Autor Thema: [74_XiaomiBTLESens.pm] Xiaomi Bluetooth Sensoren FlowerSens/Thermometer  (Gelesen 92725 mal)
Offline kroonen
  • Full Member
    • http://www.kroonen.eu/mobile
Antw:[74_XiaomiBTLESens.pm] Xiaomi Bluetooth Sensoren FlowerSens/Thermometer
« Antwort #135 am: 09 Februar 2018, 20:24:27 »
This one works again, inside (attic)  it is working, see output. I'm also going to try again in the garage, and let you know if humidity is working ok
fhem> l zoldertem
   BTMAC      4C:65:A8:D1:7D:DC
   DEF        4C:65:A8:D1:7D:DC
   INTERVAL   300
   NAME       zoldertem
   NOTIFYDEV  global,zoldertem
   NR         21
   NTFY_ORDER 50-zoldertem
   STATE      active
   TYPE       XiaomiBTLESens
   VERSION    2.0.8
   loglevel   4
     2018-02-09 20:19:52   battery         ok
     2018-02-09 20:19:52   batteryLevel    100
     2018-02-09 08:59:59   firmware        00.00.66
     2018-02-09 20:19:57   humidity        64.3
     2018-02-09 19:26:34   lastGattError   no data response
     2018-02-09 20:19:57   state           active
     2018-02-09 20:19:57   temperature     16.1
   helper:
     CallBattery 0
     CallSensDataCounter 0
     updateTimeCallBattery 1518203992.10542
     updateTimestampCallBattery 2018-02-09 20:19:52
   interval   300
   model      thermoHygroSens
   room       XiaomiBTLESens
Offline kroonen
  • Full Member
« Antwort #136 am: 09 Februar 2018, 20:36:14 »
Below 10 degrees, the humidity looks like failing again. Herre the first when placed in the garage, after couple minutes, it goes wrong
fhem> l zoldertem
   INTERVAL   300
   NAME       zoldertem
   NR         21
   STATE      active
   TYPE       XiaomiBTLESens
   VERSION    2.0.8
   loglevel   4
     2018-02-09 20:24:58   battery         ok
     2018-02-09 20:24:58   batteryLevel    100
     2018-02-09 20:25:04   humidity        55.5
     2018-02-09 20:25:04   state           active
     2018-02-09 20:25:04   temperature     13.6
   helper:
     CallBattery 0
     updateTimeCallBattery 1518204298.91355
     updateTimestampCallBattery 2018-02-09 20:24:58
   interval   300
   room       XiaomiBTLESens
fhem> l zoldertem
   INTERVAL   300
   NAME       zoldertem
   NR         21
   STATE      active
   TYPE       XiaomiBTLESens
   VERSION    2.0.8
   loglevel   4
     2018-02-09 20:31:20   humidity        0.1
     2018-02-09 20:31:20   state           active
     2018-02-09 20:31:20   temperature     9.3
   helper:
     CallBattery 0
   interval   300
   room       XiaomiBTLESens
here the logging:
2018.02.09 20:32:57 4: XiaomiBTLESens (zoldertem) - Run CreateParamGatttool with mod: write
2018.02.09 20:32:57 4: BlockingCall (XiaomiBTLESens_ExecGatttool_Run): created child (535), uses telnetPort to connect back
2018.02.09 20:32:57 5: Starting notify loop for zoldertem, 1 event(s), first is write sensor data
2018.02.09 20:32:57 5: createNotifyHash
2018.02.09 20:32:57 5: End notify loop for zoldertem
2018.02.09 20:32:57 5: XiaomiBTLESens (zoldertem) - Write XiaomiBTLESens_ExecGatttool_Run zoldertem|4C:65:A8:D1:7D:DC|write|0x10|0100
2018.02.09 20:32:57 4: XiaomiBTLESens (zoldertem) - stateRequestTimer: Call Request Timer
2018.02.09 20:32:57 4: Connection accepted from telnetPort_127.0.0.1_41188
2018.02.09 20:32:57 5: Cmd: >{BlockingRegisterTelnet($cl,4)}<
2018.02.09 20:32:57 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: call gatttool with command timeout 5 gatttool -i hci0 -b 4C:65:A8:D1:7D:DC --char-write-req -a 0x10 -n 0100 --listen 2>&1 /dev/null and loop 0
2018.02.09 20:33:02 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool loop result
2018.02.09 20:33:02 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/74_XiaomiBTLESens.pm line 487.
2018.02.09 20:33:02 1: PERL WARNING: Use of uninitialized value $gtResult[1] in substitution (s///) at ./FHEM/74_XiaomiBTLESens.pm line 488.
2018.02.09 20:33:02 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: call gatttool with command timeout 5 gatttool -i hci0 -b 4C:65:A8:D1:7D:DC --char-write-req -a 0x10 -n 0100 --listen 2>&1 /dev/null and loop 1
2018.02.09 20:33:07 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool loop result
2018.02.09 20:33:07 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: call gatttool with command timeout 5 gatttool -i hci0 -b 4C:65:A8:D1:7D:DC --char-write-req -a 0x10 -n 0100 --listen 2>&1 /dev/null and loop 2
2018.02.09 20:33:12 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool loop result Characteristic value was written successfully
Notification handle = 0x000e value,54 3d 38 2e 34 20 48 3d 37 32 2e 35 00
Notification handle = 0x000e value,54 3d 31 31 2e 36 20 48 3d 35 38 2e 38 00
Notification handle = 0x000e value,54 3d 38 2e 35 20 48 3d 37 32 2e 36 00
Notification handle = 0x000e value,54 3d 38 2e 35 20 48 3d 37 32 2e 37 00
Notification handle = 0x000e value,54 3d 31 31 2e 36 20 48 3d 35 38 2e 39 00
Notification handle = 0x000e value,54 3d 38 2e 35 20 48 3d 37 32 2e 38 00
Notification handle = 0x000e value,54 3d 31 31 2e 36 20 48 3d 35 39 2e 30 00
Notification handle = 0x000e value,54 3d 38 2e 34 20 48 3d 37 32 2e 34 00
Notification handle = 0x000e value,54 3d 31 31 2e 35 20 48 3d 35 39 2e 30 00
2018.02.09 20:33:12 4: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool result Characteristic value was written successfully
Notification handle = 0x000e value,54 3d 38 2e 34 20 48 3d 37 32 2e 35 00 ,54 3d 31 31 2e 36 20 48 3d 35 38 2e 38 00
2018.02.09 20:33:12 5: Cmd: >{BlockingStart('4')}<
2018.02.09 20:33:12 5: Cmd: >{XiaomiBTLESens_ExecGatttool_Done('zoldertem|4C:65:A8:D1:7D:DC|ok|write|0x10|{"gtResult":"54 3d 38 2e 34 20 48 3d 37 32 2e 35 00 "}')}<
2018.02.09 20:33:12 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Done: gatttool return string: zoldertem|4C:65:A8:D1:7D:DC|ok|write|0x10|{"gtResult":"54 3d 38 2e 34 20 48 3d 37 32 2e 35 00 "}
2018.02.09 20:33:12 4: XiaomiBTLESens (zoldertem) - ProcessingNotification
2018.02.09 20:33:12 4: XiaomiBTLESens (zoldertem) - ProcessingNotification: handle 0x10
2018.02.09 20:33:12 4: XiaomiBTLESens (zoldertem) - Thermo/Hygro Sens Handle0x10
2018.02.09 20:33:12 5: Starting notify loop for zoldertem, 3 event(s), first is temperature: 8.4
2018.02.09 20:33:12 5: End notify loop for zoldertem
2018.02.09 20:33:12 4: XiaomiBTLESens (zoldertem) - WriteReadings: Readings were written
2018.02.09 20:34:18 5: Cmd: >q<
2018.02.09 20:34:18 5: AnalyzeCommand: trying quit for q
Offline CoolTux
« Antwort #137 am: 10 Februar 2018, 03:12:16 »
please can you test this version https://github.com/LeonGaultier/fhem-XiaomiBTLESens/archive/master.zip.
this is not the solution for your problem, put i will see is the change code running.
can you tell me what was the value of the humidity at your last log?
Support me to buy new test hardware for development: https://paypal.me/pools/c/8gULisr9BT
Mein Dokuwiki:
https://www.cooltux.net
Offline kroonen
  • Full Member
« Antwort #138 am: 10 Februar 2018, 11:16:23 »
This reading humidity 84.0 (or maybe 83.9), and temperature 05.7 read from the physical display. I used the testversion module
fhem> l zoldertem
   INTERVAL   300
   NAME       zoldertem
   NR         21
   STATE      active
   TYPE       XiaomiBTLESens
   VERSION    2.0.8
   loglevel   4
     2018-02-10 11:07:04   battery         ok
     2018-02-10 11:07:04   batteryLevel    100
     2018-02-10 11:07:09   humidity        2.7
     2018-02-10 11:04:47   lastGattError   no data response
     2018-02-10 11:07:09   state           active
     2018-02-10 11:07:09   temperature     5.7
   helper:
     CallBattery 0
     updateTimeCallBattery 1518257224.41969
     updateTimestampCallBattery 2018-02-10 11:07:04
   interval   300
   room       XiaomiBTLESens
2018.02.10 11:06:58 4: XiaomiBTLESens (zoldertem) - Run CreateParamGatttool with mod: read
2018.02.10 11:06:58 4: BlockingCall (XiaomiBTLESens_ExecGatttool_Run): created child (2842), uses telnetPort to connect back
2018.02.10 11:06:58 5: Starting notify loop for zoldertem, 1 event(s), first is read sensor data
2018.02.10 11:06:58 5: End notify loop for zoldertem
2018.02.10 11:06:58 5: XiaomiBTLESens (zoldertem) - Read XiaomiBTLESens_ExecGatttool_Run zoldertem|4C:65:A8:D1:7D:DC|read|0x18
2018.02.10 11:06:58 4: XiaomiBTLESens (zoldertem) - stateRequestTimer: Call Request Timer
2018.02.10 11:06:58 5: End notify loop for global
2018.02.10 11:06:58 0: Featurelevel: 5.8
2018.02.10 11:06:58 0: Server started with 11 defined entities (fhem.pl:16107/2018-02-07 perl:5.024001 os:linux user:fhem pid:2835)
2018.02.10 11:06:58 4: Connection accepted from telnetPort_127.0.0.1_41396
2018.02.10 11:06:58 5: Cmd: >{BlockingRegisterTelnet($cl,1)}<
2018.02.10 11:06:58 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: call gatttool with command gatttool -i hci0 -b 4C:65:A8:D1:7D:DC --char-read -a 0x18 2>&1 /dev/null and loop 0
2018.02.10 11:06:59 4: Connection accepted from WEB_192.168.180.35_65058
2018.02.10 11:06:59 4: Connection accepted from WEB_192.168.180.35_65061
2018.02.10 11:07:00 4: WEB_192.168.180.35_65058 GET /; BUFLEN:0
2018.02.10 11:07:00 4: WEB: redirecting / to /fhem
2018.02.10 11:07:00 4: Connection accepted from WEB_192.168.180.35_65062
2018.02.10 11:07:00 4: WEB_192.168.180.35_65061 GET /fhem/pgm2/jquery.min.js; BUFLEN:0
2018.02.10 11:07:00 4: Connection accepted from WEB_192.168.180.35_65063
2018.02.10 11:07:00 4: WEB_192.168.180.35_65058 GET /fhem/pgm2/defaultCommon.css; BUFLEN:0
2018.02.10 11:07:00 4: WEB_192.168.180.35_65058 => 304 Not Modified
2018.02.10 11:07:00 4: WEB_192.168.180.35_65062 GET /fhem/images/default/icoEverything.png; BUFLEN:0
2018.02.10 11:07:00 4: WEB_192.168.180.35_65061 GET /fhem/images/default/fhemicon.png; BUFLEN:0
2018.02.10 11:07:00 4: WEB_192.168.180.35_65061 => 304 Not Modified
2018.02.10 11:07:00 4: WEB_192.168.180.35_65063 GET /fhem/pgm2/dashboard_style.css; BUFLEN:0
2018.02.10 11:07:00 4: Connection accepted from WEB_192.168.180.35_65064
2018.02.10 11:07:00 4: WEB_192.168.180.35_65058 GET /fhem/pgm2/fhemweb.js; BUFLEN:0
2018.02.10 11:07:00 4: Connection accepted from WEB_192.168.180.35_65065
2018.02.10 11:07:00 4: WEB_192.168.180.35_65064 GET /fhem/pgm2/jquery-ui.min.css; BUFLEN:0
2018.02.10 11:07:00 4: WEB_192.168.180.35_65064 => 304 Not Modified
2018.02.10 11:07:00 4: WEB_192.168.180.35_65062 GET /fhem; BUFLEN:0
2018.02.10 11:07:00 4: WEB: /fhem / RL:1388 / text/html; charset=UTF-8 / Content-Encoding: gzip
2018.02.10 11:07:00 4: WEB_192.168.180.35_65065 GET /fhem/pgm2/jquery-ui.min.js; BUFLEN:0
2018.02.10 11:07:00 4: WEB_192.168.180.35_65065 => 304 Not Modified
2018.02.10 11:07:00 4: WEB_192.168.180.35_65058 GET /fhem/pgm2/style.css?v=1518257209; BUFLEN:0
2018.02.10 11:07:00 4: WEB_192.168.180.35_65058 GET /fhem?XHR=1&inform=type=status;filter=;since=1518257219;fmt=JSON&fw_id=27&timestamp=1518257220830; BUFLEN:0
2018.02.10 11:07:02 4: Connection closed for WEB_192.168.180.35_65058: EOF
2018.02.10 11:07:02 4: WEB_192.168.180.35_65061 GET /fhem?room=XiaomiBTLESens; BUFLEN:0
2018.02.10 11:07:02 4: WEB: /fhem?room=XiaomiBTLESens / RL:1403 / text/html; charset=UTF-8 / Content-Encoding: gzip
2018.02.10 11:07:04 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool loop result Characteristic value/descriptor,64
2018.02.10 11:07:04 4: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool result Characteristic value/descriptor,64
2018.02.10 11:07:04 5: Cmd: >{BlockingStart('1')}<
2018.02.10 11:07:04 5: Cmd: >{XiaomiBTLESens_ExecGatttool_Done('zoldertem|4C:65:A8:D1:7D:DC|ok|read|0x18|{"gtResult":"64 "}')}<
2018.02.10 11:07:04 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Done: gatttool return string: zoldertem|4C:65:A8:D1:7D:DC|ok|read|0x18|{"gtResult":"64 "}
2018.02.10 11:07:04 4: XiaomiBTLESens (zoldertem) - ProcessingNotification
2018.02.10 11:07:04 4: XiaomiBTLESens (zoldertem) - ProcessingNotification: handle 0x18
2018.02.10 11:07:04 4: XiaomiBTLESens (zoldertem) - Thermo/Hygro Sens Handle0x18
2018.02.10 11:07:04 1: PERL WARNING: Illegal hexadecimal digit ' ' ignored at ./FHEM/74_XiaomiBTLESens.pm line 691.
2018.02.10 11:07:04 3: eval: {XiaomiBTLESens_ExecGatttool_Done('zoldertem|4C:65:A8:D1:7D:DC|ok|read|0x18|{"gtResult":"64 "}')}
2018.02.10 11:07:04 1: PERL WARNING: Illegal hexadecimal digit ' ' ignored at ./FHEM/74_XiaomiBTLESens.pm line 692.
2018.02.10 11:07:04 5: Starting notify loop for zoldertem, 3 event(s), first is battery: ok
2018.02.10 11:07:04 5: createNotifyHash
2018.02.10 11:07:04 5: End notify loop for zoldertem
2018.02.10 11:07:04 4: XiaomiBTLESens (zoldertem) - WriteReadings: Readings were written
2018.02.10 11:07:04 4: XiaomiBTLESens (zoldertem) - Run CreateParamGatttool with mod: write
2018.02.10 11:07:04 4: BlockingCall (XiaomiBTLESens_ExecGatttool_Run): created child (2852), uses telnetPort to connect back
2018.02.10 11:07:04 5: Starting notify loop for zoldertem, 1 event(s), first is write sensor data
2018.02.10 11:07:04 5: XiaomiBTLESens (zoldertem) - Write XiaomiBTLESens_ExecGatttool_Run zoldertem|4C:65:A8:D1:7D:DC|write|0x10|0100
2018.02.10 11:07:04 4: Connection accepted from telnetPort_127.0.0.1_41398
2018.02.10 11:07:04 5: Cmd: >{BlockingRegisterTelnet($cl,2)}<
2018.02.10 11:07:04 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: call gatttool with command timeout 5 gatttool -i hci0 -b 4C:65:A8:D1:7D:DC --char-write-req -a 0x10 -n 0100 --listen 2>&1 /dev/null and loop 0
2018.02.10 11:07:05 4: WEB_192.168.180.35_65061 GET /fhem?XHR=1&inform=type=status;filter=room=XiaomiBTLESens;since=1518257221;fmt=JSON&fw_id=26&timestamp=1518257225135; BUFLEN:0
2018.02.10 11:07:09 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool loop result Characteristic value was written successfully
Notification handle = 0x000e value,54 3d 35 2e 37 20 48 3d 38 32 2e 37 00
Notification handle = 0x000e value,54 3d 35 2e 35 20 48 3d 38 34 2e 30 00
Notification handle = 0x000e value,54 3d 35 2e 38 20 48 3d 38 33 2e 30 00
Notification handle = 0x000e value,54 3d 35 2e 36 20 48 3d 38 34 2e 30 00
Notification handle = 0x000e value,54 3d 35 2e 35 20 48 3d 38 34 2e 31 00
Notification handle = 0x000e value,54 3d 35 2e 37 20 48 3d 38 32 2e 39 00
Notification handle = 0x000e value,54 3d 35 2e 37 20 48 3d 38 32 2e 38 00
2018.02.10 11:07:09 4: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool result Characteristic value was written successfully
Notification handle = 0x000e value,54 3d 35 2e 37 20 48 3d 38 32 2e 37 00 ,54 3d 35 2e 35 20 48 3d 38 34 2e 30 00
2018.02.10 11:07:09 5: Cmd: >{BlockingStart('2')}<
2018.02.10 11:07:09 5: Cmd: >{XiaomiBTLESens_ExecGatttool_Done('zoldertem|4C:65:A8:D1:7D:DC|ok|write|0x10|{"gtResult":"54 3d 35 2e 37 20 48 3d 38 32 2e 37 00 "}')}<
2018.02.10 11:07:09 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Done: gatttool return string: zoldertem|4C:65:A8:D1:7D:DC|ok|write|0x10|{"gtResult":"54 3d 35 2e 37 20 48 3d 38 32 2e 37 00 "}
2018.02.10 11:07:09 4: XiaomiBTLESens (zoldertem) - ProcessingNotification
2018.02.10 11:07:09 4: XiaomiBTLESens (zoldertem) - ProcessingNotification: handle 0x10
2018.02.10 11:07:09 4: XiaomiBTLESens (zoldertem) - Thermo/Hygro Sens Handle0x10
2018.02.10 11:07:09 5: Starting notify loop for zoldertem, 3 event(s), first is humidity: 2.7\000
2018.02.10 11:07:09 5: createNotifyHash
2018.02.10 11:07:09 5: End notify loop for zoldertem
« Letzte Änderung: 10 Februar 2018, 11:40:19 von kroonen »
Offline CoolTux
« Antwort #139 am: 10 Februar 2018, 12:30:52 »
Ok. i need a log the temperature is greater than 10.
Mein Dokuwiki:
Offline CoolTux
« Antwort #140 am: 10 Februar 2018, 12:53:14 »
ok i have find the problem and evaluateted the solution. give me one day.
Mein Dokuwiki:
Offline CoolTux
Mein Dokuwiki:
Offline kroonen
  • Full Member
« Antwort #142 am: 10 Februar 2018, 18:55:03 »
almost, the humidity it gives 8.9 and should give 78.9
fhem> l zoldertem
   INTERVAL   300
   NAME       zoldertem
   NR         21
   STATE      active
   TYPE       XiaomiBTLESens
   VERSION    2.0.8pri1
   loglevel   4
     2018-02-10 18:51:41   battery         ok
     2018-02-10 18:51:41   batteryLevel    100
     2018-02-10 18:51:46   humidity        8.9
     2018-02-10 13:13:46   lastGattError   no data response
     2018-02-10 18:51:46   state           active
     2018-02-10 18:51:46   temperature     6.9
   helper:
     CallBattery 0
     updateTimeCallBattery 1518285101.49253
     updateTimestampCallBattery 2018-02-10 18:51:41
   interval   300
   room       XiaomiBTLESens
2018.02.10 18:47:54 5: Cmd: >get zoldertem sensorData<
2018.02.10 18:47:54 4: XiaomiBTLESens (zoldertem) - Run CreateParamGatttool with mod: write
2018.02.10 18:47:54 4: BlockingCall (XiaomiBTLESens_ExecGatttool_Run): created child (1290), uses telnetPort to connect back
2018.02.10 18:47:54 5: Starting notify loop for zoldertem, 1 event(s), first is write sensor data
2018.02.10 18:47:54 5: createNotifyHash
2018.02.10 18:47:54 5: End notify loop for zoldertem
2018.02.10 18:47:54 5: XiaomiBTLESens (zoldertem) - Write XiaomiBTLESens_ExecGatttool_Run zoldertem|4C:65:A8:D1:7D:DC|write|0x10|0100
2018.02.10 18:47:54 4: WEB: /fhem?detail=zoldertem&dev.getzoldertem=zoldertem&cmd.getzoldertem=get&arg.getzoldertem=sensorData&val.getzoldertem=&XHR=1&addLinks=1&fwcsrf=csrf_204325950458568&fw_id=50 / RL:20 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2018.02.10 18:47:54 4: Connection accepted from telnetPort_127.0.0.1_36184
2018.02.10 18:47:54 5: Cmd: >{BlockingRegisterTelnet($cl,4)}<
2018.02.10 18:47:54 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: call gatttool with command - timeout 5 gatttool -i hci0 -b 4C:65:A8:D1:7D:DC --char-write-req -a 0x10 -n 0100 --listen 2>&1 /dev/null and loop - 0
2018.02.10 18:47:59 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool loop result
2018.02.10 18:47:59 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/74_XiaomiBTLESens.pm line 485.
2018.02.10 18:47:59 1: PERL WARNING: Use of uninitialized value $gtResult[1] in substitution (s///) at ./FHEM/74_XiaomiBTLESens.pm line 486.
2018.02.10 18:47:59 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: call gatttool with command - timeout 5 gatttool -i hci0 -b 4C:65:A8:D1:7D:DC --char-write-req -a 0x10 -n 0100 --listen 2>&1 /dev/null and loop - 1
2018.02.10 18:48:04 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool loop result Characteristic value was written successfully
Notification handle = 0x000e value,54 3d 36 2e 39 20 48 3d 37 38 2e 39 00
Notification handle = 0x000e value,54 3d 36 2e 39 20 48 3d 37 38 2e 38 00
Notification handle = 0x000e value,54 3d 36 2e 38 20 48 3d 37 38 2e 33 00
Notification handle = 0x000e value,54 3d 36 2e 38 20 48 3d 37 38 2e 37 00
Notification handle = 0x000e value,54 3d 36 2e 38 20 48 3d 37 38 2e 35 00
Notification handle = 0x000e value,54 3d 36 2e 38 20 48 3d 37 38 2e 38 00
2018.02.10 18:48:04 4: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool result Characteristic value was written successfully
Notification handle = 0x000e value,54 3d 36 2e 39 20 48 3d 37 38 2e 39 00 ,54 3d 36 2e 39 20 48 3d 37 38 2e 38 00
2018.02.10 18:48:04 5: Cmd: >{BlockingStart('4')}<
2018.02.10 18:48:04 5: Cmd: >{XiaomiBTLESens_ExecGatttool_Done('zoldertem|4C:65:A8:D1:7D:DC|ok|write|0x10|{"gtResult":"54 3d 36 2e 39 20 48 3d 37 38 2e 39 00 "}')}<
2018.02.10 18:48:04 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Done: gatttool return string: zoldertem|4C:65:A8:D1:7D:DC|ok|write|0x10|{"gtResult":"54 3d 36 2e 39 20 48 3d 37 38 2e 39 00 "}
2018.02.10 18:48:04 4: XiaomiBTLESens (zoldertem) - ProcessingNotification
2018.02.10 18:48:04 4: XiaomiBTLESens (zoldertem) - ProcessingNotification: handle 0x10
2018.02.10 18:48:04 4: XiaomiBTLESens (zoldertem) - Thermo/Hygro Sens Handle0x10
2018.02.10 18:48:04 5: Starting notify loop for zoldertem, 3 event(s), first is humidity: 8.9\000
2018.02.10 18:48:04 5: End notify loop for zoldertem
2018.02.10 18:48:04 4: XiaomiBTLESens (zoldertem) - WriteReadings: Readings were written
Offline CoolTux
« Antwort #143 am: 10 Februar 2018, 19:51:17 »
exchanged numbers, sorry.
the humidity bug is fixed but i have change code from loop to outside of the loop. can you please test it? thanks
tip. verbose not global, set verbose attribut at the sensor device to 5.
Mein Dokuwiki:
Offline kroonen
  • Full Member
« Antwort #144 am: 10 Februar 2018, 20:29:29 »
It works, thnx for the support.
Another question, is there a reason why the interval can't be smaller than 300 sec. Is this for battery saving??? I like to set it to 150 sec
regards Richard
Offline CoolTux
« Antwort #145 am: 10 Februar 2018, 20:59:30 »
i have change the minimum inteval to 120s, but you have interval + random 90
Mein Dokuwiki:
Offline CoolTux
« Antwort #146 am: 10 Februar 2018, 21:17:15 »
Morgen früh wird es eine neue Version geben wo alle relevanten Änderungen welche sich in Zusammenarbeit mit kroonen ergeben haben.
Mein Dokuwiki:
Offline kroonen
  • Full Member
« Antwort #147 am: 10 Februar 2018, 21:41:43 »
I get sometimes in the logging some strange values, signs (ھɇ). I will try to debug if I get again one again.
2018-02-10_21:32:55 zoldertem write sensor data
2018-02-10_21:33:00 zoldertem temperature: ھɇ
2018-02-10_21:33:00 zoldertem humidity:
2018-02-10_21:33:00 zoldertem active
2018-02-10_21:34:45 zoldertem read sensor data
2018-02-10_21:34:49 zoldertem batteryLevel: 100
2018-02-10_21:34:49 zoldertem battery: ok
2018-02-10_21:34:49 zoldertem active
2018-02-10_21:34:49 zoldertem write sensor data
2018-02-10_21:34:54 zoldertem humidity: 79.8
2018-02-10_21:34:54 zoldertem temperature: 6.5
2018-02-10_21:34:54 zoldertem active
2018-02-10_21:38:03 zoldertem write sensor data
Offline kroonen
  • Full Member
« Antwort #148 am: 10 Februar 2018, 21:50:23 »
I got one, and some debug..
2018.02.10 21:46:09 4: XiaomiBTLESens (zoldertem) - Run CreateParamGatttool with mod: write
2018.02.10 21:46:09 4: BlockingCall (XiaomiBTLESens_ExecGatttool_Run): created child (2658), uses telnetPort to connect back
2018.02.10 21:46:09 5: Starting notify loop for zoldertem, 1 event(s), first is write sensor data
2018.02.10 21:46:09 5: End notify loop for zoldertem
2018.02.10 21:46:09 5: XiaomiBTLESens (zoldertem) - Write XiaomiBTLESens_ExecGatttool_Run zoldertem|4C:65:A8:D1:7D:DC|write|0x10|0100
2018.02.10 21:46:09 4: XiaomiBTLESens (zoldertem) - stateRequestTimer: Call Request Timer
2018.02.10 21:46:09 4: Connection accepted from telnetPort_127.0.0.1_36268
2018.02.10 21:46:09 5: Cmd: >{BlockingRegisterTelnet($cl,6)}<
2018.02.10 21:46:09 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: call gatttool with command: timeout 5 gatttool -i hci0 -b 4C:65:A8:D1:7D:DC --char-write-req -a 0x10 -n 0100 --listen 2>&1 /dev/null and loop 0
2018.02.10 21:46:14 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool loop result
2018.02.10 21:46:14 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: call gatttool with command: timeout 5 gatttool -i hci0 -b 4C:65:A8:D1:7D:DC --char-write-req -a 0x10 -n 0100 --listen 2>&1 /dev/null and loop 1
2018.02.10 21:46:14 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool loop result connect error,Transport endpoint is not connected (107)
2018.02.10 21:46:14 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: call gatttool with command: timeout 5 gatttool -i hci0 -b 4C:65:A8:D1:7D:DC --char-write-req -a 0x10 -n 0100 --listen 2>&1 /dev/null and loop 2
2018.02.10 21:46:19 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool loop result Characteristic value was written successfully
2018.02.10 21:46:19 4: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool result Characteristic value was written successfully
2018.02.10 21:46:19 5: Cmd: >{BlockingStart('6')}<
2018.02.10 21:46:19 5: Cmd: >{XiaomiBTLESens_ExecGatttool_Done('zoldertem|4C:65:A8:D1:7D:DC|ok|write|0x10|{"gtResult":"no data response"}')}<
2018.02.10 21:46:19 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Done: gatttool return string: zoldertem|4C:65:A8:D1:7D:DC|ok|write|0x10|{"gtResult":"no data response"}
2018.02.10 21:46:19 4: XiaomiBTLESens (zoldertem) - ProcessingNotification
2018.02.10 21:46:19 4: XiaomiBTLESens (zoldertem) - ProcessingNotification: handle 0x10
2018.02.10 21:46:19 4: XiaomiBTLESens (zoldertem) - Thermo/Hygro Sens Handle0x10
2018.02.10 21:46:19 1: PERL WARNING: substr outside of string at ./FHEM/74_XiaomiBTLESens.pm line 718.
2018.02.10 21:46:19 3: eval: {XiaomiBTLESens_ExecGatttool_Done('zoldertem|4C:65:A8:D1:7D:DC|ok|write|0x10|{"gtResult":"no data response"}')}
2018.02.10 21:46:19 1: PERL WARNING: Use of uninitialized value in pack at ./FHEM/74_XiaomiBTLESens.pm line 718.
2018.02.10 21:46:19 5: Starting notify loop for zoldertem, 3 event(s), first is temperature: ھɇ
2018.02.10 21:46:19 5: End notify loop for zoldertem
2018.02.10 21:46:19 4: XiaomiBTLESens (zoldertem) - WriteReadings: Readings were written
« Letzte Änderung: 10 Februar 2018, 22:11:54 von kroonen »
Offline CoolTux
« Antwort #149 am: 11 Februar 2018, 00:07:07 »
i have insert a better error handling. can you test it?
Mein Dokuwiki:
decade-submarginal
