Autor Thema: MAX, MAXScanner, testresult & battery reading values  (Gelesen 861 mal)
Offline Bob B
  • New Member
« am: 14 Oktober 2017, 14:49:31 »
I have 14 MAX thermostats and a CUL. FHEM takes care of the comms. and sends
updates to Node Red via MQTT ( & vice versa ).
The battery reading for all thermostats is 'ok'; after 10 months that's all I've ever seen.
Q1. What other battery status messages are possible (eg: when the batteries start to die)?
Q2. Is there any reading / indication / status that can be checked if a thermostat malfunctions?
eg: Sometimes (especially after first installation) a thermostat will show an actuator error message (like F2 or F3 say)
after a decalcification run. I have never been in a position to check the readings received by FHEM after
such an event. There is a reading called "testresult" but I can't find out what this means. (It's always 161.)
Any help gratefully received!
Bob
Offline fruit
  • Full Member
Antw:MAX, MAXScanner, testresult & battery reading values
« Antwort #1 am: 16 Oktober 2017, 09:37:16 »
2017-10-15_18:22:19 MAX_0759c6 battery: low
This is first time I have seen it for this actuator, installed in 2013 I think, with original supplied batteries
Not as far as I know
Feel free to follow up in German if you prefer
Offline Bob B
  • New Member
« Antwort #2 am: 18 Oktober 2017, 00:50:44 »
Thanks fruit - just what I needed to know!
(4yrs on those batteries - amazing!)
Bob
Offline Wzut
« Antwort #3 am: 25 Oktober 2017, 09:51:15 »
Thats ok, good batterys should work a year or a little bit longer.
When the life expectancy comes to an end you will first see a low for some minutes. Now its a good time to order new batterys :) Approximately some days later you will see a permanent low. Change the batterys at this point.
Maintainer der Module: MPD, UbiquitiMP, UbiquitiOut, SIP
