Autor Thema: Eltako state telegram  (Gelesen 1598 mal)
Offline claudio
  • New Member
« am: 16 Dezember 2017, 02:18:18 »
Do you know if it is possible to automatically request the Eltako's bus actor state (FSR14x2 in my case) via fhem or even setup the FAM14 to periodically send the actors state telegram to fhem ? The problem is sometimes, the state shown via fhem web interface could be wrong (not synced) with the actual state of the actor.
Actually, my FAM14 is setup like this :
Auto : position 1
BA : position 2
I've seen in the FAM14 manual that in position 4, state telegrams are asked to the actors but then, it doesn't send thoses on wireless network, so fhem could not receive them
Anyone ?
Offline claudio
  • New Member
Antw:Eltako state telegram
« Antwort #1 am: 06 Januar 2018, 03:04:08 »
Since I do not save the logs on harddrive or flash memory (ram only to prevent flash wearing), the state of my actuators are lost upon reboot of the fhem's hardware. Then, I do not know if an actuator is on or off. Do you have a solution for this (without saving the logs or state) ?
do you know why the eltako bus isn't broadcasting the status of actuators at regulars intervals for fhem to update the status ?
Offline fibbi
  • New Member
« Antwort #2 am: 11 Februar 2018, 21:02:05 »
I have the same problem, have you found any solutions?
Offline claudio
  • New Member
« Antwort #3 am: 26 Februar 2018, 02:36:18 »
Hi, no I've found a solution yet. The states of actuators are sometimes out of sync whith fhem
