CUL windows to Ubuntu
Begonnen von sdresearch, 26 Juli 2017, 15:08:24
sdresearch
Please excuse my lack of German, and I am new to all of this.
I successfully had my busware USB working in windows downloading information for a FS20 heating system. I am using CUL_v3/ atmega32u4
I want to change over to running on Ubuntu on a Qnap Nas, so I erased the firmware(in Windows)  as I could not get it working on the Nas. So I am reflashing the firmware again but in Ubuntu. However, it will not work :( as it says it cannot see the device
I have some output that may help
admin@ubuntu_1604:~/Downloads/culfw-1.66/Devices/CUL$ lsusb
Bus 002 Device 002: ID 1c05:3074
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 1005:b155 Apacer Technology, Inc.
Bus 001 Device 024: ID 03eb:2ff4 Atmel Corp. atmega32u4 DFU bootloader
Bus 001 Device 002: ID 1c05:2074
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
admin@ubuntu_1604:~/Downloads/culfw-1.66/Devices/CUL$ make usbprogram_v3
dfu-programmer atmega32u4 erase || true
dfu-programmer: no device present.
dfu-programmer atmega32u4 flash CUL_V3.hex
makefile:154: recipe for target 'do_usbprogram' failed
make: *** [do_usbprogram] Error 1
Sorry for the silly questions, and thanks
Zitatadmin@ubuntu_1604:~/Downloads/culfw-1.66/Devices/CUL$ make usbprogram_v3
You have to execute this as root or assign the "right" groups to your user, whatever "right" on your system means.
RaspiLED
you do not have to flash the Firmware again. Just flash it again under Windows and put the USB Stick in your Ubuntu Box.
Warm regards, Arnd
Gesendet von meinem SM-G800F mit Tapatalk
