Autor Thema: Anlernen von Thermostat  (Gelesen 739 mal)
Offline carpenoctem
  • New Member
« am: 11 November 2017, 19:40:52 »
ich habe mir für eine 2. Installation einen neuen nanoCUL gekauft. Dieser macht mir jedoch Probleme und ich komme zur Zeit nicht weiter.
Wenn ich ein Thermostat mit fhem pairen will, bekomme ich im Logfile folgende Fehlermeldungen:
2017.11.11 19:24:02 4: CUL_Parse: CUL0 Z1700040017AFE9000000001101A14E45513133393931383639 -45.5
2017.11.11 19:24:02 3: CUL_MAX_Parse: Pairing device 17afe9 of type HeatingThermostat with serial NEQ1399186
2017.11.11 19:24:02 1: Device changed serial from NEQ139918 to NEQ1399186
2017.11.11 19:24:07 4: CUL_Parse: CUL0 Z1700040017AFE9000000001101A14E45513133393931381211 -65.5
2017.11.11 19:24:07 3: CUL_MAX_Parse: Pairing device 17afe9 of type HeatingThermostat with serial NEQ139918
2017.11.11 19:24:08 1: Device changed serial from NEQ1399186 to NEQ139918
2017.11.11 19:24:12 4: CUL_Parse: CUL0 Z1700040017AFE9000000001101A14E45513133393931181219 -61.5
2017.11.11 19:24:13 3: CUL_MAX_Parse: Pairing device 17afe9 of type HeatingThermostat with serial NEQ13991
2017.11.11 19:24:13 1: Device changed serial from NEQ139918 to NEQ13991
2017.11.11 19:24:17 4: CUL_Parse: CUL0 Z1700040017AFE9000000001101A14E4551313339393138363B -44.5
2017.11.11 19:24:18 3: CUL_MAX_Parse: Pairing device 17afe9 of type HeatingThermostat with serial NEQ1399186
2017.11.11 19:24:18 1: Device changed serial from NEQ13991 to NEQ1399186
2017.11.11 19:24:22 4: CUL_Parse: CUL0 Z1700040017AFE9000000001101A14E45513133393931181219 -61.5
2017.11.11 19:24:22 3: CUL_MAX_Parse: Pairing device 17afe9 of type HeatingThermostat with serial NEQ13991
2017.11.11 19:24:22 1: Device changed serial from NEQ1399186 to NEQ13991
2017.11.11 19:24:27 4: CUL_Parse: CUL0 Z1700040017AFE9000000001101A14E4551313339393138363B -44.5
2017.11.11 19:24:27 3: CUL_MAX_Parse: Pairing device 17afe9 of type HeatingThermostat with serial NEQ1399186
2017.11.11 19:24:27 1: Device changed serial from NEQ13991 to NEQ1399186
2017.11.11 19:25:42 4: CUL_Parse: CUL0 ZERR300
2017.11.11 19:25:42 3: CUL0: Unknown code ZERR300, help me!
Es wirkt als ob der Empfänger nicht sauber läuft, weil sich die Serial immer ändert.
Habt ihr eine Idee woran das liegen kann? An meinem zweiten PI läuft das Thermostat einwandfrei.
list CUL0
   CMDS       ABCEeFfGhiKklMmRTtUVWXxYZz
   CUL0_MSGCNT 30
   CUL0_TIME  2017-11-11 19:37:11
   Clients    :CUL_MAX:HMS:CUL_IR:STACKABLE_CC:TSSTACKED:STACKABLE:
   DEF        /dev/serial/by-id/usb-SHK_NANO_CUL_868-if00-port0@38400 0000
   DeviceName /dev/serial/by-id/usb-SHK_NANO_CUL_868-if00-port0@38400
   FD         10
   FHTID      0000
   NAME       CUL0
   NR         27
   NR_CMD_LAST_H 17
   PARTIAL
   RAWMSG     Z0F00046012AF2A00000000190E2000A31C
   RSSI       -60
   STATE      Initialized
   TYPE       CUL
   VERSION    V 1.67 nanoCUL868
   initString X21
     2017-11-11 19:07:29   ccconf          freq:868.300MHz bWidth:101KHz rAmpl:33dB sens:8dB
     2017-11-11 19:16:34   cmds             A B C E e F f G h i K k l M m R T t U V W X x Y Z z
     2017-11-11 19:36:45   credit10ms      8
     2017-11-11 19:37:11   state           Initialized
     2017-11-11 19:07:43   uptime          0 00:07:03
   rfmode     MAX
   verbose    4
list cm
   CUL0_MSGCNT 15
   CUL0_RAWMSG Z0F00046012AF2A00000000190E2000A3
   CUL0_RSSI  -60
   DEF        123456
   IODev      CUL0
   LASTInputDev CUL0
   MSGCNT     16
   NAME       cm
   NR         29
   STATE      Defined
   TYPE       CUL_MAX
   addr       123456
   cm_MSGCNT  1
   cm_TIME    2017-11-11 19:20:07
   cnt        0
   pairmode   0
   retryCount 0
     2017-11-11 19:38:31   packetsLost     7
   sendQueue:
   IODev      CUL0
   verbose    4
RPi mit SelbstbauCUL, JeeLink und DS18B20
MAX N Basic Thermostate
Offline zweiundzwanzig
  • Full Member
Antw:Anlernen von Thermostat
« Antwort #1 am: 14 November 2017, 09:40:03 »
Können die beiden CULs sich gegenseitig "sehen"?
3x MAX CUBE mit a-culf
55x MAX Heizkörperthermostat plus
 1x MAX Wandthermostat
 1x Ubuntu Server auf VMWare
Offline carpenoctem
  • New Member
« Antwort #2 am: 15 November 2017, 17:28:45 »
Ja das konnen sie sich.
Jedoch auch, wenn der andere CUL ausgeschaltet ist, hat sich das Problem nicht gelöst.
  • Full Member
« Antwort #3 am: 19 November 2017, 12:35:09 »
Ich verstehe das nicht. Welche Serial hat das Device denn in echt? (steht im Batteriefachdeckel)
