Autor Thema: ZWAVE & CUL not working in parallel after kernel/firmware update 4.9.59  (Gelesen 876 mal)
Offline Grobi
  • New Member
Hi community,
my configuration for CUL and ZWAVE @ FHEM/PI
CUL@USB /dev/ttyACM0@38400
ZWAVE@USB /dev/ttyACM1@115200
(everything fine until firmeware 4.9.58)
I  installed firmware update 4.9.59 at 29th october 2017 and getting following errors
zwave & cul (both plugged-in @ reboot): zwave = initialized but no readings, timeout; CUL = opened, no FD
I found a post from 2016 and tried some modifications @ boot
Only zwave usb adapter @ reboot = disconnected
Add CUL  @ runtime = opened, but no answer
Only CUL usb adapter @ reboot = initialized, everything ffine
Add zwave @ runtime = initialized, everything fine
Seems, that there is an issue to the actual firmware version.
Any hints to solve the issue.
Thanks in advace!
« Letzte Änderung: 31 Oktober 2017, 14:19:35 von rene.grohmann »
Offline rudolfkoenig
  • Administrator
What do you mean by "ZWAVE@USB"?
Can you please paste the FHEM definitions?
Which firmware do you mean by 4.9.59?
Can you please show us the output of "lsusb" and "ls -l /dev/ttyACM*" ?
I suppose, that after the reboot de /dev/ttyACM devices are reversed.
In this case it is better to use the file pointed to by /dev/ttyACM*
Offline Grobi
  • New Member
Hi Rudolf,
many thanks for your fast response!
Firmware as follows:
https://github.com/raspberrypi/firmware/commits/master
(installed by "sudo rpi-udate")
pi@raspberrypi:~ $ lsusb
Bus 001 Device 005: ID 03eb:204b Atmel Corp. LUFA USB to Serial Adapter Project
Bus 001 Device 009: ID 0658:0200 Sigma Designs, Inc.
Bus 001 Device 004: ID 0781:5583 SanDisk Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pi@raspberrypi:~ $ ls -l /dev/ttyACM*
crw-rw---- 1 root dialout 166, 0 Oct 31 14:14 /dev/ttyACM0
crw-rw---- 1 root dialout 166, 1 Oct 31 14:24 /dev/ttyACM1
CUL1 definition
/dev/ttyACM0@38400 xxxx
ZWAVE definition
/dev/ttyACM1@115200
As written, everything fine until last firmware update :-(
Br,
René
  • Administrator
Second try: check the output of "ls -l /dev/serial/by-*". I expect, that you find a file with "usb-busware.de_CUL868-if00" in /dev/serial/by-id, and it is pointing to ttyACM1. In this case I propose to exchange /dev/ttyACM1 with /dev/serial/by-id/usb-busware.de_CUL868-if00, and the definition for ZWAVE (I hope it is ZWDongle) with the other one.
Offline Grobi
  • New Member
Hi Rudolf,
great hint!
After changing the definitions as follows, zwave dongle and cul are working again.
/dev/serial/by-id/usb-busware.de_CUL868-if00@38400
/dev/serial/by-id/usb-0658_0200-if00@115200
Thanks and regards,
René
