!!! Probleme mit Presence, FRITZBOX und Meldungen von Blocking.pm !!!
Begonnen von CoolTux, 05 Oktober 2017, 09:18:53
Kawaci
hey leute! ich habe ein problem mit dem lepresenced!
wenn 2 gtags zuhause sind kommt das beide abwesend sind nach nem Neustart von lepresenced sind beide für 5 min da dann wieder das selbe!
im fhem log steht
2017.11.24 15:48:25 1: localhost:5333 disconnected, waiting to reappear (gtag_red)
2017.11.24 15:48:25 1: 127.0.0.1:5333 disconnected, waiting to reappear (gtag_green)
2017.11.24 15:48:51 1: FHEMWEB SSL/HTTPS error:  SSL accept attempt failed (peer: 192.168.1.103)
2017.11.24 15:49:25 1: 127.0.0.1:5333 reappeared (gtag_green)
2017.11.24 15:49:25 1: localhost:5333 reappeared (gtag_red)
und wenn ich den status mit sudo service lepresenced abfrage
● lepresenced.service - lepresenced
   Loaded: loaded (/lib/systemd/system/lepresenced.service; enabled; vendor preset: enabled)
   Active: active (running) since Fri 2017-11-24 16:09:17 CET; 1h 37min ago
  Process: 24805 ExecStartPre=/bin/sleep 10 (code=exited, status=0/SUCCESS)
Main PID: 24848 (lepresenced)
   CGroup: /system.slice/lepresenced.service
           ├─24848 /usr/bin/perl /usr/sbin/lepresenced --device hci0 --listenaddress 0.0.0.0 --listenport 5333 --loglevel LOG_WARNING
           ├─24873 hcidump -i hci0
           └─26483 hcitool -i hci0 lescan --duplicates
Nov 24 16:09:07 fhemserver2 systemd[1]: Starting lepresenced...
Nov 24 16:09:17 fhemserver2 systemd[1]: Started lepresenced.
Nov 24 16:09:19 fhemserver2 lepresenced[24848]: [tid:1] main::bluetooth_scan_thread: Received unknown output: 'Disable scan failed: Input/output error'!
Nov 24 16:09:19 fhemserver2 lepresenced[24848]: [tid:1] main::bluetooth_scan_thread: hcitool exited, retrying...
Nov 24 16:09:24 fhemserver2 lepresenced[24848]: [tid:1] main::bluetooth_scan_thread: Received unknown output: 'Disable scan failed: Input/output error'!
Nov 24 16:09:24 fhemserver2 lepresenced[24848]: [tid:1] main::bluetooth_scan_thread: hcitool exited, retrying...
Nov 24 16:17:37 fhemserver2 lepresenced[24848]: [tid:1] main::bluetooth_scan_thread: Received unknown output: 'Disable scan failed: Input/output error'!
Nov 24 16:17:37 fhemserver2 lepresenced[24848]: [tid:1] main::bluetooth_scan_thread: hcitool exited, retrying...
Nov 24 16:17:49 fhemserver2 lepresenced[24848]: [tid:1] main::bluetooth_scan_thread: Received unknown output: 'Disable scan failed: Input/output error'!
Nov 24 16:17:49 fhemserver2 lepresenced[24848]: [tid:1] main::bluetooth_scan_thread: hcitool exited, retrying...
und das steht im syslog
Nov 24 11:31:06 fhemserver2 lepresenced[22691]: [tid:1] main::bluetooth_scan_thread: Received unknown output: 'Disable scan failed: Input/output error'!
Nov 24 11:31:06 fhemserver2 lepresenced[22691]: [tid:1] main::bluetooth_scan_thread: hcitool exited, retrying...
Nov 24 11:31:08 fhemserver2 kernel: [429732.342093] Bluetooth: hci0 advertising data length corrected
