Antw:Help a beginner
Begonnen von mugginsjm, 20 Juli 2017, 10:38:03
mugginsjm
I have an Arduino UNO connected to a CC1101 and it has been working but has now failed. What does it mean when each time I issue a GET CUL ccconf I receive different values for each of the four elements? Is this info coming from the Arduino or from the RF unit.  Also I have tried 4 different Arduino nanos connected to CC1101 and some initialize but then drop out soon after. Any help much appreciated.
RaspiLED
I have the same behaviour when I User 866MHz cc1101 from China with two resistors as voltage dividers. Without they usually work.
Do you still have problems?
Greetings Arnd
