Autor Thema: [Solved] Problems with WS-1600 weather station  (Gelesen 608 mal)
Offline alangward
  • New Member
« am: 06 Februar 2018, 16:50:18 »
I have a setup that currently includes a JeeLink and a TFA Dostmann temperature sensor (model number 30.3159).
This has been working well for the last 6 months using a LaCrosse device set up .
I wanted to increase the range of weather data captured and so have acquired a WS-1600 weather station that uses a TX22 external transmitter. It is working fine - the weather station display showing the external temperature etc.
I am unable to pair the TX22 with my JeeLink.
I have autocreate enabled and have set JLink LaCrossePairForSec 3600 ignore_battery.
What am I doing wrong? Are there any more diagnostics I can get?
Thanks
Alan
« Letzte Änderung: 09 Februar 2018, 11:48:32 von alangward »
Offline alangward
  • New Member
Antw:[Solved] Problems with WS-1600 weather station
« Antwort #1 am: 09 Februar 2018, 11:50:12 »
The problem was due to the TX22 using a different data rate from my existing data.
It required a different initCommand value to solve it.
