FIBARO System FGDW002 Door Opening Sensor 2: State wird nicht aktualisiert
Begonnen von The Grue, 06 Oktober 2017, 21:54:31
The Grue
Servus,
dieser Sensor macht mir etwas Probleme:
defmod Speisekammer.Tuer ZWave c83f1470 6
attr Speisekammer.Tuer IODev ZWDongle_0
attr Speisekammer.Tuer alias Speisekammer: Tür
attr Speisekammer.Tuer classes ZWAVEPLUS_INFO ASSOCIATION ASSOCIATION_GRP_INFO APPLICATION_STATUS BATTERY CONFIGURATION CRC_16_ENCAP DEVICE_RESET_LOCALLY FIRMWARE_UPDATE_MD MANUFACTURER_SPECIFIC MULTI_CHANNEL_ASSOCIATION ALARM POWERLEVEL SECURITY SENSOR_MULTILEVEL VERSION WAKE_UP
attr Speisekammer.Tuer icon fts_door_right
attr Speisekammer.Tuer room Speisekammer,ZWave
attr Speisekammer.Tuer vclasses ALARM:5 APPLICATION_STATUS:1 ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 BATTERY:1 CONFIGURATION:1 CRC_16_ENCAP:1 DEVICE_RESET_LOCALLY:1 FIRMWARE_UPDATE_MD:4 MULTI_CHANNEL_ASSOCIATION:3 SECURITY:1 SENSOR_MULTILEVEL:5 VERSION:2 WAKE_UP:2 ZWAVEPLUS_INFO:2
setstate Speisekammer.Tuer wakeupInterval 86400 1
setstate Speisekammer.Tuer 2017-10-06 18:33:10 alarm AccessControl: Window/Door is closed
setstate Speisekammer.Tuer 2017-09-24 13:21:47 assocGroup_1 Max 1 Nodes ZWDongle_0
setstate Speisekammer.Tuer 2017-09-24 13:21:48 assocGroup_2 Max 5 Nodes ZWDongle_0 Speisekammer.Licht
setstate Speisekammer.Tuer 2017-09-24 13:21:48 assocGroup_3 Max 5 Nodes
setstate Speisekammer.Tuer 2017-09-24 13:21:47 assocGroups 3
setstate Speisekammer.Tuer 2017-10-06 18:33:10 basicSet 0
setstate Speisekammer.Tuer 2017-10-06 21:29:09 battery 100 %
setstate Speisekammer.Tuer 2017-09-28 04:07:06 config2ndAssociationGroupTriggers SwitchAfterOpeningAndClosing
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configAssociationForClosingTimeDelay 0
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configAssociationForClosingValueSent 0
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configAssociationForOpeningTimeDelay 0
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configAssociationForOpeningValueSent 255
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configAssociationsInZWaveNetwork3 Group2And3
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configDoorWindowState Closed
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configHighTemperatureAlarmThreshold 350
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configIntervalOfTemperature50 300
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configIntervalOfTemperatureReports 0
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configLowTemperatureAlarmThreshold 100
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configTamperAlarmCancellationDelay 5
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configTamperReportingAlarmCancellation SendTamperCancellationReport
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configTemperatureAlarmReports Disabled
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configTemperatureOffset 0
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configTemperatureReportsThreshold 10
setstate Speisekammer.Tuer 2017-09-28 04:07:06 configVisualLEDIndications 6
setstate Speisekammer.Tuer 2017-09-20 20:57:35 model FIBARO System FGDW002 Door Opening Sensor 2
setstate Speisekammer.Tuer 2017-09-20 20:57:35 modelConfig fibaro/fgdw2.xml
setstate Speisekammer.Tuer 2017-09-20 20:57:35 modelId 010f-0702-1000
setstate Speisekammer.Tuer 2017-10-03 18:41:21 neighborList ZWDongle_0 Speisekammer.Licht
setstate Speisekammer.Tuer 2017-09-20 20:57:32 state wakeupInterval 86400 1
setstate Speisekammer.Tuer 2017-10-05 20:14:23 temperature 21.8 C
setstate Speisekammer.Tuer 2017-10-06 21:29:11 timeToAck 0.023
setstate Speisekammer.Tuer 2017-10-06 21:29:11 transmit OK
setstate Speisekammer.Tuer 2017-10-06 21:29:08 wakeup notification
setstate Speisekammer.Tuer 2017-09-20 21:02:57 wakeupIntervalCapabilitiesReport min 0 max 64800 default 21600 step 3600
Der State wird nicht aktualisiert. Das Ding zeigt dauernd nur "wakeupInterval 86400 1" an, anstatt "open" oder "closed" oder sowas...
Siehe auch die Zeile oben:
Woran liegt das?
Xamsum
Hi zusammen,
habe jetzt wie vorgeschlagen das Attribute "stateFormat" gesetzt. Leider habe ich nach wie vor zwei Probleme
1) Der Wert des Readings "state" wird nach wie vor nicht aktualisiert
2) Der Wert des Internals "STATE" wird jetzt auf "AccessControl: Window/Door is closed" resp "AccessControl: Window/Door is open" gesetzt. Ich bräuchte hier aber aus Kompatibiltätsgründen (habe auch Vorgängerversionen des Sensors) nur die Zustände "open"/"closed"
Gibt es eine Möglichkeit zumindest für (2) den State einfach nur auf "open"/"closed" zu setzen. Andernfalls ist eine Weiterverarbeitung des "STATES" nur schwer möglich
Viele Gruesse
--Michael
krikan
Die stateFormat und die userReadings-Lösung findest Du in diesem Thema verlinkt: https://forum.fhem.de/index.php/topic,74630.0.html
Gruß, Christian
