macht nix.
awel
#40
Hallo allerseits,
irgendwie ist in meiner Sonos-Installation noch immer der Wurm drin: Es läuft maximal eine Woche, dann gibt es Fehlermeldungen (s.u.), im Extremfall hängt fhem auf dem Raspberry.
Hier die letzten Fehlermeldungen:
2017.08.14 13:00:04 3: dwd_getalerts return value: Keine Warnmeldung für die gesuchte Region vorhanden.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2509, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2512, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2514, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2516, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2518, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2520, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2522, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2528, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2535, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2539, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2541, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2543, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2546, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2549, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2556, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2562, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2568, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2574, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2590, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2628, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2634, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2649, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2653, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2676, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2682, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2721, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2743, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2752, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2761, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2770, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2779, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2788, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2797, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2833, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2847, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2856, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2876, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2896, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2916, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2925, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2934, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2938, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2942, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2946, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2950, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2954, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2973, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 2984, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3005, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3027, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3048, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3070, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3084, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3115, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3415, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3436, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3458, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3509, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3562, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3614, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3692, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3816, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3891, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3897, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3903, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3913, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3929, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3935, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3939, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3945, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3951, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 3955, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 4011, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 4037, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 4077, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 4082, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 4299, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 4311, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 4339, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 4348, <$client> line 8.
Use of uninitialized value $workType in pattern match (m//) at ./FHEM/00_SONOS.pm line 4357, <$client> line 8.
Use of uninitialized value $workType in string eq at ./FHEM/00_SONOS.pm line 4448, <$client> line 8.
Use of uninitialized value $workType in ucfirst at ./FHEM/00_SONOS.pm line 4451, <$client> line 8.
Use of uninitialized value $udn in concatenation (.) or string at ./FHEM/00_SONOS.pm line 5634, <$client> line 8.
2017.08.14 13:01:52 1: PERL WARNING: Deep recursion on subroutine "main::SONOS_getSonosPlayerByUDN" at ./FHEM/00_SONOS.pm line 10002.
2017.08.14 13:01:52 1: PERL WARNING: Deep recursion on subroutine "main::SONOS_Log" at ./FHEM/00_SONOS.pm line 9753.
Wenn Fehlermeldungen auftauchen, erscheinen sie immer direkt nach einem Aufruf des GDS-Wetter-Moduls - das kann natürlich auch Zufall sein (siehe auch hier schon).
Htop zeigt häufig auch mehr als 4 SONOS-Threads wie der angehängte Screenshot zeigt.
Bin für jede Hilfe dankbar,
Gruß Achim
drhirn
Würde mich auch interessieren. Das müllt nämlich ordentlich das Logfile zu und ich finde die wahren Probleme nicht mehr.
Danke!
juemuc
bei mir erzeugt ein
fhem("set Sonos_Buero Speak 10 /
          de | Hier_steht_ein_File.mp3 | ")}
folgende Fehlermeldung:
ZitatUse of uninitialized value $text in substitution (s///) at ./FHEM/00_SONOS.pm line 4365.
2017.08.21 21:31:49 1: SONOS1: Da keine Endzeit ermittelt werden konnte, wird kein Restoring durchgeführt werden!
2017.08.21 21:31:50 1: SONOS1: Da keine Endzeit ermittelt werden konnte, wird kein Restoring durchgeführt werden!
Eine Ausgabe erfolgt nicht. Es wird nur angezeigt, dass eine Sprachausgabe erfolgte und als "Sahnehäubchen" wird der Sender gewechselt  >:(
Ich hoffe Reinerlein kommt bald aus dem Urlaub  ::) SonosSpeak hat wohl noch ein paar Macken.
juergen
3x Sonos Play 1, 1x Sonos Arc + Sub, 1 Sonos-One, 1x Sonos Playbar
FB6690 + FB7490 mit 4x Dect 200 und 3 Dect-ULE-Thermostate,  raspberry3B+, HM Funkmodul HM-MOD-RPI-PCB, HM Klingelsensor HM-Sen-DB-PCB, HM (IP) Fensterkontakte und  Amazon Echo Dot,  piVCCU, pi OS (bookworm).
ares
Willst Du einen Text ausgeben (Speak) oder nur eine Datei abspielen?
juemuc
Was ist der Unterschied? In der Datei steht ja mein Text. Unabhängig davon funktioniert auch die direkte Textausgabe bei mir nicht.
Jürgen
