Autor Thema: Upgrade to 5.8 breaks MYSQL logging  (Gelesen 290 mal)
Offline nottledim
  • Newbie
« am: 24 November 2017, 16:56:31 »
I'm not sure the best place to report this.  I recently upgraded FHEM to v5.8, previously 5.7 using the same config file.  I found that all logging to mysql ceased.  Log file reports logging to mysql configured and reports no errors.  I've no idea what's wrong.
Offline rudolfkoenig
  • Administrator
Antw:Upgrade to 5.8 breaks MYSQL logging
« Antwort #1 am: 24 November 2017, 17:04:33 »
Here, or in the area dedicated to the FHEM-Module affected, which is "Automatisierung" if the Module is DbLog. See also http://fhem.de/MAINTAINER.txt
I hope you've also executed the FHEM update command after the upgrade, as there is a chance that your problem was fixed in the meantime. The package available on the webpage is only meant as a starting point, to shorten the list of files transferred by upload.
