Hilfe Meine Zwave Lampe mit BM bombardiert mich mit events.
Begonnen von cornhoulio, 30 Oktober 2017, 11:01:25
cornhoulio
ich habe neuerdings eine Steinel XLED 2 XL Lampe mit Zwave.
DEF        fd34f588 10
   IODev      ZWPi
   LASTInputDev ZWPi
   MSGCNT     5660
   NAME       ZWave_SWITCH_BINARY_10
   NR         458
   STATE      off
   TYPE       ZWave
   ZWPi_MSGCNT 5660
   ZWPi_RAWMSG 0004000a03200100
   ZWPi_TIME  2017-10-30 10:31:58
   ZWaveSubDevice no
   endpointChildren ZWave_SWITCH_BINARY_10.01,ZWave_SENSOR_NOTIFICATION_10.02,ZWave_SENSOR_MULTILEVEL_10.03
   homeId     fd34f588
   isWakeUp
   nodeIdHex  0a
     2017-10-29 06:57:21   alarm           HomeSecurity: Event cleared: Motion Detection - Unknown Location, arg 0108
     2017-10-24 21:20:37   alarmTypeSupported HomeSecurity System
     2017-10-24 23:38:18   assocGroup_1    Max 1 Nodes
     2017-10-24 23:38:18   assocGroup_2    Max 16 Nodes ZWPi
     2017-10-24 23:38:19   assocGroup_3    Max 16 Nodes ZWPi
     2017-10-24 23:38:19   assocGroup_4    Max 16 Nodes ZWPi
     2017-10-24 23:38:18   assocGroups     4
     2017-10-30 10:31:58   basicSet        0
     2017-10-28 19:31:26   location        Gartenhaus
     2017-10-30 09:12:00   luminance       2000 Lux
     2017-10-24 21:41:30   mcCapability_01 ZWAVEPLUS_INFO ASSOCIATION MULTI_CHANNEL_ASSOCIATION ASSOCIATION_GRP_INFO SWITCH_BINARY SCENE_ACTIVATION SCENE_ACTUATOR_CONF SWITCH_ALL APPLICATION_STATUS
     2017-10-24 21:41:31   mcCapability_02 ZWAVEPLUS_INFO ASSOCIATION MULTI_CHANNEL_ASSOCIATION ASSOCIATION_GRP_INFO ALARM
     2017-10-24 21:41:32   mcCapability_03 ZWAVEPLUS_INFO SENSOR_MULTILEVEL ASSOCIATION MULTI_CHANNEL_ASSOCIATION ASSOCIATION_GRP_INFO
     2017-10-24 21:41:28   mcEndpoints     total 3, different
     2017-10-24 21:53:20   mcaGroups       4
     2017-10-24 21:53:20   mca_1           Max 1
     2017-10-24 21:53:20   mca_2           Max 16
     2017-10-24 21:53:21   mca_3           Max 16
     2017-10-24 21:53:21   mca_4           Max 16
     2017-10-28 18:52:47   model           0x0271 0x0001 0x1a73
     2017-10-28 18:52:47   modelId         0271-0001-1a73
     2017-10-24 21:21:15   name
     2017-10-24 21:35:57   neighborList    ZWPi
     2017-10-24 21:36:03   neighborUpdate  done
     2017-10-24 21:36:32   powerlvl        current 0 remain 0
     2017-10-24 21:36:22   powerlvlTest    node 0 status 1 frameAck 0
     2017-10-29 19:20:48   state           off
     2017-10-29 19:21:30   timeToAck       0.105
     2017-10-29 19:21:30   transmit        OK
     2017-10-24 19:14:53   version         Lib 3 Prot 4.38 App 0.48 HW 1 FWCounter 1 FW 0.15
     2017-10-24 19:15:07   zwavePlusInfo   version:01 role:AlwaysOnSlave node:Z-Wave+Node installerIcon:0700 userIcon:0700
   IODev      ZWPi
   alias      Lampe Gartenhaus
   classes    ZWAVEPLUS_INFO FIRMWARE_UPDATE_MD VERSION MANUFACTURER_SPECIFIC MULTI_CHANNEL DEVICE_RESET_LOCALLY CONFIGURATION POWERLEVEL NODE_NAMING ALARM ASSOCIATION MULTI_CHANNEL_ASSOCIATION ASSOCIATION_GRP_INFO SWITCH_BINARY SCENE_ACTIVATION SCENE_ACTUATOR_CONF SWITCH_ALL APPLICATION_STATUS SENSOR_MULTILEVEL
   icon       light_wall_1
   room       Garten
   vclasses   ALARM:4 APPLICATION_STATUS:1 ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 CONFIGURATION:1 DEVICE_RESET_LOCALLY:1 FIRMWARE_UPDATE_MD:3 MANUFACTURER_SPECIFIC:2 MULTI_CHANNEL:4 MULTI_CHANNEL_ASSOCIATION:3 NODE_NAMING:1 POWERLEVEL:1 SCENE_ACTIVATION:1 SCENE_ACTUATOR_CONF:1 SENSOR_MULTILEVEL:4 SWITCH_ALL:1 SWITCH_BINARY:1 VERSION:2 ZWAVEPLUS_INFO:2
Nach einiger Zeit normalen Betriebs fängt die Lampe an FHEM mit Events zu bomardieren:
2017-10-30 10:18:27.578 ZWave ZWave_SWITCH_BINARY_10 basicSet: 0
2017-10-30 10:18:27.628 ZWave ZWave_SWITCH_BINARY_10 basicSet: 0
2017-10-30 10:18:27.678 ZWave ZWave_SWITCH_BINARY_10 basicSet: 0
2017-10-30 10:18:27.728 ZWave ZWave_SWITCH_BINARY_10 basicSet: 0
2017-10-30 10:18:27.779 ZWave ZWave_SWITCH_BINARY_10 basicSet: 0
2017-10-30 10:18:27.828 ZWave ZWave_SWITCH_BINARY_10 basicSet: 0
2017-10-30 10:18:27.878 ZWave ZWave_SWITCH_BINARY_10 basicSet: 0
2017-10-30 10:18:27.928 ZWave ZWave_SWITCH_BINARY_10 basicSet: 0
2017-10-30 10:18:27.978 ZWave ZWave_SWITCH_BINARY_10 basicSet: 0
2017-10-30 10:18:28.028 ZWave ZWave_SWITCH_BINARY_10 basicSet: 0
2017-10-30 10:18:28.078 ZWave ZWave_SWITCH_BINARY_10 basicSet: 0
2017-10-30 10:18:28.128 ZWave ZWave_SWITCH_BINARY_10 basicSet: 0
2017-10-30 10:18:28.178 ZWave ZWave_SWITCH_BINARY_10 basicSet: 0
2017-10-30 10:18:28.228 ZWave ZWave_SWITCH_BINARY_10 basicSet: 0
Mein Zwave-Dongle ist ein Razberry in einem anderen RasPi und per Ser2Net in FHEM angebunden.
Wenn ich den Raspi mit dem Razzbery boote, hört der Spuk auf bis es dann nach einigen Stunden wieder los geht.
Hat jemand eine Idee?
Gruß Cornhoulio.
krikan
Die Assoziationen sind "seltsam".
Controller gehört in Assogroup 1; dort steht er nicht.
Dafür in allen anderen Groups. Warum?
Assogroup 2 ist für basicSet verantwortlich.
cornhoulio
Ich habe auch andere Zwave-Geräte, die machen keine Probleme.
Ich bringe das mit den Assoziationen in Ordnung und sehe dann weiter.
Danke.
