Anlernen zweier Aktoren funktioniert nicht Sw1PBU-FM
Begonnen von Bytechanger, 22 September 2017, 14:16:25
LuckyDay
Bytechanger
Also ich habe nun folgendes gemacht:
1) Device resettet
2) log geleert
3) global verbose auf 5
4) vccu hmPairForSec 60
5 ) config Knopf gedrückt (blinkt ziemlich lange)
2017.09.23 14:36:36.817 4: Connection closed for WEB_172.30.90.22_52384: EOF
2017.09.23 14:36:37.075 4: WEB_172.30.90.22_52362 POST /fhem&detail=vccu&dev.setvccu=vccu&fwcsrf=csrf_239928979354596&cmd.setvccu=set&arg.setvccu=hmPairForSec&val.setvccu=60; BUFLEN:0
2017.09.23 14:36:37.076 5: Cmd: >set vccu hmPairForSec 60<
2017.09.23 14:36:37.079 3: CUL_HM set vccu hmPairForSec 60
2017.09.23 14:36:37.333 4: WEB_172.30.90.22_52362 GET /fhem?detail=vccu&fw_id=; BUFLEN:0
2017.09.23 14:36:37.403 4: WEB: /fhem?detail=vccu&fw_id= / RL:7333 / text/html; charset=UTF-8 / Content-Encoding: gzip
2017.09.23 14:36:37.912 4: WEB_172.30.90.22_52362 GET /fhem?cmd=%7BReadingsVal(%22vccu%22%2C%22virtual%22%2C%22%22)%7D&XHR=1&fwcsrf=csrf_239928979354596; BUFLEN:0
2017.09.23 14:36:37.913 5: Cmd: >{ReadingsVal("vccu","virtual","")}<
2017.09.23 14:36:37.914 4: WEB: /fhem?cmd=%7BReadingsVal(%22vccu%22%2C%22virtual%22%2C%22%22)%7D&XHR=1&fwcsrf=csrf_239928979354596 / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2017.09.23 14:36:38.175 4: WEB_172.30.90.22_52385 GET /fhem?XHR=1&inform=type=status;filter=vccu;since=1506170196;fmt=JSON&fw_id=883×tamp=1506170199128; BUFLEN:0
2017.09.23 14:36:38.187 4: WEB_172.30.90.22_52363 GET /fhem?cmd=%7BAttrVal(%22vccu%22%2C%22room%22%2C%22%22)%7D&XHR=1&fwcsrf=csrf_239928979354596; BUFLEN:0
2017.09.23 14:36:38.188 5: Cmd: >{AttrVal("vccu","room","")}<
2017.09.23 14:36:38.189 4: WEB: /fhem?cmd=%7BAttrVal(%22vccu%22%2C%22room%22%2C%22%22)%7D&XHR=1&fwcsrf=csrf_239928979354596 / RL:26 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2017.09.23 14:36:48.268 2: CUL_HM Unknown device HM_5859DC is now defined
2017.09.23 14:36:48.269 5: Starting notify loop for global, 1 event(s), first is UNDEFINED HM_5859DC CUL_HM 5859DC
2017.09.23 14:36:48.269 5: createNotifyHash
2017.09.23 14:36:48.310 5: PRESENCE (AndyPresence) - processing events from global
2017.09.23 14:36:48.311 5: PRESENCE (AnnaPresence) - processing events from global
2017.09.23 14:36:48.319 5: PRESENCE (KerstinPresence) - processing events from global
2017.09.23 14:36:48.321 5: PRESENCE (MajaPresence) - processing events from global
2017.09.23 14:36:48.323 5: PRESENCE (TVPresence) - processing events from global
2017.09.23 14:36:48.324 5: ZE.Batterie: not on any display, ignoring notify
2017.09.23 14:36:48.353 5: End notify loop for global
2017.09.23 14:36:48.357 5: HMLAN/RAW: /E5859DC,0000,3CE3A884,FF,FFC2,0184005859DC0000002800694F45513033363034313110010100
2017.09.23 14:36:48.357 0: HMLAN_Parse: HMLAN1 R:E5859DC   stat:0000 t:3CE3A884 d:FF r:FFC2     m:01 8400 5859DC 000000 2800694F45513033363034313110010100
2017.09.23 14:36:48.359 5: HMLAN1: dispatch A1A0184005859DC0000002800694F45513033363034313110010100::-62:HMLAN1
2017.09.23 14:36:48.360 2: CUL_HM Unknown device HM_5859DC is now defined
2017.09.23 14:36:48.360 5: Starting notify loop for global, 1 event(s), first is UNDEFINED HM_5859DC CUL_HM 5859DC
2017.09.23 14:36:48.361 5: PRESENCE (AndyPresence) - processing events from global
2017.09.23 14:36:48.362 5: PRESENCE (AnnaPresence) - processing events from global
2017.09.23 14:36:48.370 5: PRESENCE (KerstinPresence) - processing events from global
2017.09.23 14:36:48.372 5: PRESENCE (MajaPresence) - processing events from global
2017.09.23 14:36:48.374 5: PRESENCE (TVPresence) - processing events from global
2017.09.23 14:36:48.375 5: ZE.Batterie: not on any display, ignoring notify
2017.09.23 14:36:48.402 5: End notify loop for global
2017.09.23 14:36:53.576 4: <hidden>: HTTP response code 200
2017.09.23 14:36:53.577 4: HttpUtils <hidden>: Got data, length: 23
2017.09.23 14:36:53.577 5: HttpUtils response header:
HTTP/1.1 200 OK
Server: nginx/1.10.1
Date: Sat, 23 Sep 2017 12:37:46 GMT
Content-Type: application/json
Content-Length: 23
Connection: close
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: GET, POST, OPTIONS
Access-Control-Expose-Headers: Content-Length,Content-Type,Date,Server,Connection
Strict-Transport-Security: max-age=31536000; includeSubdomains
2017.09.23 14:36:53.577 5: TelegramBot_Callback Telegram: called from Polling
2017.09.23 14:36:53.578 5: TelegramBot_Callback Telegram: data returned :{"ok":true,"result":[]}:
2017.09.23 14:36:53.578 5: TelegramBot_Deepencode Telegram: encoded a String from :true: to :true:
2017.09.23 14:36:53.578 5: TelegramBot_Deepencode Telegram: found an ARRAY
2017.09.23 14:36:53.579 5: TelegramBot_Deepencode Telegram: found a HASH
2017.09.23 14:36:53.579 5: TelegramBot_Callback Telegram: after encoding
2017.09.23 14:36:53.579 5: TelegramBot_Callback Telegram: polling returned result? 0
2017.09.23 14:36:53.579 5: UpdatePoll Telegram: number of results 0
2017.09.23 14:36:53.580 5: TelegramBot_UpdatePoll Telegram: called
2017.09.23 14:36:53.580 5: TelegramBot_UpdatePoll Telegram: - Initiate non blocking polling - With callback set
2017.09.23 14:36:53.581 5: TelegramBot_readToken: Read Telegram API token from file
2017.09.23 14:36:53.584 4: TelegramBot_UpdatePoll Telegram: initiate polling with nonblockingGet with 120s
2017.09.23 14:36:53.584 4: HttpUtils url=<hidden>
2017.09.23 14:36:53.586 5: IP: api.telegram.org -> 149.154.167.199
2017.09.23 14:36:53.588 5: TelegramBot_UpdatePoll Telegram: - Ende > next polling started
2017.09.23 14:36:53.589 4: TelegramBot_Callback Telegram: resulted in SUCCESS from Polling
2017.09.23 14:36:53.589 5: TelegramBot_Callback Telegram: - Ende > Control back to FHEM
2017.09.23 14:36:53.936 5: HttpUtils request header:
GET /bot201446298:AAFxWvpqw27z0W_70RTfV3kP-DC674OPEFs/getUpdates?offset=0&limit=5&timeout=120 HTTP/1.0
Host: api.telegram.org
agent: TelegramBot/1.0
User-Agent: TelegramBot/1.0
Accept: application/json
Accept-Charset: utf-8
2017.09.23 14:36:56.916 0: HMLAN_Send:  HMLAN1 I:K
2017.09.23 14:36:56.920 5: HMLAN/RAW: /HHM-LAN-IF,03C5,LEQ0640815,2CD8CE,1DA462,3CE3CB2F,001F,02
2017.09.23 14:36:56.921 0: HMLAN_Parse: HMLAN1 V:03C5 sNo:LEQ0640815 d:2CD8CE O:1DA462 t:3CE3CB2F IDcnt:001F L:2 %
2017.09.23 14:37:14.037 4: BlockingCall (FRITZBOX_Readout_Run_Web): created child (955), uses telnetForBlockingFn_1506167519 to connect back
2017.09.23 14:37:14.040 4: FRITZBOX FritzBox: Readout_Start.673 Fork process FRITZBOX_Readout_Run_Web
2017.09.23 14:37:14.060 4: FRITZBOX FritzBox: Readout_Run_Web.1255 Prepare query string for luaQuery.
2017.09.23 14:37:14.061 5: FRITZBOX FritzBox: Web_Query.4573 Request data via API luaQuery.
2017.09.23 14:37:14.783 5: FRITZBOX FritzBox: Web_Query.4581 Response: 200 OK
{"tam":[{"_node":"TAM0","Name":"Anrufbeantworter","Active":"0","Display":"1","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM1","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM2","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM3","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM4","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM5","Name":"Anrufbeantworter","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM6","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM7","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM8","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"},{"_node":"TAM9","Name":"","Active":"0","Display":"0","NumOldMessages":"0","NumNewMessages":"0"}],"wlanListNew":[{"mac":"DC:66:72:81:1D:0D","rssi":"0","speed":"0","_node":"wlanlist0"},{"mac":"E8:AB:FA:8C:DE:11","rssi":"0","speed":"0","_node":"wlanlist1"},{"mac":"74:DA:38:0E:45:DB","rssi":"0","speed":"0","_node":"wlanlist2"},{"mac":"08:EE:8B:A1:CB:3B","rssi":"0","speed":"0","_node":"wlanlist3"},{"mac":"30:19:66:CF:D5:55","rssi":"0","speed":"0","_node":"wlanlist4"},{"mac":"B4:74:43:AA:A1:D5","rssi":"0","speed":"0","_node":"wlanlist5"},{"mac":"56:31:C4:C5:68:54","rssi":"0","speed":"0","_node":"wlanlist6"},{"mac":"C4:50:06:78:8A:E1","rssi":"0","speed":"0","_node":"wlanlist7"},{"mac":"56:31:C4:C5:68:55","rssi":"0","speed":"0","_node":"wlanlist8"},{"mac":"78:F7:BE:C7:91:49","rssi":"0","speed":"0","_node":"wlanlist9"},{"mac":"78:D6:F0:20:3F:D2","rssi":"0","speed":"0","_node":"wlanlist10"},{"mac":"F0:4F:7C:7D:42:FF","rssi":"0","speed":"0","_node":"wlanlist11"},{"mac":"40:A6:D9:2A:EE:AC","rssi":"0","speed":"0","_node":"wlanlist12"},{"mac":"0C:15:39:EA:6D:A1","rssi":"0","speed":"0","_node":"wlanlist13"},{"mac":"08:EE:8B:6F:DB:19","rssi":"0","speed":"0","_node":"wlanlist14"},{"mac":"18:46:17:FB:A4:E3","rssi":"0","speed":"0","_node":"wlanlist15"}],"box_fwUpdate":"0","box_guestWlanRemain":"0","box_cpuTemp":"0","userProfil":"user0","box_wlan_5GHz":"0","TodayBytesReceivedLow":"0","box_moh":"0","box_tr064":"1","lanDeviceNew":[{"mac":"","active":"0","ip":"172.30.90.223","_node":"landevice0","online":"0","name":"AndreasVPN","ethernet":"0","speed":"0","UID":"landevice1884","guest":"0","wlan":"0"},{"mac":"DC:66:72:81:1D:0D","active":"0","ip":"","_node":"landevice1","online":"0","name":"Galaxy-Tab-S2-Andy-localdomain","ethernet":"0","speed":"0","UID":"landevice1889","guest":"0","wlan":"1"},{"mac":"08:EE:8B:6F:DB:19","active":"0","ip":"","_node":"landevice2","online":"0","name":"PC-08-EE-8B-6F-DB-19","ethernet":"0","speed":"0","UID":"landevice1899","guest":"0","wlan":"1"},{"mac":"08:EE:8B:A1:CB:3B","active":"0","ip":"","_node":"landevice3","online":"0","name":"PC-08-EE-8B-A1-CB-3B","ethernet":"0","speed":"0","UID":"landevice1888","guest":"0","wlan":"1"},{"mac":"0C:15:39:EA:6D:A1","active":"0","ip":"","_node":"landevice4","online":"0","name":"PC-0C-15-39-EA-6D-A1","ethernet":"0","speed":"0","UID":"landevice1898","guest":"0","wlan":"1"},{"mac":"F0:9F:C2:11:65:C0","active":"1","ip":"172.30.90.191","_node":"landevice5","online":"0","name":"PC-172-30-90-191","ethernet":"1","speed":"1000","UID":"landevice1874","guest":"0","wlan":"0"},{"mac":"18:46:17:FB:A4:E3","active":"0","ip":"","_node":"landevice6","online":"0","name":"PC-18-46-17-FB-A4-E3","ethernet":"0","speed":"0","UID":"landevice1900","guest":"0","wlan":"1"},{"mac":"30:19:66:CF:D5:55","active":"0","ip":"","_node":"landevice7","online":"0","name":"PC-30-19-66-CF-D5-55","ethernet":"0","speed":"0","UID":"landevice1890","guest":"0","wlan":"1"},{"mac":"40:A6:D9:2A:EE:AC","active":"0","ip":"","_node":"landevice8","online":"0","name":"PC-40-A6-D9-2A-EE-AC","ethernet":"0","speed":"0","UID":"landevice1897","guest":"0","wlan":"1"},{"mac":"56:31:C4:C5:68:54","active":"0","ip":"","_node":"landevice9","online":"0","name":"PC-56-31-C4-C5-68-54","ethernet":"0","speed":"0","UID":"landevice1891","guest":"0","wlan":"1"},{"mac":"56:31:C4:C5:68:55","active":"0","ip":"","_node":"landevice10","online":"0","name":"PC-56-31-C4-C5-68-55","ethernet":"0","speed":"0","UID":"landevice1893","guest":"0","wlan":"1"},{"mac":"74:DA:38:0E:45:DB","active":"0","ip":"","_node":"landevice11","online":"0","name":"PC-74-DA-38-0E-45-DB","ethernet":"0","speed":"0","UID":"landevice1886","guest":"0","wlan":"1"},{"mac":"78:D6:F0:20:3F:D2","active":"0","ip":"","_node":"landevice12","online":"0","name":"PC-78-D6-F0-20-3F-D2","ethernet":"0","speed":"0","UID":"landevice1895","guest":"0","wlan":"1"},{"mac":"78:F7:BE:C7:91:49","active":"0","ip":"","_node":"landevice13","online":"0","name":"PC-78-F7-BE-C7-91-49","ethernet":"0","speed":"0","UID":"landevice1894","guest":"0","wlan":"1"},{"mac":"B4:74:43:AA:A1:D5","active":"0","ip":"","_node":"landevice14","online":"0","name":"PC-B4-74-43-AA-A1-D5","ethernet":"0","speed":"0","UID":"landevice1919","guest":"0","wlan":"1"},{"mac":"C4:50:06:78:8A:E1","active":"0","ip":"","_node":"landevice15","online":"0","name":"PC-C4-50-06-78-8A-E1","ethernet":"0","speed":"0","UID":"landevice1892","guest":"0","wlan":"1"},{"mac":"E8:AB:FA:8C:DE:11","active":"0","ip":"","_node":"landevice16","online":"0","name":"PC-E8-AB-FA-8C-DE-11","ethernet":"0","speed":"0","UID":"landevice1887","guest":"0","wlan":"1"},{"mac":"F0:4F:7C:7D:42:FF","active":"0","ip":"","_node":"landevice17","online":"0","name":"PC-F0-4F-7C-7D-42-FF","ethernet":"0","speed":"0","UID":"landevice1896","guest":"0","wlan":"1"},{"mac":"","active":"0","ip":"172.30.90.224","_node":"landevice18","online":"0","name":"Test","ethernet":"0","speed":"0","UID":"landevice1883","guest":"0","wlan":"0"},{"mac":"9C:C7:A6:0E:56:FF","active":"1","ip":"172.30.90.221","_node":"landevice19","online":"0","name":"fritz.box","ethernet":"0","speed":"0","UID":"landevice1885","guest":"0","wlan":"0"}],"dectUser":[{"Intern":"","Id":"0","IntRingTone":"0","RadioRingID":"0","Name":"","AlarmRingTone0":"","G722RingToneName":"","ImagePath":"","_node":"User0","G722RingTone":""},{"Intern":"610","Id":"1","IntRingTone":"0","RadioRingID":"0","Name":"Haupt","AlarmRingTone0":"","G722RingToneName":"","ImagePath":"","_node":"User1","G722RingTone":""}],"TodayBytesReceivedHigh":"0","init":"","UMTS_enabled":"0","box_ipExtern":"172.30.90.221","userTicket":[{"_node":"ticket0","id":"743238"},{"_node":"ticket1","id":"072019"},{"_node":"ticket2","id":"251257"},{"_node":"ticket3","id":"121769"},{"_node":"ticket4","id":"462880"},{"_node":"ticket5","id":"791204"},{"_node":"ticket6","id":"596034"},{"_node":"ticket7","id":"552389"},{"_node":"ticket8","id":"954291"},{"_node":"ticket9","id":"263778"}],"userProfilNew":[{"_node":"user0","type":"4","name":"(guest)"},{"_node":"user1","type":"3","name":"(default)"}],"GSM_AcT":"","GSM_NetworkState":"0","box_connect":"5","box_fwVersion":"84.06.83","box_dect":"1","alarmClock":[{"_node":"AlarmClock0","Name":"Wecker 1","Active":"0","Weekdays":"255","Number":"1","Time":"0000"},{"_node":"AlarmClock1","Name":"Wecker 2","Active":"0","Weekdays":"255","Number":"1","Time":"0000"},{"_node":"AlarmClock2","Name":"Wecker 3","Active":"0","Weekdays":"255","Number":"1","Time":"0000"}],"box_stdDialPort":"60","radio":[{"_node":"WEBRADIO0","Name":""},{"_node":"WEBRADIO1","Name":""},{"_node":"WEBRADIO2","Name":""},{"_node":"WEBRADIO3","Name":""},{"_node":"WEBRADIO4","Name":""},{"_node":"WEBRADIO5","Name":""},{"_node":"WEBRADIO6","Name":""},{"_node":"WEBRADIO7","Name":""},{"_node":"WEBRADIO8","Name":""},{"_node":"WEBRADIO9","Name":""},{"_node":"WEBRADIO10","Name":""},{"_node":"WEBRADIO11","Name":""},{"_node":"WEBRADIO12","Name":""},{"_node":"WEBRADIO13","Name":""},{"_node":"WEBRADIO14","Name":""},{"_node":"WEBRADIO15","Name":""},{"_node":"WEBRADIO16","Name":""},{"_node":"WEBRADIO17","Name":""},{"_node":"WEBRADIO18","Name":""},{"_node":"WEBRADIO19","Name":""},{"_node":"WEBRADIO20","Name":""},{"_node":"WEBRADIO21","Name":""},{"_node":"WEBRADIO22","Name":""},{"_node":"WEBRADIO23","Name":""},{"_node":"WEBRADIO24","Name":""},{"_node":"WEBRADIO25","Name":""},{"_node":"WEBRADIO26","Name":""},{"_node":"WEBRADIO27","Name":""},{"_node":"WEBRADIO28","Name":""},{"_node":"WEBRADIO29","Name":""},{"_node":"WEBRADIO30","Name":""},{"_node":"WEBRADIO31","Name":""},{"_node":"WEBRADIO32","Name":""},{"_node":"WEBRADIO33","Name":""},{"_node":"WEBRADIO34","Name":""},{"_node":"WEBRADIO35","Name":""},{"_node":"WEBRADIO36","Name":""},{"_node":"WEBRADIO37","Name":""},{"_node":"WEBRADIO38","Name":""},{"_node":"WEBRADIO39","Name":""}],"box_wlan_24GHz":"0","TodayBytesSentHigh":"0","box_guestWlan":"0","box_tr069":"0","fonPort":[{"_node":"Port0","Name":"Ersatz","MSN":"SIP3"},{"_node":"Port1","Name":"Faxgerät HP Officejet","MSN":"SIP1#"},{"_node":"Port2","Name":"","MSN":""},{"_node":"Port3","Name":"","MSN":""}],"box_powerRate":"37","diversity":[],"GSM_RSSI":"0","wlanList":"wlanlist0","handset":[{"_node":"Handset0","FWVersion":"3.92","User":"1","Manufacturer":"AVM","Model":"0x08"},{"_node":"Handset1","FWVersion":"","User":"0","Manufacturer":"","Model":""},{"_node":"Handset2","FWVersion":"","User":"0","Manufacturer":"","Model":""},{"_node":"Handset3","FWVersion":"","User":"0","Manufacturer":"","Model":""},{"_node":"Handset4","FWVersion":"","User":"0","Manufacturer":"","Model":""},{"_node":"Handset5","FWVersion":"","User":"0","Manufacturer":"","Model":""}],"TodayBytesSentLow":"0","is_double_wlan":"1","lanDevice":"landevice0"}
2017.09.23 14:37:14.784 5: FRITZBOX FritzBox: Web_Query.4603 Decode JSON string.
2017.09.23 14:37:14.786 4: FRITZBOX FritzBox: Readout_Run_Web.1336 Recognized query answer of firmware >= 6.69
2017.09.23 14:37:14.787 5: FRITZBOX FritzBox: Web_Query.4573 Request data via API luaQuery.
2017.09.23 14:37:15.086 5: FRITZBOX FritzBox: Web_Query.4581 Response: 200 OK
{"landevice11":"0","landevice13":"2","landevice15":"2","user1_today":"0","landevice4":"0","landevice5":"2","wlanlist12":"0","wlanlist10":"0","wlanlist7":"0","wlanlist14":"0","landevice16":"0","landevice17":"2","user1_month":"0","user1_filter":"filtprof1","wlanlist0":"0","landevice10":"0","wlanlist4":"0","wlanlist6":"0","wlanlist1":"0","landevice7":"2","wlanlist3":"0","wlanlist15":"0","wlanlist8":"0","user0_today":"0","landevice0":"0","landevice8":"0","user0_month":"0","user0_filter":"filtprof2","landevice19":"0","landevice18":"0","wlanlist9":"0","wlanlist2":"0","landevice9":"0","wlanlist5":"0","landevice12":"0","landevice14":"2","landevice6":"2","landevice3":"0","wlanlist11":"0","landevice1":"2","landevice2":"0","wlanlist13":"0"}
2017.09.23 14:37:15.087 5: FRITZBOX FritzBox: Web_Query.4603 Decode JSON string.
2017.09.23 14:37:15.089 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->sid: 7f4053d305531030
2017.09.23 14:37:15.089 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->sidTime: 1506170235.08974
2017.09.23 14:37:15.090 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1: Haupt
2017.09.23 14:37:15.090 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_intern: 610
2017.09.23 14:37:15.090 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_alarmRingTone:
2017.09.23 14:37:15.091 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_intRingTone: HandsetDefault
2017.09.23 14:37:15.091 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_radio:
2017.09.23 14:37:15.092 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_custRingTone:
2017.09.23 14:37:15.092 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_custRingToneName:
2017.09.23 14:37:15.092 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_imagePath:
2017.09.23 14:37:15.093 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->610->id: 1
2017.09.23 14:37:15.093 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->610->userId: 1
2017.09.23 14:37:15.093 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_manufacturer: AVM
2017.09.23 14:37:15.094 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_model: C4
2017.09.23 14:37:15.094 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 dect1_fwVersion: 3.92
2017.09.23 14:37:15.094 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->610->brand: AVM
2017.09.23 14:37:15.095 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->610->model: C4
2017.09.23 14:37:15.095 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fon1: Ersatz
2017.09.23 14:37:15.095 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fon1_out: SIP3
2017.09.23 14:37:15.096 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fon1_intern: 1
2017.09.23 14:37:15.096 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fon2: Faxgerät HP Officejet
2017.09.23 14:37:15.096 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fon2_out: SIP1#
2017.09.23 14:37:15.097 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fon2_intern: 2
2017.09.23 14:37:15.097 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio00:
2017.09.23 14:37:15.097 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->0:
2017.09.23 14:37:15.098 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio01:
2017.09.23 14:37:15.098 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->1:
2017.09.23 14:37:15.098 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio02:
2017.09.23 14:37:15.099 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->2:
2017.09.23 14:37:15.099 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio03:
2017.09.23 14:37:15.099 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->3:
2017.09.23 14:37:15.100 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio04:
2017.09.23 14:37:15.100 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->4:
2017.09.23 14:37:15.100 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio05:
2017.09.23 14:37:15.101 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->5:
2017.09.23 14:37:15.101 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio06:
2017.09.23 14:37:15.101 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->6:
2017.09.23 14:37:15.102 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio07:
2017.09.23 14:37:15.102 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->7:
2017.09.23 14:37:15.102 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio08:
2017.09.23 14:37:15.103 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->8:
2017.09.23 14:37:15.103 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio09:
2017.09.23 14:37:15.103 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->9:
2017.09.23 14:37:15.104 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio10:
2017.09.23 14:37:15.104 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->10:
2017.09.23 14:37:15.104 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio11:
2017.09.23 14:37:15.105 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->11:
2017.09.23 14:37:15.105 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio12:
2017.09.23 14:37:15.105 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->12:
2017.09.23 14:37:15.106 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio13:
2017.09.23 14:37:15.106 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->13:
2017.09.23 14:37:15.106 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio14:
2017.09.23 14:37:15.107 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->14:
2017.09.23 14:37:15.107 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio15:
2017.09.23 14:37:15.107 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->15:
2017.09.23 14:37:15.108 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio16:
2017.09.23 14:37:15.108 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->16:
2017.09.23 14:37:15.108 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio17:
2017.09.23 14:37:15.109 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->17:
2017.09.23 14:37:15.109 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio18:
2017.09.23 14:37:15.109 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->18:
2017.09.23 14:37:15.109 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio19:
2017.09.23 14:37:15.110 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->19:
2017.09.23 14:37:15.110 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio20:
2017.09.23 14:37:15.110 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->20:
2017.09.23 14:37:15.111 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio21:
2017.09.23 14:37:15.111 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->21:
2017.09.23 14:37:15.111 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio22:
2017.09.23 14:37:15.112 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->22:
2017.09.23 14:37:15.112 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio23:
2017.09.23 14:37:15.112 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->23:
2017.09.23 14:37:15.113 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio24:
2017.09.23 14:37:15.113 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->24:
2017.09.23 14:37:15.113 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio25:
2017.09.23 14:37:15.114 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->25:
2017.09.23 14:37:15.114 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio26:
2017.09.23 14:37:15.114 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->26:
2017.09.23 14:37:15.115 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio27:
2017.09.23 14:37:15.115 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->27:
2017.09.23 14:37:15.115 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio28:
2017.09.23 14:37:15.116 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->28:
2017.09.23 14:37:15.116 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio29:
2017.09.23 14:37:15.116 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->29:
2017.09.23 14:37:15.117 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio30:
2017.09.23 14:37:15.117 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->30:
2017.09.23 14:37:15.117 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio31:
2017.09.23 14:37:15.118 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->31:
2017.09.23 14:37:15.118 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio32:
2017.09.23 14:37:15.118 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->32:
2017.09.23 14:37:15.119 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio33:
2017.09.23 14:37:15.119 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->33:
2017.09.23 14:37:15.119 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio34:
2017.09.23 14:37:15.120 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->34:
2017.09.23 14:37:15.120 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio35:
2017.09.23 14:37:15.120 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->35:
2017.09.23 14:37:15.121 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio36:
2017.09.23 14:37:15.121 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->36:
2017.09.23 14:37:15.121 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio37:
2017.09.23 14:37:15.121 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->37:
2017.09.23 14:37:15.122 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio38:
2017.09.23 14:37:15.122 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->38:
2017.09.23 14:37:15.123 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 radio39:
2017.09.23 14:37:15.123 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radio->39:
2017.09.23 14:37:15.123 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->radioCount: 40
2017.09.23 14:37:15.124 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->DC_66_72_81_1D_0D->speed: 0
2017.09.23 14:37:15.124 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->DC_66_72_81_1D_0D->speed_rx: 0
2017.09.23 14:37:15.124 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->DC_66_72_81_1D_0D->rssi: 0
2017.09.23 14:37:15.125 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->E8_AB_FA_8C_DE_11->speed: 0
2017.09.23 14:37:15.125 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->E8_AB_FA_8C_DE_11->speed_rx: 0
2017.09.23 14:37:15.125 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->E8_AB_FA_8C_DE_11->rssi: 0
2017.09.23 14:37:15.126 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->74_DA_38_0E_45_DB->speed: 0
2017.09.23 14:37:15.126 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->74_DA_38_0E_45_DB->speed_rx: 0
2017.09.23 14:37:15.126 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->74_DA_38_0E_45_DB->rssi: 0
2017.09.23 14:37:15.127 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->08_EE_8B_A1_CB_3B->speed: 0
2017.09.23 14:37:15.127 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->08_EE_8B_A1_CB_3B->speed_rx: 0
2017.09.23 14:37:15.127 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->08_EE_8B_A1_CB_3B->rssi: 0
2017.09.23 14:37:15.128 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->30_19_66_CF_D5_55->speed: 0
2017.09.23 14:37:15.128 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->30_19_66_CF_D5_55->speed_rx: 0
2017.09.23 14:37:15.128 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->30_19_66_CF_D5_55->rssi: 0
2017.09.23 14:37:15.129 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->B4_74_43_AA_A1_D5->speed: 0
2017.09.23 14:37:15.129 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->B4_74_43_AA_A1_D5->speed_rx: 0
2017.09.23 14:37:15.130 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->B4_74_43_AA_A1_D5->rssi: 0
2017.09.23 14:37:15.130 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->56_31_C4_C5_68_54->speed: 0
2017.09.23 14:37:15.130 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->56_31_C4_C5_68_54->speed_rx: 0
2017.09.23 14:37:15.131 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->56_31_C4_C5_68_54->rssi: 0
2017.09.23 14:37:15.131 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->C4_50_06_78_8A_E1->speed: 0
2017.09.23 14:37:15.131 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->C4_50_06_78_8A_E1->speed_rx: 0
2017.09.23 14:37:15.132 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->C4_50_06_78_8A_E1->rssi: 0
2017.09.23 14:37:15.132 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->56_31_C4_C5_68_55->speed: 0
2017.09.23 14:37:15.132 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->56_31_C4_C5_68_55->speed_rx: 0
2017.09.23 14:37:15.133 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->56_31_C4_C5_68_55->rssi: 0
2017.09.23 14:37:15.133 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->78_F7_BE_C7_91_49->speed: 0
2017.09.23 14:37:15.133 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->78_F7_BE_C7_91_49->speed_rx: 0
2017.09.23 14:37:15.134 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->78_F7_BE_C7_91_49->rssi: 0
2017.09.23 14:37:15.134 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->78_D6_F0_20_3F_D2->speed: 0
2017.09.23 14:37:15.134 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->78_D6_F0_20_3F_D2->speed_rx: 0
2017.09.23 14:37:15.135 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->78_D6_F0_20_3F_D2->rssi: 0
2017.09.23 14:37:15.135 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->F0_4F_7C_7D_42_FF->speed: 0
2017.09.23 14:37:15.135 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->F0_4F_7C_7D_42_FF->speed_rx: 0
2017.09.23 14:37:15.136 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->F0_4F_7C_7D_42_FF->rssi: 0
2017.09.23 14:37:15.136 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->40_A6_D9_2A_EE_AC->speed: 0
2017.09.23 14:37:15.136 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->40_A6_D9_2A_EE_AC->speed_rx: 0
2017.09.23 14:37:15.137 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->40_A6_D9_2A_EE_AC->rssi: 0
2017.09.23 14:37:15.137 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->0C_15_39_EA_6D_A1->speed: 0
2017.09.23 14:37:15.137 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->0C_15_39_EA_6D_A1->speed_rx: 0
2017.09.23 14:37:15.138 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->0C_15_39_EA_6D_A1->rssi: 0
2017.09.23 14:37:15.138 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->08_EE_8B_6F_DB_19->speed: 0
2017.09.23 14:37:15.138 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->08_EE_8B_6F_DB_19->speed_rx: 0
2017.09.23 14:37:15.139 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->08_EE_8B_6F_DB_19->rssi: 0
2017.09.23 14:37:15.139 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->18_46_17_FB_A4_E3->speed: 0
2017.09.23 14:37:15.139 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->18_46_17_FB_A4_E3->speed_rx: 0
2017.09.23 14:37:15.140 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->wlanDevice->18_46_17_FB_A4_E3->rssi: 0
2017.09.23 14:37:15.140 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->172.30.90.223: AndreasVPN
2017.09.23 14:37:15.141 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1884: AndreasVPN
2017.09.23 14:37:15.141 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: Galaxy-Tab-S2-Andy-localdomain
2017.09.23 14:37:15.141 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1889: Galaxy-Tab-S2-Andy-localdomain
2017.09.23 14:37:15.142 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-08-EE-8B-6F-DB-19
2017.09.23 14:37:15.142 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1899: PC-08-EE-8B-6F-DB-19
2017.09.23 14:37:15.142 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-08-EE-8B-A1-CB-3B
2017.09.23 14:37:15.143 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1888: PC-08-EE-8B-A1-CB-3B
2017.09.23 14:37:15.143 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-0C-15-39-EA-6D-A1
2017.09.23 14:37:15.143 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1898: PC-0C-15-39-EA-6D-A1
2017.09.23 14:37:15.144 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->172.30.90.191: PC-172-30-90-191
2017.09.23 14:37:15.144 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1874: PC-172-30-90-191
2017.09.23 14:37:15.145 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 mac_F0_9F_C2_11_65_C0: PC-172-30-90-191 (LAN2, 1 Gbit/s)
2017.09.23 14:37:15.145 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-18-46-17-FB-A4-E3
2017.09.23 14:37:15.145 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1900: PC-18-46-17-FB-A4-E3
2017.09.23 14:37:15.146 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-30-19-66-CF-D5-55
2017.09.23 14:37:15.146 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1890: PC-30-19-66-CF-D5-55
2017.09.23 14:37:15.146 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-40-A6-D9-2A-EE-AC
2017.09.23 14:37:15.147 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1897: PC-40-A6-D9-2A-EE-AC
2017.09.23 14:37:15.147 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-56-31-C4-C5-68-54
2017.09.23 14:37:15.147 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1891: PC-56-31-C4-C5-68-54
2017.09.23 14:37:15.148 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-56-31-C4-C5-68-55
2017.09.23 14:37:15.148 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1893: PC-56-31-C4-C5-68-55
2017.09.23 14:37:15.148 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-74-DA-38-0E-45-DB
2017.09.23 14:37:15.149 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1886: PC-74-DA-38-0E-45-DB
2017.09.23 14:37:15.149 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-78-D6-F0-20-3F-D2
2017.09.23 14:37:15.149 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1895: PC-78-D6-F0-20-3F-D2
2017.09.23 14:37:15.150 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-78-F7-BE-C7-91-49
2017.09.23 14:37:15.150 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1894: PC-78-F7-BE-C7-91-49
2017.09.23 14:37:15.150 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-B4-74-43-AA-A1-D5
2017.09.23 14:37:15.151 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1919: PC-B4-74-43-AA-A1-D5
2017.09.23 14:37:15.151 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-C4-50-06-78-8A-E1
2017.09.23 14:37:15.151 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1892: PC-C4-50-06-78-8A-E1
2017.09.23 14:37:15.152 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-E8-AB-FA-8C-DE-11
2017.09.23 14:37:15.152 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1887: PC-E8-AB-FA-8C-DE-11
2017.09.23 14:37:15.152 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->: PC-F0-4F-7C-7D-42-FF
2017.09.23 14:37:15.152 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1896: PC-F0-4F-7C-7D-42-FF
2017.09.23 14:37:15.153 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->172.30.90.224: Test
2017.09.23 14:37:15.153 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1883: Test
2017.09.23 14:37:15.153 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->172.30.90.221: fritz.box
2017.09.23 14:37:15.154 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->landevice->landevice1885: fritz.box
2017.09.23 14:37:15.154 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 mac_9C_C7_A6_0E_56_FF: fritz.box
2017.09.23 14:37:15.155 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_wlanCount: 0
2017.09.23 14:37:15.155 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_guestWlanCount: 0
2017.09.23 14:37:15.155 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_wlan_2.4GHz: off
2017.09.23 14:37:15.156 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_wlan_5GHz: off
2017.09.23 14:37:15.156 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_guestWlan: off
2017.09.23 14:37:15.156 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_guestWlanRemain: 0
2017.09.23 14:37:15.157 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_dect: on
2017.09.23 14:37:15.157 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_moh: default
2017.09.23 14:37:15.157 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_powerRate: 37
2017.09.23 14:37:15.158 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 fhem->is_double_wlan: 1
2017.09.23 14:37:15.158 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_fwVersion: 84.06.83
2017.09.23 14:37:15.158 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_fwUpdate: 0
2017.09.23 14:37:15.159 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_tr064: on
2017.09.23 14:37:15.159 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_tr069: off
2017.09.23 14:37:15.159 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_stdDialPort: dect1
2017.09.23 14:37:15.160 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_ipExtern: 172.30.90.221
2017.09.23 14:37:15.160 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_connect: 5
2017.09.23 14:37:15.160 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 box_cpuTemp: 0
2017.09.23 14:37:15.161 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 gsm_rssi:
2017.09.23 14:37:15.161 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 gsm_state:
2017.09.23 14:37:15.161 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 gsm_technology:
2017.09.23 14:37:15.162 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 gsm_internet:
2017.09.23 14:37:15.162 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm1: Wecker 1
2017.09.23 14:37:15.162 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm1_state: off
2017.09.23 14:37:15.163 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm1_time: 00:00
2017.09.23 14:37:15.163 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm1_target: FON 1
2017.09.23 14:37:15.163 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm1_wdays: daily
2017.09.23 14:37:15.164 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm2: Wecker 2
2017.09.23 14:37:15.164 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm2_state: off
2017.09.23 14:37:15.164 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm2_time: 00:00
2017.09.23 14:37:15.165 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm2_target: FON 1
2017.09.23 14:37:15.165 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm2_wdays: daily
2017.09.23 14:37:15.165 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm3: Wecker 3
2017.09.23 14:37:15.166 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm3_state: off
2017.09.23 14:37:15.166 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm3_time: 00:00
2017.09.23 14:37:15.166 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm3_target: FON 1
2017.09.23 14:37:15.167 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 alarm3_wdays: daily
2017.09.23 14:37:15.167 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 tam1: Anrufbeantworter
2017.09.23 14:37:15.167 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 tam1_state: off
2017.09.23 14:37:15.167 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 tam1_newMsg: 0
2017.09.23 14:37:15.167 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 tam1_oldMsg: 0
2017.09.23 14:37:15.168 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 user01: (guest)
2017.09.23 14:37:15.168 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 user01_thisMonthTime: 0:00
2017.09.23 14:37:15.168 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 user01_todayTime: 0:00
2017.09.23 14:37:15.168 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 user01_todaySeconds: 0
2017.09.23 14:37:15.168 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 user01_type: Guest
2017.09.23 14:37:15.169 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 userTicket01: 743238
2017.09.23 14:37:15.169 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 .box_TodayBytesReceivedHigh: 0
2017.09.23 14:37:15.169 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 .box_TodayBytesReceivedLow: 0
2017.09.23 14:37:15.169 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 .box_TodayBytesSentHigh: 0
2017.09.23 14:37:15.169 5: FRITZBOX FritzBox: Readout_Add_Reading.1974 .box_TodayBytesSentLow: 0
2017.09.23 14:37:15.170 4: FRITZBOX FritzBox: Readout_Run_Web.1681 Captured 247 values
2017.09.23 14:37:15.170 5: FRITZBOX FritzBox: Readout_Run_Web.1682 Handover to main process (6548): fhem->sid|7f4053d305531030|fhem->sidTime|1506170235.08974|dect1|Haupt|dect1_intern|610|dect1_alarmRingTone||dect1_intRingTone|HandsetDefault|dect1_radio||dect1_custRingTone||dect1_custRingToneName||dect1_imagePath||fhem->610->id|1|fhem->610->userId|1|dect1_manufacturer|AVM|dect1_model|C4|dect1_fwVersion|3.92|fhem->610->brand|AVM|fhem->610->model|C4|fon1|Ersatz|fon1_out|SIP3|fon1_intern|1|fon2|Faxgerät HP Officejet|fon2_out|SIP1#|fon2_intern|2|radio00||fhem->radio->0||radio01||fhem->radio->1||radio02||fhem->radio->2||radio03||fhem->radio->3||radio04||fhem->radio->4||radio05||fhem->radio->5||radio06||fhem->radio->6||radio07||fhem->radio->7||radio08||fhem->radio->8||radio09||fhem->radio->9||radio10||fhem->radio->10||radio11||fhem->radio->11||radio12||fhem->radio->12||radio13||fhem->radio->13||radio14||fhem->radio->14||radio15||fhem->radio->15||radio16||fhem->radio->16||radio17||fhem->radio->17||radio18||fhem->radio->18||radio19||fhem->radio->19||radio20||fhem->radio->20||radio21||fhem->radio->21||radio22||fhem->radio->22||radio23||fhem->radio->23||radio24||fhem->radio->24||radio25||fhem->radio->25||radio26||fhem->radio->26||radio27||fhem->radio->27||radio28||fhem->radio->28||radio29||fhem->radio->29||radio30||fhem->radio->30||radio31||fhem->radio->31||radio32||fhem->radio->32||radio33||fhem->radio->33||radio34||fhem->radio->34||radio35||fhem->radio->35||radio36||fhem->radio->36||radio37||fhem->radio->37||radio38||fhem->radio->38||radio39||fhem->radio->39||fhem->radioCount|40|fhem->wlanDevice->DC_66_72_81_1D_0D->speed|0|fhem->wlanDevice->DC_66_72_81_1D_0D->speed_rx|0|fhem->wlanDevice->DC_66_72_81_1D_0D->rssi|0|fhem->wlanDevice->E8_AB_FA_8C_DE_11->speed|0|fhem->wlanDevice->E8_AB_FA_8C_DE_11->speed_rx|0|fhem->wlanDevice->E8_AB_FA_8C_DE_11->rssi|0|fhem->wlanDevice->74_DA_38_0E_45_DB->speed|0|fhem->wlanDevice->74_DA_38_0E_45_DB->speed_rx|0|fhem->wlanDevice->74_DA_38_0E_45_DB->rssi|0|fhem->wlanDevice->08_EE_8B_A1_CB_3B->speed|0|fhem->wlanDevice->08_EE_8B_A1_CB_3B->speed_rx|0|fhem->wlanDevice->08_EE_8B_A1_CB_3B->rssi|0|fhem->wlanDevice->30_19_66_CF_D5_55->speed|0|fhem->wlanDevice->30_19_66_CF_D5_55->speed_rx|0|fhem->wlanDevice->30_19_66_CF_D5_55->rssi|0|fhem->wlanDevice->B4_74_43_AA_A1_D5->speed|0|fhem->wlanDevice->B4_74_43_AA_A1_D5->speed_rx|0|fhem->wlanDevice->B4_74_43_AA_A1_D5->rssi|0|fhem->wlanDevice->56_31_C4_C5_68_54->speed|0|fhem->wlanDevice->56_31_C4_C5_68_54->speed_rx|0|fhem->wlanDevice->56_31_C4_C5_68_54->rssi|0|fhem->wlanDevice->C4_50_06_78_8A_E1->speed|0|fhem->wlanDevice->C4_50_06_78_8A_E1->speed_rx|0|fhem->wlanDevice->C4_50_06_78_8A_E1->rssi|0|fhem->wlanDevice->56_31_C4_C5_68_55->speed|0|fhem->wlanDevice->56_31_C4_C5_68_55->speed_rx|0|fhem->wlanDevice->56_31_C4_C5_68_55->rssi|0|fhem->wlanDevice->78_F7_BE_C7_91_49->speed|0|fhem->wlanDevice->78_F7_BE_C7_91_49->speed_rx|0|fhem->wlanDevice->78_F7_BE_C7_91_49->rssi|0|fhem->wlanDevice->78_D6_F0_20_3F_D2->speed|0|fhem->wlanDevice->78_D6_F0_20_3F_D2->speed_rx|0|fhem->wlanDevice->78_D6_F0_20_3F_D2->rssi|0|fhem->wlanDevice->F0_4F_7C_7D_42_FF->speed|0|fhem->wlanDevice->F0_4F_7C_7D_42_FF->speed_rx|0|fhem->wlanDevice->F0_4F_7C_7D_42_FF->rssi|0|fhem->wlanDevice->40_A6_D9_2A_EE_AC->speed|0|fhem->wlanDevice->40_A6_D9_2A_EE_AC->speed_rx|0|fhem->wlanDevice->40_A6_D9_2A_EE_AC->rssi|0|fhem->wlanDevice->0C_15_39_EA_6D_A1->speed|0|fhem->wlanDevice->0C_15_39_EA_6D_A1->speed_rx|0|fhem->wlanDevice->0C_15_39_EA_6D_A1->rssi|0|fhem->wlanDevice->08_EE_8B_6F_DB_19->speed|0|fhem->wlanDevice->08_EE_8B_6F_DB_19->speed_rx|0|fhem->wlanDevice->08_EE_8B_6F_DB_19->rssi|0|fhem->wlanDevice->18_46_17_FB_A4_E3->speed|0|fhem->wlanDevice->18_46_17_FB_A4_E3->speed_rx|0|fhem->wlanDevice->18_46_17_FB_A4_E3->rssi|0|fhem->landevice->172.30.90.223|AndreasVPN|fhem->landevice->landevice1884|AndreasVPN|fhem->landevice->|Galaxy-Tab-S2-Andy-localdomain|fhem->landevice->landevice1889|Galaxy-Tab-S2-Andy-localdomain|fhem->landevice->|PC-08-EE-8B-6F-DB-19|fhem->landevice->landevice1899|PC-08-EE-8B-6F-DB-19|fhem->landevice->|PC-08-EE-8B-A1-CB-3B|fhem->landevice->landevice1888|PC-08-EE-8B-A1-CB-3B|fhem->landevice->|PC-0C-15-39-EA-6D-A1|fhem->landevice->landevice1898|PC-0C-15-39-EA-6D-A1|fhem->landevice->172.30.90.191|PC-172-30-90-191|fhem->landevice->landevice1874|PC-172-30-90-191|mac_F0_9F_C2_11_65_C0|PC-172-30-90-191 (LAN2, 1 Gbit/s)|fhem->landevice->|PC-18-46-17-FB-A4-E3|fhem->landevice->landevice1900|PC-18-46-17-FB-A4-E3|fhem->landevice->|PC-30-19-66-CF-D5-55|fhem->landevice->landevice1890|PC-30-19-66-CF-D5-55|fhem->landevice->|PC-40-A6-D9-2A-EE-AC|fhem->landevice->landevice1897|PC-40-A6-D9-2A-EE-AC|fhem->landevice->|PC-56-31-C4-C5-68-54|fhem->landevice->landevice1891|PC-56-31-C4-C5-68-54|fhem->landevice->|PC-56-31-C4-C5-68-55|fhem->landevice->landevice1893|PC-56-31-C4-C5-68-55|fhem->landevice->|PC-74-DA-38-0E-45-DB|fhem->landevice->landevice1886|PC-74-DA-38-0E-45-DB|fhem->landevice->|PC-78-D6-F0-20-3F-D2|fhem->landevice->landevice1895|PC-78-D6-F0-20-3F-D2|fhem->landevice->|PC-78-F7-BE-C7-91-49|fhem->landevice->landevice1894|PC-78-F7-BE-C7-91-49|fhem->landevice->|PC-B4-74-43-AA-A1-D5|fhem->landevice->landevice1919|PC-B4-74-43-AA-A1-D5|fhem->landevice->|PC-C4-50-06-78-8A-E1|fhem->landevice->landevice1892|PC-C4-50-06-78-8A-E1|fhem->landevice->|PC-E8-AB-FA-8C-DE-11|fhem->landevice->landevice1887|PC-E8-AB-FA-8C-DE-11|fhem->landevice->|PC-F0-4F-7C-7D-42-FF|fhem->landevice->landevice1896|PC-F0-4F-7C-7D-42-FF|fhem->landevice->172.30.90.224|Test|fhem->landevice->landevice1883|Test|fhem->landevice->172.30.90.221|fritz.box|fhem->landevice->landevice1885|fritz.box|mac_9C_C7_A6_0E_56_FF|fritz.box|box_wlanCount|0|box_guestWlanCount|0|box_wlan_2.4GHz|off|box_wlan_5GHz|off|box_guestWlan|off|box_guestWlanRemain|0|box_dect|on|box_moh|default|box_powerRate|37|fhem->is_double_wlan|1|box_fwVersion|84.06.83|box_fwUpdate|0|box_tr064|on|box_tr069|off|box_stdDialPort|dect1|box_ipExtern|172.30.90.221|box_connect|5|box_cpuTemp|0|gsm_rssi||gsm_state||gsm_technology||gsm_internet||alarm1|Wecker 1|alarm1_state|off|alarm1_time|00:00|alarm1_target|FON 1|alarm1_wdays|daily|alarm2|Wecker 2|alarm2_state|off|alarm2_time|00:00|alarm2_target|FON 1|alarm2_wdays|daily|alarm3|Wecker 3|alarm3_state|off|alarm3_time|00:00|alarm3_target|FON 1|alarm3_wdays|daily|tam1|Anrufbeantworter|tam1_state|off|tam1_newMsg|0|tam1_oldMsg|0|user01|(guest)|user01_thisMonthTime|0:00|user01_todayTime|0:00|user01_todaySeconds|0|user01_type|Guest|userTicket01|743238|.box_TodayBytesReceivedHigh|0|.box_TodayBytesReceivedLow|0|.box_TodayBytesSentHigh|0|.box_TodayBytesSentLow|0|readoutTime|1.11
2017.09.23 14:37:15.256 4: Connection accepted from telnetForBlockingFn_1506167519_127.0.0.1_50338
2017.09.23 14:37:15.509 5: Cmd: >{BlockingStart('48')}<
2017.09.23 14:37:19.929 4: WEB_172.30.90.22_52362 GET /fhem/FileLog_logWrapper?dev=Logfile&type=text&file=fhem-2017-09.log; BUFLEN:0
list autocreate
No device named autocreate found
list HM_5859DC
No device named HM_5859DC found
Das Device sollte also erstellt werden, aber irgendwas geht da schief...
Greets
Byte
LuckyDay
naja ohne autocreate kein pairing möglich. warum fehlt das bei dir???
define autocreate autocreate
attr autocreate filelog ./log/%NAME-%Y.log
so stehts orginal in der fhem.cfg drin !
Bytechanger
genau dass war es!
DANKE!
Ich kann mir ehrlich gesagt nicht erklären, warum der Eintrag aus der Config fehlte!
Greets
Byte
