bekomme keine Icon´s von openautomation.css
Begonnen von Wasserwerk33, 04 Januar 2018, 19:52:17
Wasserwerk33
Hallo Leute.
Wieso bekomme ich keine Icon´s von openautomation.css angezeigt.
In meiner Index-seite ist openautomation.css" hinterlegt und in fhem befindet es sich unter diesem Ordner /opt/fhem/www/images/openautomation
ist irgendetwas falsch??
so sieht mein Header aus
<head>
     /* FHEM tablet ui */
     * UI builder framework for FHEM
     * Version: 2.5.*
     * URL: https://github.com/knowthelist/fhem-tablet-ui
     * Copyright (c) 2015-2017 Mario Stephan <mstephan@shared-files.de>
     * Under MIT License (http://www.opensource.org/licenses/mit-license.php)
     * - create a new folder named 'tablet' in /<fhem-path>/www
     * - copy all files incl. sub folders into /<fhem-path>/www/tablet
     * - add 'define TABLETUI HTTPSRV ftui ./www/tablet Tablet' in fhem.cfg
     * - Tadaaa! A new fhem ui in http://<fhem-url>:8083/fhem/tablet/
    <link rel="icon" href="favicon.ico" type="image/x-icon" />
    <!-- define your personal style here, it wont be overwritten  -->
    <link rel="stylesheet" href="css/fhem-green-ui.css" />
    <link rel="stylesheet" href="css/fhem-tablet-ui-user.css" />
<link rel="stylesheet" type="text/css" href="css/fhem-tablet-ui.css" />
    <link rel="stylesheet" type="text/css" href="css/fhem-grayblue-user-ui.css" />
    <link rel="stylesheet" type="text/css" href="css/fhem-tablet-ui-user.css" />
    <link rel="stylesheet" type="text/css" href="css/fhem-tablet-ui-weekprofile.css" />
<link rel="stylesheet" href="/fhem/tablet/css/fhem-tablet-ui-wdtimer.css" />
<link rel="stylesheet" href="lib/material-icons.min.css" />
<link rel="stylesheet" href="lib/fhemSVG.css" />
<link rel="stylesheet" href="lib/openautomation.css" />
<link rel="shortcut icon" type="image/x-icon" href="images/home.ico" />
<!-- Custom Fonts -->
<link rel="stylesheet" href="fonts/roman/style.css" />
<link rel="stylesheet" href="fonts/material/style.css" />
<!-- Scripts -->
    <script src="../pgm2/jquery.min.js"></script>
    <script src="lib/jquery.toast.min.js"></script>
    <script src="js/fhem-tablet-ui.js" defer>
<!--meta name="viewport" content="maximum-scale=1.0, user-scalable=yes"-->
      <!--meta name="widget_base_width" content="70"-->
      <!--meta name="widget_base_height" content="147"--></script>
      <meta name="mobile-web-app-capable" content="yes">
      <meta name="apple-mobile-web-app-capable" content="yes">
      <meta http-equiv="X-UA-Compatible" content="IE=edge">
      <meta name="gridster_disable" content="1">
      <meta name="widget_margin" content="1">
      <meta name="longpoll_type" content="websocket">
      <!-- 1=longpoll;0=shortpoll every 30sec; "ajax" -> HTTP AJAX; websocket-->
      <meta name="debug" content="0">
      <!-- 1=output to console;0=not output -->
      <meta name="toast" content="1">
      <!-- 1=Toast messages deaktivieren ;0=not output -->
      <meta name="lang" content="de">
      <meta name="toast" content="1"> <!-- 1,2,3...= n Toast-Messages, 0: No Toast-Messages -->
<!-- Cache -->
    <meta http-equiv="Cache-Control" content="no-store" />
    <!-- Remove this line to enable for usage with WebViewControl
    <script defer>var wvcDevices = {'12345': 'Tablet'}; var wvcUserCssFile="webviewcontrol.css"</script>
    <script src="../pgm2/cordova-2.3.0.js" defer></script>
    <script src="../pgm2/webviewcontrol.js" defer></script>
    <!-- End for WebViewControl -->
    <title>FHEM-Tablet-UI</title>
</head>
MKeY
#1
die openautomation.css sollte in /opt/fhem/www/tablet/lib/ vorhanden sein sowie die in der css verlinkte dateien in /opt/fhem/www/tablet/fonts/
in images sind die svgs, auf die dann verlinkt wird
schon geprüft?
Wer Fehler findet, darf sie behalten!
RPi's, D1Mini
Homematic, Hue, Sonoff, Alexa, Xiaomi, ConBee
Prusa MK2.5, Prusa MK3S (MMU2S vorhanden, aber nervtötend)
Lowrider 2CNC
Wasserwerk33
Gerade nochmal nachgeschaut ja liegt auch openautomation.css
Wasserwerk33
hsepm
Wasserwerk33
#5
ja ist bei 755
die von wetter  funktionieren zum beispiel. andere wie phone wieder nicht.
Habe unten nochmal ein Bild angehangen da wird auch z.B. das wetter übermorgen angezeigt und das von gerade nur als Internetseite.
hjgode
und noch ein thread mit nem problem aber ohne lösung.
Weiter so...
Debian SID mit aktuellem FHEM, nanoCUL 866, JeeLink EC3000, fhemduino, SIGNALduino,
3 x TFA TH Sensor, 1 x TFA TH Arduino Sender, 3 x EC3000, 4 x Elro Schaltsteckdosen, ESA2000
offline: Wibo Funkthermostat, 2 x ELV Funkthermostat FHT80, 2 FS20 ST4 Funksteckdose
setstate
Weiter so...
Aber Zynismus hilft auch nicht weiter, oder?
ZitatWieso bekomme ich keine Icon´s von openautomation.css angezeigt.
Alle im FTUI verfügbare Icons werden in der icons_table.html angezeigt. Ist es dort dabei?
