Autor Thema: Divoom Aurabox + Timebox + TimeboxEvo [Update, kommunizieren funktioniert]  (Gelesen 24419 mal)
Offline mumpitzstuff
sudo cpan upgrade GD
Wie sieht’s damit aus? Du bist genau eine Version unter der benötigten...
Offline LaMa163
  • New Member
Scheint kein Update installieren zu können.
@FHEM:~ $ sudo cpan upgrade GD
Loading internal null logger. Install Log::Log4perl for logging messages
Reading '/root/.cpan/Metadata'
  Database was generated on Sat, 18 Jan 2020 05:55:12 GMT
Warning: Cannot install upgrade, don't know what it is.
Try the command
    i /upgrade/
to find objects with matching identifiers.
Running install for module 'GD'
Checksum for /root/.cpan/sources/authors/id/R/RU/RURBAN/GD-2.71.tar.gz ok
'YAML' not installed, will not store persistent state
Configuring R/RU/RURBAN/GD-2.71.tar.gz with Makefile.PL
Package gdlib was not found in the pkg-config search path.
Perhaps you should add the directory containing `gdlib.pc'
to the PKG_CONFIG_PATH environment variable
No package 'gdlib' found
 at Makefile.PL line 449.
*** can not find package gdlib
*** check that it is properly installed and available in PKG_CONFIG_PATH
Warning: No success on command[/usr/bin/perl Makefile.PL INSTALLDIRS=site]
  /usr/bin/perl Makefile.PL INSTALLDIRS=site -- NOT OK
« Letzte Änderung: 19 Januar 2020, 00:08:12 von mumpitzstuff »
