Natural Language User Interface 95_Babble.pm
Begonnen von Prof. Dr. Peter Henning, 28 Dezember 2017, 17:37:03
the ratman
so, einmal nerv ich noch. nur, damits nicht untergeht:
die warnings beim aufrufen von babble sind immer noch da ... falls man da was tun könnte ...
das kommt bei jedem einzelnen aufruf:2018.02.28 16:10:05 1: logfile wurde von hand gelöscht
2018.02.28 19:12:24 1: [Babble_getdevs] No entry in command table under wetter for local FHEM device proplanta with attribute babbleDevice=wetter
2018.02.28 19:12:24 1: PERL WARNING: Use of uninitialized value $l in print at fhem.pl line 4925.
2018.02.28 19:12:24 1: eval: {Babble_Html("babble")}
2018.02.28 19:12:24 1: stacktrace:
2018.02.28 19:12:24 1:     main::__ANON__                      called by fhem.pl (4925)
2018.02.28 19:12:24 1:     main::FileWrite                     called by ./FHEM/95_Babble.pm (449)
2018.02.28 19:12:24 1:     main::Babble_save                   called by ./FHEM/95_Babble.pm (1705)
2018.02.28 19:12:24 1:     main::Babble_getplaces              called by ./FHEM/95_Babble.pm (1905)
2018.02.28 19:12:24 1:     main::Babble_Html                   called by (eval 81025) (1)
2018.02.28 19:12:24 1:     (eval)                              called by fhem.pl (1079)
2018.02.28 19:12:24 1:     main::AnalyzePerlCommand            called by ./FHEM/98_weblink.pm (99)
2018.02.28 19:12:24 1:     main::weblink_FwFn                  called by ./FHEM/01_FHEMWEB.pm (1896)
2018.02.28 19:12:24 1:     main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (1067)
2018.02.28 19:12:24 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (537)
2018.02.28 19:12:24 1:     main::FW_Read                       called by fhem.pl (3528)
2018.02.28 19:12:24 1:     main::CallFn                        called by fhem.pl (690)
2018.02.28 19:12:24 1: [Babble_save]
2018.02.28 19:12:24 1:     main::Babble_save                   called by ./FHEM/95_Babble.pm (1848)
2018.02.28 19:12:24 1:     main::Babble_getwords               called by ./FHEM/95_Babble.pm (1921)
2018.02.28 19:12:24 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/95_Babble.pm line 1979.
2018.02.28 19:12:24 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (1979)
2018.02.28 19:12:24 1: PERL WARNING: Use of uninitialized value $cmd in index at ./FHEM/95_Babble.pm line 2059.
2018.02.28 19:12:24 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (2059)
2018.02.28 19:12:24 1: PERL WARNING: Use of uninitialized value $cmd in concatenation (.) or string at ./FHEM/95_Babble.pm line 2077.
2018.02.28 19:12:24 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (2077)
2018.02.28 19:12:25 1: PERL WARNING: Use of uninitialized value $l in print at fhem.pl line 4925.
2018.02.28 19:12:25 1: eval: {Babble_Html("babble")}
2018.02.28 19:12:25 1: stacktrace:
2018.02.28 19:12:25 1:     main::__ANON__                      called by fhem.pl (4925)
2018.02.28 19:12:25 1:     main::FileWrite                     called by ./FHEM/95_Babble.pm (449)
2018.02.28 19:12:25 1:     main::Babble_save                   called by ./FHEM/95_Babble.pm (1705)
2018.02.28 19:12:25 1:     main::Babble_getplaces              called by ./FHEM/95_Babble.pm (1905)
2018.02.28 19:12:25 1:     main::Babble_Html                   called by (eval 81031) (1)
2018.02.28 19:12:25 1:     (eval)                              called by fhem.pl (1079)
2018.02.28 19:12:25 1:     main::AnalyzePerlCommand            called by ./FHEM/98_weblink.pm (99)
2018.02.28 19:12:25 1:     main::weblink_FwFn                  called by ./FHEM/01_FHEMWEB.pm (1896)
2018.02.28 19:12:25 1:     main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (1067)
2018.02.28 19:12:25 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (537)
2018.02.28 19:12:25 1:     main::FW_Read                       called by fhem.pl (3528)
2018.02.28 19:12:25 1:     main::CallFn                        called by fhem.pl (690)
2018.02.28 19:12:25 1: [Babble_save]
2018.02.28 19:12:25 1:     main::Babble_save                   called by ./FHEM/95_Babble.pm (1848)
2018.02.28 19:12:25 1:     main::Babble_getwords               called by ./FHEM/95_Babble.pm (1921)
2018.02.28 19:12:25 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/95_Babble.pm line 1979.
2018.02.28 19:12:25 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (1979)
2018.02.28 19:12:25 1: PERL WARNING: Use of uninitialized value $cmd in index at ./FHEM/95_Babble.pm line 2059.
2018.02.28 19:12:25 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (2059)
2018.02.28 19:12:25 1: PERL WARNING: Use of uninitialized value $cmd in concatenation (.) or string at ./FHEM/95_Babble.pm line 2077.
2018.02.28 19:12:25 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (2077)
→do↑p!dnʇs↓shit←
OK, back again.
Bitte mal die komplette Definition von Babble posten, und idealerweise eine Kopie des BabbleFile.
pah
the ratman
der listInternals:
   NAME       babble
   NR         177
   STATE      Initialized
   TYPE       Babble
   VERSION    1.31
   DATA:
     re_articles ((der)|(die)|(das)|(den)|(des)|(dem)|(zur))
     re_devs    ((wetter))
     re_ids     ((hallo))
     re_places  ((start)|(frontends)|(fhem)|(fritzbox)|(computer)|(homematic)|(hue)|(harmony)|(kalender)|(umwelt)|(multimedia)|(logik und schalten)|(wohnzimmer)|(schlafzimmer)|(bad)|(gästezimmer)|(treibhaus)|(terrasse)|(draussen))
     re_prepos  ((von)|(vom)|(des)|(der)|(in)|(im)|(auf)|(bei)|(am))
     re_quests  ((wie)|(wo)|(wann))
     re_status  ((status)|(wert)|(wetter)|(zeit))
     re_times   ((heute)|(morgen)|(übermorgen)|(nacht)|(vormittag)|(nachmittag))
     re_verbparts ((zu)|(auf)|(ent)|(wider)|(ein)|(an)|(aus)|(ab)|(um))
     re_verbsc  ((mache)|(schalten)|(sagen)|(machen)|(machs)|(öffnen)|(schließe)|(schalte)|(sag)|(schließen)|(sags)|(schalt)|(öffne)|(mach)|(schließ))
     re_verbsi  (?P<verbsi>(schalten)|(machen)|(öffnen)|(schließen)|(sagen))
     re_writes  ((status)|(wert)|(wetter)|(zeit))
     articles:
       der
       die
       das
       den
       des
       dem
       zur
     command:
       wetter:
         none:
           none:
             none
     devcontacts:
       wetter:
         wetter
         proplanta
         0
     devs:
       wetter
     devsalias:
       wetter:
         0
     help:
     places:
       start
       frontends
       fhem
       fritzbox
       computer
       homematic
       hue
       harmony
       kalender
       umwelt
       multimedia
       logik und schalten
       wohnzimmer
       schlafzimmer
       bad
       gästezimmer
       treibhaus
       terrasse
       draussen
     prepos:
       von
       vom
       des
       der
       in
       im
       auf
       bei
       am
     quests:
       wie
       wo
       wann
     rooms:
       start
       frontends
       fhem
       fritzbox
       computer
       homematic
       hue
       harmony
       kalender
       umwelt
       multimedia
       logik und schalten
     splaces:
       wohnzimmer
       schlafzimmer
       bad
       gästezimmer
       treibhaus
       terrasse
       draussen
     status:
       Status
       Wert
       Wetter
       Zeit
     times:
       heute
       morgen
       übermorgen
       nacht
       vormittag
       nachmittag
     verbparts:
       zu
       auf
       ent
       wider
       ein
       an
       aus
       ab
       um
     verbs:
       mach       machen
       mache      machen
       machen     machen
       machs      machen
       sag        sagen
       sagen      sagen
       sags       sagen
       schalt     schalten
       schalte    schalten
       schalten   schalten
       schließ   schließen
       schließe  schließen
       schließen schließen
       öffne     öffnen
       öffnen    öffnen
     verbsi:
       schalten
       machen
       öffnen
       schließen
       sagen
     verbsicc:
       ARRAY(0x55e4d05b9f10)
       ARRAY(0x55e4d0579bf0)
       ARRAY(0x55e4d05bfa90)
       ARRAY(0x55e4d055be90)
       ARRAY(0x55e4d0314a28)
     writes:
       Status
       Wert
       Wetter
       Zeit
     2018-02-28 15:28:06   lockstate       unlocked
     2018-03-10 08:02:54   savedate        Sat Mar 10 08:02:54 2018
     2018-03-09 08:37:42   state           Initialized
   babbleArticles der die das den des dem zur
   babblePlaces wohnzimmer schlafzimmer bad gästezimmer treibhaus terrasse draussen
   babblePrepos von vom des der in im auf bei am
   babbleQuests wie wo wann
   babbleStatus Status Wert Wetter Zeit
   babbleTimes heute morgen übermorgen nacht vormittag nachmittag
   babbleVerbParts zu auf ent wider ein an aus ab um
   babbleVerbs schalt,schalte:schalten mach,machs,mache:machen öffne:öffnen schließe,schließ:schließen sag,sags:sagen
   babbleWrites sagen senden hinzufügen entfernen ändern löschen
   noChatBot  0
   room       babbleRoom
sicherheitshalber noch alles, was das log schreibt am weg von der startseite zum device2018.03.10 08:02:54 1: [Babble_getdevs] No entry in command table under wetter for local FHEM device proplanta with attribute babbleDevice=wetter
2018.03.10 08:02:54 1: PERL WARNING: Use of uninitialized value $l in print at fhem.pl line 4964.
2018.03.10 08:02:54 1: eval: {Babble_Html("babble")}
2018.03.10 08:02:54 1: stacktrace:
2018.03.10 08:02:54 1:     main::__ANON__                      called by fhem.pl (4964)
2018.03.10 08:02:54 1:     main::FileWrite                     called by ./FHEM/95_Babble.pm (449)
2018.03.10 08:02:54 1:     main::Babble_save                   called by ./FHEM/95_Babble.pm (1705)
2018.03.10 08:02:54 1:     main::Babble_getplaces              called by ./FHEM/95_Babble.pm (1905)
2018.03.10 08:02:54 1:     main::Babble_Html                   called by (eval 550647) (1)
2018.03.10 08:02:54 1:     (eval)                              called by fhem.pl (1095)
2018.03.10 08:02:54 1:     main::AnalyzePerlCommand            called by ./FHEM/98_weblink.pm (99)
2018.03.10 08:02:54 1:     main::weblink_FwFn                  called by ./FHEM/01_FHEMWEB.pm (1901)
2018.03.10 08:02:54 1:     main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (1072)
2018.03.10 08:02:54 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (538)
2018.03.10 08:02:54 1:     main::FW_Read                       called by fhem.pl (3546)
2018.03.10 08:02:54 1:     main::CallFn                        called by fhem.pl (706)
2018.03.10 08:02:54 1: [Babble_save]
2018.03.10 08:02:54 1:     main::Babble_save                   called by ./FHEM/95_Babble.pm (1848)
2018.03.10 08:02:54 1:     main::Babble_getwords               called by ./FHEM/95_Babble.pm (1921)
2018.03.10 08:02:54 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/95_Babble.pm line 1979.
2018.03.10 08:02:54 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (1979)
2018.03.10 08:02:54 1: PERL WARNING: Use of uninitialized value $cmd in index at ./FHEM/95_Babble.pm line 2059.
2018.03.10 08:02:54 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (2059)
2018.03.10 08:02:54 1: PERL WARNING: Use of uninitialized value $cmd in concatenation (.) or string at ./FHEM/95_Babble.pm line 2077.
2018.03.10 08:02:54 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (2077)
2018.03.10 08:02:54 1:     main::Babble_Html                   called by (eval 550649) (1)
mit file meinste das "bubblefile" direkt im fhem root?
das besteht aus 2 leeren zeilen
→do↑p!dnʇs↓shit←
Zitatdas besteht aus 2 leeren zeilen
Ich habe gerade eine neue Version eingecheckt, die dieses Problem hoffentlich endgültig löst.
pah
Raemsna
ich versuche mich gerade auch an dem Modul Babble.
kurze Frage dazu: Ist es möglich / vorgesehen, auch Resident Devices mit Babble zu steuern (oder löst man das über die Benutzeroberfläche)?
z.B. Tochter ist eingeschlafen / aufgewacht, usw.
Vielen Dank und Grüße
Raemsna
the ratman
ZitatIch habe gerade eine neue Version eingecheckt, die dieses Problem hoffentlich endgültig löst.
dank dir, dann schaun ma morgen nach 8 uhr weiter *g*
btw. werbung in eigener sache: schon gelesen? https://forum.fhem.de/index.php/topic,85479.msg778627.html#msg778627
vielleicht interessierts dich ja ...
→do↑p!dnʇs↓shit←
Zitatkurze Frage dazu: Ist es möglich / vorgesehen, auch Resident Devices mit Babble zu steuern (oder löst man das über die Benutzeroberfläche)?
Das geht über die Benutzungsoberfläche, und es ist prinzipiell alles Steuerbare zu bedienen.
Allerdings weiß ich nicht, was an
ZitatTochter ist eingeschlafen / aufgewacht
steuerbar wäre.
Bitte das Problem etwas genauer beschreiben.
pah
Raemsna
Allerdings weiß ich nicht, was ansteuerbar wäre.
pah
Ich würde gerne per Sprachsteuerung wenn meine Tochter eingeschlafen ist ihren state im Resident Device auf "asleep" setzen, wenn sie dann wieder aufwacht auf "awoken". Dann wird im Modul Schlafdauer usw. per Reading festgehalten...
Raemsna
Ganz einfach.
1. Möglichkeit: Direkt das Resident Device setzen.
2. Möglichkeit:  Dummy einrichten, der den Schlafzustand der Tochter beschreibt. Dieser Dummy wird über Babble geschaltet.
Dann ein Notify, welches bei einer Änderung des Dummy das Resident Device schaltet.
Die zweite Möglichkeit eröffnet ziemlich weit gehende Auswertefunktionalitäten, gleitende Mittelwerte etc. Darin kann ich mich zwar täuschen (weil ich das eigentlich nicht verwende) - aber ich denke, dass dies mit einem Dummy einfacher geht, als direkt mit Resident Device.
pah
Raemsna
#175
Hallo pah,
vielen Dank für die prompte Antwort.
Ich habs jetzt so versucht siehe Anhang.
Device wird gefunden, Verb und Status konfiguriert (eingeschlafen / aufgewacht), aber wenn ich als Test "Annelie ist eingeschlafen" eingebe, kommt "undefined"...
Danke nochmal für einen Hinweis (ich finde die Idee dieses Moduls einfach nur super und versuche mich einzuarbeiten) :)
Raemsna
Edit: Folgendes kommt im Log:
[Babble_DoIt] Command ist.none.none.eingeschlafen/ undefined, reply =
Nun ja, das ist ja keine Anweisung an FHEM - sondern eine nicht-imperative Zustandsbeschreibung. Ich muss mal überlegen, wie man so etwas in die Semantik einbaut.
Was funktioniert ist: "Setze Amelie auf eingeschlafen".
Dazu muss bei den Verben "setzen" mit Konjugation "setze" hinzugefügt werden.
pah
the ratman
#177
schade ...
immer noch beim aufrufen des babble-raums2018.03.11 09:00:00 1: logfile wurde automatisch gelöscht
2018.03.11 10:48:03 1: [Babble_getdevs] No entry in command table under wetter for local FHEM device proplanta with attribute babbleDevice=wetter
2018.03.11 10:48:03 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/95_Babble.pm line 1978.
2018.03.11 10:48:03 1: eval: {Babble_Html("babble")}
2018.03.11 10:48:03 1: stacktrace:
2018.03.11 10:48:03 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (1978)
2018.03.11 10:48:03 1:     main::Babble_Html                   called by (eval 58764) (1)
2018.03.11 10:48:03 1:     (eval)                              called by fhem.pl (1095)
2018.03.11 10:48:03 1:     main::AnalyzePerlCommand            called by ./FHEM/98_weblink.pm (99)
2018.03.11 10:48:03 1:     main::weblink_FwFn                  called by ./FHEM/01_FHEMWEB.pm (1901)
2018.03.11 10:48:03 1:     main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (1072)
2018.03.11 10:48:03 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (538)
2018.03.11 10:48:03 1:     main::FW_Read                       called by fhem.pl (3546)
2018.03.11 10:48:03 1:     main::CallFn                        called by fhem.pl (706)
2018.03.11 10:48:03 1: PERL WARNING: Use of uninitialized value $cmd in index at ./FHEM/95_Babble.pm line 2058.
2018.03.11 10:48:03 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (2058)
2018.03.11 10:48:03 1: PERL WARNING: Use of uninitialized value $cmd in concatenation (.) or string at ./FHEM/95_Babble.pm line 2076.
2018.03.11 10:48:03 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (2076)
2018.03.11 10:48:03 1:     main::Babble_Html                   called by (eval 58766) (1)
das file ist auch noch mit 2 leer zeilen. die rechte des files passen übrigens.
nachtrag:
trage ich mal für wetter was ein, kommt beim aufruf nur mehr2018.03.11 10:53:08 1: logfile wurde von hand gelöscht
2018.03.11 10:53:12 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/95_Babble.pm line 1978.
2018.03.11 10:53:12 1: eval: {Babble_Html("babble")}
2018.03.11 10:53:12 1: stacktrace:
2018.03.11 10:53:12 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (1978)
2018.03.11 10:53:12 1:     main::Babble_Html                   called by (eval 61127) (1)
2018.03.11 10:53:12 1:     (eval)                              called by fhem.pl (1095)
2018.03.11 10:53:12 1:     main::AnalyzePerlCommand            called by ./FHEM/98_weblink.pm (99)
2018.03.11 10:53:12 1:     main::weblink_FwFn                  called by ./FHEM/01_FHEMWEB.pm (1901)
2018.03.11 10:53:12 1:     main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (1072)
2018.03.11 10:53:12 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (538)
2018.03.11 10:53:12 1:     main::FW_Read                       called by fhem.pl (3546)
2018.03.11 10:53:12 1:     main::CallFn                        called by fhem.pl (706)
2018.03.11 10:53:12 1:     main::Babble_Html                   called by (eval 61129) (1)
nu hat der onkel auch mal das file gefüllt ... es wird ...
→do↑p!dnʇs↓shit←
the ratman
ach, ich seh grad, seit dem letzten update kommt wieder2018.03.13 11:26:17 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/95_Babble.pm line 1978.
2018.03.13 11:26:17 1: eval: {Babble_Html("babble")}
2018.03.13 11:26:17 1: stacktrace:
2018.03.13 11:26:17 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (1978)
2018.03.13 11:26:17 1:     main::Babble_Html                   called by (eval 88627) (1)
2018.03.13 11:26:17 1:     (eval)                              called by fhem.pl (1095)
2018.03.13 11:26:17 1:     main::AnalyzePerlCommand            called by ./FHEM/98_weblink.pm (99)
2018.03.13 11:26:17 1:     main::weblink_FwFn                  called by ./FHEM/01_FHEMWEB.pm (1901)
2018.03.13 11:26:17 1:     main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (1072)
2018.03.13 11:26:17 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (538)
2018.03.13 11:26:17 1:     main::FW_Read                       called by fhem.pl (3546)
2018.03.13 11:26:17 1:     main::CallFn                        called by fhem.pl (706)
2018.03.13 11:26:17 1: PERL WARNING: Use of uninitialized value $cmd in index at ./FHEM/95_Babble.pm line 2058.
2018.03.13 11:26:17 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (2058)
2018.03.13 11:26:17 1: PERL WARNING: Use of uninitialized value $cmd in concatenation (.) or string at ./FHEM/95_Babble.pm line 2076.
2018.03.13 11:26:17 1:     main::__ANON__                      called by ./FHEM/95_Babble.pm (2076)
2018.03.13 11:26:17 1:     main::Babble_Html                   called by (eval 88631) (1)
wenn ich in den babble-raum gehe
→do↑p!dnʇs↓shit←
Die Meldung aus Zeile 2076 kommet daher, dass ein Schaltkommando undefiniert ist.
Ich habe gerade Babble Version 1.33 eingecheckt, darin wird dieser Fehler abgefangen.
pah
