Some details debug, but don't see hum in log?
2018.02.08 21:46:40 4: XiaomiBTLESens (zoldertem) - Run CreateParamGatttool with mod: read
2018.02.08 21:46:40 4: BlockingCall (XiaomiBTLESens_ExecGatttool_Run): created child (923), uses telnetPort to connect back
2018.02.08 21:46:40 5: Starting notify loop for zoldertem, 1 event(s), first is read sensor data
2018.02.08 21:46:40 5: End notify loop for zoldertem
2018.02.08 21:46:40 4: XiaomiBTLESens (zoldertem) - Read XiaomiBTLESens_ExecGatttool_Run zoldertem|4C:65:A8:D1:7D:DC|read|0x18
2018.02.08 21:46:40 4: XiaomiBTLESens (zoldertem) - stateRequestTimer: Call Request Timer
2018.02.08 21:46:40 5: End notify loop for global
2018.02.08 21:46:40 0: Featurelevel: 5.8
2018.02.08 21:46:40 0: Server started with 10 defined entities (fhem.pl:16107/2018-02-07 perl:5.024001 os:linux user:fhem pid:915)
2018.02.08 21:46:40 4: Connection accepted from WEB_192.168.180.35_54728
2018.02.08 21:46:40 4: Connection accepted from telnetPort_127.0.0.1_59626
2018.02.08 21:46:41 4: WEB_192.168.180.35_54728 GET /fhem?XHR=1&inform=type=status;filter=;since=1518122782.584;fmt=JSON&fw_id=26×tamp=1518122794778; BUFLEN:0
2018.02.08 21:46:41 5: Cmd: >{BlockingRegisterTelnet($cl,1)}<
2018.02.08 21:46:41 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: call gatttool with command gatttool -i hci0 -b 4C:65:A8:D1:7D:DC --char-read -a 0x18 2>&1 /dev/null and loop 0
2018.02.08 21:46:45 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool loop result Characteristic value/descriptor,64
2018.02.08 21:46:45 4: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool result Characteristic value/descriptor,64
2018.02.08 21:46:45 5: Cmd: >{BlockingStart('1')}<
2018.02.08 21:46:45 5: Cmd: >{XiaomiBTLESens_ExecGatttool_Done('zoldertem|4C:65:A8:D1:7D:DC|ok|read|0x18|{"gtResult":"64 "}')}<
2018.02.08 21:46:45 4: XiaomiBTLESens (zoldertem) - ExecGatttool_Done: gatttool return string: zoldertem|4C:65:A8:D1:7D:DC|ok|read|0x18|{"gtResult":"64 "}
2018.02.08 21:46:45 5: XiaomiBTLESens (zoldertem) - ProcessingNotification
2018.02.08 21:46:45 4: XiaomiBTLESens (zoldertem) - ProcessingNotification: handle 0x18
2018.02.08 21:46:45 5: XiaomiBTLESens (zoldertem) - Thermo/Hygro Sens Handle0x18
2018.02.08 21:46:45 1: PERL WARNING: Illegal hexadecimal digit ' ' ignored at ./FHEM/74_XiaomiBTLESens.pm line 682.
2018.02.08 21:46:45 3: eval: {XiaomiBTLESens_ExecGatttool_Done('zoldertem|4C:65:A8:D1:7D:DC|ok|read|0x18|{"gtResult":"64 "}')}
2018.02.08 21:46:45 1: PERL WARNING: Illegal hexadecimal digit ' ' ignored at ./FHEM/74_XiaomiBTLESens.pm line 683.
2018.02.08 21:46:45 5: Starting notify loop for zoldertem, 3 event(s), first is battery: ok
2018.02.08 21:46:45 5: createNotifyHash
2018.02.08 21:46:45 5: End notify loop for zoldertem
2018.02.08 21:46:45 4: XiaomiBTLESens (zoldertem) - WriteReadings: Readings were written
2018.02.08 21:46:45 4: XiaomiBTLESens (zoldertem) - Run CreateParamGatttool with mod: write
2018.02.08 21:46:45 4: BlockingCall (XiaomiBTLESens_ExecGatttool_Run): created child (933), uses telnetPort to connect back
2018.02.08 21:46:45 5: Starting notify loop for zoldertem, 1 event(s), first is write sensor data
2018.02.08 21:46:45 4: XiaomiBTLESens (zoldertem) - Write XiaomiBTLESens_ExecGatttool_Run zoldertem|4C:65:A8:D1:7D:DC|write|0x10|0100
2018.02.08 21:46:45 4: Connection accepted from telnetPort_127.0.0.1_59628
2018.02.08 21:46:45 5: Cmd: >{BlockingRegisterTelnet($cl,2)}<
2018.02.08 21:46:45 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: call gatttool with command timeout 15 gatttool -i hci0 -b 4C:65:A8:D1:7D:DC --char-write-req -a 0x10 -n 0100 --listen 2>&1 /dev/null and loop 0
2018.02.08 21:47:00 5: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool loop result Characteristic value was written successfully
Notification handle = 0x000e value,54 3d 36 2e 31 20 48 3d 36 38 2e 37 00
Notification handle = 0x000e value,54 3d 36 2e 32 20 48 3d 36 37 2e 39 00
Notification handle = 0x000e value,54 3d 36 2e 31 20 48 3d 36 39 2e 30 00
Notification handle = 0x000e value,54 3d 36 2e 33 20 48 3d 36 37 2e 39 00
Notification handle = 0x000e value,54 3d 36 2e 31 20 48 3d 36 38 2e 38 00
Notification handle = 0x000e value,54 3d 36 2e 32 20 48 3d 36 38 2e 30 00
Notification handle = 0x000e value,54 3d 36 2e 30 20 48 3d 36 38 2e 37 00
2018.02.08 21:47:00 4: XiaomiBTLESens (zoldertem) - ExecGatttool_Run: gatttool result Characteristic value was written successfully
2018.02.08 21:47:00 5: Cmd: >{BlockingStart('2')}<
2018.02.08 21:47:00 5: Cmd: >{XiaomiBTLESens_ExecGatttool_Done('zoldertem|4C:65:A8:D1:7D:DC|ok|write|0x10|{"gtResult":"54 3d 36 2e 31 20 48 3d 36 38 2e 37 00 \nNotification handle = 0x000e value"}')}<
2018.02.08 21:47:00 4: XiaomiBTLESens (zoldertem) - ExecGatttool_Done: gatttool return string: zoldertem|4C:65:A8:D1:7D:DC|ok|write|0x10|{"gtResult":"54 3d 36 2e 31 20 48 3d 36 38 2e 37 00 \nNotification handle = 0x000e value"}
2018.02.08 21:47:00 5: XiaomiBTLESens (zoldertem) - ProcessingNotification
2018.02.08 21:47:00 4: XiaomiBTLESens (zoldertem) - ProcessingNotification: handle 0x10
2018.02.08 21:47:00 5: XiaomiBTLESens (zoldertem) - Thermo/Hygro Sens Handle0x10
2018.02.08 21:47:00 5: Starting notify loop for zoldertem, 3 event(s), first is temperature: 6.1
2018.02.08 21:47:00 5: End notify loop for zoldertem
2018.02.08 21:47:00 4: XiaomiBTLESens (zoldertem) - WriteReadings: Readings were written
BTMAC 4C:65:A8:D1:7D:DC
DEF 4C:65:A8:D1:7D:DC
INTERVAL 300
NAME zoldertem
NOTIFYDEV global,zoldertem
NR 21
NTFY_ORDER 50-zoldertem
STATE active
TYPE XiaomiBTLESens
VERSION 2.0.5
loglevel 4
2018-02-08 21:46:45 battery ok
2018-02-08 21:46:45 batteryLevel 100
2018-02-08 15:18:45 firmware 00.00.66
2018-02-08 21:47:00 humidity 8.7
2018-02-08 21:02:58 lastGattError charWrite faild
2018-02-08 21:47:00 state active
2018-02-08 21:47:00 temperature 6.1
helper:
CallBattery 0
CallSensDataCounter 0
updateTimeCallBattery 1518122805.32754
updateTimestampCallBattery 2018-02-08 21:46:45
interval 300
model thermoHygroSens
room XiaomiBTLESens
