Autor Thema: Readingsgroup und Error Argument "Bezug" isn't numeric in division  (Gelesen 1376 mal)
Offline Decki
  • Jr. Member
ich finde den Fehler nicht, obwohl dieser Fehler schon mehrfach im Forum behandelt wurde.
Hier die Fehlermeldung, die jede Minute kommt:
2017.11.19 03:56:35 1: PERL WARNING: Argument "Bezug" isn't numeric in division (/) at (eval 41814) line 1.
2017.11.19 03:56:35 1: stacktrace:
2017.11.19 03:56:35 1:     main::__ANON__                      called by (eval 41814) (1)
2017.11.19 03:56:35 1:     (eval)                              called by ./FHEM/33_readingsGroup.pm (357)
2017.11.19 03:56:35 1:     main::lookup2                       called by ./FHEM/33_readingsGroup.pm (1399)
2017.11.19 03:56:35 1:     main::readingsGroup_Notify          called by fhem.pl (3497)
2017.11.19 03:56:35 1:     main::CallFn                        called by fhem.pl (3417)
2017.11.19 03:56:35 1:     main::DoTrigger                     called by fhem.pl (4391)
2017.11.19 03:56:35 1:     main::readingsEndUpdate             called by ./FHEM/47_OBIS.pm (578)
2017.11.19 03:56:35 1:     main::OBIS_Parse                    called by ./FHEM/47_OBIS.pm (248)
2017.11.19 03:56:35 1:     main::OBIS_Read                     called by fhem.pl (3497)
2017.11.19 03:56:35 1:     main::CallFn                        called by fhem.pl (759)
Hier die Readingsgroup:
define Energiewewerte_Strom_Gas readingsGroup <Energieverbrauchswerte>,<aktuell>,<heute>,<gestern>,<Monat> \
Stromzaehler:<Stromrichtung:>,dir_total_consumption \
KaCo_Real:<akt.Solarstrom:>,AC_LEISTUNG Stromzaehler:<Einspeise-Bezugsleistung:>,power \
P_Eigenverbrauch:<akt.Solar-Eigenverbrauch:>,state \
Solarrechner:<Zählerstand-SolarStrom:>,Stromzaehler_total_feed_CounterCurrent,Stromzaehler_total_feed_EnergyDay,Stromzaehler_total_feed_EnergyDayLast,Stromzaehler_total_feed_EnergyMonth \
Stromrechner:<Zählerstand-Strom-Bezug:>,Stromzaehler_total_consumption_CounterCurrent,Stromzaehler_total_consumption_EnergyDay,Stromzaehler_total_consumption_EnergyDayLast,Stromzaehler_total_consumption_EnergyMonth\
Solarrechner:<Solar-Ertrag:>,<>,Stromzaehler_total_feed_EnergyCostDay,Stromzaehler_total_feed_EnergyCostDayLast,Stromzaehler_total_feed_EnergyCostMonth \
Stromrechner:<Stromkosten:>,<>,Stromzaehler_total_consumption_EnergyCostDay,Stromzaehler_total_consumption_EnergyCostDayLast,Stromzaehler_total_consumption_EnergyCostMonth \
Gasrechner:<Gaskosten:>,<>,Gasverbrauch_countsOverall_EnergyCostDay,Gasverbrauch_countsOverall_EnergyCostDayLast,Gasverbrauch_countsOverall_EnergyCostMonth \
Gasrechner:<Zählerstand-Gas:>,Gasverbrauch_countsOverall_Meter,Gasverbrauch_countsOverall_EnergyDay,Gasverbrauch_countsOverall_EnergyDayLast,Gasverbrauch_countsOverall_EnergyMonth\
WasserUhr:<Zählerstand-Wasseruhr:>,countsOverall_Meter\
attr Energiewewerte_Strom_Gas alias Solar- Strom- Gas- Werte:
attr Energiewewerte_Strom_Gas alwaysTrigger 2
attr Energiewewerte_Strom_Gas eventMap in:Bezug out:Einspeisung
attr Energiewewerte_Strom_Gas nameStyle {($READING eq "aktuell" ||$READING eq "heute" ||$READING eq "gestern" ||$READING eq "Monat")?'style="text-align:right"' :'style=""'}
attr Energiewewerte_Strom_Gas nonames 1
attr Energiewewerte_Strom_Gas room Energie
attr Energiewewerte_Strom_Gas userReadings EigenverbrauchInKwh: {ReadingsNum ("KaCo_Real:AC_LEISTUNG",0) + ReadingsNum ("Stromzaehler:power",0)}
attr Energiewewerte_Strom_Gas valueFormat {power => '{sprintf("%.1f W",$NUM/1)}',\
AC_LEISTUNG =>"%.1f W", state=>"%.1f W", \
countsOverall => $VALUE/100 .' m³', \
countsPerDay => $VALUE/100 .' m³', \
countsPerDay =>"%.1f m³",\
Stromzaehler_total_consumption_EnergyCostDay =>"%.2f €", \
Stromzaehler_total_consumption_EnergyCostDayLast =>"%.2f €", \
Stromzaehler_total_consumption_EnergyCostMonth =>"%.2f €", \
Stromzaehler_total_consumption_EnergyMonth =>"%.1f KWh", \
Stromzaehler_total_consumption_EnergyDay => '{sprintf( "%.1f kWh",$NUM/1000)}', \
Stromzaehler_total_consumption_EnergyDayLast =>"%.1f KWh", \
Stromzaehler_total_consumption_CounterCurrent =>"%.1f KWh", \
Stromzaehler_total_feed_CounterMonthLast => '{sprintf( "%.1f kWh",$NUM/1000)}', \
Stromzaehler_total_feed_CounterDayLast => '{sprintf( "%.1f kWh",$NUM/1000)}', \
Stromzaehler_total_feed_CounterCurrent => '{sprintf( "%.1f kWh",$NUM/1)}', \
Stromzaehler_total_feed_EnergyCostDay =>"%.2f €", \
Stromzaehler_total_feed_EnergyCostDayLast =>"%.2f €", \
Stromzaehler_total_feed_EnergyCostMonth =>"%.2f €", \
Stromzaehler_total_feed_EnergyDay =>"%.1f KWh", \
Stromzaehler_total_feed_EnergyDayLast =>"%.1f KWh", \
Stromzaehler_total_feed_EnergyMonth =>"%.1f KWh", \
Gasverbrauch_countsOverall_EnergyCostMonth => "%.2f € ", \
Gasverbrauch_countsOverall_EnergyCostDay => "%.2f € ", \
Gasverbrauch_countsOverall_EnergyMeterLast => $VALUE/100 .' m³', \
Gasverbrauch_countsOverall_EnergyCostDayLast => "%.2f € ", \
Gasverbrauch_countsOverall_Meter =>"%.1f m³", \
Gasverbrauch_countsOverall_EnergyDay => '{sprintf( "%.1f m³",$NUM/100)}', \
Gasverbrauch_countsOverall_EnergyDayLast => '{sprintf( "%.1f m³",$NUM/100)}', \
Gasverbrauch_countsOverall_EnergyMonth => '{sprintf( "%.1f m³",$NUM/100)}'}
attr Energiewewerte_Strom_Gas valueStyle {if ($READING eq "power" && $VALUE > 1){'style="color:red;;;;text-align:right"'}elsif($READING eq "power" && $VALUE < 1){'style="color:green;;;;text-align:right"'}else{'style="text-align:right"'} }
attr Energiewewerte_Strom_Gas verbose 0
und hier das dazugehörige Device:
##Stromzaehlerlesekopf
define Stromzaehler OBIS /dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_00F30001-if00-port0@9600,8,N,1, SML
attr Stromzaehler directions {">" => "Bezug", "<"=>"Einspeisung"}
attr Stromzaehler event-min-interval .*:60
attr Stromzaehler event-on-change-reading .*
attr Stromzaehler ignoreUnknown on
attr Stromzaehler interval 30
attr Stromzaehler pollingMode on
attr Stromzaehler room Unsorted
attr Stromzaehler unitReadings off
attr Stromzaehler verbose 2
define FileLog_Stromzaehler FileLog ./log/Stromzaehler-%Y-%m.log Stromzaehler:power:.*|Stromzaehler:total_consumption:.*
attr FileLog_Stromzaehler nrarchive 3
attr FileLog_Stromzaehler room Unsorted
define SVG_FileLog_Stromzaehler_1 SVG FileLog_Stromzaehler:SVG_FileLog_Stromzaehler_1:CURRENT
attr SVG_FileLog_Stromzaehler_1 room Energie
attr SVG_FileLog_Stromzaehler_1 title "Stromertrag Min $data{min1}, Max $data{max1}, Last $data{currval1}"
das ganze nochmals als list Ausgabe:
   DEF        <Energieverbrauchswerte>,<aktuell>,<heute>,<gestern>,<Monat>
   NAME       Energiewewerte_Strom_Gas
   NR         303
   NTFY_ORDER 50-Energiewewerte_Strom_Gas
   STATE      Initialized
   TYPE       readingsGroup
   alwaysTrigger 2
   mayBeVisible 1
   CONTENT:
     Gasrechner 1
     KaCo_Real  1
     P_Eigenverbrauch 1
     Solarrechner 1
     Stromrechner 1
     Stromzaehler 1
     WasserUhr  1
   CONTENT2:
   DEVICES:
     ARRAY(0x3764958)
     ARRAY(0x279b6f0)
     ARRAY(0x383a0c0)
     ARRAY(0x328eae8)
     ARRAY(0x328b638)
     ARRAY(0x3606290)
     ARRAY(0x3859710)
     ARRAY(0x37fd3e0)
     ARRAY(0x3628250)
     ARRAY(0x3589be0)
     ARRAY(0x37fede0)
     ARRAY(0x32675d0)
   fhem:
     lastDefChange 16
     last_update 1511199992.16543
   helper:
     DEF
     valueStyle {if ($READING eq "power" && $VALUE > 1){'style="color:red;;text-align:right"'}elsif($READING eq "power" && $VALUE < 1){'style="color:green;;text-align:right"'}else{'style="text-align:right"'} }
     positions:
       Gasrechner.Gasverbrauch_countsOverall_EnergyCostDay 10:3
       Gasrechner.Gasverbrauch_countsOverall_EnergyCostDayLast 10:4
       Gasrechner.Gasverbrauch_countsOverall_EnergyCostMonth 10:5
       Gasrechner.Gasverbrauch_countsOverall_EnergyDay 11:3
       Gasrechner.Gasverbrauch_countsOverall_EnergyDayLast 11:4
       Gasrechner.Gasverbrauch_countsOverall_EnergyMonth 11:5
       Gasrechner.Gasverbrauch_countsOverall_Meter 11:2
       KaCo_Real.AC_LEISTUNG 3:2
       P_Eigenverbrauch.state 5:2
       Solarrechner.Stromzaehler_total_feed_CounterCurrent 6:2
       Solarrechner.Stromzaehler_total_feed_EnergyCostDay 8:3
       Solarrechner.Stromzaehler_total_feed_EnergyCostDayLast 8:4
       Solarrechner.Stromzaehler_total_feed_EnergyCostMonth 8:5
       Solarrechner.Stromzaehler_total_feed_EnergyDay 6:3
       Solarrechner.Stromzaehler_total_feed_EnergyDayLast 6:4
       Solarrechner.Stromzaehler_total_feed_EnergyMonth 6:5
       Stromrechner.Stromzaehler_total_consumption_CounterCurrent 7:2
       Stromrechner.Stromzaehler_total_consumption_EnergyCostDay 9:3
       Stromrechner.Stromzaehler_total_consumption_EnergyCostDayLast 9:4
       Stromrechner.Stromzaehler_total_consumption_EnergyCostMonth 9:5
       Stromrechner.Stromzaehler_total_consumption_EnergyDay 7:3
       Stromrechner.Stromzaehler_total_consumption_EnergyDayLast 7:4
       Stromrechner.Stromzaehler_total_consumption_EnergyMonth 7:5
       Stromzaehler.dir_total_consumption 2:2
       Stromzaehler.power 4:2
     values:
       formated:
         undef
         undef
         ARRAY(0x3873718)
         ARRAY(0x3854dd0)
         ARRAY(0x32625c0)
         ARRAY(0x36fc388)
       orig:
         undef
         undef
         ARRAY(0x38705f0)
         ARRAY(0x38545a8)
         ARRAY(0x3582780)
         ARRAY(0x3841c48)
       prefixsuffix:
         undef
         undef
         ARRAY(0x3854410)
         ARRAY(0x37fdb60)
         ARRAY(0x384b4a8)
         ARRAY(0x382ed30)
   alwaysTrigger 2
   nonames    1
   room       Energie
   verbose    0
Hier wird das "Richtungszeichen" gegen Einspeisung oder Bezug ausgetauscht. es ist das Reading dir_total_consumption, welches auch mit Bezug oder Einspeisung angezeigt wird.
Mit Stromrichtung wird nichts berechnet. Kann ich nicht einen ersetzten Wert in Readingsgroup benutzen?
Danke für eure Hilfe
Andy
« Letzte Änderung: 20 November 2017, 21:50:46 von Decki »
Raspi 2 im Schaltschrank, USB IR Lesekopf am EHz21, Gaszähler mit Reedkontakt, Jeelink,  16 FS20 Aktoren,  3 Ufos für LED, 11 FS20 Rolladenaktore, AMAD 4.0 mit Sprachausgabe
Offline Decki
  • Jr. Member
Antw:Readingsgroup und Error Argument "Bezug" isn't numeric in division
« Antwort #1 am: 23 November 2017, 23:02:21 »
hat keiner eine Idee, was den Fehler verursacht?
Offline amenomade
« Antwort #2 am: 24 November 2017, 01:41:09 »
Ich muss sagen: ich habe versucht, mich damit zu beschäftigen, aber dein Ding ist so komplex, dass ich aufgegeben habe. Kannst Du vielleicht das Problem begrenzen, indem Du die Struktur deines ReadingsGroups schlanker machst?
FHEM 5.8 Pi 3, EchoDot, CUL868+Selbstbau 1/2λ-Dipol-Antenne, USB Optolink / Vitotronic, und HM Komponenten, Rademacher Duofern Jalousien, Fritz!Dect Thermostaten
Offline Decki
  • Jr. Member
« Antwort #3 am: 24 November 2017, 15:32:13 »
Hallo amenomade,
danke für deine Benühungen. Hier weiter Infos zu dem Problem.
wenn ich in der Readingsgroup diesen Eintrag entferne, dann  wird das log nicht mehr geflutet:
Das ist das Reading aus dem OBIS Modul Stromzaehler mit diesem Attribut:
attr Stromzaehler directions {">" => "Bezug", "<"=>"Einspeisung"}. Das komische ist, dass ich den Wert des Attributs drections überschreibe, aber es dann noch das Attribut dir_total_consumption gibt, das dann den Wert Bezug oder Einspeisung hat. Directions selbst kann ich nicht als Readings auswählen.
Gruss Andreas
Offline amenomade
« Antwort #4 am: 24 November 2017, 18:50:22 »
Zeig mal bitte ein "list Stromzaehler"
Offline Decki
  • Jr. Member
« Antwort #5 am: 26 November 2017, 16:14:54 »
Hier das list Stromzaehler
   DEF        /dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_00F30001-if00-port0@9600,8,N,1, SML
   DeviceName /dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_00F30001-if00-port0@9600,8,N,1,
   MeterType  SML
   NAME       Stromzaehler
   NR         194
   PARTIAL
   STATE      opened
   TYPE       OBIS
     2016-08-05 19:56:34   1.0.0.0.9.255   06-45-4D-48-01-04-C5-6C-B8-C3
     2016-08-05 19:56:34   129.129.199.130.3.255 EMH
     2016-08-05 19:56:34   129.129.199.130.5.255 110C-DE3D-9852-AA33-FCB8-C1B2-0838-F645-2DEA-81C2-F1B5-3196-AD19-E2DA-210C-1E20-E1DA-6AB2-0139-9CE3-5131-AC3D-07BB-E598-01
     2017-11-25 16:45:53   Version         EMH\06454D480104C56CB8C3
     2017-11-26 16:13:04   dir_total_consumption Bezug
     2017-11-26 16:13:04   dir_total_feed  Bezug
     2017-11-26 16:13:04   power           2477.5
     2017-11-23 21:17:36   state           opened
     2017-11-26 16:13:04   total_consumption 7474685.8
     2017-11-26 16:13:04   total_consumption_Ch1 7474685.8
     2017-11-26 16:13:04   total_consumption_Ch2 0
     2017-11-26 16:13:04   total_feed      32567337.2
     2017-11-26 16:13:04   total_feed_Ch1  32567337.2
     2017-11-26 16:13:04   total_feed_Ch2  0
   helper:
     BUFFER
     EoM        1
     SPEED      5
     SPEED2     5
     TRIGGERTIME 1511468256.3155
     Channels:
     DEVICES:
       30
     directions:
       <          Einspeisung
       >          Bezug
   ignoreUnknown on
   interval   30
   pollingMode on
   room       Unsorted
   unitReadings off
   verbose    2
Offline amenomade
« Antwort #6 am: 26 November 2017, 22:31:35 »
Hmm. Ich kann mich es nicht erklären. Kannst Du eventuell den Stromzäehler auf verbose 5 setzen, und ein Log Auszug zeigen? Nur um zu gucken wie das reading mit "directions" sich verhält.
Offline Decki
  • Jr. Member
« Antwort #7 am: 27 November 2017, 20:13:38 »
Hier das Logprotokoll:2017.11.27 20:09:19 5: SW:
2017.11.27 20:09:19 4: Wrote
2017.11.27 20:09:19 5: OBIS (Stromzaehler) - Internal timer set to 2017-11-27 20:09:49
2017.11.27 20:09:21 5: SML-Parse 1B1B1B1B010101017607001017D4AB77620062007263010176010107001009528E7D0B06454D480104C56CB8C3010163DEFA007607001017D4AB78620062007263070177010B06454D480104C56CB8C3070100620AFFFF726201650952FA457A77078181C78203FF0101010104454D480177070100000009FF010101010B06454D480104C56CB8C30177070100010800FF6401018201621E52FF56000475C21A0177070100020800FF6401018201621E52FF560013699AB50177070100010801FF0101621E52FF56000475C21A0177070100020801FF0101621E52FF560013699AB50177070100010802FF0101621E52FF5600000000000177070100020802FF0101621E52FF5600000000000177070100100700FF0101621B52FF55000016380177078181C78205FF01726201650952FA4501018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101638EAE007607001017D4AB7B6200620072630201710163F4E700001B1B1B1B1A01B920
2017.11.27 20:09:21 5: OBIS: Full message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
2017.11.27 20:09:21 5: OBIS: Telegram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
2017.11.27 20:09:21 5: OBIS: Telegram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
2017.11.27 20:09:21 5: OBIS: Telegram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
2017.11.27 20:09:21 5: OBIS: Telegram=0177070100020800FF6401018201621E52FF560013699AB50177070100010801FF0101621E52FF56000475C21A0177070100020801FF0101621E52FF560013699AB50177070100010802FF0101621E52FF5600000000000177070100020802FF0101621E52FF5600000000000177070100100700FF0101621B52FF55000016380177078181C78205FF01726201650952FA4501018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101638EAE007607001017D4AB7B6200620072630201710163F4E700001B1B1B1B1A01B920
2017.11.27 20:09:21 5: OBIS: Telegram=0177070100010801FF0101621E52FF56000475C21A0177070100020801FF0101621E52FF560013699AB50177070100010802FF0101621E52FF5600000000000177070100020802FF0101621E52FF5600000000000177070100100700FF0101621B52FF55000016380177078181C78205FF01726201650952FA4501018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101638EAE007607001017D4AB7B6200620072630201710163F4E700001B1B1B1B1A01B920
2017.11.27 20:09:21 5: OBIS: Telegram=0177070100020801FF0101621E52FF560013699AB50177070100010802FF0101621E52FF5600000000000177070100020802FF0101621E52FF5600000000000177070100100700FF0101621B52FF55000016380177078181C78205FF01726201650952FA4501018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101638EAE007607001017D4AB7B6200620072630201710163F4E700001B1B1B1B1A01B920
2017.11.27 20:09:21 5: OBIS: Telegram=0177070100010802FF0101621E52FF5600000000000177070100020802FF0101621E52FF5600000000000177070100100700FF0101621B52FF55000016380177078181C78205FF01726201650952FA4501018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101638EAE007607001017D4AB7B6200620072630201710163F4E700001B1B1B1B1A01B920
2017.11.27 20:09:21 5: OBIS: Telegram=0177070100020802FF0101621E52FF5600000000000177070100100700FF0101621B52FF55000016380177078181C78205FF01726201650952FA4501018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101638EAE007607001017D4AB7B6200620072630201710163F4E700001B1B1B1B1A01B920
2017.11.27 20:09:21 5: OBIS: Telegram=0177070100100700FF0101621B52FF55000016380177078181C78205FF01726201650952FA4501018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101638EAE007607001017D4AB7B6200620072630201710163F4E700001B1B1B1B1A01B920
2017.11.27 20:09:21 5: OBIS: Telegram=0177078181C78205FF01726201650952FA4501018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101638EAE007607001017D4AB7B6200620072630201710163F4E700001B1B1B1B1A01B920
2017.11.27 20:09:21 4: MSG IS:
/EMH\06454D480104C56CB8C3
129-129:199.130.3*255(EMH)
1-0:0.0.9*255(06454D480104C56CB8C3)
1-0:1.8.0*255(>7482626.6*Wh)
1-0:2.8.0*255(>32568798.9*Wh)
1-0:1.8.1*255(7482626.6*Wh)
1-0:2.8.1*255(32568798.9*Wh)
1-0:1.8.2*255(0*Wh)
1-0:2.8.2*255(0*Wh)
1-0:16.7.0*255(568.8*W)
129-129:199.130.5*255(110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE59801)
2017.11.27 20:09:21 5: OBIS (Stromzaehler) - Msg-Parse: /EMH\06454D480104C56CB8C3
2017.11.27 20:09:21 5: OBIS (Stromzaehler) - Msg-Parse: 129-129:199.130.3*255(EMH)
2017.11.27 20:09:21 5: Msg 129-129:199.130.3*255(EMH) is of type ManufID
2017.11.27 20:09:21 5: OBIS (Stromzaehler) - Msg-Parse: 1-0:0.0.9*255(06454D480104C56CB8C3)
2017.11.27 20:09:21 5: Msg 1-0:0.0.9*255(06454D480104C56CB8C3) is of type Serial
2017.11.27 20:09:21 5: OBIS (Stromzaehler) - Msg-Parse: 1-0:1.8.0*255(>7482626.6*Wh)
2017.11.27 20:09:21 5: Msg 1-0:1.8.0*255(>7482626.6*Wh) is of type Counter
2017.11.27 20:09:21 4: Set total_consumption to 7482626.6
2017.11.27 20:09:21 5: OBIS (Stromzaehler) - Msg-Parse: 1-0:2.8.0*255(>32568798.9*Wh)
2017.11.27 20:09:21 5: Msg 1-0:2.8.0*255(>32568798.9*Wh) is of type Counter
2017.11.27 20:09:21 5: OBIS (Stromzaehler) - Msg-Parse: 1-0:1.8.1*255(7482626.6*Wh)
2017.11.27 20:09:21 5: Msg 1-0:1.8.1*255(7482626.6*Wh) is of type Counter
2017.11.27 20:09:21 4: Set total_consumption_Ch1 to 7482626.6
2017.11.27 20:09:21 5: OBIS (Stromzaehler) - Msg-Parse: 1-0:2.8.1*255(32568798.9*Wh)
2017.11.27 20:09:21 5: Msg 1-0:2.8.1*255(32568798.9*Wh) is of type Counter
2017.11.27 20:09:21 5: OBIS (Stromzaehler) - Msg-Parse: 1-0:1.8.2*255(0*Wh)
2017.11.27 20:09:21 5: Msg 1-0:1.8.2*255(0*Wh) is of type Counter
2017.11.27 20:09:21 4: Set total_consumption_Ch2 to 0
2017.11.27 20:09:21 5: OBIS (Stromzaehler) - Msg-Parse: 1-0:2.8.2*255(0*Wh)
2017.11.27 20:09:21 5: Msg 1-0:2.8.2*255(0*Wh) is of type Counter
2017.11.27 20:09:21 5: OBIS (Stromzaehler) - Msg-Parse: 1-0:16.7.0*255(568.8*W)
2017.11.27 20:09:21 5: Msg 1-0:16.7.0*255(568.8*W) is of type Channels
2017.11.27 20:09:21 5: OBIS (Stromzaehler) - Msg-Parse: 129-129:199.130.5*255(110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE59801)
2017.11.27 20:09:21 5: Msg 129-129:199.130.5*255(110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE59801) is of type PublicKey
2017.11.27 20:09:21 5: OBIS (Stromzaehler) - Msg-Parse: !
2017.11.27 20:09:21 1: RMDIR: ./restoreDir/2017-11-21
2017.11.27 20:09:49 5: SW:
2017.11.27 20:09:49 4: Wrote
2017.11.27 20:09:49 5: OBIS (Stromzaehler) - Internal timer set to 2017-11-27 20:10:19
2017.11.27 20:09:52 5: SML-Parse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
2017.11.27 20:09:52 5: OBIS: Full message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
2017.11.27 20:09:52 5: OBIS: Telegram=1B1B1B1B010101017607001017D4ABD7620062007263010176010107001009528E9D0B06454D480104C56CB8C3010163E464007607001017D4ABD8620062007263070177010B06454D480104C56CB8C3070100620AFFFF726201650952FA637A77078181C78203FF0101010104454D480177070100000009FF010101010B06454D480104C56CB8C30177070100010800FF6401018201621E52FF56000475C24A0177070100020800FF6401018201621E52FF560013699AB50177070100010801FF0101621E52FF56000475C24A0177070100020801FF0101621E52FF560013699AB50177070100010802FF0101621E52FF5600000000000177070100020802FF0101621E52FF5600000000000177070100100700FF0101621B52FF55000015AC0177078181C78205FF01726201650952FA6301018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101633BAB007607001017D4ABDB6200620072630201710163659700001B1B1B1B1A010F1E
2017.11.27 20:09:52 5: OBIS: Telegram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
2017.11.27 20:09:52 5: OBIS: Telegram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
2017.11.27 20:09:52 5: OBIS: Telegram=0177070100020800FF6401018201621E52FF560013699AB50177070100010801FF0101621E52FF56000475C24A0177070100020801FF0101621E52FF560013699AB50177070100010802FF0101621E52FF5600000000000177070100020802FF0101621E52FF5600000000000177070100100700FF0101621B52FF55000015AC0177078181C78205FF01726201650952FA6301018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101633BAB007607001017D4ABDB6200620072630201710163659700001B1B1B1B1A010F1E
2017.11.27 20:09:52 5: OBIS: Telegram=0177070100010801FF0101621E52FF56000475C24A0177070100020801FF0101621E52FF560013699AB50177070100010802FF0101621E52FF5600000000000177070100020802FF0101621E52FF5600000000000177070100100700FF0101621B52FF55000015AC0177078181C78205FF01726201650952FA6301018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101633BAB007607001017D4ABDB6200620072630201710163659700001B1B1B1B1A010F1E
2017.11.27 20:09:52 5: OBIS: Telegram=0177070100020801FF0101621E52FF560013699AB50177070100010802FF0101621E52FF5600000000000177070100020802FF0101621E52FF5600000000000177070100100700FF0101621B52FF55000015AC0177078181C78205FF01726201650952FA6301018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101633BAB007607001017D4ABDB6200620072630201710163659700001B1B1B1B1A010F1E
2017.11.27 20:09:52 5: OBIS: Telegram=0177070100010802FF0101621E52FF5600000000000177070100020802FF0101621E52FF5600000000000177070100100700FF0101621B52FF55000015AC0177078181C78205FF01726201650952FA6301018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101633BAB007607001017D4ABDB6200620072630201710163659700001B1B1B1B1A010F1E
2017.11.27 20:09:52 5: OBIS: Telegram=0177070100020802FF0101621E52FF5600000000000177070100100700FF0101621B52FF55000015AC0177078181C78205FF01726201650952FA6301018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101633BAB007607001017D4ABDB6200620072630201710163659700001B1B1B1B1A010F1E
2017.11.27 20:09:52 5: OBIS: Telegram=0177070100100700FF0101621B52FF55000015AC0177078181C78205FF01726201650952FA6301018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101633BAB007607001017D4ABDB6200620072630201710163659700001B1B1B1B1A010F1E
2017.11.27 20:09:52 5: OBIS: Telegram=0177078181C78205FF01726201650952FA6301018302110CDE3D9852AA33FCB8C1B20838F6452DEA81C2F1B53196AD19E2DA210C1E20E1DA6AB201399CE35131AC3D07BBE598010101633BAB007607001017D4ABDB6200620072630201710163659700001B1B1B1B1A010F1E
2017.11.27 20:09:52 4: MSG IS:
1-0:1.8.0*255(>7482631.4*Wh)
Ich hoffe dass das weiterhilft.
Andreas
Offline Decki
  • Jr. Member
« Antwort #8 am: 05 Dezember 2017, 09:42:32 »
kann ich alternativ das Errorlogging dieser  Readingsgroup deaktivieren?
Verbose=0 habe ich schon, aber das Log-File wird immer noch zugemüllt.
Offline Decki
  • Jr. Member
Hier noch weitere Hinweise zur Lösung meines Problems:
In der Readingsgroup Zeile Stromzaehler:<Stromrichtung:>,dir_total_consumption  ist der "Wert" dir_total_consumption Text und keine Zahl, nämlich Bezug.
Erwartet die Readingsgroup hier numerische Werte?
Was muss ich machen, damit hier Text angenommen wird? Der Text Bezug wird in der Readingsgroup nicht umformatiert, deshalb ist die Fehlermeldung "Bezug" isn't numeric in division etwas seltsam.
decade-submarginal
