lepresenced und G-Tags - nach einiger Zeit nur noch absent/unreachable
Begonnen von stiefl, 18 August 2017, 13:00:51
ToKa
Gerne
ps aux|grep [l]epresenced;sudo zgrep "telling hcidump to restart" /var/log/syslog*
root       508  0.7  1.1  38060 11544 ?        Ssl  Apr10  50:39 /usr/bin/perl /usr/sbin/lepresenced --device hci0 --listenaddress 0.0.0.0 --listenport 5333 --loglevel LOG_WARNING
/var/log/syslog:Apr 15 01:23:01 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2', telling hcidump to restart...
/var/log/syslog:Apr 15 01:23:01 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Add Device To White List (0x08|0x0011) plen 7', telling hcidump to restart...
/var/log/syslog:Apr 15 01:23:01 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7', telling hcidump to restart...
/var/log/syslog:Apr 15 01:23:03 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2', telling hcidump to restart...
/var/log/syslog:Apr 15 01:23:03 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Create Connection (0x08|0x000d) plen 25', telling hcidump to restart...
/var/log/syslog:Apr 15 01:23:04 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2', telling hcidump to restart...
/var/log/syslog:Apr 15 01:23:04 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Read Remote Used Features (0x08|0x0016) plen 2', telling hcidump to restart...
/var/log/syslog.4.gz:Apr 11 23:38:31 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2', telling hcidump to restart...
/var/log/syslog.5.gz:Apr 10 01:23:01 starhome lepresenced[28034]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2', telling hcidump to restart...
/var/log/syslog.5.gz:Apr 10 01:23:01 starhome lepresenced[28034]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Add Device To White List (0x08|0x0011) plen 7', telling hcidump to restart...
/var/log/syslog.5.gz:Apr 10 01:23:01 starhome lepresenced[28034]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7', telling hcidump to restart...
/var/log/syslog.5.gz:Apr 10 01:23:01 starhome lepresenced[28034]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Create Connection (0x08|0x000d) plen 25', telling hcidump to restart...
/var/log/syslog.5.gz:Apr 10 01:23:02 starhome lepresenced[28034]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2', telling hcidump to restart...
/var/log/syslog.5.gz:Apr 10 01:23:02 starhome lepresenced[28034]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Read Remote Used Features (0x08|0x0016) plen 2', telling hcidump to restart...
Torsten
RaspberryPi3 mit RaZberry2 und Conbee II
Fibaro: FGWPE/F-101 Switch & FIBARO System FGWPE/F Wall Plug Gen5, FGSD002 Smoke Sensor
EUROtronic: SPIRIT Wall Radiator Thermostat Valve Control
Shelly2.5 Rollladenaktoren
Zipato Bulb 2, Osram und InnrLight
PatrickR
Hi!
Danke für den Logauszug. Zumindest an 3 Tagen hat der letzte Patch aus der 0.91dev zugeschlagen. Da ich den Bug nicht rekonstruieren kann, kann ich natürlich nicht sagen, ob der Neustart der hcidumps tatsächlich nötig war aber zumindest läuft lepresenced durch.
Habe nun im SVN Version 0.92 inkl. neuem DEB-Package committet. Es entspricht funktionell 0.91dev.
Patrick
lepresenced - Tracking von Bluetooth-LE-Tags (Gigaset G-Tag) mittels PRESENCE
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the universe trying to produce bigger and better idiots. So far, the universe is winning." - Rich Cook
ToKa
Hallo Patrick,
heute morgen waren meine beiden G-Tags leider absent. Erst ein Neustart von lepresenced hat geholfen. Anbei das Log und die Ausgaben von hcitool bzw. systemctl:
root       469  0.5  1.1  38056 11912 ?        Ssl  Apr18  23:46 /usr/bin/perl /usr/sbin/lepresenced --device hci0 --listenaddress 0.0.0.0 --listenport 5333 --loglevel LOG_WARNING
/var/log/syslog.1:Apr 20 01:23:00 starhome lepresenced[469]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2', telling hcidump to restart...
/var/log/syslog.1:Apr 20 01:23:00 starhome lepresenced[469]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Add Device To White List (0x08|0x0011) plen 7', telling hcidump to restart...
/var/log/syslog.1:Apr 20 01:23:00 starhome lepresenced[469]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7', telling hcidump to restart...
/var/log/syslog.1:Apr 20 01:23:01 starhome lepresenced[469]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2', telling hcidump to restart...
/var/log/syslog.1:Apr 20 01:23:01 starhome lepresenced[469]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Create Connection (0x08|0x000d) plen 25', telling hcidump to restart...
/var/log/syslog.1:Apr 20 01:23:02 starhome lepresenced[469]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2', telling hcidump to restart...
/var/log/syslog.1:Apr 20 01:23:02 starhome lepresenced[469]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Read Remote Used Features (0x08|0x0016) plen 2', telling hcidump to restart...
/var/log/syslog.1:Apr 20 01:23:05 starhome lepresenced[469]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: Disconnect (0x01|0x0006) plen 3', telling hcidump to restart...
/var/log/syslog.1:Apr 20 01:23:06 starhome lepresenced[469]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Read Remote Used Features (0x08|0x0016) plen 2', telling hcidump to restart...
/var/log/syslog.1:Apr 20 01:23:06 starhome lepresenced[469]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2', telling hcidump to restart...
/var/log/syslog.2.gz:Apr 19 05:20:17 starhome lepresenced[469]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2', telling hcidump to restart...
/var/log/syslog.6.gz:Apr 15 01:23:01 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2', telling hcidump to restart...
/var/log/syslog.6.gz:Apr 15 01:23:01 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Add Device To White List (0x08|0x0011) plen 7', telling hcidump to restart...
/var/log/syslog.6.gz:Apr 15 01:23:01 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7', telling hcidump to restart...
/var/log/syslog.6.gz:Apr 15 01:23:03 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2', telling hcidump to restart...
/var/log/syslog.6.gz:Apr 15 01:23:03 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Create Connection (0x08|0x000d) plen 25', telling hcidump to restart...
/var/log/syslog.6.gz:Apr 15 01:23:04 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2', telling hcidump to restart...
/var/log/syslog.6.gz:Apr 15 01:23:04 starhome lepresenced[508]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: LE Read Remote Used Features (0x08|0x0016) plen 2', telling hcidump to restart...
hcitool dev
Devices:
        hci0    B8:27:EB:A9:23:AA
systemctl status lepresenced
● lepresenced.service - lepresenced
   Loaded: loaded (/lib/systemd/system/lepresenced.service; enabled; vendor preset: enabled)
   Active: active (running) since Sat 2020-04-18 08:55:06 CEST; 2 days ago
  Process: 278 ExecStartPre=/bin/sleep 10 (code=exited, status=0/SUCCESS)
Main PID: 469 (lepresenced)
    Tasks: 5 (limit: 2305)
   Memory: 13.0M
   CGroup: /system.slice/lepresenced.service
           ├─  469 /usr/bin/perl /usr/sbin/lepresenced --device hci0 --listenaddress 0.0.0.0 --listenport 5333 --loglevel LOG_WARNING
           ├─  594 hcidump -i hci0
           └─32132 hcitool -i hci0 lescan --duplicates
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
Beste Grüße
Torsten
PatrickR
Schick bitte mal ein vollständiges Log mit
grep lepresenced /var/log/syslog
Von unterwegs gesendet.
ToKa
Hallo Patrick,
heute morgen leider auch schon wieder der Effekt, dass die G-Tags nicht erreichbar waren. Vielleicht liegt es auch daran, dass in den letzten Tagen mal wieder die Eprom-Software vom PI aktualisiert wurde. Auffällig ist im log, dass auch Fehlermeldungen vom hci Device kommen.
grep lepresenced /var/log/syslog*
/var/log/syslog:Apr 22 07:21:38 starhome lepresenced[8394]: Thread 2 terminated abnormally: Illegal division by zero at /usr/sbin/lepresenced line 280, <$hcidump> line 4314111.
/var/log/syslog:Apr 22 07:21:38 starhome systemd[1]: Stopping lepresenced...
/var/log/syslog:Apr 22 07:21:39 starhome lepresenced[8394]: [tid:1] main::bluetooth_scan_thread: hcitool exited, retrying...
/var/log/syslog:Apr 22 07:21:39 starhome systemd[1]: lepresenced.service: Main process exited, code=exited, status=1/FAILURE
/var/log/syslog:Apr 22 07:21:39 starhome systemd[1]: lepresenced.service: Failed with result 'exit-code'.
/var/log/syslog:Apr 22 07:21:39 starhome systemd[1]: Stopped lepresenced.
/var/log/syslog:Apr 22 07:21:39 starhome systemd[1]: Starting lepresenced...
/var/log/syslog:Apr 22 07:21:49 starhome systemd[1]: Started lepresenced.
/var/log/syslog:Apr 22 07:21:50 starhome lepresenced[26167]: [tid:1] main::bluetooth_scan_thread: Received 'Set scan parameters failed: Input/output error', resetting...
/var/log/syslog:Apr 22 07:21:50 starhome lepresenced[26167]: [tid:1] main::bluetooth_scan_thread: hcitool exited, retrying...
/var/log/syslog.1:Apr 21 07:50:27 starhome systemd[1]: Stopping lepresenced...
/var/log/syslog.1:Apr 21 07:50:27 starhome lepresenced[469]: [tid:1] main::bluetooth_scan_thread: hcitool exited, retrying...
/var/log/syslog.1:Apr 21 07:50:28 starhome lepresenced[469]: Thread 2 terminated abnormally: Illegal division by zero at /usr/sbin/lepresenced line 280, <$hcidump> line 17712378.
/var/log/syslog.1:Apr 21 07:50:29 starhome systemd[1]: lepresenced.service: Main process exited, code=exited, status=1/FAILURE
/var/log/syslog.1:Apr 21 07:50:29 starhome systemd[1]: lepresenced.service: Failed with result 'exit-code'.
/var/log/syslog.1:Apr 21 07:50:29 starhome systemd[1]: Stopped lepresenced.
/var/log/syslog.1:Apr 21 07:50:29 starhome systemd[1]: Starting lepresenced...
/var/log/syslog.1:Apr 21 07:50:39 starhome systemd[1]: Started lepresenced.
grep hci /var/log/syslog
Apr 22 00:46:54 starhome kernel: [316229.323989] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324022] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324071] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324137] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324172] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324205] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324292] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324341] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324398] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324468] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324478] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324532] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324592] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324625] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324656] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324721] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.324866] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.337872] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.337989] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.338039] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.338255] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.338291] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.338325] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.338411] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.338428] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.338508] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.338581] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.338600] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.338661] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.398531] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.398892] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.398909] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399038] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399065] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399084] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399194] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399242] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399265] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399333] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399386] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399443] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399498] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399519] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399567] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399582] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399634] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399701] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399744] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399820] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399839] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399885] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399961] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.399995] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.400033] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.400065] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.498632] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.498653] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.498691] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.498735] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.498750] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.498866] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.498926] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.498958] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.498994] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.499025] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.499067] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.499099] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.499168] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.499210] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.499241] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.499280] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.499316] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.499347] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.499384] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.499414] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.499451] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.499500] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.593922] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.593997] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594052] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594075] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594107] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594152] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594174] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594218] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594253] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594288] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594367] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594414] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594447] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594487] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594540] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594567] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594598] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594638] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594673] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594696] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594737] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594781] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594839] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.594887] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.641540] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.641564] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.641593] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.641631] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.641677] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.641701] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.641746] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.641800] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.641821] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.641866] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.641901] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.641936] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.641970] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.642005] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.642040] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.642079] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.642114] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.642148] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.642188] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.642244] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.642291] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.642326] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.642360] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.642399] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.817875] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.817915] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.817973] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818010] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818033] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818090] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818126] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818160] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818194] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818217] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818262] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818298] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818338] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818372] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818406] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818443] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818478] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818512] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818549] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818585] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818607] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.818652] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.863921] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.863957] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.863973] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864012] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864042] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864118] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864179] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864188] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864219] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864270] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864292] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864352] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864376] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864427] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864450] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864501] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864533] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864570] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864601] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864637] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864670] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864707] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864738] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864776] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864812] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864844] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864879] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:54 starhome kernel: [316229.864916] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.978662] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.978697] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.978764] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.978787] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.978818] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.978864] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.978896] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.978948] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.979027] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.979051] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.979083] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.979125] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.979160] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.979200] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.979236] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.979270] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.979304] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.979339] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.979373] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.979444] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.979460] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316229.979512] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134023] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134051] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134092] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134112] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134259] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134268] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134287] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134355] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134378] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134458] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134507] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134577] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134610] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134642] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134707] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134754] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134778] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134821] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134855] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.134885] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.136995] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.137078] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.137119] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.137244] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.137288] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.137313] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.137378] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.137417] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.137457] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.137505] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.137521] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.137566] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.137637] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.137675] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.137950] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.297857] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.297900] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298002] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298025] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298060] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298115] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298137] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298190] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298212] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298243] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298294] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298316] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298432] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298494] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298533] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298564] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298604] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.298672] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.403964] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.403986] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404024] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404055] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404194] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404239] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404276] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404297] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404358] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404389] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404435] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404467] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404501] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404543] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404574] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404611] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404644] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404680] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404715] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404751] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404783] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404819] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404855] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404890] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.404926] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.417989] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418012] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418085] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418094] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418127] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418214] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418249] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418282] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418332] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418348] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418439] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418462] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418517] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418569] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418600] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418646] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418699] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.418747] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.578680] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.578714] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.578730] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.578768] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.578824] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.578840] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.578917] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.578976] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579008] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579041] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579074] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579110] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579147] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579185] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579223] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579254] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579292] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579329] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579364] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579395] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579431] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579466] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579497] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.579536] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674014] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674040] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674059] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674140] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674197] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674261] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674317] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674373] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674395] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674440] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674472] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674524] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674575] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674629] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674650] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674692] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674725] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674755] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674831] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674865] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674902] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.674949] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.737222] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.737244] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.737378] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.737401] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.737457] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.737513] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.737585] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.737632] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.737663] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.737827] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.737854] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.737922] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.737948] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.737981] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.738048] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.897918] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.897962] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.897999] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.898121] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.898155] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.898209] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.898240] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.898277] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.898309] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.898340] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.898380] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:55 starhome kernel: [316230.898416] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.404449] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.404472] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.404509] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.404543] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.404572] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.404610] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.404647] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.404684] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.404745] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.404785] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.404826] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.404870] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.404887] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.404935] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.405002] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.405042] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.405113] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.405156] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.405200] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.405215] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.405263] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.405296] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.405332] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.405375] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.405414] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.483950] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.483982] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.483997] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.484114] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.484146] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.484189] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.484211] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.484265] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.484286] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.484338] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.484378] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.484409] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.484451] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.484487] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.484523] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.484566] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.484601] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.538742] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.538774] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.538794] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.538860] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.538882] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.538935] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.538956] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.538987] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.539044] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.539076] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.539109] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.539145] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.539176] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.539216] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.539253] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.539292] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.539324] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.539361] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 00:46:56 starhome kernel: [316231.539398] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 01:24:43 starhome kernel: [318498.749997] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 01:24:43 starhome kernel: [318498.750018] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 01:24:43 starhome kernel: [318498.750046] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 01:24:44 starhome kernel: [318499.839065] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 01:24:44 starhome kernel: [318499.839074] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 01:24:44 starhome kernel: [318499.839079] Bluetooth: hci0: Dropping invalid advertising data
Apr 22 01:24:44 starhome kernel: [318499.839095] Bluetooth: hci0: Frame reassembly failed (-84)
Apr 22 01:24:44 starhome kernel: [318499.839117] Bluetooth: hci0: Frame reassembly failed (-84)
Die Uhrzeit 01:24 passt auch zur Uhrzeit des "Verschwindens" der G-Tags in fhem. Erst der Neustart von lepresenced behebt das Problem.
Beste Grüße
Torsten
PatrickR
Hallo Torsten,
Tatsächlich wird die Fehlermeldung auch bei anderen RPi-Nutzern berichtet, die mit der Firmware experimentiert haben, z. B. (aus 2019): https://forum-raspberrypi.de/forum/thread/42416-bluetooth-hci0-frame-reassembly-failed-84/
Die division by zero ist definitiv was, was ich in lepresenced noch fangen werde. Aber da es bislang nie berichtet wurde und der Code schon länger drin ist, gehe ich davon aus, dass die Ursache tiefer liegt (s. o.).
Patrick
ToKa
Zitat von: PatrickR am 22 April 2020, 12:18:12
Hallo Torsten,Tatsächlich wird die Fehlermeldung auch bei anderen RPi-Nutzern berichtet, die mit der Firmware experimentiert haben, z. B. (aus 2019): https://forum-raspberrypi.de/forum/thread/42416-bluetooth-hci0-frame-reassembly-failed-84/
Hallo Patrick,
ja habe ich auch schon gelesen, wobei mein update kein experimentelles über rpi-update war, sondern ganz normal über apt update kam.
Danke schon mal für's fixen der division by zero.
Torsten
Eistee
Der Bluetooth Fehler existiert seit raspbian buster. Hier wurde für den PI4 etwas grundlegendes geändert was dafür sorgt das das Bluetooth vom PI3 nicht mehr richtig funktioniert. Also gibt es zwei mögliche Fehlerbehebungen:
1. Man bleibt bei raspbian strech
2. Man verwendet einen USB Bluetooth Dongel
Gonzo
ich hatte bisher nur local-bluetooth auf dem RPI3 verwendet und wollte jetzt auf lan-bluetooth umsteigen um später auch auf mehreren RPI die Abfragen zu machen.
Dazu habe ich gestern lepresenced-0.92-1.deb installiert und es scheint auch soweit alles zu funktionieren.
Heute vormittag habe ich zusätzlich presenced-rpi-1.4.deb installiert und seitdem habe ich folgende Meldungen im Syslog
pi@fhem:~ $ grep presenced /var/log/syslog
Jul 16 07:05:42 fhem presenced[18460]: Starting Presence Daemon: presenced.
Jul 16 07:08:23 fhem lepresenced[12670]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: Remote Name Request (0x01|0x0019) plen 10', telling hcidump to restart...
Jul 16 07:10:28 fhem lepresenced[12670]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: Remote Name Request (0x01|0x0019) plen 10', telling hcidump to restart...
Jul 16 07:12:34 fhem lepresenced[12670]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: Remote Name Request (0x01|0x0019) plen 10', telling hcidump to restart...
Jul 16 07:14:39 fhem lepresenced[12670]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: Remote Name Request (0x01|0x0019) plen 10', telling hcidump to restart...
Jul 16 07:16:44 fhem lepresenced[12670]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: Remote Name Request (0x01|0x0019) plen 10', telling hcidump to restart...
Jul 16 07:17:48 fhem lepresenced[12670]: [tid:1] main::bluetooth_scan_thread: hcitool exited, retrying...
Jul 16 07:18:49 fhem lepresenced[12670]: [tid:2] main::bluetooth_dump_thread: Received '< HCI Command: Remote Name Request (0x01|0x0019) plen 10', telling hcidump to restart...
Die Fehlermeldungen beginnen nachdem presenced installiert und gestartet wurde, und kommen im 2 Minuten Takt.
Nämlich immer genau dann wenn PRESENCE auf presenced zugreift (define s.u.). Deaktiviere ich das PRESENCE Device in FHEM bekomme ich auch keine Fehlermeldungen.
Wie ist die korrekte Vorgehensweise presenced und lepresenced gleichzeitig laufen zu lassen?
Meine Defines:
   DEF        lan-bluetooth A4:50:46:xxx 127.0.0.1:5111 120
   DeviceName 127.0.0.1:5111
   FD         40
   FUUID      5cf95d5c-f33f-5757-c289-6d40a50c89e81a54
   FVERSION   73_PRESENCE.pm:0.207820/2019-12-19
   INTERVAL_NORMAL 120
   INTERVAL_PRESENT 120
   MODE       lan-bluetooth
   NAME       presHandy
   NOTIFYDEV  global
   NR         243
   NTFY_ORDER 50-presHandy
   PARTIAL
   STATE      disabled
   TYPE       PRESENCE
   DEF        lan-bluetooth EF:D3:15:xxx 127.0.0.1:5333 60
   DeviceName 127.0.0.1:5333
   FD         82
   FUUID      5f0ee13b-f33f-5757-750d-760fe1ea3a9d9616
   INTERVAL_NORMAL 60
   INTERVAL_PRESENT 60
   MODE       lan-bluetooth
   NAME       presSmartBand
   NOTIFYDEV  global
   NR         460
   NTFY_ORDER 50-presSmartBand
   PARTIAL
   STATE      absent
   TYPE       PRESENCE
Danke für jeden Tipp.
mumpitzstuff
Ich bin mir nicht ganz sicher, aber das schliesst sich meines Erachtens gegenseitig aus. Entweder presenced oder lepresenced auf einem Gerät aber nicht beides. Was aber funktioniert ist lepresenced lokal laufen zu lassen und ebventuell auch auf anderen Geräten und alle Informationen über collectord einzusammeln und daraus den Anwesenheitsstatus zu generieren.
Gonzo
Es scheint beides zu laufen, bisher sieht es zumindest so aus als ob beide Geräte (jeweils über presenced und lepresenced) erkannt werden.
Aber ich habe inzwischen noch andere Diskussionen gefunden dass es bei manchen geht und bei anderem nicht, z.B. https://forum.fhem.de/index.php/topic,71479.msg629928.html#msg629928
Die Einträge in syslog irritieren mich halt etwas. Kann man unterdrücken aber ich wollte erst der Ursache auf den Grund gehen.
mumpitzstuff
Lepresenced erfordert immer einen uneingeschränkten Zugriff auf Bluetooth. Wenn etwas anderes dazwischen funkt was ebenfalls darauf zugreift, dann wird lepresenced abgeschossen und startet sich wenn du Glück hast von selbst neu. Es ist absolut reiner Zufall das sowas über längere Zeit funktioniert! Versuch deshalb bitte die Kombination aus lepresenced und collectord zu verwenden, das funktioniert zuverlässig und erspart dir viel Ärger.
dieda
Bei mir läuft LePrensenced ja seit Monaten nicht rund und nur ein Neustart hilf. Das war auf Jessie und auf Buster so. Ne Ursache konnte ich nicht ausmachen. Es läuft kein weiteres Progrämmchen welches Bluetooth nutzt...
Aber, jetzt die Frage: Mit welchem Befehl kann man heraus finden ob irgendwas anderes Bluetooth nutzt?
Komponenten:
Sensoren und Aktoren: FS20, Max!, Zigbee, Zwave
IODev:  Cul1101, MaxLan, ZWAVE, Deconz
Router: KD-Fritte (6360)
Sonstiges: Raspberries,  1x LMS,1 FHEM, 1 x zum Testen,  Logitech-Clients,  Onkyo, SamsungTV, Squeezebox, TabletUIs
mumpitzstuff
Auf dem internen Bluetooth eines Pi? Das macht sehr oft Probleme. Am besten einen externen Adapter für 10€ kaufen, die laufen in der Regel zuverlässiger.
Gonzo
OK, verstanden. Das konnte ich aus dem Wiki nicht genau herauslesen ob beides gleichzeitig funktioniert oder nicht. Und bei einigen scheint es ja trotzdem (irgendwie) zu laufen.
Wenn ich trotzdem beides laufen lassen möchte, ist es dann mit einem externen Bluetooth Dongle möglich? Also z.B. presenced greift auf das interne Bluetooth zu und lepresenced auf den Dongle?
Ich habe momentan normale BT Geräte und BTLE gemischt, sonst müsste ich mich für das eine oder andere entscheiden.
