Brand new user, want to monitor dB levels from microphone input
Begonnen von hal8999, 03 Februar 2018, 22:16:56
hal8999
Hey all,
I am planning to install fhem on a brand-new ubuntu instance for a sole purpose. I have a contact microphone and I would like to log the dB of noise as close to real-time as possible. I will be using the 3.5mm input plug on the built-in sound card on the motherboard... Thanks!
herrmannj
hal8999
thanks! I realized in my original post that I didn't actually ask a question, hah!
What module would I use to measure input from the sound card's microphone? I only need to measure the dB level, not the actual sound. So I don't want to be recording WAV files or any such thing to disk. Just the levels...
(PS: when I set the default language to English, the captcha challenges are still in german, which is a little annoying. is there any way to fix that in your phpBB?)
rudolfkoenig
ZitatWhat module would I use to measure input from the sound card's microphone? I only need to measure the dB level, not the actual sound. So I don't want to be recording WAV files or any such thing to disk. Just the levels...
As far as I know there is no such FHEM Module. Anyway, FHEM ist not well suited to convert raw audio to DB values. I wrote a small C-Program about 10 years ago for this taks, which dumped the output in a FHEM compatible format, so I could visualize it in FHEM with a fake FileLog.
Zitat(PS: when I set the default language to English, the captcha challenges are still in german, which is a little annoying. is there any way to fix that in your phpBB?)
Not that I know of. There are some 10 "challanges", half of them is in english, so you could try to reload the side, if it appears unsolvable.
JoWiemann
Welcome to Fhem. As far as I know there ist a Solution in ESP Easy. And for ESP Easy you will find the Fhem module EspBridge.
Grüße Jörg
Jörg Wiemann
