Fehler nach Installation
Begonnen von miche, 11 September 2017, 18:28:27
miche
ich habe smartvisu nach der Anleitung auf meintechblog installiert.
Jedoch kommt beim Aufruf nicht die Config Page sondern nur eine Seite mit HTML/PHP Code:
Hab ich beim installieren was übersehen?
<?php
* @package     smartVISU
* @author      Martin Gleiß
* @copyright   2012
* @license     GPL [http://www.gnu.de]
* Version of smartVISU
define ('config_version', '2.7');
// get config-variables
require_once 'lib/includes.php';
require_once const_path_system.'functions_twig.php';
// init parameters
$request = array_merge($_GET, $_POST);
// detect page and path
if ($request['page'] == '')
   $request['page'] = config_index;
if (is_file(const_path."pages/".config_pages."/".$request['page'].".html")
      or is_file(const_path."apps/".$request['page'].".html")
      or is_file(const_path."pages/smarthome/".$request['page'].".html")
      or is_file(const_path."pages/base/".$request['page'].".html")
   // init template engine
   require_once const_path.'vendor/Twig/Autoloader.php';
   Twig_Autoloader::register();
   $loader = new Twig_Loader_Filesystem(const_path.'apps');
   if (is_dir(const_path.'pages/'.config_pages))
      $loader->addPath(const_path.'pages/'.config_pages);
   if (dirname($request['page']) != '.')
      $loader->addPath(const_path.'pages/'.config_pages.'/'.dirname($request['page']));
   // add dir if is not directly choosen
   if (config_driver == 'smarthome.py' and config_pages != 'smarthome' and is_dir(const_path."pages/smarthome"))
      $loader->addPath(const_path.'pages/smarthome');
   $loader->addPath(const_path.'pages/base');
   $loader->addPath(const_path.'widgets');
   // init environment
   $twig = new Twig_Environment($loader);
   if (config_cache)
      $twig->setCache(dirname(__FILE__).'/temp');
   foreach ($request as $key => $val)
      if ($key == "page")
         $val = basename(str_replace('.', '_', $val));
      $twig->addGlobal($key, $val);
   $twig->addGlobal('pagepath', dirname($request['page']));
   if (config_design == 'ice')
      $twig->addGlobal('icon1', 'icons/bl/');
      $twig->addGlobal('icon0', 'icons/sw/');
   elseif (config_design == 'greenhornet')
      $twig->addGlobal('icon1', 'icons/gn/');
      $twig->addGlobal('icon0', 'icons/ws/');
   else
      $twig->addGlobal('icon1', 'icons/or/');
   foreach (get_defined_constants() as $key => $val)
      if (substr($key, 0, 6) == 'config')
   $twig->addFilter('_', new Twig_Filter_Function('twig_concat'));
   $twig->addFilter('round', new Twig_Filter_Function('twig_round'));
   $twig->addFilter('bit', new Twig_Filter_Function('twig_bit'));
   $twig->addFilter('substr', new Twig_Filter_Function('twig_substr'));
   $twig->addFilter('smartdate', new Twig_Filter_Function('twig_smartdate'));
   $twig->addFunction('uid', new Twig_Function_Function('twig_uid'));
   $twig->addFunction('once', new Twig_Function_Function('twig_once'));
   $twig->addFunction('isfile', new Twig_Function_Function('twig_isfile'));
   $twig->addFunction('dir', new Twig_Function_Function('twig_dir'));
   $twig->addFunction('docu', new Twig_Function_Function('twig_docu'));
   $twig->addFunction('lang', new Twig_Function_Function('twig_lang'));
   $twig->addFunction('implode', new Twig_Function_Function('twig_implode', array('is_safe' => array('html'))));
   // init lexer comments
   $lexer = new Twig_Lexer($twig, array('tag_comment' => array('/**', '*/')));
   $twig->setLexer($lexer);
   // load template
   try
      $template = $twig->loadTemplate($request['page'].'.html');
      $ret = $template->render(array());
      // try to zip the output
      if ((strpos($_SERVER['HTTP_ACCEPT_ENCODING'], 'gzip') !== false) && (ini_get('zlib.output_compression') !== false))
         header("Content-Encoding: gzip");
         $ret = "\x1f\x8b\x08\x00\x00\x00\x00\x00".substr(gzcompress($ret, 9), 0, -4).pack("V", crc32($ret)).pack("V", strlen($ret));
      echo $ret;
   catch (Exception $e)
      // header("HTTP/1.0 602 smartVISU Template Error");
      echo "<pre>\n";
      echo str_repeat(" ", 71)."smartVISU\n";
      echo str_repeat(" ", 62).date('H:i, d.m').", v".config_version."\n";
      echo str_repeat("-", 80)."\n\n";
      echo "Error accoured in twig-template engine!\n\n";
      echo "error: <b>".$e->getRawMessage()."</b>\n";
      echo "file:  ".$e->getTemplateFile()."\n";
      echo "line:  ".$e->getTemplateLine()."\n\n";
      echo "\n</pre>";
else
   header("HTTP/1.0 404 Not Found");
   echo "<pre>\n";
   echo "Error loading Page '<b>".$request['page']."</b>' !\n\n";
   echo "Check config.php -> 'config_pages' for correct Pages/Project configuration\n";
   echo "or try the <a href='index.php'>index</a> page!\n\n";
   echo "\n</pre>";
dev0
Dann solltest Du auch meintechblog fragen, wenn es nicht funktioniert.
Btw: code tags verwenden.
smai
Du scheinst kein PHP installiert/aktiviert zu haben.
Und weshalb verwendest du eine alte Version der smartVISU?
miche
Halo, vielen Dank!
PHP wurde anscheinend nicht installiert.
Jetzt geht's, Update hab ich auch noch gemacht.
Ich bin ja grad erst am Anfang von Smartvisu weil mein HomeKit seit denn wochenende nicht mehr geht und darum brauch ich eine Alternative!
