Merkwürdiges Verhalten - kein Pairing möglich - Fentserkontakt
Begonnen von Tedious, 30 Oktober 2017, 08:06:58
Tedious
Guten Morgen,
ich habe hier einen Fensterkontakt den ich nicht gepairt bekomme. Logauszug erkellt mich leider nicht wirklich. Werksreset habe ich schon mehrfach gemact... jemand eine Idee?
2017.10.30 08:04:20 1: Logfile gelöscht
2017.10.30 08:04:36 3: CUL_MAX_Parse: Pairing device 13c283 of type ShutterContact with serial MKF0063442
2017.10.30 08:04:36 1: ERROR: empty name in readingsBeginUpdate
2017.10.30 08:04:36 1: stacktrace:
2017.10.30 08:04:36 1:     main::readingsBeginUpdate           called by ./FHEM/10_MAX.pm (642)
2017.10.30 08:04:36 1:     main::MAX_Parse                     called by fhem.pl (3676)
2017.10.30 08:04:36 1:     main::Dispatch                      called by ./FHEM/14_CUL_MAX.pm (357)
2017.10.30 08:04:36 1:     main::CUL_MAX_Parse                 called by fhem.pl (3676)
2017.10.30 08:04:36 1:     main::Dispatch                      called by ./FHEM/00_CUL.pm (947)
2017.10.30 08:04:36 1:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (831)
2017.10.30 08:04:36 1:     main::CUL_Read                      called by fhem.pl (3480)
2017.10.30 08:04:36 1:     main::CallFn                        called by fhem.pl (694)
2017.10.30 08:04:36 1: readingsUpdate(,groupid,0) missed to call readingsBeginUpdate first.
2017.10.30 08:04:36 1:     main::readingsBulkUpdate            called by ./FHEM/10_MAX.pm (652)
2017.10.30 08:04:36 1: readingsUpdate(,state,waiting for data) missed to call readingsBeginUpdate first.
2017.10.30 08:04:36 1:     main::readingsBulkUpdate            called by ./FHEM/10_MAX.pm (883)
2017.10.30 08:04:36 1: readingsUpdate(,RSSI,-60) missed to call readingsBeginUpdate first.
2017.10.30 08:04:36 1:     main::readingsBulkUpdate            called by ./FHEM/10_MAX.pm (884)
2017.10.30 08:04:36 1:     main::MAX_Parse                     called by fhem.pl (3695)
2017.10.30 08:04:36 3: cm: Unknown code MAX,0,define,13c283,ShutterContact,MKF0063442,0, help me!
2017.10.30 08:04:36 1:     main::readingsBeginUpdate           called by ./FHEM/14_CUL_MAX.pm (362)
2017.10.30 08:04:36 1: readingsUpdate(,firmware,1.0) missed to call readingsBeginUpdate first.
2017.10.30 08:04:36 1:     main::readingsBulkUpdate            called by ./FHEM/14_CUL_MAX.pm (363)
2017.10.30 08:04:36 1: readingsUpdate(,testresult,0) missed to call readingsBeginUpdate first.
2017.10.30 08:04:36 1:     main::readingsBulkUpdate            called by ./FHEM/14_CUL_MAX.pm (364)
2017.10.30 08:04:37 1: ERROR: empty name in readingsBeginUpdate
2017.10.30 08:04:37 1: stacktrace:
2017.10.30 08:04:37 1:     main::readingsBeginUpdate           called by ./FHEM/10_MAX.pm (642)
2017.10.30 08:04:37 1:     main::MAX_Parse                     called by fhem.pl (3676)
2017.10.30 08:04:37 1:     main::Dispatch                      called by ./FHEM/14_CUL_MAX.pm (303)
2017.10.30 08:04:37 1:     main::CUL_MAX_Parse                 called by fhem.pl (3676)
2017.10.30 08:04:37 1:     main::Dispatch                      called by ./FHEM/00_CUL.pm (947)
2017.10.30 08:04:37 1:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (831)
2017.10.30 08:04:37 1:     main::CUL_Read                      called by fhem.pl (3480)
2017.10.30 08:04:37 1:     main::CallFn                        called by fhem.pl (694)
2017.10.30 08:04:37 1:     main::MAX_Parse                     called by ./FHEM/10_MAX.pm (847)
2017.10.30 08:04:37 1: readingsUpdate(,battery,ok) missed to call readingsBeginUpdate first.
2017.10.30 08:04:37 1:     main::readingsBulkUpdate            called by ./FHEM/10_MAX.pm (761)
2017.10.30 08:04:37 1: readingsUpdate(,onoff,1) missed to call readingsBeginUpdate first.
2017.10.30 08:04:37 1:     main::readingsBulkUpdate            called by ./FHEM/10_MAX.pm (762)
2017.10.30 08:04:37 1: readingsUpdate(,state,waiting for data) missed to call readingsBeginUpdate first.
2017.10.30 08:04:37 1:     main::readingsBulkUpdate            called by ./FHEM/10_MAX.pm (883)
2017.10.30 08:04:37 1: readingsUpdate(,RSSI,-57.5) missed to call readingsBeginUpdate first.
2017.10.30 08:04:37 1:     main::readingsBulkUpdate            called by ./FHEM/10_MAX.pm (884)
2017.10.30 08:04:37 1:     main::MAX_Parse                     called by fhem.pl (3695)
2017.10.30 08:04:37 3: cm: Unknown code MAX,1,Ack,13c283,0112, help me!
Grüße Sascha
Tedious
Ein manuelles Anlegen funktoniert auch nicht...
define Tuer_EZ MAX ShutterContact 13c283
liefert nur
MAX_Define: Device with addr 13c283 is already defined
In der cfg steht kein Device...
Tedious
Update... ich habe mal die fhem.cfg per Hand sortiert. Nachdem ein CUL der MAX steuerte rausgeflogen war und der MapleCUN 4x den Job übernommen hat stand die Definition des MapleCUN hinter der Definition von cm. Hab das mal umgestrickt, zumindest konnte ich ihn jetzt per Hand definieren. Liefert noch Status ??, muss ich heute Abend zuhause mal testen ob er auch reagiert... ich berichte...
RaspiLED
Hi Tedious,
Wenn es ein Maple ist, interessiert mich auch wie Du die Stackables (mit oder ohne cc) definiert hast. Vielleicht hast Du ja lists für uns ;-)
Gruß Arnd
Raspi2 mit FHEM, CUL, Signalduino, MySensors, HomeBridge, Presence, Bravia, ...
SibbeH
Gestern Abend, nachdem ich einen Fensterkontakt definiert habe, hatte ich die gleichen Benachrichtigungen in die Log.
Es handelt sich um ein gleichen Log wie Tedious in seinem Log hat, mit Hinweisen auf dieselben Zeilennummern.
In meinem Fall ist es ein Busware CUL.
Ich habe einen Shutdown-Restart gemacht und dann könnte ich auf normale weise den Fensterkontakt definieren.
SibbeH
Raspberry Pi, CULV3, 3xCUNO, MAX Thermostat, MAX Wandthermostat, HM, HmIP. UWZ, WeekProfile
Tedious
klar, kein Thema:
#mapleCUN
define mapleCUL CUL /dev/ttyACM0@38400 4444
attr mapleCUL addvaltrigger 1
attr mapleCUL alias CUL_Max
attr mapleCUL icon cul_cul
attr mapleCUL rfmode MAX
attr mapleCUL room CULs
define mapleCUN2 STACKABLE_CC mapleCUL
attr mapleCUN2 addvaltrigger 1
attr mapleCUN2 alias CUL_433
attr mapleCUN2 icon cul_cul
attr mapleCUN2 rfmode SlowRF
attr mapleCUN2 room CULs
define mapleCUN3 STACKABLE_CC mapleCUN2
attr mapleCUN3 addvaltrigger 1
attr mapleCUN3 alias CUL_Homematic
attr mapleCUN3 hmId #####
attr mapleCUN3 icon cul_cul
attr mapleCUN3 rfmode HomeMatic
attr mapleCUN3 room CULs
define mapleCUN4 STACKABLE_CC mapleCUN3
attr mapleCUN4 addvaltrigger 1
attr mapleCUN4 icon cul_cul
attr mapleCUN4 rfmode SlowRF
attr mapleCUN4 room CULs
Läuft übrigens problemlos seit ich die fhem.cfg modifiziert haben.
RaspiLED
Schön das es läuft ;-)
Auch dies ist wieder eine Stackable_CC config! Hat irgendjemand die Stackable Variante funktionstüchtig?
Gruß Arnd
nonamenogame
#7
auch wenn ich hier schon länger nichts mehr geschrieben wurde, hänge ich mich mal hier dran.
Seit Kurzen habe ich auch zwei MapleCUL mit LAN und 4 Fach Sender, die beiden Dinger laufen einwandfrei soweit.
Allerdings habe ich mir auch die MAx Fensterkontakte besorgt, und da es meine bislang ersten und einzigen MAX Devices sind, frage ich mich, wie ich die am Besten eingebunden bekomme.
Wenn ich das nun richtig verstehe, definiert ihr nach dem maple einen cm?
und dann geht der Rest über den cm?
OK, genau so, wie beschrieben, funktioniert es ;-)
Gruss und Dank
